跳转到主内容
Google Pixel 3 XL Back Cover Replacement
Arthur Shi
Arthur Shi2 其他贡献者
最后更新于 November 14, 2022
10 - 40 分钟
中等
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
This guide shows how to remove and replace the glass back cover or back panel for your Pixel 3 XL.
Depending on your replacement part, you may need to transfer additional parts to your new back cover. This guide includes additional steps to transfer the fingerprint sensor, flash diffuser, and camera bracket to a replacement back cover. Replacing or swapping the NFC antenna is not included in these steps.
你所需要的
配件
工具
查看更多...
  1. Google Pixel 3 XL Back Cover Replacement, Heat the edge of the back cover: 步骤 1 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Heat the edge of the back cover: 步骤 1 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Heat the edge of the back cover: 步骤 1 中的图像 3,3
    • Heat an iOpener and apply it to the right edge of the back cover for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • While you wait, note the following areas on the back cover:
    • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
    • Fingerprint sensor cable—be careful not to slice through the cable as you pry
  2. Google Pixel 3 XL Back Cover Replacement, Create a gap under the back cover: 步骤 2 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Create a gap under the back cover: 步骤 2 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Create a gap under the back cover: 步骤 2 中的图像 3,3
    • Apply a suction cup to the heated edge of the back cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Suction cup doesn’t work on severely cracked glass.
    Jeffrey Kongthong - 回复
    Step 1 - 2 took me about 50 minutes. Back and forth with heat and trying with suction cup. I could get my finger nail in but not the pick. Took two people, but we finally got a pick in. 2 year old phone.
    Andrew Messier - 回复
    Took about 15 minutes and three total attempts. On the third attempt, I also used a thinner, metal, pick to widen the gap just enough for the plastic pick to fit (Though be careful as you can easily break it with a metal pick). The phone is three years old.
    Hotohori - 回复
    Could not get in with the pick or in from the side. Targeted the bottom of the phone with the iOpener and managed to gently create some space for the pick with the opener tool.
    Daniel R. - 回复
    I also struggled here for a while. I ended up working my way around the entire edge of the phone until I found one spot where I could pry up the back panel. I used a jimmy instead of the opening pics. I also used a hairdryer on lower heat instead of the iopener. 3 year old phone.
    Bryan Wethington - 回复
    Took 30 minutes + to get the back cover off. Used another suction cup to grip from the busted screen and the ifixit suction cup for the back. A thinner Acoustic guitar pick was required opposed to the standard Blues picks provided in the kit (har-har). Would HIGHLY suggest getting a pick into both the back and the front before removing the panels as it will give you more surfaces to pry from. Made that mistake...
    Brian Sommer - 回复
    Over 2 hours of trying, I keep reheating the pouch and let it sit on the edge for sometimes up to 10 minutes since the directed 1 minute wasn't working. Physically cant get enough leverage on the back of the phone; picks are too thick to get under the crack, and the suction cup pops off before I can get enough force to see any gap open. Phone is 5 years old. I really need some help
    Grant Cooper - 回复
    Hey Grant!
    I hear your pain—the adhesives on this phone are very strong. The initial gap is one of the hardest parts of the procedure. Here are some suggestions:
    * If you have a hair dryer, give that a shot. Heat the edge until it is slightly too hot to the touch.
    * These adhesives separate not with extreme force, but with constant steady force and time. Try heating the edge and pull on the suction cup with firm force for about a minute to let the adhesive separate.
    * If you have an opening tool, you can try this procedure to get the initial gap.
    Arthur Shi -
    Need a guide for if the back glass is broken!
    Lazybagel - 回复
  3. Google Pixel 3 XL Back Cover Replacement, Loosen the right edge adhesives: 步骤 3 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Loosen the right edge adhesives: 步骤 3 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Loosen the right edge adhesives: 步骤 3 中的图像 3,3
    • Slide the opening pick along the right edge to slice through the adhesive.
    • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
    • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Google Pixel 3 XL Back Cover Replacement, Heat the bottom edge of the back cover: 步骤 4 中的图像 1,1
    • Apply a heated iOpener to the bottom of the back cover for a minute.
  5. Google Pixel 3 XL Back Cover Replacement, Slice through the bottom adhesives: 步骤 5 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Slice through the bottom adhesives: 步骤 5 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Slice through the bottom adhesives: 步骤 5 中的图像 3,3
    • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
    • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
    • Leave a pick in the edge to prevent the adhesive from re-sealing.
  6. Google Pixel 3 XL Back Cover Replacement, Slice through the remaining edges: 步骤 6 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Slice through the remaining edges: 步骤 6 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Slice through the remaining edges: 步骤 6 中的图像 3,3
    • Continue heating and slicing the remaining edges of the phone.
    • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
    • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
    The back cover is Glass!!!!. DO NOT PRY HARD, IT WILL BREAK!!!!!!!
    You must go slowly and let the heat do the work, if you force the cover off, it will shatter.
    Paul Bernstein - 回复
  7. Google Pixel 3 XL Back Cover Replacement, Slice through the leftover adhesive: 步骤 7 中的图像 1,1
    • Gently pry up the right edge of the back cover.
    • Use an opening pick to slice through any remaining adhesive along the edges.
  8. Google Pixel 3 XL Back Cover Replacement, Swing open the back cover: 步骤 8 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Swing open the back cover: 步骤 8 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Swing open the back cover: 步骤 8 中的图像 3,3
    • Swing the right edge of the back cover upwards and rest the flipped panel along the left side of the phone.
    • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • During reassembly, follow this guide to install custom-cut adhesives for your back cover.
    • If you replaced the fingerprint sensor, you'll need to use this software tool to make the phone recognize the new sensor.
    Reassembly is way harder. The adhesive guide is generic and not super helpful, so don't be surprised if things went smoothly until you get to this step and then everything starts sticking to things its not supposed to.
    Christopher Trimby - 回复
    This is great but how you address that fact that the phone is tied to a particular fingerprint sensor and after replacing, the new sensor is not recognized by the original phone?
    Dave - 回复
    Hi Dave!
    There's a software calibration tool that you can use to calibrate your new fingerprint sensor. I've updated this step to include a link to the tool.
    Arthur Shi -
    I have a pixel 3 xl and I can't get the tool to work. I finally got the driver's installed after several hours and it says it's for pixel 6 and up basically. So I tried the other option and it's basically saying to do a factory reset? Did I mess something up on the install or what am I doing wrong here? Thanks
    Cody L Paulsell - 回复
    Uhhh
    So, apparently the connector on the motherboard for the fingerprint sensor is just ridiculously fragile, because after plugging and screwing everything in (pretty much reassembled except for the adhesive), I closed up the phone and powered it on to test if everything was working, and when I opened it back up and let the top hang off to the side, it just snapped off. I didn't even have it tensioned that much, it was just hanging off to the side and snapped. So now I've traded a non-functional camera with a non-functional and irreparable (unless I get a new motherboard) fingerprint sensor.
    The guide really ought to emphasize how delicate that connector really is. I have a google drive link here to a photo of the remnants of my poor fingerprint sensor connector :( link
    Mindle - 回复
    Wasted a ton of time and effort (and money) trying to use this guide to repair my Pixel 3XL. Then I get to the software calibration tool and find:
    Unsupported device
    This is not a compatible device. Only Pixel 6, 6 Pro, 6a, 7, 7 Pro, 7a devices can install this software.
    I cannot say how frustrating it is when a guide and website that tried to be so helpful ends up like this. Failure due to referencing tools not on the site and not suitable for the job.
    Ross Chesley - 回复
    I too want to stress just how sensitive the fingerprint sensor cable is. Be sure you are only lifting the back away a very small amount until you are able to disconnect the cable. I thought I was being careful and ended up still putting a small tear in the cable!
    The good news is that a replacement sensor is well under $10 shipped. Also, I'm not sure why this guide recommends the use of the software tool.
    It is not compatible with the 3XL (and I'm not sure it ever was). I had some reservations when I read this when I had to replace my sensor, but I found comments else where stating that nothing was needed. Sure enough, when I got my new sensor installed, it worked with no issues. I didn't need to calibrate, or reset my device. I just needed to set my fingerprints up again.
    Ben H - 回复
  9. Google Pixel 3 XL Back Cover Replacement, Remove the fingerprint sensor tape: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • User tweezers to carefully peel up the yellow tape over the fingerprint sensor connector.
    This step is utterly unnecessary. It achieves nothing, and the tape is there for a reason (I'm not sure why, maybe to prevent short circuits). I didn't remove this tape while disassembling and it didn't change anything.
    Krzeszny - 回复
    The Kapton tape should adhere to both the cable and the connector. It helps prevent the cable from slipping out of the ZIF connector. You're right in that you don't have to completely remove the tape—I've adjusted the step to reflect this.
    Arthur Shi -
    I just finished this guide, thank you. It would be nice to have a "before ribbon removed" reference picture that's also without the Kapton tape in place if possible. I was no longer certain how far back into the ZIF connector I had to place the ribbon cable as I simply forgot what it looked like before removing it. Basically, it "felt" like it was out too far, but since I had no reference I couldn't compare. Step 10 has good close up pics, but the ribbon cable is already out a bit so a bad reference.
    teknomedic - 回复
  10. Google Pixel 3 XL Back Cover Replacement, Disconnect the fingerprint sensor: 步骤 10 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Disconnect the fingerprint sensor: 步骤 10 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Disconnect the fingerprint sensor: 步骤 10 中的图像 3,3
    • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
    • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
    • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
  11. Google Pixel 3 XL Back Cover Replacement, Remove the back cover: 步骤 11 中的图像 1,1
    • Remove the back cover.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 XL Back Cover Replacement, Heat the fingerprint sensor: 步骤 12 中的图像 1,1
    • Apply a heated iOpener over the fingerprint sensor for a minute.
  13. Google Pixel 3 XL Back Cover Replacement, Pry up the fingerprint sensor: 步骤 13 中的图像 1,3 Google Pixel 3 XL Back Cover Replacement, Pry up the fingerprint sensor: 步骤 13 中的图像 2,3 Google Pixel 3 XL Back Cover Replacement, Pry up the fingerprint sensor: 步骤 13 中的图像 3,3
    • Insert the edge of an opening tool underneath the square portion of the fingerprint sensor and slowly pry up to loosen the sensor.
    • Continue prying around the perimeter of the fingerprint sensor until it is loosened.
  14. Google Pixel 3 XL Back Cover Replacement, Loosen the fingerprint sensor: 步骤 14 中的图像 1,1
    • From the outer side of the back cover, use your finger to push the fingerprint sensor out of its cutout.
  15. Google Pixel 3 XL Back Cover Replacement, Remove the fingerprint sensor: 步骤 15 中的图像 1,1
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    • Remove the fingerprint sensor.
    • If you are transferring the fingerprint sensor to a new back cover, use some double-sided tape such as Tesa tape to affix it to the new panel.
  16. Google Pixel 3 XL Back Cover Replacement, Remove the flash diffuser: 步骤 16 中的图像 1,1
    • Insert the edge of an opening tool underneath the plastic flash diffuser and slowly pry up to loosen the diffuser.
    • Remove the diffuser.
  17. Google Pixel 3 XL Back Cover Replacement, Remove the rear camera bracket: 步骤 17 中的图像 1,1
    • Insert the edge of an opening tool underneath the camera bracket and pry up to loosen it.
    • Remove and transfer the camera bracket to your replacement part.
    • Compare your new replacement back cover to the original part. You may need to transfer additional components or remove adhesive backings from the new part before installing.
    No mention of the NFC Coil, almost forgot to move that one to the new back cover -.-'
    Isaias Baez - 回复
结论
10等其他人完成本指南。
Arthur Shi
于01/03/18注册
283,753 声望
创作了587篇指南
团队
iFixit iFixit 的会员
Staff
120 名成员
创作了19,665篇指南
11指南评论
What’s the flat pice that surrounds the fingerprint sensor? It appears to have two pieces that connect with a terminal on the logic board.
Grant Pauli - 回复
Is it the NFC reader?
Grant Pauli -
Correct! That is the NFC coil.
Arthur Shi -
I successfully installed the screen but accidentally broke off the gold tab sticking up from the mother board shield. It can be seen on the picture of step 11 next to the NFC connectors. Do you know what this is for and how it will affect the function of the phone?
Sal Arias - 回复
Hi Sal!
That tab looks to be a grounding clip, which would normally touch the fingerprint sensor bracket. I don’t think it is vital for daily function.
Arthur Shi -
I don’t see it addressed in the breakdown but how do you remove the NFC reader from the old back cover ?
kevin brady - 回复
Hey Kevin!
The NFC coil is lightly adhered to the back cover. Slowly and carefully peel it off the back cover. You can either apply a heated iOpener or some high-concentration (over 90%) isopropyl alcohol to help loosen the adhesive.
Arthur Shi -
What adhesive do we use to refit the back panel?
Kiran C - 回复
Is this replacement eradicate ip68 water resistance rating completely or depends on how we fix it.
Shees Nadeem - 回复
Hello! The level of water resistance depends on how you fix it. Technically, it will not be IP68 rated, because that requires certification.
Arthur Shi -
Where to buy the back cover.
alamri86 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 112
总计 15,422
