跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
相机无法保持开机状态
相机开机后不久即关机,这表明电池故障、充电器故障或电池连接问题。
电池或连接可能存在故障
如果相机开机后反复自动关机,说明电池无法保持电量或连接不良。你应该检查电池连接,并考虑更换电池,详见此电池更换指南。
充电器可能存在故障
如果检查确认电池和连接没有问题,可能是充电器未能正常为电池充电。你可以考虑更换充电器。
主板可能存在故障
如果相机完全无法开机且电池检查无误,则可能是主板发生故障。你可以考虑使用此Canon EOS 70D 主板更换指南更换主板。
相机无法对焦
如果在拍照时画面始终模糊不清,这是对焦组件出现问题的常见症状。
镜头内对焦主板可能存在故障
如果你无法使用自动/手动对焦功能,请考虑使用此对焦主板指南更换镜头内的对焦主板。
屏幕无法显示
如果相机已开机且顶部屏幕正常显示,但相机的翻转屏没有图像,则屏幕可能已损坏。
屏幕组件可能已损坏
如果屏幕破裂或损坏,你应该使用此液晶触摸屏更换指南更换相机屏幕。
SD 卡错误
如果拍照时屏幕显示“SD Card Error”(SD 卡错误)消息,你可能需要格式化 SD 卡。
SD 卡格式化不正确
如果拍照时屏幕弹出“SD Card Error”(SD 卡错误)消息,你应该使用此SD 卡格式化指南重新格式化 SD 卡。
Paul
于03/12/18注册
1,005 声望
创作了3篇指南
8条评论
In SCN mode, I cannot change out of Handheld Night Scene. It is like it is stuck
mjh5x - 回复 分享
Canon seems to have changed the importance to quality that it used to distinguish it. I still have an Elph 300S that is about twelve years old and a T2i which i bought in Radio Shack and both are still working fine. I'm disappointed because i bought a 70D in second hand from a seller in a famous online store and it looked like new and working fine. But, suddenly it's impossible to turn it on. I tried everything recommended with no avail because I've seen a lot of people with the same problem and Canon seems to give no importance to it and don't care about it. That has made me change to another brand that I'm considering.
juan jusino - 回复 分享
Canon eos70d ISO & aperture increases automatically while changing shutter speed in manual mode. Please
Kajal Kanti Mukherjee - 回复 分享
I think the arrival of MILCs and success of Sony made them lose their calm and brain. These days Canon is not producing quality cameras anymore, even good lenses are becoming increasingly rare. Perhaps it’s time for Canon users to think seriously about other brands.
Quazi Sanjeed - 回复 分享
Problem with EOS70D: shutter stays open on first shot. It is not a lens issue as lenses have been swapped. Lens must be turned to disconnect contacts and then reconnected. The shutter completes the shot when the lens is electrically reconnected and then the camera goes back to regular shooting. A time lapse of approximately 1min will restart the error.
bedels - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 146
总计 10,616
