此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
加热iOpener并将其覆盖在显示屏的上边缘两分钟。
在开始撬动屏幕前注意以下区域:
显示面板边缘的细条粘合剂
厚粘合剂
容易损坏的OLED显示面板
撬动过程中可能会受损的显示屏排线
将你的新零件与原装零件进行对比。在安装新零件之前,你可能需要迁移剩余的组件或移除新零件上的粘合剂衬垫。
如果你的 Pixel 在更换屏幕后无法开机,可能是因为电池重新连接时手机已悄无声息地开机了。按住电源按钮几秒钟,直到手机震动关机。随后,重新连接屏幕,再试一次。
要重新组装设备,请按相反顺序执行这些说明。
请将电子废弃物送到通过 R2 或 e-Stewards 认证的回收商处进行回收。
维修过程不如预期?查看我们的 Google Pixel XL Answers 社区 以获取故障排除帮助。
34等其他人完成本指南。
由衷感谢以下译者:
100%
Scott_Hsu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
11指南评论
I just connected the screen to the phone, but the screen doesn’t start. Do I have to restart in a special way the phone to make it works? All possible button combinations to restart the phone doesn’t work
The iFixIt iOpener tool is a complete waste of money. It didn’t loosen up the glue at all. I am requesting a refund on Amazon.com
Drew Hookway - 回复 分享
Hi Drew, sorry to hear that your iOpener didn’t work too well in your repairs. We like to think it’s a pretty valuable and inexpensive tool, but it does have its quirks — namely, not everyone’s microwave is specced to operate at the same temperatures, so not everyone will achieve the most optimal temperature during that heating process.
For what it’s worth, we do put a Lifetime Warranty on the iOpener tools, so our Support team would be happy to replace that one for you, if you’d like. If so, please reach out to them by using the Contact link on the help page: http://help.ifixit.com. Otherwise, you are welcome to request a refund via Amazon and we will oblige.
We wish you all the best in your future repairs.
Kadan Sharpe - 回复 分享
I am sure the iOpener does work, but it probably takes a long time to heat the adhesive enough for screen removal and would require several applications. I got one as part of my screen replacement kit, although I have a heat gun so I didn’t end up using it. That being said my screen took at least four minutes of heating, with some re-heating to remove the broken shards. I would also imagine that adhesives vary from manufacturer, since this is my first screen replacement all I know is that the adhesive on the Pixel XL is really strong!
Don’t forget to transfer the speaker cloth to the new screen. I got it all back together before realizing that there was just an ugly hole.
