跳转到主内容
加入维修社区 - 创建账户
Google Pixel Display Adhesive Installation
你所需要的
  1. Google Pixel Display Adhesive Installation, Display Adhesive: 步骤 1 中的图像 1,3 Google Pixel Display Adhesive Installation, Display Adhesive: 步骤 1 中的图像 2,3 Google Pixel Display Adhesive Installation, Display Adhesive: 步骤 1 中的图像 3,3
    • Peel away and remove all the old display adhesive from the body of your phone.
    • Use the point of your spudger to scour away and remove any lingering adhesive.
    • Using metal tools can lead to scratching the glass!
    • If you are reinstalling your existing display, remove all the old adhesive from that as well.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    • While high-concentration isopropyl alcohol is generally safe for use with electronics, it can wear away the foam padding on the midframe. Be careful as you clean the narrow edges of the frame.
    添加评论
  2. Google Pixel Display Adhesive Installation: 步骤 2 中的图像 1,3 Google Pixel Display Adhesive Installation: 步骤 2 中的图像 2,3 Google Pixel Display Adhesive Installation: 步骤 2 中的图像 3,3
    • The replacement adhesive should only be applied to the edges of the frame, but may come with the center filled in.
    • To remove the unnecessary center section of the adhesive strip, carefully peel away the center portion of both the white (paper) and black (adhesive) layers, starting with the U-shaped cutout.
    询问修复机器人
    添加评论
  3. Google Pixel Display Adhesive Installation: 步骤 3 中的图像 1,2 Google Pixel Display Adhesive Installation: 步骤 3 中的图像 2,2
    • Peel off and discard the remaining paper liner, exposing the adhesive underneath.
    添加评论
  4. Google Pixel Display Adhesive Installation: 步骤 4 中的图像 1,2 Google Pixel Display Adhesive Installation: 步骤 4 中的图像 2,2
    • Hold the adhesive sheet with the exposed adhesive facing down, and carefully align it into the lower edge of the phone.
    • Make sure the adhesive sheet is oriented correctly, with the rectangular cutout for the earpiece speaker at the top.
    • When it's correctly aligned, lower the rest of the adhesive sheet into the phone.
    添加评论
  5. Google Pixel Display Adhesive Installation: 步骤 5 中的图像 1,3 Google Pixel Display Adhesive Installation: 步骤 5 中的图像 2,3 Google Pixel Display Adhesive Installation: 步骤 5 中的图像 3,3
    • Firmly press the adhesive into place.
    • You can use the flat end of a spudger to press along the edges and other hard-to-reach areas.
    添加评论
  6. Google Pixel Display Adhesive Installation: 步骤 6 中的图像 1,2 Google Pixel Display Adhesive Installation: 步骤 6 中的图像 2,2
    • Peel off and discard the plastic liner, exposing the display adhesive.
    添加评论
  7. Google Pixel Display Adhesive Installation: 步骤 7 中的图像 1,2 Google Pixel Display Adhesive Installation: 步骤 7 中的图像 2,2
    • Once the new adhesive is exposed, do your best not to touch it—either with your hand, or the display. If you can, try to hold the display up and away from the rest of the phone (as shown in the step photo) while performing this step.
    • Re-attach the display cable connector.
    • Screw the connector bracket back in place.
    • Power on your phone to make sure your repair was successful.
    • Do not remove or adjust the display cable while the phone is powered on.
    添加评论
  8. Google Pixel Display Adhesive Installation: 步骤 8 中的图像 1,1
    • Once you are sure the display is functioning properly, carefully align it with the chassis and firmly press it into place.
    • To help the display adhesive bond more securely, heat the perimeter of the display and then place the phone face-up under a heavy stack of books for 30 minutes.
    添加评论
结论
取消:我没有完成这个指南。
48等其他人完成本指南。
Taylor Dixon
于06/26/18注册
72,642 声望
创作了94篇指南
2指南评论
What is the included tesa tape for?
Koelton Carere - 回复 分享
The Tesa tape is to adhere the battery to the frame. You don't want anything moving around inside your phone--that can stress, damage, or disconnect ribbon connectors.
David Bauman - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 31
过去 30 天: 109
总计 20,325
