简介
The main motherboard controls all functions of the camera.
你所需要的
Hold the camera with the lens pointing down. Press the highlighted button with your finger to release the cover.
Pull cover over to expose the battery.
Pull Touchscreen out and rotate 90 degrees. Remove the four 3 mm Phillips #000 head screws that are now exposed at the hinge.
Remove the two 5 mm Phillips #000 head screws that near the viewfinder.
Use a spudger and pry apart the two plastic columns surrounding the screen hinge.
Rotate the screen forward 90 degrees and push it back into its housing against the camera.
Use spudger to lift edge of black heat tape.
Slowly peel back black heat tape.
12等其他人完成本指南。
3条评论
Great write up and illustrations. I'm in the process of repairing a 70D and this will be a great help.
Thank you and keep up the good work!
Hi, do you know if after replacing the main board it is necessary to configure the camera with some software ? (I heard of spt software)
Hi Tyler my Canon Camera eos 70D isn’t working anymore is it possible to replace the motherboard?
