简介
使用本指南更换iPhone SE 2022的破裂或损坏的屏幕。
本指南使用的是A2783(国际通用型)型号。
屏幕组件已经包含了前置摄像头,听筒扬声器和EMI防护罩,从而使维修更加容易。
为了保留Touch ID的功能,请将原来的Home键/Touch ID传感器转移到新屏幕上。Home键是与主板在出场时配对的,所以如果更换成别的Home键,则会造成这个功能失灵。
注意: 原彩显示和自动亮度调节功能在更换屏幕后将被禁用,即使你更换的是原装 Apple 屏幕也是如此。
如果在重新组装时不更换胶条,你的设备将正常运行,但很可能会失去防水保护。
在重新组装设备时,需要更换粘合剂来重新连接组件。
你所需要的
从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
将重叠的透明包装胶带条黏在 iPhone 的后玻璃上,直到覆盖整个手机后部。
如果在接下来的几个步骤中无法让吸盘粘在手机上,请将强力胶带(折叠到把手中,然后用它提起后玻璃。
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
加热 iOpener并将其穿过反向钳。
折叠 iOpener,使其位于 iPhone 的底部边缘。
等待一分钟,让粘合剂有机会释放并出现开口间隙。
将撬片插入间隙中。
跳过接下来的三个步骤。
It took a few tries to get this done -- with a broken screen the packing tape interferes with the suction cup hold. I eventually had to resort to a classic iSclack. Bear in mind that you don't need much of an initial opening, just enough to get a pick in. After a couple of minutes of the pick sitting there the surrounding adhesive will stretch and you'll be able to get two in for Step 9.
Neal Sofge - 回复
在这个步骤中使用的工具:Magnetic Project Mat$19.95
卸下固定下部屏幕排线挡板的四颗十字螺丝:
两个 1.2 毫米长的螺丝
两个 2.8 毫米长的螺丝
使用镊子将 Home键组件从屏幕的正面提起,从而将其卸下。
Do you know where I can get a replacement part
Sorry if this is a dumb question, but is there a guide to actually installing the part once these steps are all completed? I get the idea of going backwards, but it seems like there are places that adhesive must be applied, and perhaps some tips on how to do that correctly (or incorrectly! :D ) that might warrant spelling it our for us old folks.
I’ve got a SE3 here and got the part from Apple self repair! How ever that does not configure
请在重新密封手机前将手机开机并测试你的维修是否成功。
若要重新组装你的设备,请按倒序执行这些说明。
固定新屏幕的最好方法是在框架上贴一张定制的双面胶,然后将屏幕放回原来的位置。
请将你的电子垃圾送到R2或e- steward认证的回收商。
19等其他人完成本指南。
由衷感谢以下译者:
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
6条评论
HOLA
Cambié la pantalla del iphone se 2022 , pero no me funciona la nueva pantalla. al volver a poner la original que solo estaba quebrada pero funcionaba, ahora ya no funciona.
no funciona. al parecer es otra pantalla. no da imagen
la pantalla 2020 no me funciono tampoco en un se 2022.
i real need my phone fix for school im only 12
^ I second that, if I'm going to guy it, I would like to know what all the steps are spelled out.
