此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
特色指南
iFixit的工作人员认为该指南特别酷。
简介
转到步骤 1 ↓本维修指南由 iFixit 员工编写,未经谷歌认可。 了解更多关于我们维修指南的信息,请点击此处。
按照本指南打开 Pixel XL 以拆卸并更换其电池。如果你的电池发生鼓包,请采取适当的预防措施。
在拆解手机之前,请将电池电量消耗至 25% 以下。 如果电池意外被刺穿,可能会起火和/或爆炸,但如果在放电状态下,发生这种情况的可能性会大大降低。
Pixel XL 的非增强型显示面板非常脆弱,并用强力粘合剂固定在中框上,这使得维修工作变得困难。显示面板有很大的破裂风险,特别是如果它已经有了微小的裂纹。 在撬开阶段,请务必使用充足的热量,并极其小心地进行操作。
电池由非常强力的粘合剂固定。你可能需要使用高浓度(超过 90%)的异丙醇,以便将电池从手机中撬开。
你所需要的
加热iOpener并将其覆盖在显示屏的上边缘两分钟。
在开始撬动屏幕前注意以下区域:
显示面板边缘的细条粘合剂
厚粘合剂
容易损坏的OLED显示面板
撬动过程中可能会受损的显示屏排线
如果你的 Pixel 在你重新连接屏幕后无法开机,可能是手机在电池重新连接时静默开启了。长按电源按钮几秒钟,直到手机振动关机。之后,重新连接屏幕,再试一次。
要重新组装设备,请按相反顺序执行这些说明。
完成本指南后,校准你新安装的电池。
请将你的电子废弃物交给R2 或 e-Stewards 认证回收机构。
维修过程不如预期?查看我们的 Google Pixel XL Answers 社区以获取故障排除帮助。
60等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
48指南评论
I applied the heat with the iOpener multiple times around the edges (reheating it as needed to where it could barely handle it), and they refused to lift up with the suction cup.
Eventually the screen cracked as I was attempting to pry up an edge out of desperation. First attempt at fixing my own phone = fail whale :(
john fatteu - 回复 分享
Sorry to hear about the unsuccessful repair, John!
Our Support team is here to assist in the event you need to find additional parts to complete your repairs, or if you decide you wish to return the kit that you ordered. Feel free to reach out to us via help.ifixit.com and we’ll do our best to assist you.
Cheers,
Kadan Sharpe - 回复 分享
Is there an ideal temperature to head the adhesive to without destroying the screen?
Jeremy Sing - 回复 分享
@martinsing For most adhesives, 80-85° C is about right. You might have to maintain that temperature for a few minutes before it softens up.
How much deeper do I need to cut with the picks/etc top and bottom. The ~1.5mm of my picks isn’t deep enough to cut all the glue on the bottom (haven’t tried on the top yet); my sides were ‘easy’ to free in that my bad battery already lifed them free leaving the screen secured only top and bottom. I can probe deeper with a card or spudger, but how much farther should I be going.
