跳转到主内容
制冰机出现故障通常有几个原因。如果你的制冰机无法制冰、只能碎冰、无法出冰,或者无法停止制冰,请先查看对应的指南。在重置冰箱电源后,如果 24 小时内仍没有制冰,你可能需要重置制冰机本身。
使用重置按钮
在制冰机下方放置抹布和冰桶,以防止测试过程中积水。
  • 将制冰机电源开关关闭 5 秒钟,然后重新打开。
  • 按压并保持重置按钮 5 秒钟。
  • 将感应臂上下拨动几次。
此时设备应进入测试模式,并将运行手动制冰循环。观察感应臂移动,以及冰盘倾倒或弹出冰块的情况。随后会开始注水循环。你的制冰机现已重置。
相关页面
故障排除:Frigidaire 制冰机无法工作
讨论:制冰机停止制冰且水流缓慢
如何:维护冰箱
Bill Gilbert
于06/30/22注册
41,043 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
119 名成员
创作了72,955篇指南
11条评论
It seems that my feeler arm is stuck in the up position
Ian - 回复 分享
I just replaced the ice tray assembly. It worked making ice and dumping into the bin for two days then stopped. There are ice cubes in the tray but it doesn't dump them into the bin. Anyone have this proble? Anyone know a fix?
Dan Reidmiller - 回复 分享
Did you ever figure out a solution? I’m having the same issue. I think it is a bad motor
Jon Stilwell - 回复 分享
Also having this issue presently. It doesn't dump. Just continually refills. But there is uce in it it doesn't rotate to dump. But does sometimes dump
Casey Allan - 回复 分享
Oh, Frigidaire FFHB2740PPBA
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 157
过去 30 天: 677
总计 56,071
