此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
在这个步骤中使用的工具:Tweezers$4.99
移除固定无线充电+nfc模组的11个3.7毫米十字螺丝
如果有哪颗螺丝在完全拧松后还是很难卸下,你可以用 镊子 将其取出。
在电池的每个角落下方涂抹 1-2 滴高浓度 (>90%) 异丙醇,并让其渗透几分钟,以帮助削弱粘合剂。
或者 使用刚加热的 iOpener 对着电池背后的显示屏加热两分钟,以帮助软化粘合剂。如果需要,请重复加热并重新放置 iOpener。
要重新组装设备,请按相反顺序执行这些说明。
为了获得最佳性能,在完成本指南后,请校准你新安装的电池。
56等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
14指南评论
this Iso + Heat method makes tough adhesive a thing of the past! just be patient. like the guide says, 2 mins to allow iso to penetrate
I applied the alcohol using a small paint brush, dipped into my iso jar, and “painted” along the battery edges.
roughly 30 seconds with heat gun on the front glass, boom, a freed battery
Just received this kit and I see it comes with the big adhesive, but it also has a smaller blue adhesive and a rectangle thing(that I think goes behind the battery?) that has a small one with it. Where do these things go?
Check out their guide they have up now for the replacement of this adhesive. Specifically, take a look at the pictures in step 10 to see where the little pieces are supposed to go.
Highly recommend against doing this. Even going carefully and reheating, 2 of the corners cracked when moving the pick through. So much for taking perfect care of the phone for 2 years =o(
Ditto. I ended up cracking my glass using the iOpener method as well. After no ordering and replacing the rear glass as well now, I am resorting to only using isopropyl alcohol from now on. No matter how hot I got the iOpener, how long I let it heat soak the adhesive, or how many times i reheated the iOpener and reapplied it, I never got any of this adhesive to come off without a risky struggle. And upon ordering all the adhesive kits, I still was shipped missing pieces of adhesive (camera, fingerprint reader, specific support adhesive, etc.). Very frustrating and time consuming process; far more than what these guides say it takes.
