跳转到主内容
Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement
Paul
Paul3 其他贡献者
最后更新于 January 3, 2025
15 - 25 分钟
中等
In this guide, you will learn how to replace the main board in the EF-S 18-135mm lens. The main board is crucial to the correct operation of the lens, passing focus commands from the camera to the lens.
你所需要的
工具
查看更多...
  1. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: 步骤 1 中的图像 1,3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: 步骤 1 中的图像 2,3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: 步骤 1 中的图像 3,3
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 2 中的图像 1,2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5.5mm JIS #000 screws for the lens mount ring (silver ring).
    • Remove the two 4mm JIS #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 3 中的图像 1,2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 3 中的图像 2,2
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 4 中的图像 1,2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 4 中的图像 2,2
    • This step involves handling sensitive electronics. Avoid static discharge.
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 5 中的图像 1,3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 5 中的图像 2,3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: 步骤 5 中的图像 3,3
    • Remove the two 4mm JIS #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
结论
另外一个人完成了本指南。
Paul
于03/12/18注册
873 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 41
总计 2,665
