跳转到主内容
iPhone X 电池更换
你所需要的
视频概述
  1. iPhone X 电池更换, 防撬螺丝: 步骤 1 中的图像 1,1
    • 开始之前,将iPhone电池放电至25%以下。 充电的锂离子电池如果意外刺破,可能会引起火灾和/或爆炸。
    • 在开始拆卸之前关闭你的iPhone。
    • 卸下iPhone底部的两颗6.9毫米五角梅花型长螺丝。
    • 如果螺丝滑牙或损坏,更换这些螺丝
    • 拆解iPhone的显示屏将损害其防水密封性。 在执行此步骤之前,请准备好新的密封胶条,或者在不更换密封条的情况下重新组装iPhone,但请不要让iPhone与液体接触。
    There are 6.81mm long screws!
    Daniel - 回复
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - 回复
    same situation here
    kaunomarcius - 回复
    Same issue for me too, how do I get the stripped screw out?
    patronics - 回复
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    patronics - 回复
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - 回复
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - 回复
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - 回复
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - 回复
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - 回复
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - 回复
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - 回复
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - 回复
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - 回复
  2. iPhone X 电池更换, 标记你的三角撬片: 步骤 2 中的图像 1,3 iPhone X 电池更换, 标记你的三角撬片: 步骤 2 中的图像 2,3 iPhone X 电池更换, 标记你的三角撬片: 步骤 2 中的图像 3,3
    • 如果插入太深,三角撬片可能会损坏你的设备。 按照此步骤标记撬片并防止损坏。
    • 从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
    • 你还可以用不同的尺寸标记三撬片的其他角。
    • 或者,将 将一枚硬币 粘在距撬片尖端 3 毫米处。
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - 回复
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - 回复
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - 回复
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - 回复
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - 回复
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - 回复
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - 回复
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - 回复
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - 回复
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - 回复
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - 回复
  3. iPhone X 电池更换, 用胶带覆盖任何裂缝: 步骤 3 中的图像 1,3 iPhone X 电池更换, 用胶带覆盖任何裂缝: 步骤 3 中的图像 2,3 iPhone X 电池更换, 用胶带覆盖任何裂缝: 步骤 3 中的图像 3,3
    • 如果你的 iPhone 屏幕破裂,请在维修过程中用胶带粘住玻璃,以遏制进一步的破损并防止人身伤害。
    • 将透明胶带条重叠地放在 iPhone 屏幕上,直至覆盖整个表面。
    • 佩戴护目镜,以保护您的眼睛免受维修过程中晃动的玻璃的伤害。
    • 如果在接下来的几步中无法让吸盘粘住,请将一块强力胶带(例如管道胶带)折叠成手柄状,然后用它抬起屏幕。
    • 如果其他方法都失败,你可以将吸盘粘到屏幕上。
  4. iPhone X 电池更换, 反向钳使用指南: 步骤 4 中的图像 1,3 iPhone X 电池更换, 反向钳使用指南: 步骤 4 中的图像 2,3 iPhone X 电池更换, 反向钳使用指南: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • 接下来的两个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 向后拉蓝色手柄以解锁反向钳臂。
    • 将支撑臂滑过 iPhone 的左边缘或右边缘。
    • 将吸盘放置在 iPhone 底部边缘附近 - 一个位于正面,一个位于背面。
    • 将吸盘挤压在一起,对所需区域施加吸力。
    • 如果发现设备表面太光滑而反向钳无法吸住,你可以使用胶带来创造一个更容易抓握的表面。
  5. iPhone X 电池更换: 步骤 5 中的图像 1,3 iPhone X 电池更换: 步骤 5 中的图像 2,3 iPhone X 电池更换: 步骤 5 中的图像 3,3
    • 向前拉蓝色手柄以锁定手臂。
    • 顺时针旋转手柄 360 度或直到吸盘开始拉伸。
    • 确保吸盘彼此保持对齐。 如果它们开始滑出不对齐,请稍微松开吸盘并重新对齐手臂。
  6. iPhone X 电池更换: 步骤 6 中的图像 1,3 iPhone X 电池更换: 步骤 6 中的图像 2,3 iPhone X 电池更换: 步骤 6 中的图像 3,3
    • 加热 iOpener 并将其穿过反向钳。
    • 你还可以使用吹风机热风枪或电热板,但过热可能会损坏显示屏和/或内部电池,因此请小心操作。
    • 折叠 iOpener,使其位于 iPhone 的底部边缘。
    • 等待一分钟,让粘合剂有机会释放并出现开口间隙。
    • 在屏幕和塑料边框下方插入三角撬片,而不是屏幕本身
    • 如果反向钳无法形成足够的间隙,请对该区域施加更多热量并将手柄旋转四分之一圈。
    • 反向钳一次不要超过四分之一圈,两次之间要等待一分钟。让反向钳和时间来为你工作。
    • 跳过接下来的两个步骤。
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 回复
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  7. iPhone X 电池更换: 步骤 7 中的图像 1,1
    • 加热iPhone的下边缘将有助于软化固定显示器的粘合剂,使其更容易打开。
    • 使用吹风机热风枪准备一个iOpener,并将其放置到iPhone的下边缘约一分钟,以软化下面的粘合剂。
    • 如果您使用吹风机或热风枪,请勿过度加热,因为这可能会损坏屏幕。
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - 回复
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - 回复
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - 回复
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - 回复
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - 回复
    thaks for this advise, I was looking for this as I dont have a heat gun haha, nice hack
    Andres Chaparro -
  8. iPhone X 电池更换: 步骤 8 中的图像 1,2 iPhone X 电池更换: 步骤 8 中的图像 2,2
    • 如果使用单个吸盘,将其应用到手机的底部边缘,同时避免玻璃的弯曲部分。
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - 回复
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - 回复
  9. iPhone X 电池更换: 步骤 9 中的图像 1,3 iPhone X 电池更换: 步骤 9 中的图像 2,3 iPhone X 电池更换: 步骤 9 中的图像 3,3
    • 牢牢的拉起吸盘,使前面板和后壳之间产生一个微小的间隙。
    • 将撬片插入屏幕塑料边框下方的缝隙中,而不是屏幕本身
    • 将屏幕固定到位的防水粘合剂非常牢固; 创造这个初始间隙需要很大的力量。 如果你很难打开间隙,请施加更多热量,然后轻轻地上下摇动屏幕以削弱粘合剂,直到形成足够的间隙以插入工具。
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - 回复
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - 回复
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 回复
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - 回复
  10. iPhone X 电池更换: 步骤 10 中的图像 1,3 iPhone X 电池更换: 步骤 10 中的图像 2,3 iPhone X 电池更换: 步骤 10 中的图像 3,3
    • 将三角撬片沿着 iPhone 的左下角向上滑动,切开固定显示屏的粘合剂。
    • 请勿将撬片插入超过 3 毫米,否则可能会损坏内部组件。
  11. iPhone X 电池更换, 注意事项: 步骤 11 中的图像 1,1
    • iPhone 的右边缘有易损排线。 请勿将撬片插入此处,插入此处可能会损坏排线。
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - 回复
  12. iPhone X 电池更换: 步骤 12 中的图像 1,3 iPhone X 电池更换: 步骤 12 中的图像 2,3 iPhone X 电池更换: 步骤 12 中的图像 3,3
    • 将撬片重新插入 iPhone 的底部边缘,然后将其向上滑动到右侧以继续分离粘合剂。
    • 请勿将撬片尖端插入超过 3 毫米,否则可能会损坏显示屏排线。
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
    William Olstad - 回复
  13. iPhone X 电池更换: 步骤 13 中的图像 1,3 iPhone X 电池更换: 步骤 13 中的图像 2,3 iPhone X 电池更换: 步骤 13 中的图像 3,3
    • 显示屏的顶部边缘被胶水和卡扣固定。
    • 沿显示屏的上角滑动撬片,同时朝着Lightning端口的方向向下轻轻拉动或推动显示屏。
    • 如果用力太大,固定显示屏的卡扣会被折断。 请小心操作!
    • 将撬片滑动到对角,并切掉所有剩余用来固定显示器的粘合剂。
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - 回复
  14. iPhone X 电池更换: 步骤 14 中的图像 1,1
    • 拉上吸盘上的小凸起,将其从前面板上取下。
  15. iPhone X 电池更换: 步骤 15 中的图像 1,3 iPhone X 电池更换: 步骤 15 中的图像 2,3 iPhone X 电池更换: 步骤 15 中的图像 3,3
    • 从iPhone显示屏的左侧向上打开iPhone,就像面对书本底部时,翻开最后一页一样。
    • 不要试图将屏幕和手机完全分开,因为几条易碎的连接线任然与iPhone的控制板连接着。
    • 如图所示,保证屏幕的框架也和屏幕一起拆开,而不是还卡在手机里。
    • 在重新组装过程中,将显示器放置到位,沿着顶部边缘对齐夹子,然后小心地将顶部边缘压入到位,然后将其余部分向下收紧。 如果不能轻松安装到位,请检查显示器周边的夹子状况,确保它们没有弯曲。
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - 回复
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - 回复
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - 回复
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - 回复
  16. iPhone X 电池更换, 屏幕组件: 步骤 16 中的图像 1,1
    • 拧出固定逻辑板支架的5个符合以下长度Y000规格的螺丝
    • 3个1.1mm的螺丝
    • 1个3.1mm的螺丝
    • 1个3.7mm的螺丝
    • 做这步的时候,注意记住每个螺丝位置并在安装的时候准确的拧回去,因为这保护你的摄像头不被破坏。
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - 回复
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - 回复
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - 回复
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - 回复
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - 回复
  17. iPhone X 电池更换: 步骤 17 中的图像 1,1
    • 移除后盖
    • 后盖可能会轻轻在粘连着,用稳定并缓慢的力度将其分开。
    • 在你装回去的过程中,在屏幕密封之前这是一个测试你的iPhone是否功能完好的好机会,但要注意在测试完后一定要关机后才能继续进行下一步哦。
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - 回复
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - 回复
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - 回复
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
    Max Glanzmann - 回复
  18. iPhone X 电池更换: 步骤 18 中的图像 1,2 iPhone X 电池更换: 步骤 18 中的图像 2,2
    • 用撬棍的尖端或干净的指甲去撬开电池与逻辑板的连接
    • 尽量不要损伤在逻辑板或其他板周围的黑色硅脂,这是用来加强防水防尘能力的
    • 轻轻挑开那个接口,避免逻辑板意外的连到电池上接通手机的电源
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - 回复
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - 回复
    Thanks, already did it)
    Stephen Hedrick -
  19. iPhone X 电池更换: 步骤 19 中的图像 1,2 iPhone X 电池更换: 步骤 19 中的图像 2,2
    • 用撬棍或者指甲来断开前面板传感器的连接
  20. iPhone X 电池更换: 步骤 20 中的图像 1,2 iPhone X 电池更换: 步骤 20 中的图像 2,2
    • 使用撬棒的尖端或手指甲来撬开OLED面板排线的插头。
    • 想要重新连接这种按压型插头,先将插头的一侧对准位置轻轻按压到位,然后在另一侧重复操作。切忌从中间按压插头。如果插头没有对准位置就对其进行按压的话,插头的触脚会被折弯,会对插头插座造成永久性的损坏。
    Snap ‘em in like little Legos.
    Ray Johnson - 回复
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - 回复
  21. iPhone X 电池更换: 步骤 21 中的图像 1,2 iPhone X 电池更换: 步骤 21 中的图像 2,2
    • 使用Spudger撬棒的尖端将数据排线的插头从插座撬开。
    • 这个插头所处于的隐蔽位置使其不容易重新连接上。要花点时间小心地将其对准位置,然后用你的手指先轻轻地将其一侧按压到位,然后是另一侧。你可以感觉得到它卡在正确的位置。
    • 如果维修完后发现屏幕有任何触摸失灵的部位,请先断开电池连接然后重新连接这个插头,确保其完整的卡在了正确的位置,并且插座里没有灰尘或其他的损坏。
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - 回复
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - 回复
  22. iPhone X 电池更换: 步骤 22 中的图像 1,3 iPhone X 电池更换: 步骤 22 中的图像 2,3 iPhone X 电池更换: 步骤 22 中的图像 3,3
    • 前面板传感器组弯折型的排线在这里被一点点粘胶粘住了。
    • 小心地提起排线直到粘胶被分离。
    Do this sensor affect face id?
    bonglkv - 回复
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - 回复
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - 回复
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    William Olstad - 回复
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - 回复
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - 回复
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - 回复
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - 回复
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - 回复
    I have damaged the front panel sensor assembly flex cable. Does it carry multiple channels of info or is it just one solid piece that can be soldered back together? If not, will the phone still work except Face ID?
    Bodger Rabbit - 回复
  23. iPhone X 电池更换: 步骤 23 中的图像 1,1
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - 回复
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - 回复
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - 回复
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - 回复
    Just to confirm the face id is not affected when replacing the earpiece assembly? Am I correct
    mubeen.2011@hotmail.co.uk - 回复
    Sorry for the late response, but you are NOT correct. Replacing the earpiece speaker assembly will result in the loss of Face ID functionality. That's the whole assembly, including the speaker, dot projector and flood illuminator. If you unsolder the speaker from the assembly, that can be replaced by itself without losing Face ID, but any other part will cause it to quit working.
    Jerry Wheeler -
  24. iPhone X 电池更换, 下方扬声器: 步骤 24 中的图像 1,2 iPhone X 电池更换, 下方扬声器: 步骤 24 中的图像 2,2
    • 当心:不要碰到 iPhone 底部附近的三排接地板。
    • 移除 Taptic Engine 和扬声器下方的金属保护罩上的 7 颗螺丝:
    • 两颗 1.9mm Y000型螺丝
    • 一颗 1.2mm Y000型螺丝
    • 一颗 1.6mm Y000型螺丝
    • 一颗 2.4mm 十字螺丝
    • 一颗 1.7mm 十字螺丝
    • 一颗 1.5mm 十字螺丝
    For battery replacement:
    It is not necessary to remove Taptic Engine and speaker to replace a battery. Go straight to the step #33
    Additional video: https://youtu.be/2GfBOlJEW10
    Alexander - 回复
    I wish I seen this before I did all that! Thank you for that information. Next time I do something like this. I'm gonna pay more attention to the comments.
    Eric Marino -
    Removing the Taptic Engine and speaker greatly improves your chances of getting the battery adhesive strips out intact. If those break, you’ll have a much tougher time.
    Jeff Suovanen -
    Boy, I tried to skip removing these items but was unable to get the glue strips out with them in place, not much to grab and tabs were kind of stuck to a seam in the battery, and hard to tell the difference between the seam and the strip tabs. For me I had to remove these items to get this done.
    marshallburchard -
    I stopped removing things after getting the display side off. There were 3 screws stripped on the speaker cover which wouldn't come out so I punted. Just pried the battery out with a smudger tool and some patience, starting at the top and working towards the bottom. New battery is in and working fine.
    Andy Price - 回复
    The 2.4mm screw identified as “green” needs a Y000 screwdriver
    seb6po - 回复
    Thanks for not removing the following steps. this made me break the connector for the bottom speakers >:(
    Andrew Romano - 回复
    The color codes are missing from my display — only on this step.
    nat2 - 回复
    The screws color and quantities in list don’t match the schematic ! I wish i had a magnetic screw mat before starting, because not only i removed the Taptic Engine and speaker unnecessarily, but i also lost a screw ?
    fb.mailing.lists - 回复
    For first timer, dont think its possible to skip these steps and remove battery. It’s hard to remove the glue
    Wex - 回复
    Does anyone know the purpose of this bracket "with grounding pads"? What would be the possible side effects if it was damaged or not connected properly during reassembly?
    Anne Aunyme - 回复
    Hello, in my case the grounding pads are damaged. I've had problems since EMC. When I try to charge wirelessly, the iphone starts wild button presses (Gosting).
    Does anyone know, where I can get new grounding pads (with or without bracket)?
    Ulrich Höfelmeyer -
    I had to remove the tactic and speaker could not get the glue strips out so glad the steps to do so were in this guide.
    P Bond - 回复
    Sure would like to know WHY the warning "Be careful not to touch the three rows of grounding pads..." What would or could happen if I did touch them??
    Chad Gagnon - 回复
    Removing the battery strips is a major PITA, just skip this step and everything onwards, remove the one strip on the top part of the battery (according to step 33) and for the bottom part of the battery, pry it off with a plastic spudger.
    Yes, this is not the elegant solution, but the quickest and easiest one. This method is better, as you don't want to keep the old battery anyway, so why bother. (You must not puncture the battery though! But as long as you're only working with a plastic tool and are careful, nothing can happen from my experience.)
    speaker gasket - 回复
    Remove the adhesive from the top part of the battery, squirt some ipa into the bottom part and it will come off easily, then skip to 38.
    Kim Boulton - 回复
  25. iPhone X 电池更换: 步骤 25 中的图像 1,2 iPhone X 电池更换: 步骤 25 中的图像 2,2
    • 从离电池最近的边缘提起金属支架。不要完全移除它,上面仍然连接着一个小排线。
    Ulrich Höfelmeyer - 回复
  26. iPhone X 电池更换: 步骤 26 中的图像 1,2 iPhone X 电池更换: 步骤 26 中的图像 2,2
    • 移开金属罩的同时,使用撬棒的尖端来断开下方的排线的连接。
  27. iPhone X 电池更换: 步骤 27 中的图像 1,1
    • 移除金属罩。
    My bracket was in two pieces.
    Jim Steward - 回复
  28. iPhone X 电池更换: 步骤 28 中的图像 1,2 iPhone X 电池更换: 步骤 28 中的图像 2,2
    • 移除扬声器排线上方保护罩的2.1mm Y000型螺丝。
    L'unique vis non?
    Easy Repair - 回复
    Effectivement ;-) Merci pour les bons yeux et la remarque !
    Claire Miesch -
  29. iPhone X 电池更换: 步骤 29 中的图像 1,1
    • 移除扬声器排线保护罩。
  30. iPhone X 电池更换: 步骤 30 中的图像 1,2 iPhone X 电池更换: 步骤 30 中的图像 2,2
    • 使用撬棒的尖端断开扬声器排线的连接。
    As mentioned in a comment by timblake2112 (see step 29), this step is not necessary and can be skipped skipped. I would advise you to do so, as removing your speaker is guaranteed to ruin your gasket and rubber seal. This will result in loss of water resistancy of your iPhone and could potentially harm the sound quality of your speaker.
    Try removing the Taptic Engine without removing the speaker. It might still be possible removing the battery adhesive strips and your speaker will stay in its original condition.
    speaker gasket - 回复
  31. iPhone X 电池更换: 步骤 31 中的图像 1,2 iPhone X 电池更换: 步骤 31 中的图像 2,2
    • 当撬起扬声器的时候,小心不要损坏您刚才断开连接的排线。如果必要的话,将其移到一边来为扬声器的移出预留出空间。
    • 将Spudger撬棒插入手机后壳边缘旁,扬声器的上缘。
    • 轻轻地撬起扬声器的顶端。
    • 当重新安装扬声器的时候,请检查排线的位置,确保其不会卡在扬声器下。
  32. iPhone X 电池更换: 步骤 32 中的图像 1,3 iPhone X 电池更换: 步骤 32 中的图像 2,3 iPhone X 电池更换: 步骤 32 中的图像 3,3
    • 握住扬声器的边缘并摇晃,将其与底部的粘胶分离。
    • 将扬声器拉离手机后壳直到与胶圈分离。
    speaker gasket - 回复
  33. iPhone X 电池更换: 步骤 33 中的图像 1,2 iPhone X 电池更换: 步骤 33 中的图像 2,2
    • 移除扬声器。
    You don’t need to remove the speaker and ruin its gasket. You can wiggle and slide the taptic engine out without removing the speaker. I’ve done this twice on rear shell replacement jobs.
    timblake2112 - 回复
    Maybe I'm a bit daft, but where's the instruction just how to line up the speaker gasket when replacing? I only have one so I'd like to avoid wrecking it. And I completely cleaned off the old one in order to do a good job of things. Why no simple instruction from part supply link?
    MrRoundel - 回复
  34. iPhone X 电池更换, 更换扬声器密封圈: 步骤 34 中的图像 1,3 iPhone X 电池更换, 更换扬声器密封圈: 步骤 34 中的图像 2,3 iPhone X 电池更换, 更换扬声器密封圈: 步骤 34 中的图像 3,3
    • 扬声器密封圈不可重复使用。在重新组装时,请按照以下步骤更换密封圈。
    • 用镊子剥离粘贴在扬声器边框上的旧密封圈。
    • 用超细纤维布或异丙醇酒精擦拭扬声器边框,去除所有残留的粘胶。
    • 在安装扬声器密封圈之前, 请在其底部找到正确的方向—— 密封圈上的大开口 应该对准 扬声器格栅网
    • 从密封圈上取下更大、透明的衬垫,用镊子将密封圈小心地放在扬声器底部。
    • 为避免碰触暴露在外的粘合剂,只需抓住衬垫的外边缘。
    • 用手指或撬棒用力按压密封圈,使粘胶紧密固定。
    • 移除剩余的衬垫,将扬声器安装到位,确保扬声器接口不会卡在其下方。
  35. iPhone X 电池更换, Taptic Engine 线性马达: 步骤 35 中的图像 1,2 iPhone X 电池更换, Taptic Engine 线性马达: 步骤 35 中的图像 2,2
    • 移除固定Taptic Engine的2.3mm 十字螺丝。
  36. iPhone X 电池更换: 步骤 36 中的图像 1,2 iPhone X 电池更换: 步骤 36 中的图像 2,2
    • 使用撬棒撬起Taptic Engine排线的插头。
  37. iPhone X 电池更换: 步骤 37 中的图像 1,1
    • 移除Taptic Engine。
  38. iPhone X 电池更换, 电池: 步骤 38 中的图像 1,1
    • iPhone X 的电池被四张易拉胶条粘在手机后壳上——一张在上侧,三张在下侧。
    • 每张胶条的末端各有一个黑色的拉条微微粘在电池的边缘。
  39. iPhone X 电池更换: 步骤 39 中的图像 1,3 iPhone X 电池更换: 步骤 39 中的图像 2,3 iPhone X 电池更换: 步骤 39 中的图像 3,3
    • 将第一块电池的胶带拉条从电池边缘分离。
    • 每个拉条的中央都有一个小圆孔,如果您拿起拉条比较困难的话,可以使用工具穿过圆孔来拉起它。
    • 不要使用任何尖锐物品刺破电池。可能会导致化学液体泄漏或起火。
    hole breaks instantly on pulling. adhesive tab does not release from side of battery
    Dominick garton - 回复
    I had a lot of trouble with this. Only two came out properly and the others snapped off. I heated up the back of the phone with a hair dryer then used the flat end of the spudger to slowly pry it off right to left, bottom to top.
    Grant - 回复
    just pry it off, why bother
    speaker gasket - 回复
  40. iPhone X 电池更换: 步骤 40 中的图像 1,3 iPhone X 电池更换: 步骤 40 中的图像 2,3 iPhone X 电池更换: 步骤 40 中的图像 3,3
    • 重复上一步的操作来分离剩下的两个拉条。
    • 注意不要损坏中间胶条下方的扬声器排线接口。
  41. iPhone X 电池更换: 步骤 41 中的图像 1,3 iPhone X 电池更换: 步骤 41 中的图像 2,3 iPhone X 电池更换: 步骤 41 中的图像 3,3
    • 接下来的步骤中,您将缓慢的拉出电池下的每一张胶条。当您拉动时,这种特殊的易拉胶条会失去粘性。从而您可以轻松的拿起电池。
    • 如果胶条断裂了,不要惊慌!它们并没有想象中的那么好用。继续阅读以下的步骤来移除断裂的胶条。
    • 为了提高您的成功几率:
    • 不要按压电池。握住手机的两侧。
    • 当您拉动的时候保持胶条平直,不要起皱。
    • 保持非常缓慢的速度来拉动胶条,胶条的拉动与分离需要一点时间。移除每张胶条大约需要15至30秒的时间。
    • 拉动胶条时保持较低的角度,避免电池下缘将胶条刮断。
    • 如果胶条断裂到电池下方无法取出,继续操作另一张胶条,然后继续接下来额外的步骤。
  42. iPhone X 电池更换: 步骤 42 中的图像 1,3 iPhone X 电池更换: 步骤 42 中的图像 2,3 iPhone X 电池更换: 步骤 42 中的图像 3,3
    在这个步骤中使用的工具:
    • 拿住一张露在电池外的胶带拉条,朝向手机的底部,缓慢的将其从电池下拉出。
    • 保持稳定持续的拉力拉动胶条,直到其从电池和后盖中央滑出。
    • 胶条会被拉伸到正常长度的数倍。如果必要的话可以拉动电池旁胶条已经露出的部分。
    • 如果胶条在移除的过程中断裂,使用手指或钝镊子来夹住胶条剩余的部分继续拉动。
    • 如果胶条在电池下断裂无法取出,尝试移除剩余的胶条,然后继续按照接下来的指南操作。
    I found it easier to grab the end of the adhesive strip sideways with narrow tweezers, "twirl " the tweezers to wrap the strip around them a few times, then gently pull the strip with the tweezers.
    punkinann - 回复
  43. iPhone X 电池更换: 步骤 43 中的图像 1,3 iPhone X 电池更换: 步骤 43 中的图像 2,3 iPhone X 电池更换: 步骤 43 中的图像 3,3
    • 重复之前的操作移除另一边的胶条,最后移除中间的胶条。
  44. iPhone X 电池更换: 步骤 44 中的图像 1,3 iPhone X 电池更换: 步骤 44 中的图像 2,3 iPhone X 电池更换: 步骤 44 中的图像 3,3
    • 移除中间的胶条。
    • 不要刮到下方的扬声器排线!
  45. iPhone X 电池更换: 步骤 45 中的图像 1,2 iPhone X 电池更换: 步骤 45 中的图像 2,2
    • 这个拉条与Face ID硬件距离非常近。如果损坏了Face ID,只能由Apple官方修复,所以请小心操作。
    • 拉起上方电池边缘最后一张胶带上的拉条。
    surtout ne pas passer avec la spatule par le bas, vous risqueriez d arracher la nappe du volume et du nfc,
    Ludovic Klein - 回复
  46. iPhone X 电池更换: 步骤 46 中的图像 1,3 iPhone X 电池更换: 步骤 46 中的图像 2,3 iPhone X 电池更换: 步骤 46 中的图像 3,3
    • 拉起并移除最后一张胶条。
    • 胶条从手机分离时可能会弹起电池,所以请用手掌覆盖机身来保护——不要按压电池,过大压力可能会使胶条断裂。
    • 如果您成功移除了所有胶条,请跳过下一步。
    • 不过,如果某一张胶条断裂到电池下方导致其无法取出,请继续下一步
  47. iPhone X 电池更换, 从iPhone中移除电池的另一种方法: 步骤 47 中的图像 1,2 iPhone X 电池更换, 从iPhone中移除电池的另一种方法: 步骤 47 中的图像 2,2
    • 如果任何胶条断裂导致电池无法从后盖取下,准备一个iOpener或使用电吹风来加热手机后盖电池所处的位置。
    • 加热手机至后盖触摸起来微微烫手的程度。不要使手机过热,否则可能会导致电池爆炸。
    • 将手机转过来,在电池下穿一根结实的细线(比如牙线或者细的吉他弦)。
    • 使用一块布包裹住细线的末端(或者戴手套)来保护您的手指。
    • 像锯木头一样拉动细线来分离电池下的胶条。可能胶条分离的会有些慢,但是心急吃不了热豆腐。不要损坏电池
    • 如果您选择使用工具撬起电池,请务必小心,有可能会损坏电池排线或损坏下方的无线充电元件。
    if you use a guitar string, remember NOT to use a METALLIC guitar string.
    Ross King - 回复
    flexible plastic rules with alcohol work too
    Wex - 回复
    I can confirm that IPA (Iso Propyl Alcohol) and, in my case, the plastic plectra in any iFixit kit worked a treat.
    P Bond -
  48. iPhone X 电池更换: 步骤 48 中的图像 1,1
    • 从底部边缘抓住电池,然后将其从iPhone中取出。
    • 如果iPhone中残留有酒精溶液,请在安装新电池之前先将其擦拭干净或风干。
    • 在安装新电池之前,请重新安装Taptic Engine和扬声器。 这有助于在安装过程中正确对齐电池。
    • 在安装备用电池之前,请暂时将电池连接器重新连接至逻辑板插槽。 这样可以确保电池在其凹槽中正确对齐。
    • 安装好电池,断开连接,然后继续重新组装设备。
    • 如果你的新电池没有背胶, 参考这篇手册以获取更换背胶的方法。
    • 重新组装后强制重启手机。这样可以避免一些问题,方便故障排除。
    When reinstalling the battery, the Taptic Engine does serve as a useful way to orient the battery, but it should also be noted that if you push right up against that as you install the battery (as I did) and don’t pay any attention to power connector (shown in step 14), there is a risk that the connector from the battery will not line exactly with the connector port on the board. Mine was only off a mm so I had to get a little creative to try to get it to stretch to reach and connect to the port on the board. Just keep that in mind as you place the battery (with adhesive) down.
    Jesse Bolane - 回复
    Connect the battery first then put it in place. Other way it is hard to adjust power connector.
    Alexander - 回复
    I would also HIGHLY suggest re-installing the speaker as well before installing the battery - it was a very tight squeeze as the bottom-right of the battery was snug against the speaker when I tried to get that back in.
    cgtyoder - 回复
结论
将新的更换配件与原始配件进行比较 —— 在​​安装之前,你可能需要转移剩余配件或从新配件上移除粘合剂背衬。
若想重新组装你的设备,请倒序按照本指南操作。
将你的电子废料带到R2 or e-Stewards 认证的回收商
维修不像计划中一样进行?查阅问题解答论坛来排查错误。
416等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Jeff Suovanen
于08/06/13注册
440,080 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,632篇指南
57指南评论
In the store it says the iSlack is only for iPhone 5 and 6. In this review the iSlack is used (without tray). Does that mean it can be used on the iPhone X as well?
Ronald van der Meer - 回复
@rvdm The little bracket in the middle of the iSclack is sized for iPhone 5, but that bracket is optional and very easy to detach. At that point you have a really great general-purpose suction tool that works for all kinds of devices (even bigger ones like tablets). I’ll see about updating the description on the store page to reflect that fact. ;)
Jeff Suovanen -
Have you all ever had a problem of the phone staying stuck on a percentage and takes so long to charge plz let me know because I just got my iPhone X and it take so long to charge and I got it brand new from AT&T
Cristan Montes - 回复
Esta solucionado el tema del Chip Texas instrument para baterias no reemplazadas en Apple, gracias.
FELIX MARQUEZ - 回复
¿A qué te refieres con eso?
Tomas -
C’è un errore di traduzione al passo 33 BATTERIA , iphone X diventa iphone 8.
Marco
Marco Pautasso - 回复
Ciao Marco! Hai occhi di lince! Grazie per il commento. Ho corretto la traduzione. Commenti di questo tipo sono sempre benvenuti. Hai anche la possibilità di adattare direttamente la traduzione, cliccando sull’icona “Traduci”. Saluti, Claire
Claire Miesch -
Note that my replacement battery was completely dead when I installed it, so when I tested it, I thought perhaps something wasn’t hooked up right. After removing the bracket for the connectors and reattaching the battery connector I tried again. Since that failed, I plugged the phone in. I got a “no charge” battery icon. After a few minutes I removed the phone from the charger. The phone stayed on with the “plug in the phone” icon, so I knew everything was put back together correctly.
Jon12 - 回复
Critical Note! When installing the new battery make sure the connector lines up. The instructions mention having the speaker and taptic engine in place so I focused on squaring up with those. This was a mistake! Now my connector is 2mm too low and won’t line up. Not sure how I will fix this yet but hopefully I won't need to remove everything again.
Christopher Jones - 回复
Where can I buy a genuine original iPhone X battery as amazon Walmart sells fake batteries
masrin - 回复
You can not buy a genuine battery.
Alexander -
How to make out a genuine original battery from a fake one sold all over the globe?
masrin - 回复
Super Set, auch toll das hier die Dichtung dabei ist. Akku lädt und zeit die %-Werte an. Beim nächsten Mal kauf Ichs gleich hier"! War jetzt schon die 2te Reparatur. Mittlerweile schaff ich das schon ca. 40 min ;)
Danke
Peter - 回复
Aparecerá el porcentaje de la batería en el apartado de “salud”?
Gustavo González Martínez - 回复
removing the components that are below the battery seems rather unnecessary to me, you could remove the battery without taking those out
Samuel Casas - 回复
I had an issue with a swollen battery on a iphone X, the battery was pushing the display assembly and the phone couldn’t close properly. Replaced with new battery and all went fine. Great guide as always
Georgi Ivanov - 回复
This battery already comes with battery health indicator or need to reprogram the battery ?
danial nabil - 回复
Big thank you for introduction!
commaai - 回复
It would be nice if this addressed the waterproof adhesive, mentioned in Step 6. Doesn’t pulling the phone apart make it no longer watertight?
Winston - 回复
Instructions for replacing the adhesive seals are linked in the guide (Step 19). I wouldn’t count on your phone being waterproof after a repair, but a phone from 2017-2018 likely won’t be particularly water-resistant anymore, anyway. Those seals tend to degrade over time.
Jeff Suovanen -
Hi, I bought the battery from you and installed it exactly like your steps.
But after two days of use, a message appears to me that this battery is not original and its percentage cannot be read !!!
What to do now ???
Fahad Mohammad Fahad - 回复
When changing the battery to a third party one, are there any notifications that appear such as “not a genuine battery” and does reprogramming the battery help prevent this.
Farjad Akram - 回复
BE WARNED! THE IPHONE’S OUTSIDE IS VERY, VERY SHARP! I escaped with 4 cuts on my fingers.
AemVR - 回复
I replaced two of these in one night. The first one worked great but the second’s OLED screen won’t come on. The phone is on because I can hear it charge when I plug it in, but for some reason the screen is dead.
Lucas - 回复
If you’re buying the battery from iFixit I strongly suggest getting the full kit and not the battery-only option so that you get the glue and the gasket. Great guide, thank you!
Grant - 回复
It is perfectly possible to do the replacement without removing anything other than the bracket and the battery connector.
This reduces the number of steps to about 10 and takes about 15 minutes.
Neil Roberts - 回复
Awesome guide! I finished it, and now I have a fully working X
Just one thing: the video and the instructions differ on step 20, making the rest unnecessary according to the video guide. On the other hand, it may facilitate taking the glue off, especially for newbies.
Ed Oliver - 回复
I don’t want to sound like “that guy,” but the cost of a battery replacement is only $69 at an Apple Store. This DIY solution, which can go t!ts up anywhere along the 43 steps, requires the purchase of parts that cost almost as much as just letting Apple do it. I love fixing/replacing/upgrading my hardware as much as the next guy, but this seems like a scenario where the majority of people would be better off visiting an Apple Store.
koelpien - 回复
Except that authorized stores won’t replace a swollen battery, and neither will Apple. Otherwise yes, if the few hours extra and a few 10s of dollars is the additional price for a turnkey solution, most folks are better off having the work done for them.
Mike Hocker -
Was suffering from a hugely swollen battery so it made removing the adhesive pretty difficult (and I was being super careful since the battery had swollen so much). The “stretch and pull” with the adhesive was a no-go and I was hesitant to heat the phone. I ended up slowly pulling up on the battery at the top and gently working the adhesive away. It took some time, but worked out.
Great guide, as usual!
Patrick C - 回复
Jeg har lige skiftet batteri på min iPhone X i starten kunne jeg kun oplade trådløst, men nu kan jeg slet ikke oplade Den reagerer slet ikke på noget mere den er helt død Hvad kan jeg gøre ???
enok - 回复
The adhesive under the original battery broke. ALL TABS RIPPED APART! I have no floss nor metal guitar string. Help please. This is my only mobile phone. I need it 24/7.
vmm - 回复
Commentary on swelled batteries: don’t tell Apple, they will mark your iPhone SerialNumber in their database as not repairable and you will never be able to get a battery replacement in the future (per Apple phone support, as we tried to get their swollen battery replaced by appointment). We are not happy campers, now I need to use up valuable time replacing the battery. At least replacing the battery is an option with the help of iFixit. (oh, and they won’t put in a new battery if I remove the old one either— although once the old one is removed the hardest part of the work is done)
Mike Hocker - 回复
Wasn’t too bad, except some of the screws that need to be removed are tiny and I found out that my eyes are not the best anymore ?.
jabuka - 回复
Many thanks for this great tutorial !! Just changed the battery of my 4 years old iPhone X, I’m very happy to have a fresh one inside !
Faabio - 回复
Hello,
I have an iPhone X Model number MQAF2LZ/A bought in Perú and once I started removing the display I noticed it doesn’t open like in the pictures or video here. There is a connector behind the ear piece that connects to the main board and I can’t open it. I see if I force it I will break this connector. Have somebody worked with this model? and recommend where to buy a replacement display? The one I bought is for model number MQAF2LL/A (USA). (the ribbon cables look different)
John W - 回复
Today I show you how to replace the battery of the Iphone X. We need one screwdriver, one suction cup, 1 iopener, 1 pair of tweezers, 1 plastic pry tool, and 1 spudger.  Remember to turn off the power. The replacement can cause the loss of water resistance. To replace the battery for iphone X, do the following steps. Step 1, use the screwdrive to remove the screws at the bottom. Use Iopener to soften the adhesive. Clip the suction cup onto the screen and use a pry tool to pry out the screen. Lift up the screen 90 degrees on the right. Take off the small screws holding the battery cable and the motherboard. Next, use the tweezers to lift up the metal bracket. Use a spudger to pry away the battery connector and 3 display connectors. Use tweezers to remove the battery stripe. Remove the old battery. Reverse the above steps to install the new battery.
Hội Nguyễn - 回复
This takes me like 2 mins no tools required and I reused the adhesives also so less waste . I dont pull anything or use tools bar a tri star….. Should be updated . Soak in alcohol slightly leave for 2 mins remove battery , dry and replace using old adhesive (which is perfect) no cleaning ….Digithaiz
Sam Barton - 回复
Jeez I dont mind even making you a guide for this as its mostly sit and wait for all of the 5 mins max this takes!
Sam Barton - 回复
Porcentaje de la Condición de la batería funcionará bien?
Inksane BēLCK - 回复
Misma pregunta.
Tomas -
Hallo,
ich habe mein iphone x display und batterie ausgetauscht, allerdings bekomme ich die fehlermeldung
Apple erfasst die Hardwarekennungen Ihres iPhones, um unsere Dienste zu identifizieren und zu aktivieren.
İch habe mein iphone x damals in der türkei gekauft und leider komme ich nach weiter woran kann das liegen ?
mst Ozyn - 回复
Excellent guide! Took about1,5 - 2 hours too including trying to remove all of that black sticky stuff! :) Should have bought some isopropanol... Aligning and fixing the new sealing was a bit tricky! Really had to think for a while which layer of plastic to remove first...
No problem removing the adhesive under the battery which never has worked on older iphones! pehww.... :)
Thomas Lundström - 回复
Worked great. Only putting the display adhesive on was difficult. I am thinking about fixing the broken display now, because it maked so much fun!
Mike Stanke - 回复
Personnellement je n’ai pas démonté les haut parleur et le bas de l’iPhone … j’ai directement chauffé à l’arrière et décollé la batterie …. Plus rapide et moins dangereux pour le reste
Dark Stig - 回复
I don't know if it's common knowledge, but I just flashed on what the first sign of my battery expanding was. I used an Otterbox Defender case on my iPhone X. 3-6 months before the battery made its expansion obvious, the volume buttons started not working well. I thought it was the Otterbox. But now that I've replaced the battery the volume buttons are working fine. Somehow the battery was distorting the physical interface between the phone buttons and the case buttons. By the time I noticed the battery inflating, it had pushed up the display screen away from its frame. Apparently the battery was getting rather dangerous for possible setting itself ablaze.
MrRoundel - 回复
0% Remaining cómo solucionar ??
Ernesto Salazar - 回复
I replaced my battery just fine but now my screen is wonky. I’m getting yellow and black lines and it’s not working properly. I reattached everything twice but still no luck. Any body have the same issues or a fix? My screen was perfect before changing out my battery.
Jeremy - 回复
This battery has to be reprogrammed to work with the health condition battery?
Tomas - 回复
Thanks so much - this is exactly what I needed :)
Molly Floyd - 回复
Holala, mais quelle galère juste pour changer la batterie sur le X !
Thibault Cadet - 回复
Absolut spitze. Danke
Lu66 - 回复
Had my iPhone X battery replaced by Apple today; they replaced the speaker (no charge). They say that the speaker has to be replaced when the battery is replaced. They did not explain why.
LaoK - 回复
Please how can I jump battery terminals to the motherboard terminals with only positive and negative with jumping wire
Ramstar - 回复
Please how can I jump iPhone X battery terminals to the motherboard with only positive and negative terminals to get correct battery percentage?
Ramstar - 回复
For a total novice with electronic repairs this was a little stressful at first, but once I got a proper start, (i.e. was able to separate the screen from the case) I was easily able to follow along and complete the battery repair.  Not everything went according to plan, for example when the adhesive tabs under the battery were not accessible enough to pull, but lift and scrap method worked well.
Would be helpful if there were instructions (for novices) of how to install the new battery, what order (if any) to reattach the connections, how to place and peel the new screen adhesive, and then how to reattach the screen.  Perhaps these are available, and I’ve missed them.
Brilliant tutorial and left buzzing with confidence after watching my iPhone switch on, respond to commands,  and start charging.  Thank you.
mac - 回复
添加评论
浏览统计数据:
过去 24 小时: 151
过去 7 天: 1,048
过去 30 天: 5,236
总计 844,963
