跳转到主内容
加入维修社区 - 创建账户
Google Pixel 6a Battery Replacement
你所需要的
视频概述
  1. Google Pixel 6a Battery Replacement, Safety Precautions: 步骤 1 中的图像 1,2 Google Pixel 6a Battery Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    添加评论
  2. Google Pixel 6a Battery Replacement, Screen removal information: 步骤 2 中的图像 1,3 Google Pixel 6a Battery Replacement, Screen removal information: 步骤 2 中的图像 2,3 Google Pixel 6a Battery Replacement, Screen removal information: 步骤 2 中的图像 3,3
    • Before starting your repair, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    添加评论
  3. Google Pixel 6a Battery Replacement, Anti-Clamp instructions: 步骤 3 中的图像 1,3 Google Pixel 6a Battery Replacement, Anti-Clamp instructions: 步骤 3 中的图像 2,3 Google Pixel 6a Battery Replacement, Anti-Clamp instructions: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over the right edge of your phone.
    • Position the suction cups near the middle of the right edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    询问修复机器人
    添加评论
  4. Google Pixel 6a Battery Replacement: 步骤 4 中的图像 1,3 Google Pixel 6a Battery Replacement: 步骤 4 中的图像 2,3 Google Pixel 6a Battery Replacement: 步骤 4 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    询问修复机器人
    添加评论
  5. Google Pixel 6a Battery Replacement: 步骤 5 中的图像 1,2 Google Pixel 6a Battery Replacement: 步骤 5 中的图像 2,2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp so it lays on the right edge of the phone.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    询问修复机器人
    添加评论
  6. Google Pixel 6a Battery Replacement, Heat the right edge: 步骤 6 中的图像 1,1
    • Heat an iOpener and apply it to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    添加评论
  7. Google Pixel 6a Battery Replacement, Insert an opening pick: 步骤 7 中的图像 1,3 Google Pixel 6a Battery Replacement, Insert an opening pick: 步骤 7 中的图像 2,3 Google Pixel 6a Battery Replacement, Insert an opening pick: 步骤 7 中的图像 3,3
    • Apply a suction cup to the screen, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the bezel and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    添加评论
  8. Google Pixel 6a Battery Replacement, Reposition the opening pick: 步骤 8 中的图像 1,3 Google Pixel 6a Battery Replacement, Reposition the opening pick: 步骤 8 中的图像 2,3 Google Pixel 6a Battery Replacement, Reposition the opening pick: 步骤 8 中的图像 3,3
    • While still applying suction, pivot the pick upwards to a steep angle.
    • Carefully push the pick in while prying to reposition the opening pick into the bezel seam.
    • Only insert the pick up to 3.5 mm to avoid damaging the internals.
    添加评论
  9. Google Pixel 6a Battery Replacement, Release the right clips: 步骤 9 中的图像 1,3 Google Pixel 6a Battery Replacement, Release the right clips: 步骤 9 中的图像 2,3 Google Pixel 6a Battery Replacement, Release the right clips: 步骤 9 中的图像 3,3
    • Slide the pick along the right edge to release the plastic clips securing the bezel to the frame.
    • Position the pick at the top-right edge before moving to the next step.
    添加评论
  10. Google Pixel 6a Battery Replacement, Release the top right clips: 步骤 10 中的图像 1,3 Google Pixel 6a Battery Replacement, Release the top right clips: 步骤 10 中的图像 2,3 Google Pixel 6a Battery Replacement, Release the top right clips: 步骤 10 中的图像 3,3
    • Rotate the opening pick around the top-right corner of the phone to release the clips.
    • Leave the opening pick in the top-right corner to prevent the clips from re-locking.
    • Only insert the pick up to 4 mm to avoid damaging the internals.
    询问修复机器人
    添加评论
  11. Google Pixel 6a Battery Replacement, Release the top clips: 步骤 11 中的图像 1,3 Google Pixel 6a Battery Replacement, Release the top clips: 步骤 11 中的图像 2,3 Google Pixel 6a Battery Replacement, Release the top clips: 步骤 11 中的图像 3,3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the top edge to release the clips.
    • When slicing around the front camera, only insert the pick up to 3 mm to avoid damaging the lens.
    询问修复机器人
    添加评论
  12. Google Pixel 6a Battery Replacement, Release the top left clips: 步骤 12 中的图像 1,3 Google Pixel 6a Battery Replacement, Release the top left clips: 步骤 12 中的图像 2,3 Google Pixel 6a Battery Replacement, Release the top left clips: 步骤 12 中的图像 3,3
    • Rotate the opening pick around the top-left corner of the phone to release the clips.
    • Leave the opening pick in the top-left corner to prevent the clips from re-locking.
    添加评论
  13. Google Pixel 6a Battery Replacement, Release the left clips: 步骤 13 中的图像 1,3 Google Pixel 6a Battery Replacement, Release the left clips: 步骤 13 中的图像 2,3 Google Pixel 6a Battery Replacement, Release the left clips: 步骤 13 中的图像 3,3
    • Slide the pick along the left edge to release the clips.
    • Only insert the pick up to 3 mm to avoid damaging the internals.
    • Repeat the rotating and sliding procedure for the remaining edge.
    • At this point, the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to release any remaining clips.
    添加评论
  14. Google Pixel 6a Battery Replacement, Reposition the screen: 步骤 14 中的图像 1,3 Google Pixel 6a Battery Replacement, Reposition the screen: 步骤 14 中的图像 2,3 Google Pixel 6a Battery Replacement, Reposition the screen: 步骤 14 中的图像 3,3
    • Don't try to remove the screen all the way yet. It's still connected to the frame by a flex cable.
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    添加评论
  15. Google Pixel 6a Battery Replacement, Remove the display cable bracket: 步骤 15 中的图像 1,3 Google Pixel 6a Battery Replacement, Remove the display cable bracket: 步骤 15 中的图像 2,3 Google Pixel 6a Battery Replacement, Remove the display cable bracket: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    • The display cable bracket is secured with metal clips.
    • Use tweezers to bend the bottom side of the bracket upwards, releasing the metal clip.
    • Remove the display cable bracket.
    • During reassembly, insert the top side of the bracket first before pressing down the other side. Failure to do so could result in sparks and logic board damage.
    添加评论
  16. Google Pixel 6a Battery Replacement, Disconnect the display cable: 步骤 16 中的图像 1,3 Google Pixel 6a Battery Replacement, Disconnect the display cable: 步骤 16 中的图像 2,3 Google Pixel 6a Battery Replacement, Disconnect the display cable: 步骤 16 中的图像 3,3
    • Be very careful performing this step, as you risk damaging tiny components around the press connector.
    • Insert the tip of an opening pick under the bottom right edge of the display cable press connector, right above the nearby screw hole.
    • Pry up and disconnect the display cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    添加评论
  17. Google Pixel 6a Battery Replacement, Screen information: 步骤 17 中的图像 1,1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    询问修复机器人
    添加评论
  18. Google Pixel 6a Battery Replacement, Reassembly information: 步骤 18 中的图像 1,2 Google Pixel 6a Battery Replacement, Reassembly information: 步骤 18 中的图像 2,2
    • Remove the screen.
    • During reassembly:
    • If you replaced your screen, check the front-facing camera hole and the sensor cutout on your replacement screen, and remove any remaining liners.
    • Check your phone if the proximity sensor's rubber gasket is missing—it might be stuck to the back of your old screen. Replace it if necessary.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone.
    • Remember to reinstall the display cable bracket.
    • Follow this guide to replace the screen adhesive.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    添加评论
  19. Google Pixel 6a Battery Replacement, Remove the silver tape: 步骤 19 中的图像 1,2 Google Pixel 6a Battery Replacement, Remove the silver tape: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to peel back the silver tape connecting the midframe and the top speaker.
    • Don't completely remove the tape. You only need to remove the bridge between the midframe and the top speaker.
    询问修复机器人
    添加评论
  20. Google Pixel 6a Battery Replacement: 步骤 20 中的图像 1,3 Google Pixel 6a Battery Replacement: 步骤 20 中的图像 2,3 Google Pixel 6a Battery Replacement: 步骤 20 中的图像 3,3
    • Use tweezers to peel back the tape covering the two screws on both sides of the USB-C port.
    询问修复机器人
    添加评论
  21. Google Pixel 6a Battery Replacement, Unfasten the midframe: 步骤 21 中的图像 1,2 Google Pixel 6a Battery Replacement, Unfasten the midframe: 步骤 21 中的图像 2,2
    • Use a T3 Torx screwdriver to remove the 16 screws securing the midframe to the frame:
    • Eight 4.3 mm screws
    • Five 2.9 mm screws
    • Two 4.9 mm screws
    • One 4.6 mm screw
    添加评论
  22. Google Pixel 6a Battery Replacement, Release the midframe clips: 步骤 22 中的图像 1,2 Google Pixel 6a Battery Replacement, Release the midframe clips: 步骤 22 中的图像 2,2
    • Insert a spudger between the top of the midframe and the frame, near the front camera.
    • Pry up with the spudger to release the top of the midframe from its clips.
    询问修复机器人
    添加评论
  23. Google Pixel 6a Battery Replacement: 步骤 23 中的图像 1,2 Google Pixel 6a Battery Replacement: 步骤 23 中的图像 2,2
    • Insert a spudger between the bottom left of the midframe and the frame.
    • Pry up with the spudger to release the bottom of the midframe from its clips.
    询问修复机器人
    添加评论
  24. Google Pixel 6a Battery Replacement, Remove the midframe: 步骤 24 中的图像 1,2 Google Pixel 6a Battery Replacement, Remove the midframe: 步骤 24 中的图像 2,2
    • Remove the midframe.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    添加评论
  25. Google Pixel 6a Battery Replacement, Remove the thermal paste: 步骤 25 中的图像 1,3 Google Pixel 6a Battery Replacement, Remove the thermal paste: 步骤 25 中的图像 2,3 Google Pixel 6a Battery Replacement, Remove the thermal paste: 步骤 25 中的图像 3,3
    • Use the flat end of a spudger to scrape off the thermal paste.
    • Clean any remaining thermal paste with isopropyl alcohol and either a coffee filter or a lint-free cloth.
    • Repeat the cleaning process for the thermal paste on the midframe.
    • During reassembly, follow this guide for reapplying thermal paste to your device.
    询问修复机器人
    添加评论
  26. Google Pixel 6a Battery Replacement, Disconnect the battery: 步骤 26 中的图像 1,2 Google Pixel 6a Battery Replacement, Disconnect the battery: 步骤 26 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery's press connector.
    询问修复机器人
    添加评论
  27. Google Pixel 6a Battery Replacement, Unfasten the 5G mmWave antenna bracket: 步骤 27 中的图像 1,2 Google Pixel 6a Battery Replacement, Unfasten the 5G mmWave antenna bracket: 步骤 27 中的图像 2,2
    • If your device doesn't have a 5G mmWave antenna, skip the next four steps.
    • Use a T3 Torx screwdriver to remove the 2.9 mm screw securing the 5G mmWave antenna bracket.
    添加评论
  28. Google Pixel 6a Battery Replacement, Remove the 5G mmWave antenna bracket: 步骤 28 中的图像 1,3 Google Pixel 6a Battery Replacement, Remove the 5G mmWave antenna bracket: 步骤 28 中的图像 2,3 Google Pixel 6a Battery Replacement, Remove the 5G mmWave antenna bracket: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to pull the bracket towards the right edge of the phone and disconnect its clip.
    • Remove the 5G mmWave antenna bracket.
    询问修复机器人
    添加评论
  29. Google Pixel 6a Battery Replacement, Disconnect the 5G mmWave antenna: 步骤 29 中的图像 1,2 Google Pixel 6a Battery Replacement, Disconnect the 5G mmWave antenna: 步骤 29 中的图像 2,2
    • Use a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
    询问修复机器人
    添加评论
  30. Google Pixel 6a Battery Replacement: 步骤 30 中的图像 1,2 Google Pixel 6a Battery Replacement: 步骤 30 中的图像 2,2
    • Use tweezers, or your fingers, to remove the 5G mmWave antenna.
    询问修复机器人
    添加评论
  31. Google Pixel 6a Battery Replacement, Remove the battery spacer: 步骤 31 中的图像 1,3 Google Pixel 6a Battery Replacement, Remove the battery spacer: 步骤 31 中的图像 2,3 Google Pixel 6a Battery Replacement, Remove the battery spacer: 步骤 31 中的图像 3,3
    在这个步骤中使用的工具:
    • If your device doesn't have a battery spacer, skip the next three steps.
    • Insert an opening pick between the plastic battery spacer and the battery.
    • Slide the pick forward while prying to separate enough of the spacer to grip it with tweezers.
    询问修复机器人
    添加评论
  32. Google Pixel 6a Battery Replacement: 步骤 32 中的图像 1,2 Google Pixel 6a Battery Replacement: 步骤 32 中的图像 2,2
    • Use tweezers, or your fingers, to peel the battery spacer away from the device.
    询问修复机器人
    添加评论
  33. Google Pixel 6a Battery Replacement: 步骤 33 中的图像 1,2 Google Pixel 6a Battery Replacement: 步骤 33 中的图像 2,2
    • Remove the battery spacer.
    • If your replacement battery didn't come with this spacer, transfer it to your replacement part.
    询问修复机器人
    添加评论
  34. Google Pixel 6a Battery Replacement, Separate the battery pull tabs: 步骤 34 中的图像 1,3 Google Pixel 6a Battery Replacement, Separate the battery pull tabs: 步骤 34 中的图像 2,3 Google Pixel 6a Battery Replacement, Separate the battery pull tabs: 步骤 34 中的图像 3,3
    • Use tweezers, or your fingers, to peel the plastic pull tabs away from the battery.
    询问修复机器人
    添加评论
  35. Google Pixel 6a Battery Replacement, Heat the battery's adhesive: 步骤 35 中的图像 1,1
    • Heat an iOpener and apply it to the back of the device for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the battery is susceptible to heat damage.
    询问修复机器人
    添加评论
  36. Google Pixel 6a Battery Replacement, Separate the battery's adhesive: 步骤 36 中的图像 1,3 Google Pixel 6a Battery Replacement, Separate the battery's adhesive: 步骤 36 中的图像 2,3 Google Pixel 6a Battery Replacement, Separate the battery's adhesive: 步骤 36 中的图像 3,3
    • Pull the tabs back and forth in a sawing motion down the length of the battery to separate the adhesive underneath.
    • Work slowly. It's easy to lose your grip and accidentally pull the tab up from under the battery.
    • If you're having difficulty separating the adhesive, apply more heat and wait for the adhesive to loosen.
    添加评论
  37. Google Pixel 6a Battery Replacement, Remove the battery: 步骤 37 中的图像 1,3 Google Pixel 6a Battery Replacement, Remove the battery: 步骤 37 中的图像 2,3 Google Pixel 6a Battery Replacement, Remove the battery: 步骤 37 中的图像 3,3
    • Tilt the battery out of the device to separate the rest of the adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, place the battery pull tab back into position and temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated and fold the pull tabs back into place.
    添加评论
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. For instructions on how to replace the display adhesive, click here.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
For optimal performance, calibrate your newly installed battery after completing this guide.
取消:我没有完成这个指南。
122等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
244,748 声望
创作了1,203篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,226篇指南
42指南评论
Great instructions- all done and successful!
Many thanks
Dan Wilkinson - 回复 分享
The placement of the battery adhesives and display adhesives during reassembly is not clear. The battery adhesive (IF356-344-1) seems to contain other parts that do not appear in the disassembly
Dan Flynn - 回复 分享
Just finished this myself. Not sure why the battery adhesive package seemed to come with extra spacer pieces that didn't appear during the teardown.
Almost forgot to reapply thermal paste before putting the midframe back in, oops.
Joe Wileman - 回复 分享
Great instructions, I fixed it, thanks! One comment, instead of following the generic pre-cut adhesive instructions in step 36, use the Pixel 6a specific adhesive guide in step 17.
Craig - 回复 分享
This was great, ultimately, I was successful. I think it would be good to outright state the best times to remove the original adhesive on the screen and battery during disassembly. Probably step 18. I skipped over it entirely when trying to reassemble my first time, and wound up needing to throw out one adhesive kit. It's a good thing I had an extra since I was replacing both screen and battery.
Sean Rice - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 192
过去 7 天: 1,327
过去 30 天: 5,910
总计 218,280
