跳转到主内容
加入维修社区 - 创建账户
2021 年发布的 Dell Inspiron 16-7610 笔记本电脑的维修信息。它也被称为 Inspiron 16 Plus 7610。
Possible to replace integrated webcam?
I suddenly started having issues with my internal webcam. All of a sudden it started being really blurry. I've tried cleaning the lens, but it does not work. I'm thinking perhaps a seal cracked and now moisture has gotten in there. Is it possible to replace just the internal webcam? Or do I need to replace entire screen to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@zak18311 you did not give us your laptops model number but selected the Dell Inspiron 16-7610. You can download teh service manual for that computer from here Looks like that model has the camera integrated into the display assembly (the bezel around it actually). the camera is available as a spare part here for example. So that means you could try and use some heat to soften the glue that the screen into the assembly. Probably not an easy task and might be risking breaking the display, but nothing wrong with trying.
这个答案有帮助吗?
得分 1
1条评论:
Dell probably uses snaps on these, that's the best case though. If not, it's clips and (hopefully) weak adhesive.
由完成的 分享
添加一条评论
添加你的答案
Zak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 900
