用手指、撬棒、塑料打开工具或镊子清除大块粘合剂。
使用除胶剂或高浓度(> 90%)异丙醇去除金属表面上的残留物。用不起毛的布或咖啡过滤器朝一个方向擦拭,直到所有残留的粘合剂消失。
剥下任何衬板之前,先找到无色面应粘附的表面。
为了使粘贴操作更容易,你可以将条带对准手机上的预期位置,然后向下粘贴一条边以将条带固定到位。这将使你能够剥离衬板并露出胶粘剂而不会难以对齐。
一旦确定好胶条如何在表面上贴合,就将无色衬纸剥离。
从U形切口(如果有)开始,小心地剥离白(纸)层和黑(胶粘剂)层的中心部分。
撕掉并丢弃剩余的纸衬,使下面的粘合剂露出来。
如果正确使用,粘合剂应能长时间可靠地工作。
维修不能恢复设备的防水性能。注意不要设备远离各种液体。
112等其他人完成本指南。
由衷感谢以下译者:
25%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
9指南评论
Diese Anleitung sollte im Akku-Tausch Tutorial verlinkt sein und auch in der Produktbeschreibung. Ich habe diesen Artikel erst gefunden, nachdem ich die Rückseite schon befestigt hatte (zum Glück richtig).
Although obvious to anyone who has used this type of strip, I didn't realize it until my first experience gluing a screen into my phone: the adhesive is ONLY the black goo attached to the strips. Once you peel off the clear side, place the strip and then peel off the coloured side, all that's left is the black goo, hopefully exactly where it needs to be. Mine could be carefully re-aligned with tweezers as necessary before setting the screen into place.
What's the popular recommendation regarding how long to leave weight on these pre-cut adhesive strips?
It merely says 'a few hours'?
Is it okay to check on it or is it like opening the oven door?
It's okay to check, and 2 hours is usualy plenty enough.
If you have any OLED display, DO NOT put books on it!!! Unlike LCDs, some Hard OLEDs cannot handle the pressure. If you have bought a display from ifixit they will also not warranty it and consider it user damage!!! That last section need to put in a warning for OLEDs.
