跳转到主内容
iPhone 12 Loudspeaker Replacement
Adam O'Camb
Adam O'Camb4 其他贡献者
最后更新于 July 10, 2024
1 - 2 小时
中等
Use this guide to remove and replace the loudspeaker in an iPhone 12. The loudspeaker is the speaker at the bottom of an iPhone.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. iPhone 12 Loudspeaker Replacement, Remove the pentalobe screws: 步骤 1 中的图像 1,1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 12 Loudspeaker Replacement, Mark your opening picks: 步骤 2 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Mark your opening picks: 步骤 2 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Mark your opening picks: 步骤 2 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 12 Loudspeaker Replacement, Tape over any cracks: 步骤 3 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Tape over any cracks: 步骤 3 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Tape over any cracks: 步骤 3 中的图像 3,3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 12 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 4 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 4 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 12 Loudspeaker Replacement: 步骤 5 中的图像 1,3 iPhone 12 Loudspeaker Replacement: 步骤 5 中的图像 2,3 iPhone 12 Loudspeaker Replacement: 步骤 5 中的图像 3,3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 12 Loudspeaker Replacement: 步骤 6 中的图像 1,3 iPhone 12 Loudspeaker Replacement: 步骤 6 中的图像 2,3 iPhone 12 Loudspeaker Replacement: 步骤 6 中的图像 3,3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 12 Loudspeaker Replacement, Heat the bottom edge: 步骤 7 中的图像 1,1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 12 Loudspeaker Replacement, Apply a suction cup: 步骤 8 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Apply a suction cup: 步骤 8 中的图像 2,2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  9. iPhone 12 Loudspeaker Replacement, Lift the screen slightly: 步骤 9 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Lift the screen slightly: 步骤 9 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Lift the screen slightly: 步骤 9 中的图像 3,3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 12 Loudspeaker Replacement, Heat the right edge: 步骤 10 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Heat the right edge: 步骤 10 中的图像 2,2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 12 Loudspeaker Replacement, Separate the right adhesive: 步骤 11 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Separate the right adhesive: 步骤 11 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Separate the right adhesive: 步骤 11 中的图像 3,3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  12. iPhone 12 Loudspeaker Replacement, Heat the top edge: 步骤 12 中的图像 1,1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 12 Loudspeaker Replacement, Separate the top adhesive: 步骤 13 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Separate the top adhesive: 步骤 13 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Separate the top adhesive: 步骤 13 中的图像 3,3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  14. iPhone 12 Loudspeaker Replacement, Heat the left edge: 步骤 14 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Heat the left edge: 步骤 14 中的图像 2,2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 12 Loudspeaker Replacement, Screen information: 步骤 15 中的图像 1,1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  16. iPhone 12 Loudspeaker Replacement, Separate the left adhesive: 步骤 16 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Separate the left adhesive: 步骤 16 中的图像 2,2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  17. iPhone 12 Loudspeaker Replacement, Open the iPhone: 步骤 17 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Open the iPhone: 步骤 17 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Open the iPhone: 步骤 17 中的图像 3,3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  18. iPhone 12 Loudspeaker Replacement, Unscrew the battery and display connector cover: 步骤 18 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 12 Loudspeaker Replacement, Remove the battery and display connector cover: 步骤 19 中的图像 1,1
    • Remove the cover.
  20. iPhone 12 Loudspeaker Replacement, Disconnect the battery: 步骤 20 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Disconnect the battery: 步骤 20 中的图像 2,2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 12 Loudspeaker Replacement, Disconnect the display cable: 步骤 21 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Disconnect the display cable: 步骤 21 中的图像 2,2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 12 Loudspeaker Replacement, Disconnect the digitizer cable: 步骤 22 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Disconnect the digitizer cable: 步骤 22 中的图像 2,2
    • Use a spudger or a fingernail to disconnect the digitizer cable connector.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  23. iPhone 12 Loudspeaker Replacement, Unscrew the front sensor connector cover: 步骤 23 中的图像 1,1
    • Use a Y000 driver to remove four screws securing the front sensor connector cover.
    • Three 1.1 mm long screws
    • One 1.4 mm long screw
  24. iPhone 12 Loudspeaker Replacement, Remove the front sensor connector cover: 步骤 24 中的图像 1,3 iPhone 12 Loudspeaker Replacement, Remove the front sensor connector cover: 步骤 24 中的图像 2,3 iPhone 12 Loudspeaker Replacement, Remove the front sensor connector cover: 步骤 24 中的图像 3,3
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
  25. iPhone 12 Loudspeaker Replacement, Disconnect the front sensors: 步骤 25 中的图像 1,2 iPhone 12 Loudspeaker Replacement, Disconnect the front sensors: 步骤 25 中的图像 2,2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  26. iPhone 12 Loudspeaker Replacement, Remove the display assembly: 步骤 26 中的图像 1,1
  27. iPhone 12 Loudspeaker Replacement, Unscrew the loudspeaker: 步骤 27 中的图像 1,1
    • Use a Phillips driver to remove the four 1.6 mm screws securing the loudspeaker.
  28. iPhone 12 Loudspeaker Replacement, Remove the loudspeaker: 步骤 28 中的图像 1,1
    • Remove the loudspeaker.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Answers community for help.
9等其他人完成本指南。
Adam O'Camb
于04/11/15注册
209,006 声望
创作了416篇指南
一条评论
Every guide that I've seen has you remove the screen completely before replacing the speaker. This seems to be the hardest and riskiest part of the repair. The screen ribbon cables don't seem to obstruct access to the speaker. Is there a reason that you can't leave the ribbon cables alone and just prop the screen up at a right angle to the phone body and then replace the speaker? I can see the logic behind disconnecting the battery but what about the other cables?
Keith Silver - 回复
添加评论
浏览统计数据:
过去 24 小时: 35
过去 7 天: 181
过去 30 天: 723
总计 30,066
