此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
本指南介绍了如何在已拆开的 iPad 上涂抹显示屏组件粘合剂。
粘合剂首先要涂在 显示屏 上,而不是中框上。
你所需要的
在这个步骤中使用的工具:Tweezers$4.99
在涂抹新的粘合剂之前,请彻底清洁显示屏部件和框架上的所有残留物。
使用 镊子 拉起残留的胶带部分。
使用开启工具或撬棒刮去残留物。你可以使用高浓度(超过90%)的异丙醇软化粘合剂。
朝一个方向擦拭以清除残留物,以免弄脏。
维修未按计划进行?请查阅 论坛 来寻求帮助。
64等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
11指南评论
Thanks, I was able to fix my wife’s shattered digitizer screen on the iPad 6th gen with this guide!
I managed to get it done, but this was a personal nightmare for me and more difficult than replacing the battery in my ipad. There are too many instruction that say “remove plastic” and I have no idea which layer; there was nothing on the packaging to indicate which side was up or which side was the front and I ended up guessing the wrong direction because it “looked” right, but wasn’t. A simple sticker on the packaging indicating a direction would have removed all of the frustration. I only managed to figure it out by removing all of the plastic so that the sticky side of the adhesive was exposed and then I could finally see how it was supposed to fit and how I was supposed to press down with the other side of the plastic to push the adhesive side into the frame.
Fixed a cracked iPad 4 mini screen; I agree with twizzlercraze72. Some kind of labeling would have saved so much peeling and re-sticking. I ended up with a gap next to my home button. An expensive lesson to learn.
CBrewington - 回复 分享
For me, actually replacing the battery wasn’t too bad, but I ended up using too much isopropyl to clean off the old glue, and it seeped under the display and ruined it. Wish Apple didn’t use so much glue. It massively impedes repairability, which is not very environmentally sound. My iPad was perfect apart from the battery - it’s now got a perfect battery but the iPad is ruined :-(
Alex Harness - 回复 分享
Same here :(. $50 repair just turned into $250!
Paul Manos - 回复 分享
