跳转到主内容
How to Replace the Adhesive for Your Google Pixel 6a
你所需要的
  1. How to Replace the Adhesive for Your Google Pixel 6a, Clean the frame: 步骤 1 中的图像 1,3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the frame: 步骤 1 中的图像 2,3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the frame: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Any residual adhesive or debris on the frame will prevent your screen from sealing properly.
    • Use the flat end of your spudger to scrape off as much adhesive from the frame as you can.
    • Use tweezers or your fingers to peel and remove any remaining adhesive.
    • Clean the perimeter of the frame with a small amount of highly-concentrated isopropyl alcohol (over 90%) and a lint-free or microfiber cloth.
  2. How to Replace the Adhesive for Your Google Pixel 6a, Clean the screen: 步骤 2 中的图像 1,3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the screen: 步骤 2 中的图像 2,3 How to Replace the Adhesive for Your Google Pixel 6a, Clean the screen: 步骤 2 中的图像 3,3
    • If you're reusing your screen, clean it as you did for the frame.
  3. How to Replace the Adhesive for Your Google Pixel 6a, Orient the adhesive: 步骤 3 中的图像 1,2 How to Replace the Adhesive for Your Google Pixel 6a, Orient the adhesive: 步骤 3 中的图像 2,2
    • Before removing any liners, position the adhesive with the clear liner facing down over the frame to find the proper orientation.
    • Use features such as the upper loudspeaker cutout and conductive tape to orient the adhesive.
  4. How to Replace the Adhesive for Your Google Pixel 6a, Remove the adhesive liner: 步骤 4 中的图像 1,1
    • Peel the clear liner off of the adhesive.
  5. How to Replace the Adhesive for Your Google Pixel 6a, Apply the adhesive: 步骤 5 中的图像 1,3 How to Replace the Adhesive for Your Google Pixel 6a, Apply the adhesive: 步骤 5 中的图像 2,3 How to Replace the Adhesive for Your Google Pixel 6a, Apply the adhesive: 步骤 5 中的图像 3,3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lay the adhesive onto the frame, starting with the bottom or top edge. Make small corrections as you go.
  6. How to Replace the Adhesive for Your Google Pixel 6a: 步骤 6 中的图像 1,2 How to Replace the Adhesive for Your Google Pixel 6a: 步骤 6 中的图像 2,2
    • Use a spudger or your fingers to press along the perimeter of the adhesive and adhere it to the frame.
  7. How to Replace the Adhesive for Your Google Pixel 6a, Remove the liners: 步骤 7 中的图像 1,3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the liners: 步骤 7 中的图像 2,3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the liners: 步骤 7 中的图像 3,3
    • Grab the pull tab on the upper right of the frame and peel off the main liner.
  8. How to Replace the Adhesive for Your Google Pixel 6a, Check for small liners: 步骤 8 中的图像 1,1
    • Check the front-facing camera hole on the replacement screen and remove any remaining protective liners in it.
    • Check the sensor cutout on the replacement screen and remove any remaining protector liners in it.
  9. How to Replace the Adhesive for Your Google Pixel 6a, Continue reassembly: 步骤 9 中的图像 1,1
    • Return to your phone's guide and continue reassembly.
    • Remember to reinstall the display cable bracket.
    • Finish this guide when your screen is installed and you're ready to seal the phone up.
  10. How to Replace the Adhesive for Your Google Pixel 6a, Remove the final liner: 步骤 10 中的图像 1,3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the final liner: 步骤 10 中的图像 2,3 How to Replace the Adhesive for Your Google Pixel 6a, Remove the final liner: 步骤 10 中的图像 3,3
    • Grab the pull tab on the bottom edge of the frame and peel off the remaining liner.
  11. How to Replace the Adhesive for Your Google Pixel 6a, Install the screen: 步骤 11 中的图像 1,2 How to Replace the Adhesive for Your Google Pixel 6a, Install the screen: 步骤 11 中的图像 2,2
    • Flip the screen over and lay it onto the frame.
    • Press along the perimeter of the screen to secure it.
终点
144等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,871 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,738篇指南
23指南评论
Yup. That worked, Don't rush it, and get a proper suction cup, but i have a perfectly repaired 6a, very happy, and thank you
Eoin Fleming - 回复
Great advice, but there must be something I'm missing. Now my phone can't show the screen
icanwecanyoucan - 回复
When this happened to me, I went back and put the display cable in again. It wasn't done properly. I'm sure you got it fixed by now, but you should not forget the metal bracket too.
YuropeCat -
Will this provide the same water resistance as the original screen?
Noam Etten - 回复
Depends on how well you seat the adhesive, but generally speaking, it's very hard to get to the same level of water resistance. It will probably be somewhat resistant.
Water resistance should be treated as an additional protection, not as a feature. Do not submerge your electronic device in water by purpose. (even if it's factory new)
Gabriele Turelli (CappyT) -
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 159
过去 30 天: 945
总计 40,226
