MacBook Air 13" Early 2015 Upper Case Replacement
简介
转到步骤 1Use this guide to replace the upper case, including the keyboard, of your MacBook Air 13" Early 2015.
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
nijafe -
So this is a legit back cover for MacBook Air?
I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
Lance Berc - 回复
Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
The driver for the screws inside the case are named, as "T5".
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
how does a person put the battery connector back in?- that is the only thing i’m afraid of touching after putting new fan in.
I found it was possible to put the battery connector back in as the last step, however having gone through that and found it to be a little challenging, I would actually recommend attaching the battery connector before screwing back in the bracket. That way you’ll put a lot less stress on the connector cable.
When you are plugging the connector back in, make sure to give it some extra pressure to make sure it is all the way in. It may look like it’s in but needs to be pushed harder!
After disconnecting the power, you may skip directly to step 18. I don’t know why someone would think it necessary to disconnect all the other stuff. There is no need whatsoever to do so. The more things you disconnect, the more things you risk damaging. Many of the parts in steps 4 through 17 are quite delicate, and easy damaged.
The screw in step 18 is easily accessed without removing even the rubber gasket. Regarding step 18, only remove the screw. (This screw is rather long, with long threads.)
It’s helpful to take photographs of this area before removing the screw, so you’ll know what it’s supposed to look like when you put it back together.
There are only 16 steps in this repair process. I wonder whether you are commenting on a different repair.
Gyandev -
What if your battery doesn’t have that clear tab?
Yep, exactly the issue that I have
Unscrew the battery first, then let the cable flex out a little. Use a spudger or small pick to push the connector out from the board.
Nathan -
Where can i buy the battery connector?
Macbook air 2015 battery connector where can I purchase?
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
When putting this back together, be careful you don’t flip I/O board cable. It will fit, but the computer will not work. You’ll know it’s wrong if it covers the fan.
Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
the instructions should really indicate you’re only disconnecting one end of the cable. you disconnect the other end in step 6.
Bonjour,quand je retire la nappe de la carte E/S , l’éclairage de l’écran s’affiche mais quand je remets la nappe de la carte E/S ,j’ai un écran noir.J’attends votre réponse.Cordialement.
I literally did this wrong just like you warned not to! Very easy to do…
I watched the video twice and went really slowly through steps and it works!!! It was a little scary but we got through it! Thanks so much!!
20.00000.000$
Dewi Oasis - 回复
While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
pour le remontage
de mon coté tout c’est bien passé, il faut juste bien vérifier la nappe de la carte E/S soit à l’endroit, car sinon l’ordinateur refuse de démarrer ( se référer à la photo du coup )
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
The end of that cord slips into the channel whose lid you just flipped up. Don’t forget to re-insert that when reseating the fan and before flipping that retaining flap closed, it’s easy to miss and should have been part of these instructions, ifixit!
Thank you so much! Without your comment, I wouldn’t of realized that the ribbon cable is supposed to go into the socket (I know, dumb mistake now that I think about it). You also made me go back and correctly insert the microphone cable. Cheers!
After my repair, my fan is super loud now! Any tips?
I didn’t find any need to unplug the fan. All I did was remove the three screws which hold the fan to the case and gently fold the fan out of the way. All you are trying to do is gain enough room to route the camera cable into the little cut-out in the I/O board so it can go below the board along the edge of the fan.
I agree, BobY. I too didn't disconnect the fan cable. Those retaining flaps are so tiny it's hard even to see whether or not they are flipped up, so I was happy not to have to deal with it. That meant, however, that I had to be extra careful not to stress the fan cable when removing the fan (or more precisely, just lifting it out of the way rather than removing it completely), but I seem to have succeeded.
Gyandev -
I wish I'd read these comments before unplugging that cable. I can't figure out how to reseat the cable so I can close the retaining flap. It would help if I could see it better, or had a better idea of how it was connected before I unplugged it.
Peel the rubber gasket off the adhesive on the top of the fan.
When putting the computer together, pay attention to the placement of the gasket. It has a pin on the left side the enters the main board from the bottom. The right side straddles the tip of the heat pipe and there is a photo later on with close-up.
Remove the following three screws securing the fan to the upper case:
One 5.2 mm T5 Torx screw
One 3.3 mm T5 Torx screw
One 4.4 mm T5 Torx screw with a short head
I was unable to remove the 4.4 mm screw with the T5. I needed to use the T4 to get a grip so I didn’t strip the head.
The 3.3mm Torx is actually a 4.4mm
Lift the fan from the I/O board side and pull it free from the upper case.
Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
I didn’t find any need to remove the fan. I had no trouble routing the camera cable between the fan and the I/O board by just tilting the edge of the fan nearest the I/O board up and out of the way (pretty much what is being shown in the picture above).
I agree. I had to put something under the tilted (not removed) fan in order to have room to work, but it went okay.
Gyandev -
I removed it but it was a little tricky getting the ribbon cable back in. I was afraid it would break but it finally seated after a little wiggling.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
The connector has a latch (at least mine does) that prevents it from simply sliding out. To release it, I inserted a 5/64 flathead screwdriver to lift the edge of the socket. Then the jack and cable easily slides out.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
when i did this the whole socket came off the board and i had to get a replacement i/o board. Be warned, do this very carefully and avoid my mistake
If you are here to replace the logic board, you can skip steps 12-16, they’re unnecessary to replace the logic board.
maccentric - 回复
How do you put this back?? I’m struggling to figure out how to get the connector back into the socket of the new I/O board
You just line it up and push it down into the socket. Straight down, not sideways.
For Display disassembly you can skip this step.
I replaced a broken display of a MB Air with the functional of another MB Air. I removed the I/O board while disassembling the first Display, then I saw the comments so I tried it out while disassembling the second display. Worked out totally fine and saved me some time.
Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
There was black tape covering this socket. It was attached to the ribbon tape. I needed to pull up the tape covering the socket to expose the retaining clip.
Thanks Brant!
The note about the black tape should be in RED in the main text above. I broke off the connector thinking the tape was part of the cable assembly. Always read the comments. Always. : )
Ripped the connector off the picture was too small and I couldn’t see what part to lift.
If you click on the picture, you'll get a nice detailed blown-up view.
Steps 13 and 14 are unnecessary
Remove the single 4.1 mm T5 Torx screw securing the I/O board to the upper case.
Steps 14-15 & 28-29 seem unnecessary. I managed to replace the logic board without removing the I/O board or right speaker, although that means the logic board cannot be removed easily - the right rear corner is hindered by part of the chassis so that the edge of the logic board facing the battery should be lifted gently first and then the board be slid away from that obstructing part.
Exact, the step 14 is unnecessary
Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
This is really tricky. I couldn't de-route the cable as long as the I/O board was still in place. Had to lift the board mostly out of place in order to get enough slack in the cable to de-route it. Otherwise, I was going to have to force the de-routing, which seemed like a really bad idea.
Lift the I/O board from the logic board side and pull it free from the upper case.
Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
Nor for the logic board removal
maccentric - 回复
The back end of the microphone riibbon cable may be stuck down with a bit of glue under the flap. You can gently loosen it with a flat spudger.
how do I reattach the riibbon cable now that the adhesive has been removed?
I wonder if you weren't replacing the I/O board, BobY, but rather were doing some other repair. I say this because the microphone ribbon cable has to be disconnected from the I/O board in order to replace the I/O board, which is the repair that I was working on. And that disconnect/reconnect was definitely the fussiest part of this entire repair. Such tiny components to handle! In the end, I had to resort to using a tweezers, and even then I wasn't sure that everything was fully seated and secure.
Gyandev -
I wasn't replacing the I/O Board, I was replacing the entire Display Assembly--I got to this step within the instructions for replacing the Display Assembly. Maybe iFixit uses the same comments if they link to this same step from a different set of repair instructions? My comment was meant to convey you definitely don't need to remove the I/O Board to replace the Display Assembly.
BobY -
I got to this point (Step 16) within the instructions for replacing the Display Assembly, which is where I'm entering this comment. My comment was meant to convey it isn't necessary to remove the I/O Board to replace the Display Assembly, but you certainly would need to remove the I/O Board to replace the I/O Board.
Remove the following five screws securing the battery to the upper case:
Three 6.9 mm T5 Torx screws
Two 3.0 mm T5 Torx screws
what is that little hole or clip in the middle o battery?
Edy Surpat - 回复
There’s both a hole for a screw and a clip to hold the bottom case
Hello,
the battery is now delivered with a transparent plastic taped allover the new battery.
is it needed or shall it be removed
kind regards
Hello,
If the plastic is easily removable from the battery, it should be removed. However, if the plastic is glued onto the battery, do not remove the plastic.
The centre screw (of the three 6.9mm T5 described above) seems to be a bit thicker diameter than the other two corner (6.9mm screws - although I don't have a tool to make precise measurement). Replace this thicker screw to its centre position on the battery.
Not having a T5 bit, and somewhat dismayed at needing such an odd size of a familiar driver, I found aT6 bit worked fine for me...
I accidently broke off a 6.9 mm T5 Torx screw the one that goes in the center of the battery. Is it a big deal if all the other screws are in place holding the battery as well at the back end case? It seems secure but a piece of the screw that broke off is stuck in the center, and I can’t take it out to replace it with a new one. Is it a big deal? I powered on the computer and the battery is working at 39% to start
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Personally I would like a short description on why we have to calibrate a brand new battery for what reason?
@albertnumber1 You can find a detailed explanation of calibration here. The short(ish) answer is that the battery charge % reading on your device is really just a guess, one that is generated by a mathematical model of what’s going on inside the chemical battery. That model needs data points (like full charge and discharge flags) in order to work correctly. Without calibration, nothing bad will happen, but you may get some unreliable battery % readings.
1. Glad someone was able to clear up the reason we need to calibrate
2. During the process, if for some reason, say my cat waltzing all over my desk, disconnects the magsafe for a moment while in the final full charge cycle, what impact would this have?
The replacement battery’s connector didn’t align with the port as easily as the original’s. Instead of pointing straight back from the battery, the cable pointed at a significant angle. In order to connect the new battery, I had to hold it a slight diagonal angle while connecting it, before placing the new battery into the chassis and securing it.
After replacing the battery, the laptop (MBA early 2015) shut off immediately whenever it was unplugged from the MagSafe connector, despite reporting a full charge. To resolve this, I performed an SMC reset: I re-opened the case, unplugged the battery, held down the power button for 5 seconds with the battery unplugged, then re-connected the battery, re-attached the lid, and pressed the power button again. It immediately booted up as expected on battery power.
I found these two little broken tabs under the battery. Not sure where they came from, but Ididn’t put them back in anywhere.
These are from the old battery. Not totally necessary.
Good opportunity to blow or brush away some accumulated dust from a unit like mine (5 -6 years service) when the battery is out. Also at this time, used the thin probe tool to ream out some debris from the rim of the base.
The replacement battery cable seemed too long to fit well but when I examined the original, I noted a distinct v kink downwards in that one. A gentle push down in the middle formed a V and permitted the new cable to fit Presumably without harm..
howardmat3 - 回复
The instructions on this step say to remove the plastic film on the replacement battery, but the introduction says to leave it on. Which step is correct?
Hi William!
Good question! If the film is lightly adhered, you can peel and remove the film.
Hi how can I discharge the battery (MacBook air 2017) quickly as the battery has swollen and I need to get it out, at the moment I am running lots of apps but it still shows 6%?
max screen brightness and run some cpu benchmark
Shorting the battery is very dangerous. Leave the computer on until it shuts down on its own.
Good morning, I just replaced my first battery. The light on the magnet is red now. Will that color change to green to inform me that it is fully charged? Thanks, Julie
Re: leaving it unplugged for 5 hours after the battery goes flat - isn't that a bad thing? I thought Li-ion batteries get damaged by letting them go completely flat?
I have the same question, but from what i read the battery is still on 10% when the mac shuts down (to keep the battery healthy, so the 0% on the mac display is actually not the real battery charge)
Does anyone know what the four white (or red) dots on the underside of the battery mean?
Those are the liquid damage detectors. If they are red it means liquid has gotten into them. Always a bad sign
I've got a problem with the second MBA 2017 I did a battery replacement on. Replaced the battery, charged to 100%. Drained the battery and waited 5+ hours. Now it's stuck on 1% and won't charge. I've tried SMC reset by opening it up again, disconnect the new battery, hold the power button for 5 sec, connect the battery again but without any luck. Any suggestions?
Seems like a power cycle fixed the issue (turning the computer off, unplugging the MagSafe, holding the power button for 10 sec, plugging MagSafe back in).
Installing and conditioning the new battery was a breeze with your instructions and tool. But I get a message saying the date/time was set incorrectly. I could not reset it using the date/time in system preferences and the laptop was running hot with the fan running at full blast. Instead I had to shut it down and restart it in safe mode by pushing the shift button when I heard the start up chime and releasing it when the Apple logo appeared. Once in safe mode the date/time was correct and I restarted in normal mode. It's all good now. iFixit's comments allude to chip dependent issues and your should look at their detailed comments if you are having issues on restart after install. Thanks for a great product!
Grab the plastic pull tab secured to the display data cable lock and rotate it towards the top side of the computer.
Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
One of my terminals is broken. What solutions do you recommend me
Omar Lopez - 回复
You’re actually pushing the connector from side to side toward the front of the case (or towards the track pad). It’s not a vertical motion at all.
Jay Quilty - 回复
I’d also mention to be careful taking these off and putting them back on. I also accidentally pulled a terminal off it’a cable.
If the process is taken to replace the top case, you can leave the AirPort card hanging from the antenna wires. Only remove the card’s retaining screw and slide the card to the right (direction of the antenna connectors) to separate it from the main board.
Disconnect the camera cable connector with the tip of a spudger.
Pull the camera cable parallel to the face of the I/O board toward the front edge of the Air to disconnect it from its socket.
You’ve missed a whole section here on removing the fan. It’s still present in Step 19 pics, but gone by Step 23. It’s not that it’s difficult to work out how to do it. But, when reassembling and following the steps in reverse, it’s handy to know when to use which screws!
Ah! –my bad. The steps for removing Fan etc. are there –up round Step 13. It’s just your photos that are slightly out of sync, as it’s back in place again by Step 19. So, while working in reverse, it looks like it’s not been covered.
On getting it on — i feel it's implied by the word "push” you can walk it out with the spudger. I couldn't wanage that, and instead walked it out by taking the cord between my index and thumb and walking it out by pulling it to the right and then the left repeatedly in a
Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
Use your spudger to gently pull the keyboard backlight ribbon cable out of its socket.
Do you know where i can buy the retaining clip ?
Not sure you can. I’d just use some kapton tape to hold it in place and call it good.
Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
What is this cables for?
It’s a speaker cable
This is the one that gave me the hardest time!!! It does pop up and out tho.
Remove the six 6.3 mm T5 Torx screws securing the logic board to the upper case.
When re-assembling the motherboard, attach all 6 screws but do not completely tighten yet.
First make sure the rubber gasket is sitting properly, that the 7th screw hole (from Step 18) is properly aligned, and the Airport wire is sitting properly and also not caught under the heat sink.
Once everything is well aligned, start tightening the screws while watching out for the alignment. I found it useful to keep an eye on screw-hole from Step 18 as a reference.
Going in this order, there is a 7th screw securing the logic board to the frame; the heatsink is secured to the logic board with 4 screws, and secured to the frame with 1 more screw. Either take the heatsink off first, or remove that last screw underneath two small black wires, next to the left (as viewed when using the computer; if the computer is flipped over with the cover off and the monitor hinge end of the computer farthest from you, it is in the far right corner) set of three big torx screws that hold the hinge in place. The exact location of this screw is pictured in step 35's second picture; the screw goes through the loop visible below the rubber fan insulator. Scoot those 2 li'l wires out of the way and remove that screw, then the logic board comes right out. If this isn't clear, please let me know and I'll try to describe it better, or add a photo. If I'm posting this to the wrong instruction page, let me know; I was pretty sure I correctly identified my rig, but if not, sorry for the N00bage.
I got an extra screw hiding under the rubber gasket holding the end of the heatsink to the chassis. Ended up bending the heatsink a little cause I wasn't looking for it.
“Samsung RAM module”… do you mean the SSD? That stick of NVRAM is totally your hard drive.
Exactly, he means SSD (storage) the RAM (memory) is soldered to this 820-00165 logic board. Also on this model the 2015 MBA there is no logic board retaining screw under the SSD
Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
This is the same screws as step 17.
Joseph Lee - 回复
Good catch! We did some sleuthing and it looks like a couple guides did indeed have an extra section of steps! All better now =)
In my computer these screws were the same size as the other side’s hinge screws. All 6 are the same size.
Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
It’s not clear what you mean by “This step is not needed.” If you want to remove the logic board from the upper case in order to put it onto your replacement upper case, you will have to remove this screw.
This step is only needed if you’re replacing the ENTIRE top case. Simply swapping out the trackpad unit does not make this step necessary. This entire tutorial assumes you’re replacing the entire top case which is an expensive mistake if you’re simply replacing the trackpad and/or keyboard. The keyboard is removable as well despite those many tiny rivets. Save money and time by not replacing the entire top case for a bad trackpad and/or keyboard. I needed to accomplish this step because I also removed and replaced the keyboard.
NOTE: There is a sort of clamp/washer attached to this screw that I didn’t know about until I flipped the laptop up on its side and it fell onto the desk. Also: you need to reset it *before* the motherboard
In my computer this screw was not there, nor was a related washer. I got it used so perhaps someone has already been there and did not replace the screw.
Also, the photo here shows how this end of the fan gasket is placed
Slide the flat end of a spudger under the right speaker from the end nearest the hinge to the front edge of the Air to loosen the adhesive.
Remove the right speaker from the upper case.
You don’t really *have* to remove the speaker, especially if your replacement upper case assembly already includes the speakers.
I found the same. If you already have speakers in your new upper case, you can leave them. When you put the logic board back in, it will be a tight fit. I had to start with the corner near the right hinge (the Thunderbolt port corner) and work it in to place.
If it is difficult to remove the speakers you can use Isopropyl Alcohol to loosen the adhesive holding the speakers in place. Make sure to keep the Isopropyl Alcohol away from the speaker itself.
BluRepairs - 回复
Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
Keep loose cables clear of the board so they aren't caught under it.
Make sure the antenna cables are inserted into their respective notches, as highlighted in the second picture.
It’s probably worth mentioning here that during reassembly you want to tuck the rubber gasket under the extension of the heat sink that the fan slots into.
Remove the inner two 5.6 mm T8 Torx screws securing the right display hinge to the upper case.
Open the Air slowly until the hinges slide out of their notches.
Once the two display hinges have cleared the upper case, remove the display and set it aside.
MBA 2017: At this point I had to deroute the antenna cable from a channel along the back edge of the the upper case. Good to make note of this routing.
Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
Remove the left speaker from the upper case.
Not necessary to remove this. I was replacing a top case that included the speakers.
Same as the speaker in Step 29, which seems like it can also be left in place.
Replacing the entire top case is not necessary with the common spilled beverage situations. You can purchase a trackpad as well as keyboard for much less than the cost of an entirely new top case. Why replace the expensive aluminum top case unless it is itself broken which is unlikely.
BluRepairs - 回复
Use the flat end of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
If needed, apply a little heat from an iOpener or hairdryer to soften the adhesive.
Remove the microphone from the upper case.
If you’re replacing a top case with one provided by Apple, you won’t need to transfer the microphone to the new top case.
Hot air really helps here.
I really sweated over removing the microphone, but as Carroll mentioned, it’s not necessary since it was supplied with the iFixit upper case. Thanks, because it was a b*tch to remove and I probably damaged it in the process. Even with heat.
I did not have a mic in my Ifixit. Am I assuming I need to put it back? with adhesive
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
Please note that if you are replacing the keyboard you must save this cable for the new one!
In keyboard replacement, don’t need to take the cable off at all.
While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
I could not figure this out from the description. I was concerned about pulling too hard, so I elected to leave the ribbon cable in place until I removed the trackpad. It became obvious what to do at the point. The fact that the retaining flap is entirely hidden under the ribbon cable, and is on the keyboard side of the connector, was lost on me.
Remove the following seven screws:
Six 1.6 mm Phillips screws securing the trackpad to the upper case.
One 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
On The MacBook I worked on. It was not necessary to remove the 1.4mm T5 torx set screw. Which I found out after I broke a T5 bit in it.
BROKE my T5 bit on this “set screw” too. Correct, it isn’t necessary to remove, I recommend removing it from the steps.
Broken bit is perhaps a novice move by me, perhaps a cheap Torx screwdriver. Certainly made the rest of the repair dicey.
Yep the replacement case I got had one already installed; you can remove the trackpad with this screw in place, so you may not need to remove it.
John Noble - 回复
I had trouble removing the 6 Phillips screws. Even though I have a Phillips size 00 screwdriver it is not engaging the screws properly — I cannot get them to turn without stripping. I ordered the philips 00 screwdriver from iFixit and am HOPING that solves it.
Yes, make sure you have a good quality screwdriver that gets excellent purchase on these screws, and bear down to make sure you don’t strip them. I stripped one and had to drill it out with a 1/16” carbide drill bit. I’ll end up with only two screws on one side but I imagine it should be OK.
I was able to cheaply replace the keyboard as well as the trackpad, both without replacing the expensive aluminum frame. I followed these steps and then added a few to the end. I was able to easily remove the keyboard black cover/film by lifting the adhesive edges from the case. Then I removed the white backlight layer. Unlike earlier Macbook Pros, this Air model has the keyboard both screwed AND riveted to the aluminum frame. No biggie! I removed the tiny black screws from the keyboard edges then used pliers to pull the keyboard away from the aluminum frame. With this method I removed about 80% of the rivets which left perfect holes for the screws that came with the keyboard. After seating the new keyboard unit I was able to fasten it to the aluminum frame with screws on the keyboard edges as well as in the popped rivet holes. This tutorial can be modified near the end to create a keyboard replacement tutorial. See Rivet-pop method on YouTube, 20min into this video:
All the steps went swimmingly, until I got to this step. As soon as I put in the Phillips 00 screw driver, I immediately knew that one of the Phillips screws was already partly stripped - probably during original assembly. Sure enough, no engagement. Does anyone know how to remove such a tiny stripped screw?
The Phillips #00 recommended in the “Tools” section did not work for me and almost stripped the screws. I tried a Phillips #000 and it worked perfectly.
Carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
Remove the trackpad from the upper case.
The upper case remains.
I’m disappointed that you didn’t touch on the keyboard removal process, even if it was touching on it without images.
62等其他人完成本指南。
8指南评论
helped me change out a keyboard easy to follow
maybe not hard closer to a medium challange
Difficulty max medium…did this in 20-30min
Wonderful guide! Can’t do anything without you guys!
As usual, a perfect guide. I was able to complete the top case replacement in roughly 30 minutes. I purchased your P5 Pentalobe Screwdriver along with the magnetized organizer mat which certainly helped me with getting the replacement done that quickly.
Truly excellent guide. Carried out with Essentials Electronic Toolkit. Was actually enjoyable!
Used this guide to replace the keyboard on my late 2015. When I got it all apart, the keyboard wouldn’t pop off. After carefully removing the black cover that’s secured with adhesive around the perimeter (visible in photos in the guide) and the clear plastic thing below it, I finally accessed the keyboard itself. There were an enormous number of very tiny phillips head screws securing the perimeter, which I removed. Still holding the keyboard in was maybe 50 or so points, between all the keys. Initially they looked like spot welds but were more like rivets, where the aluminum of the case had been peened through holes in the steel part of the keyboard. I started by drilling these out, but quickly found out that they just pop pff with some force, but certainly destroying my water damaged keyboard. I placed the new one on and replaced the perimeter screws. After reassembling everything it works great. I thought the keyboard might be mushy but it’s not. I was glad to have the 64 driver set. Thanks Ifixit!
how do you remove the keyboard. I go the replacement but it appears that the keys are reviled in. There are screws on the edges, but appears to have some kind of other fixtures around the keys.
never mind. Just have to use sheer force to remove the keyboard
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - 回复
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - 回复
I thought I could replace my 256 Gb SSD with 512? regards
ola m - 回复
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - 回复
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - 回复
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - 回复
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - 回复
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - 回复
P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
William Skinner - 回复
I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
eric -
Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
Dennis Eaton - 回复
My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
Pennny Beach - 回复
The supplied kit and instructions worked perfectly!
Nikolay Andreev - 回复
Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
joemoog - 回复
Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
Merci pour votre aide.
chicco33 - 回复
oui, vous aurez besoin d’un adaptateur, pour completez le changement.
Dan -
The tool kit should include tweezers for re-inserting the battery connector.
Andre Clement - 回复
P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
michaelquinnell - 回复
Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
Thomas Lewis - 回复
To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
Pentalobe 1.2(mm)
also
P4 = 0.8
P6 = 1.5
Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
nijafe -
I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
Sean Love - 回复
Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
John Brennand - 回复
Just installed on a MacBookAir6,2 (13-inch, Early 2014).
Was very easy.
New iFixit battery looks great so far:
Jonathan Cross - 回复
can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
hawk_lpc -
Screw P5 Pentalobe 1.2
Mario Verlent - 回复
Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
Joel Sebastian - 回复
Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
Donald Niamath - 回复
Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
Amir Zaidi - 回复
Thank you very much for the guilde. My MBA2011 had reborn !
Billy Wong - 回复
Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
See great advice: Electrostatic Discharge
Fletcher Cole - 回复
… und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
Blatt - 回复
Fot All People ha ing trouble finding their SSD
DONT PRESS CMD +R + POWER
instead press
OPTION+CMD+R +POWER
I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
Albert - 回复
IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
Good luck. - Eric J.
ECJohansen - 回复
On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
Rich Garella - 回复
shrhh - 回复
Is it possible to change an upper case with a german keyboard for an english one?
Rogerio Pefi - 回复
if you are intending to change it to British layout you don't need to change the keyboard at all, just the keys, buy either a set of a1466 key caps ( I assume you have a 2017 MacBook Air?) or a cheap a1466 keyboard (can even be a broken one), remove the keys that are different and replace them with the other keycaps, and then set the macbook's language to British and you are set
Kai Mcpherson -
