你所需要的
工具
视频概述
好吧,我们已经拿到了苹果的最新圣诞长袜填塞礼品,它正在在我们的拆解桌上。是时候看看它的构造了。目前已知的信息:
每只 AirPod 重 0.14 盎司(4 克),充电盒重量为 1.34 盎司(38 克)
每只 AirPod 的大小为 16.5 mm × 18.0 mm × 40.5 mm,而充电盒的大小为 44.3 mm × 21.3 mm × 53.5 mm
利用蓝牙技术和苹果的 W1 芯片进行无线连接
使用麦克风、光学传感器和一个运动加速计来进行入耳检测
采用波束成形技术的麦克风加上一个额外的加速计来过滤外界噪音
AirPods 单次充满电可以使用 5 个小时,而配合充电盒使用则可以超过 24 小时
看看这里都有些什么元器件:
苹果 343500130(应该就是 W1 无线通讯芯片)
赛普拉斯 CY8C4146FN 可编程 SoC。
Maxim MAX98730EWJ 低功耗立体声音频编解码器
德州仪器 TPS62743 300 mA DC-DC 降压转换器
Bosch Sensortec BMA282 加速度传感器
STMicroelectronics 加速度计/陀螺仪
大概率为某种串行闪存
在付出大量的血汗,和见证一堆的胶水之后,我们呈现给你:
耳机拆解全家福。
充电盒拆解全家福。
这个拆解当中,每一个超棒的 X 光图像均由我们在 Creative Electron 机智的朋友提供。你好,伙计们!
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
99指南评论
do the airpods feature the same driver as the earpods?
Jason Wilson - 回复 分享
Great question, trying to find this out myself.
SJDragonetti - 回复 分享
It looks like it's a bit different. The EarPod teardown has a pretty nice comparison of the generations of earbuds from Apple in step 11. They look like they mostly have open-back designs while the new AirPods have a black plastic (and mesh?) that covers the back of the driver. Apple EarPods 拆解
I would be interested in seeing these compared to the new PowerBeats 3 since that headphone model also uses a membrane-style speaker in the midsection bulge of the stem.
Josiah Knoll - 回复 分享
It wouldn't really matter. The EarPods had a lot of tuning done to them through the ports on the front, back, and stems (cover with tape and see what happens). The AirPods have ports moved as well as less air in the housings (replaced with logic boards, batteries, and other electronics. So even if they do use the same drivers, they'll sound substantially different.
