跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
iPhone 14 屏幕替换
你所需要的
  1. iPhone 14 屏幕替换, 移除五角螺丝: 步骤 1 中的图像 1,2 iPhone 14 屏幕替换, 移除五角螺丝: 步骤 1 中的图像 2,2
    • 在取下螺丝前请先将你的手机关机。
    • 取下手机底部的两颗 6.8 毫米长的五角 P2 螺丝。
    PLEASE remove back first and disconnect battery before taking cables off!! as per Apple instructions
    PC Technology Group - 回复
  2. iPhone 14 屏幕替换, 标记你的三角撬片: 步骤 2 中的图像 1,3 iPhone 14 屏幕替换, 标记你的三角撬片: 步骤 2 中的图像 2,3 iPhone 14 屏幕替换, 标记你的三角撬片: 步骤 2 中的图像 3,3
    • 如果插入太深,三角撬片可能会损坏你的设备。 按照此步骤标记撬片并防止损坏。
    • 从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
    • 你还可以用不同的尺寸标记三撬片的其他角。
    • 或者,将 将一枚硬币 粘在距撬片尖端 3 毫米处。
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - 回复
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - 回复
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - 回复
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - 回复
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - 回复
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - 回复
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - 回复
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - 回复
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - 回复
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - 回复
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - 回复
  3. iPhone 14 屏幕替换, 用胶带覆盖破损: 步骤 3 中的图像 1,3 iPhone 14 屏幕替换, 用胶带覆盖破损: 步骤 3 中的图像 2,3 iPhone 14 屏幕替换, 用胶带覆盖破损: 步骤 3 中的图像 3,3
    • 如果 iPhone 的后玻璃破裂,请在维修过程中通过在玻璃上贴胶带来防止进一步破损并防止人身伤害。
    • 将重叠的透明包装胶带条黏在 iPhone 的后玻璃上,直到覆盖整个手机后部。
    • 戴上安全眼镜以保护你的眼睛免受修理过程松散玻璃的伤害。
    • 如果在接下来的几个步骤中无法让吸盘粘在手机上,请将强力胶带(折叠到把手中,然后用它提起后玻璃。
    • 如果所有措施都不可行,你可以用502胶把吸盘粘到后玻璃上。
    Had to do the superglue. Also that glass was so shattered that it came off in pieces, took my almost an hour to get the whole screen of. Tape didn't really help there, it would just pull the tape off instead of the screen. Do note that the whole screen assembly is quite thick, I think I initially put my pick in a layer inbetween.
    Gijs Leegwater - 回复
    1st step you have forgotten remove the back to disconnect battery golden rule battery first
  4. iPhone 14 屏幕替换, 反向钳使用指南: 步骤 4 中的图像 1,3 iPhone 14 屏幕替换, 反向钳使用指南: 步骤 4 中的图像 2,3 iPhone 14 屏幕替换, 反向钳使用指南: 步骤 4 中的图像 3,3
    • 接下来的两个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 参照本指南了解如何使用附带的胶带固定屏幕。
    • 将蓝色手柄拉向铰链以解锁反向钳的手臂。
    • 将反向钳手臂滑过 iPhone 的左边缘或右边缘。
    • 将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
    • 向下推吸盘以将吸力施加到所需区域。
    • 如果发现设备表面太光滑而反向钳无法吸住,请使用包装胶带来创造一个更容易抓握的表面。
  5. iPhone 14 屏幕替换: 步骤 5 中的图像 1,3 iPhone 14 屏幕替换: 步骤 5 中的图像 2,3 iPhone 14 屏幕替换: 步骤 5 中的图像 3,3
    • 向前拉蓝色手柄以锁定手臂。
    • 顺时针转动手柄 360 度或直到吸盘开始拉伸。
    • 确保吸盘彼此对齐。 如果在拉伸过程中吸盘慢慢不对齐,请松开吸盘并重新对齐手臂。
  6. iPhone 14 屏幕替换: 步骤 6 中的图像 1,3 iPhone 14 屏幕替换: 步骤 6 中的图像 2,3 iPhone 14 屏幕替换: 步骤 6 中的图像 3,3
    • 将iPhon放在在坚硬的物品上,比如硬皮书,这样你就可以解放你的双手并且使手机与桌面平行--这样做会使下面的步骤变得简单。
    • 使用吹风机沿着 iPhone 的底部边缘加热。 手机玻璃应该比较热而手无法触摸。
    • 有关如何使用吹风机的完整说明,请查看本指南。
    • 等待一分钟,让胶水软化,手机出现一个开口。
    • 当反向钳创造出足够大的间隙时,在后玻璃下方插入三角撬片。
    • 如果反向钳没有创造出足够的间隙,请对该区域施加更多热量并将手柄旋转四分之一圈。
    • 一次不要转动超过四分之一圈,并且在转动之间等待一分钟。 让反向钳和时间为你工作。
    • 跳过下两个步骤
  7. iPhone 14 屏幕替换, 加热手机的底部边缘: 步骤 7 中的图像 1,1
    • 如果你使用的是吸柄,请按照接下来的两个步骤松开后玻璃。
    • 使用吹风机热风枪加热 iPhone 的底部边缘 90 秒,或直到后玻璃稍微热到无法触摸为止。
    • 切勿用吹风机长时间吹一个地方。
  8. iPhone 14 屏幕替换, 插入三角撬片: 步骤 8 中的图像 1,3 iPhone 14 屏幕替换, 插入三角撬片: 步骤 8 中的图像 2,3 iPhone 14 屏幕替换, 插入三角撬片: 步骤 8 中的图像 3,3
    • 将吸柄放在屏幕的底部,请避开后壳的最边缘。
    • 用牢固、恒定的压力拉起吸盘,在屏幕和外边框之间形成微小的间隙。
    • 将撬片插入屏幕塑料边框下方的缝隙中
    • 固定屏幕的胶水非常牢固;创造出这个初始缝隙需要很大的力量。如果很难创造出缝隙,请施加更多的热量,并轻轻地上下摇动后壳,以软化胶水,直到你创造出足够的缝隙来插入撬片。
  9. iPhone 14 屏幕替换, 加热右侧: 步骤 9 中的图像 1,2 iPhone 14 屏幕替换, 加热右侧: 步骤 9 中的图像 2,2
    • 使用吹风机加热 iPhone 的右边缘 90 秒,或直到屏幕稍微热到无法触摸为止。
  10. iPhone 14 屏幕替换, 划开右边缘胶水: 步骤 10 中的图像 1,3 iPhone 14 屏幕替换, 划开右边缘胶水: 步骤 10 中的图像 2,3 iPhone 14 屏幕替换, 划开右边缘胶水: 步骤 10 中的图像 3,3
    • 在 iPhone 的右下角滑动三角撬片以分离其胶水。
    • 继续向上滑动 iPhone 的右边缘,直到到达右上角。
    • 将撬片插入手机的深度不要超过 3 毫米,否则可能会损坏内部组件。
    • 在继续之前将撬片留在手机右上角。
  11. iPhone 14 屏幕替换, 加热手机的上侧: 步骤 11 中的图像 1,1
    • 使用吹风机加热 iPhone 的顶部边缘 90 秒或直到屏幕稍微太热而无法触摸。
  12. iPhone 14 屏幕替换, 划开顶部胶水: 步骤 12 中的图像 1,3 iPhone 14 屏幕替换, 划开顶部胶水: 步骤 12 中的图像 2,3 iPhone 14 屏幕替换, 划开顶部胶水: 步骤 12 中的图像 3,3
    • 在 iPhone 的右上角滑动三角撬片以分离顶部粘合剂。
    • 请勿将撬片插入超过 3 毫米,你可能会损坏顶部传感器。
    • 在继续之前将撬片留在左上角。
  13. iPhone 14 屏幕替换, 加热手机左侧: 步骤 13 中的图像 1,2 iPhone 14 屏幕替换, 加热手机左侧: 步骤 13 中的图像 2,2
    • 使用吹风机加热 iPhone 的左边缘 90 秒或直到屏幕略微太热而无法触摸。
  14. iPhone 14 屏幕替换, 注意事项: 步骤 14 中的图像 1,1
    • iPhone 的左边缘有2根易损的排线。请勿在此插入三角撬片 ,你很可能会损坏排线。
  15. iPhone 14 屏幕替换, 切开左侧胶水: 步骤 15 中的图像 1,2 iPhone 14 屏幕替换, 切开左侧胶水: 步骤 15 中的图像 2,2
    • 屏幕左侧的排线很容易被撬片损坏。 按照此替代程序划开左侧的胶水。
    • 在 iPhone 的左下角插入第二个三角撬片。
    • 同时扭动两个撬片,直到左侧的卡扣松开。
    • 逐渐施加扭转力。
    • 如果你在分离胶水时遇到问题,请重新加热左边缘。
    My glass was so shattered that twisting picks never was going to create enough force for the centre to come loose. I just pulled up the corners with my hands.
    Gijs Leegwater - 回复
  16. iPhone 14 屏幕替换, 打开手机: 步骤 16 中的图像 1,3 iPhone 14 屏幕替换, 打开手机: 步骤 16 中的图像 2,3 iPhone 14 屏幕替换, 打开手机: 步骤 16 中的图像 3,3
    • 从屏幕上取下吸柄。
    • 旋转 iPhone,使手机右侧朝向你。
    • 从右侧向上像翻书一样的打开手机。
    • 维修手机时,请将屏幕靠在一个物体上以保持其支撑。
    • 如果手边没有任何东西来支撑手机,可以用吸柄来做手机支架
    • 在重新组装过程中,请将屏幕放置到位,然后将卡扣沿上边缘对齐,并小心地将上边缘压到位,然后将其余部分扣下。如果卡扣比较难卡到位,请检查屏幕卡扣的状况,确保它们没有弯曲。
  17. iPhone 14 屏幕替换, 松开屏幕接口盖螺丝: 步骤 17 中的图像 1,2 iPhone 14 屏幕替换, 松开屏幕接口盖螺丝: 步骤 17 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • 使用 Y000 螺丝刀卸下用于固定屏幕接口盖的 0.8 毫米长螺丝。
    • 在整个维修过程中,请保管好每一个螺丝 ,并确保它们从哪里来到哪里去,以免损伤你的设备。
    • 在重新组装过程中,这是在将显示屏密封到位之前打开 iPhone 并测试所有功能的最好时机。 在继续维修之前,请务必将 iPhone 完全断电。
  18. iPhone 14 屏幕替换, 卸下屏幕接口盖: 步骤 18 中的图像 1,3 iPhone 14 屏幕替换, 卸下屏幕接口盖: 步骤 18 中的图像 2,3 iPhone 14 屏幕替换, 卸下屏幕接口盖: 步骤 18 中的图像 3,3
    • 用镊子夹住接口盖的螺孔端。
    • 轻轻提起盖子以松开另一边的闩锁。
    • 卸下屏幕接口盖。
    • 重新组装期间,确保盖子正确盖好。
  19. iPhone 14 屏幕替换, 断开屏幕连接: 步骤 19 中的图像 1,2 iPhone 14 屏幕替换, 断开屏幕连接: 步骤 19 中的图像 2,2
    • 使用撬棒的尖端将接口从其插座中垂直向上撬开,从而断开屏幕排线。
    • 要重新连接像这样的按压式接口 请小心将其对齐并先向下按压一侧,直到其卡入到位,然后按压另一侧。 请勿按压接口的中间位置。如果接口未对准,按压中间位置可能会导致下面的针脚弯曲以造成永久性的损坏。
    It is necessary to disconnect the battery flex cable prior to disconnecting the screen to prevent any electrical damage to the device. This guide is inaccurate. You have to remove the rear glass panel first to disconnect the battery.
    Alec - 回复
    @robialecm It's not necessary, although it is a bit risky to do it without disconnecting the battery by just turning it off. Anyway, I wanted to check if the new screen was working before fully reassembling, otherwise the warranty on my replacement screen would be void. I have to admit I accidentally turned on the phone a few times, it's hard to not press the power button every once in a while. I managed to turn off the phone more or less by pressing volume up then volume down then hold power button then wait until reboot, keep holding power button until screen goes dark, then quickly release. But I was lucky that the new screen didn't sustain any damage because I'm pretty sure the phone was on while I was messing with the display connector.
    Gijs Leegwater - 回复
    I was very careful reconnecting the cables, and therefore it took my a very long time. Every time I pushed one side, the other side would come out. In the end the trick was to keep one side pressed down while gently - not too gently - pressing the other side.
    Gijs Leegwater - 回复
  20. iPhone 14 屏幕替换, 松开前传感器接口盖: 步骤 20 中的图像 1,2 iPhone 14 屏幕替换, 松开前传感器接口盖: 步骤 20 中的图像 2,2
    • 使用 Y000 螺丝刀卸下固定前传感器接口盖的 0.9 毫米长螺丝。
  21. iPhone 14 屏幕替换, 拆下前传感器接口盖: 步骤 21 中的图像 1,3 iPhone 14 屏幕替换, 拆下前传感器接口盖: 步骤 21 中的图像 2,3 iPhone 14 屏幕替换, 拆下前传感器接口盖: 步骤 21 中的图像 3,3
    • 用镊子夹住接口盖的螺孔端。
    • 轻轻提起盖子以松开另一边的闩锁。
    • 拆下前传感器接口盖。
    • 重新组装期间,确保盖子安装正确。
  22. iPhone 14 屏幕替换, 断开前传感器接口排线: 步骤 22 中的图像 1,2 iPhone 14 屏幕替换, 断开前传感器接口排线: 步骤 22 中的图像 2,2
    • 使用撬棒的尖端将接口从其插座中垂直向上撬开,从而断开前传感器排线。
  23. iPhone 14 屏幕替换, 移除屏幕: 步骤 23 中的图像 1,2 iPhone 14 屏幕替换, 移除屏幕: 步骤 23 中的图像 2,2
    • 移除屏幕
    • 用酒精(>90%) 清洁相关区域后,在必要的地方涂上新的粘合剂。
    • 在重新组装过程中,如果你想更换屏幕粘合剂,请在此处暂停。
  24. iPhone 14 屏幕替换, 松开前传感器保护盖: 步骤 24 中的图像 1,1
    • 其余步骤演示如何将前传感器组件转移到新屏幕。如果你的更换屏幕预装了组件,请跳过这些步骤。
    • 使用 Y000 螺丝刀拧下固定传感器组件保护盖的两颗 1.4 毫米长的螺钉。
  25. iPhone 14 屏幕替换, 拆下前传感器保护盖: 步骤 25 中的图像 1,2 iPhone 14 屏幕替换, 拆下前传感器保护盖: 步骤 25 中的图像 2,2
    在这个步骤中使用的工具:
    • 使用镊子或手指卸下前传感器组件保护盖。
  26. iPhone 14 屏幕替换, 加热前传感器组件: 步骤 26 中的图像 1,1
    • 加热 iOpener并将其贴在屏幕的上边缘两分钟。
    • 也可以使用吹风机热风枪或电热板,但要小心不要让手机过热——显示屏容易受到热损坏。
  27. iPhone 14 屏幕替换, 断开环境光传感器: 步骤 27 中的图像 1,2 iPhone 14 屏幕替换, 断开环境光传感器: 步骤 27 中的图像 2,2
    • 在环境光传感器与其屏幕凹槽之间插入三角撬片。
    • 用尖头撬起,将环境光传感器与屏幕分开。
  28. iPhone 14 屏幕替换, 断开接近传感器: 步骤 28 中的图像 1,2 iPhone 14 屏幕替换, 断开接近传感器: 步骤 28 中的图像 2,2
    • 在接近传感器与其屏幕上的凹槽之间插入三角撬片。
    • 用尖头针撬起,将接近传感器与屏幕分离。
  29. iPhone 14 屏幕替换, 重新定位接近传感器: 步骤 29 中的图像 1,2 iPhone 14 屏幕替换, 重新定位接近传感器: 步骤 29 中的图像 2,2
    • 使用镊子或手指将接近传感器电缆移离屏幕。
  30. iPhone 14 屏幕替换, 断开麦克风连接: 步骤 30 中的图像 1,3 iPhone 14 屏幕替换, 断开麦克风连接: 步骤 30 中的图像 2,3 iPhone 14 屏幕替换, 断开麦克风连接: 步骤 30 中的图像 3,3
    • 在麦克风排线下方插入三角撬片,靠近麦克风(金属矩形)。
    • 将三角撬片沿着麦克风周边滑动,以分离其粘合剂。
  31. iPhone 14 屏幕替换, 拆下前传感器组件: 步骤 31 中的图像 1,3 iPhone 14 屏幕替换, 拆下前传感器组件: 步骤 31 中的图像 2,3 iPhone 14 屏幕替换, 拆下前传感器组件: 步骤 31 中的图像 3,3
    • 此时,粘合剂可能已经冷却。如果是这样,请将加热的 iOpener 应用于组件一分钟,然后再继续。
    • 在前传感器组件左侧下方插入三角撬片。
    • 将撬片滑到组件下方,将其与框架分离。
  32. iPhone 14 屏幕替换: 步骤 32 中的图像 1,2 iPhone 14 屏幕替换: 步骤 32 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    • 拆下前传感器组件。
    • 将组件转移到新屏幕时,请遵循以下说明:
    • 将传感器连接到框架中的插槽,以帮助对齐组件的主要部分。
    • 使用 Tesa 胶带重新粘合组件中不再有粘性的任何部分。
结论
请在重新密封手机前将手机开机并测试你的维修是否成功。
若要重新组装你的设备,请按倒序执行这些说明。
固定新屏幕的最好方法是在框架上贴一张定制的双面胶,然后将屏幕放回原来的位置。
请将你的电子垃圾送到R2或e- steward认证的回收商
修理遇到困难? 试试 故障排除, 或者访问我们的 论坛 寻求帮助。
25等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
123,755 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,131篇指南
8条评论
Is there still a software lock that disables face id / auto brightness?
Yung Bruh - 回复
What about the battery isnt it a risk to connect it like this. Feels like half of the repair job,
atlas Tanko - 回复
Hi atlas Tanko, you're right, normally we recommend disconnecting the battery before replacing the screen. Due to the design of the iPhone 14 and 14 Plus (separate entry methods for screen and battery replacements), we consider it safe in this case. For the iPhone 14 Pro and Pro Max, we still include steps for disconnecting the battery during screen replacements.
Manuel Haeussermann -
Hi
iPhone 14 not showing display after replacement.
Connected old one, still no display.
I have previously discharged battery down, managed to access torch and also let screen on up to 10m at time - even though screen was quite damaged.
I am a 'careful repairer', but of course one can easily short pins of screen connector while trying to fit it, even though I use magnified glasses to see I do it as best as possible.
Any idea, do not know the 14 at all.
Thanks
JoeBlog - 回复
Hi JoeBlog,
Sorry to hear that you're facing some issues with your repair. How long did you let your phone charge after the repair? Did the device show signs of turning on, like vibration while booting / doing a hard reboot? Does it get recognized when being plugged into a computer? Please also check our troubleshooting resources for the iPhone 14.
you don't disconnect the battery ?
neo mobiles - 回复
Always disconnect the Battery!
Oliver -
添加评论
浏览统计数据:
过去 24 小时: 110
过去 7 天: 586
过去 30 天: 2,388
总计 68,894
