跳转到主内容
加入维修社区 - 创建账户
Core Assembly Removal
你所需要的
  1. Core Assembly Removal, Power down your watch: 步骤 1 中的图像 1,2 Core Assembly Removal, Power down your watch: 步骤 1 中的图像 2,2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    询问修复机器人
    添加评论
  2. Core Assembly Removal, Unfasten the back cover: 步骤 2 中的图像 1,1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    询问修复机器人
    添加评论
  3. Core Assembly Removal, Loosen the back cover adhesive: 步骤 3 中的图像 1,1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    询问修复机器人
    添加评论
  4. Core Assembly Removal, Pry up the back cover assembly: 步骤 4 中的图像 1,3 Core Assembly Removal, Pry up the back cover assembly: 步骤 4 中的图像 2,3 Core Assembly Removal, Pry up the back cover assembly: 步骤 4 中的图像 3,3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    添加评论
  5. Core Assembly Removal, Disconnect the sensor assembly cable: 步骤 5 中的图像 1,2 Core Assembly Removal, Disconnect the sensor assembly cable: 步骤 5 中的图像 2,2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    询问修复机器人
    添加评论
  6. Core Assembly Removal, Remove the back cover assembly: 步骤 6 中的图像 1,3 Core Assembly Removal, Remove the back cover assembly: 步骤 6 中的图像 2,3 Core Assembly Removal, Remove the back cover assembly: 步骤 6 中的图像 3,3
    • Remove the back cover assembly.
    添加评论
  7. Core Assembly Removal, Disconnect the microphone cable: 步骤 7 中的图像 1,2 Core Assembly Removal, Disconnect the microphone cable: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
    询问修复机器人
    添加评论
  8. Core Assembly Removal, Unfasten the core assembly: 步骤 8 中的图像 1,1
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
    询问修复机器人
    添加评论
  9. Core Assembly Removal, Pry up the core assembly: 步骤 9 中的图像 1,2 Core Assembly Removal, Pry up the core assembly: 步骤 9 中的图像 2,2
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
    询问修复机器人
    添加评论
  10. Core Assembly Removal, Swing open the core assembly: 步骤 10 中的图像 1,3 Core Assembly Removal, Swing open the core assembly: 步骤 10 中的图像 2,3 Core Assembly Removal, Swing open the core assembly: 步骤 10 中的图像 3,3
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
    添加评论
  11. Core Assembly Removal, Disconnect the display cables: 步骤 11 中的图像 1,3 Core Assembly Removal, Disconnect the display cables: 步骤 11 中的图像 2,3 Core Assembly Removal, Disconnect the display cables: 步骤 11 中的图像 3,3
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
    询问修复机器人
    添加评论
  12. Core Assembly Removal, Remove the core assembly: 步骤 12 中的图像 1,2 Core Assembly Removal, Remove the core assembly: 步骤 12 中的图像 2,2
    • Remove the core assembly.
    询问修复机器人
    添加评论
结论
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Dominik Schnabelrauch
于11/23/16注册
260,312 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了26,617篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 43
总计 1,510
