跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
123 个问题 查看全部
I need to recover data from a PC after OS reinstall
First off. A note to any advertisers and spammers (you know who you are) who may recommend their software: I Don't want your useless piece of software. no matter how "Amazing" it is. I'm having none of it.
There's that. So, I need a free data recovery program that I could boot off of or works pretty dang well. This HDD has had it's OS uninstalled, been reformatted, OS installed, Configured, and used for 2 hours or so. (OS is Windows XP) I was thinking plug the HDD into another PC and use Recuva but I'm not sure if that's really good for this kind of mess up. It's probably gone at this point, but it's worth a shot. Thanks!
@mayer @oldturkey03 @danj @paperboypaddy Any recommendations? if not, I'm open for others. (Non-sponsored and stuff)
Ugh. Advertisers and spammers will be everywhere on this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
9条评论
完成的
@zerocool278 I'm curious if you know as much about PC's as me... Seems like you would.
完成的
@captainsnowball
Chances are slim, but you can try, just to share my experience... a user also asked me to re image his hard drive, telling me he has backed up all his data, but he had forgotten to copied his PST files.... tried some software like GetDataBack, etc, but sadly, as it has been used for some time... files has been overwritten.
完成的
@captainsnowball Sorry I’m not the greatest at recovering drives others than a drive that works and doesn’t have any data deleted. I do know that data that wasn’t written over with 0’s are recoverable, just not sure how.
完成的
For XP there was Disk Commander 2005 from Winternals that can help recover lost data. It is available for free but hard to find, I was able to find it and download it to fix a problem with a friend's crashed hard drive. If you are lucky the OS is in the same part as the original OS, if you have not installed apps then there is a slim chance of success.
完成的
显示更多的4条评论
添加一条评论
3个答案
已选择的解决方案
I don't think here is any free software to recover your whole data from PC. You should get help from an technical expert, they can help you to recover your data without installing a software.
这个答案有帮助吗?
得分 0
1条评论:
@digitalbulls Do you know why we’re here?! We’re here to save as much money and time as possible, getting data recovered from a expert will cost $Hundreds!
完成的
添加一条评论
最有帮助的答案
@captainsnowball all my tools come from Hiren's Boot CD. The more you use this drive the less data you will be recovering. Anytime you write to it, parts will be lost....
这个答案有帮助吗?
得分 1
2条评论:
Ill take a look. thanks!
完成的
@oldturkey03 I cannot find a proper download. do you have a link?
完成的
添加一条评论
"GetDataBack" is the only one that really worked for me. Unfortunately, it isn't free.
Also be careful that you don't write new data to that drive.
Since you installed a new OS over it already, you may already be in trouble.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aiden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 172
