跳转到主内容
iPhone SE 2022 屏幕替换
你所需要的
  1. iPhone SE 2022 屏幕替换, 移除五角螺丝: 步骤 1 中的图像 1,2 iPhone SE 2022 屏幕替换, 移除五角螺丝: 步骤 1 中的图像 2,2
    • 在取下螺丝前请先将你的手机关机。
    • 取下手机底部的两颗3.4 毫米长的五角螺丝。
  2. iPhone SE 2022 屏幕替换, 标记你的三角撬片: 步骤 2 中的图像 1,3 iPhone SE 2022 屏幕替换, 标记你的三角撬片: 步骤 2 中的图像 2,3 iPhone SE 2022 屏幕替换, 标记你的三角撬片: 步骤 2 中的图像 3,3
    • 如果插入太深,三角撬片可能会损坏你的设备。 按照此步骤标记撬片并防止损坏。
    • 从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
    • 你还可以用不同的尺寸标记三撬片的其他角。
    • 或者,将 将一枚硬币 粘在距撬片尖端 3 毫米处。
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - 回复
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - 回复
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - 回复
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - 回复
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - 回复
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - 回复
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - 回复
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - 回复
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - 回复
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - 回复
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - 回复
  3. iPhone SE 2022 屏幕替换, 用胶带覆盖破损: 步骤 3 中的图像 1,3 iPhone SE 2022 屏幕替换, 用胶带覆盖破损: 步骤 3 中的图像 2,3 iPhone SE 2022 屏幕替换, 用胶带覆盖破损: 步骤 3 中的图像 3,3
    • 如果 iPhone 的后玻璃破裂,请在维修过程中通过在玻璃上贴胶带来防止进一步破损并防止人身伤害。
    • 将重叠的透明包装胶带条黏在 iPhone 的后玻璃上,直到覆盖整个手机后部。
    • 戴上安全眼镜以保护你的眼睛免受修理过程松散玻璃的伤害。
    • 如果在接下来的几个步骤中无法让吸盘粘在手机上,请将强力胶带(折叠到把手中,然后用它提起后玻璃。
    • 如果所有措施都不可行,你可以用502胶把吸盘粘到后玻璃上。
  4. iPhone SE 2022 屏幕替换, 反向钳使用指南: 步骤 4 中的图像 1,3 iPhone SE 2022 屏幕替换, 反向钳使用指南: 步骤 4 中的图像 2,3 iPhone SE 2022 屏幕替换, 反向钳使用指南: 步骤 4 中的图像 3,3
    • 接下来的两个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 将蓝色手柄拉向铰链以解锁反向钳的手臂。
    • 将反向钳手臂滑过 iPhone 的左边缘或右边缘。
    • 将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
    • 向下推吸盘以将吸力施加到所需区域。
    • 如果发现设备表面太光滑而反向钳无法吸住,请使用包装胶带来创造一个更容易抓握的表面。
  5. iPhone SE 2022 屏幕替换: 步骤 5 中的图像 1,3 iPhone SE 2022 屏幕替换: 步骤 5 中的图像 2,3 iPhone SE 2022 屏幕替换: 步骤 5 中的图像 3,3
    • 向前拉蓝色手柄以锁定手臂。
    • 顺时针转动手柄 360 度或直到吸盘开始拉伸。
    • 确保吸盘彼此对齐。 如果在拉伸过程中吸盘慢慢不对齐,请松开吸盘并重新对齐手臂。
  6. iPhone SE 2022 屏幕替换: 步骤 6 中的图像 1,3 iPhone SE 2022 屏幕替换: 步骤 6 中的图像 2,3 iPhone SE 2022 屏幕替换: 步骤 6 中的图像 3,3
    • 加热 iOpener并将其穿过反向钳。
    • 你还可以使用吹风机热风枪或电热板,但过热可能会损坏显示屏和/或内部电池,因此请小心操作。
    • 折叠 iOpener,使其位于 iPhone 的底部边缘。
    • 等待一分钟,让粘合剂有机会释放并出现开口间隙。
    • 将撬片插入间隙中。
    • 如果反向钳无法形成足够的间隙,请对该区域施加更多热量并将手柄旋转四分之一圈。
    • 一次不要转动超过四分之一圈,并在转动之间等待一分钟。 把工作交给反向钳和时间来完成。
    • 跳过接下来的三个步骤。
    It took a few tries to get this done -- with a broken screen the packing tape interferes with the suction cup hold. I eventually had to resort to a classic iSclack. Bear in mind that you don't need much of an initial opening, just enough to get a pick in. After a couple of minutes of the pick sitting there the surrounding adhesive will stretch and you'll be able to get two in for Step 9.
    Neal Sofge - 回复
  7. iPhone SE 2022 屏幕替换, 加热屏幕胶水: 步骤 7 中的图像 1,1
    • 如果你使用的是吸柄,请按照下面两个步骤松开后玻璃。
    • 准备一个 iOpener 并将其放置在屏幕上至少两分钟以软化下面的胶水。
    • 你也可以使用吹风机、热风枪或热板,但要注意不要使手机过热--屏幕和电池都很容易受热损坏。
  8. iPhone SE 2022 屏幕替换, 插入三角撬片: 步骤 8 中的图像 1,3 iPhone SE 2022 屏幕替换, 插入三角撬片: 步骤 8 中的图像 2,3 iPhone SE 2022 屏幕替换, 插入三角撬片: 步骤 8 中的图像 3,3
    • 将吸柄固定在前面板的下半部分,尽可能靠近 Home 键。
    • 用吸柄提起屏幕,在屏幕和手机框架之间形成一个小间隙。
    • 如果你在制造这个缝隙时遇到困难,请对屏幕的下半部分施加更多的热量。请遵循iOpener 的使用指南,避免过度加热。
    • 将撬片插入屏幕边框下产生的缝隙里。
  9. iPhone SE 2022 屏幕替换, 划开胶水: 步骤 9 中的图像 1,3 iPhone SE 2022 屏幕替换, 划开胶水: 步骤 9 中的图像 2,3 iPhone SE 2022 屏幕替换, 划开胶水: 步骤 9 中的图像 3,3
    • 将三角撬片划到手机右下角以切开屏幕胶水。
    • 在手机底部插入第二个三角撬片。
    • 将三角撬片划到左下角以切开胶水。
    • 将三角撬片留在原位,以防止胶水重新密封。
  10. iPhone SE 2022 屏幕替换, 划开胶水: 步骤 10 中的图像 1,3 iPhone SE 2022 屏幕替换, 划开胶水: 步骤 10 中的图像 2,3 iPhone SE 2022 屏幕替换, 划开胶水: 步骤 10 中的图像 3,3
    • 如果胶水变得难以切割,它很可能已经冷却下来。 使用你的 iOpener 两到三分钟重新加热。
    • 沿着手机的左边滑动左下三角撬片以切割胶水。
    • 请停在屏幕的左上角附近。
    • 此时请不要试图撬开屏幕的上部,因为屏幕是由塑料卡扣固定的,强行撬开可能造成其损坏。
  11. iPhone SE 2022 屏幕替换: 步骤 11 中的图像 1,3 iPhone SE 2022 屏幕替换: 步骤 11 中的图像 2,3 iPhone SE 2022 屏幕替换: 步骤 11 中的图像 3,3
    • 沿着手机的右边缘滑动右下三角撬片以切割粘合剂。
    • 请勿将撬片插入超过 3 毫米,否则可能会损坏内部元件。
    • 停在屏幕的右上角附近。
  12. iPhone SE 2022 屏幕替换, 提起屏幕: 步骤 12 中的图像 1,2 iPhone SE 2022 屏幕替换, 提起屏幕: 步骤 12 中的图像 2,2
    • 移除三角撬片。
    • 轻轻拉起吸柄,以提起屏幕的底部
    • 请不要把显示器抬高超过15º,否则你很可能会损坏连接显示器的排线。
    • 移除吸柄。
  13. iPhone SE 2022 屏幕替换, 划开剩下的胶水: 步骤 13 中的图像 1,3 iPhone SE 2022 屏幕替换, 划开剩下的胶水: 步骤 13 中的图像 2,3 iPhone SE 2022 屏幕替换, 划开剩下的胶水: 步骤 13 中的图像 3,3
    • 在显示屏左上角下方插入三角撬片。
    • 沿着手机的左上角和顶部移动三角撬片以切割剩余的胶水。
  14. iPhone SE 2022 屏幕替换, 松开屏幕卡扣: 步骤 14 中的图像 1,2 iPhone SE 2022 屏幕替换, 松开屏幕卡扣: 步骤 14 中的图像 2,2
    • 沿着充电端口的方向稍稍向下滑动屏幕,使其与后壳的卡扣脱离。
  15. iPhone SE 2022 屏幕替换, 提起屏幕: 步骤 15 中的图像 1,3 iPhone SE 2022 屏幕替换, 提起屏幕: 步骤 15 中的图像 2,3 iPhone SE 2022 屏幕替换, 提起屏幕: 步骤 15 中的图像 3,3
    • 像翻书一样从左侧翻开手机屏幕以打开手机。
    • 此时不要尝试将显示器与手机组件完全分开。因为屏幕仍和主板由几条脆弱的排线连接着。
    • 在维修手机时,请将掀开的手机屏幕靠在另一个物体上以使其保持直立状态。
  16. iPhone SE 2022 屏幕替换, 拧开下部屏幕排线挡板螺丝: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • 卸下固定下部屏幕排线挡板的四颗十字螺丝:
    • 两个 1.2 毫米长的螺丝
    • 两个 2.8 毫米长的螺丝
    • 在整个过程中请确认每个螺丝的位置,以便在重新组装期间每个螺丝都回到原来的位置 。将螺钉安装在错误的位置会造成永久性损坏。
  17. iPhone SE 2022 屏幕替换, 移除底部屏幕排线挡板: 步骤 17 中的图像 1,2 iPhone SE 2022 屏幕替换, 移除底部屏幕排线挡板: 步骤 17 中的图像 2,2
    • 使用镊子来移除底部屏幕排线挡板
  18. iPhone SE 2022 屏幕替换, 断开电池连接: 步骤 18 中的图像 1,2 iPhone SE 2022 屏幕替换, 断开电池连接: 步骤 18 中的图像 2,2
    • 使用撬棒的尖端将接头从其插座上直接向上撬开,从而断开电池的连接。
  19. iPhone SE 2022 屏幕替换, 断开显示器和触屏感应器排线的连接: 步骤 19 中的图像 1,3 iPhone SE 2022 屏幕替换, 断开显示器和触屏感应器排线的连接: 步骤 19 中的图像 2,3 iPhone SE 2022 屏幕替换, 断开显示器和触屏感应器排线的连接: 步骤 19 中的图像 3,3
    • 显示器和触屏感应器的排线是相互叠放。 为了避免排线损坏,请先断开上部排线,切勿尝试同时断开两者。
    • 使用撬棒的尖端将接头从其插槽中向上撬起,从而断开底部的两条排线。
    • 要重新连接这种按压式的接口 ,请小心对齐并向下按压接口的一侧,直至其卡入到位,然后再重复另一侧。请不要按压接口的中间位置。如果接口未对准,针脚可能会弯曲,从而造成永久性损坏。
  20. iPhone SE 2022 屏幕替换, 拧开前传感器组件挡板的螺丝: 步骤 20 中的图像 1,1
    • 使用十字螺丝刀卸下固定前传感器组件挡板的三颗 1.2 毫米长的螺钉。
  21. iPhone SE 2022 屏幕替换, 卸下前传感器组件挡板: 步骤 21 中的图像 1,2 iPhone SE 2022 屏幕替换, 卸下前传感器组件挡板: 步骤 21 中的图像 2,2
    • 使用镊子小心地卸下前传感器组件挡板。
  22. iPhone SE 2022 屏幕替换, 断开前传感器组件排线: 步骤 22 中的图像 1,2 iPhone SE 2022 屏幕替换, 断开前传感器组件排线: 步骤 22 中的图像 2,2
    • 使用撬棒的尖端将接口从其插座中向上撬起,从而断开前传感器组件的连接。
  23. iPhone SE 2022 屏幕替换, 移除屏幕: 步骤 23 中的图像 1,2 iPhone SE 2022 屏幕替换, 移除屏幕: 步骤 23 中的图像 2,2
    • 移除屏幕。
  24. iPhone SE 2022 屏幕替换, 拧开Home键保护盖螺丝: 步骤 24 中的图像 1,1
    • 卸下固定Home键保护盖的4个螺丝
    • 三个1.2毫米长的Y000螺钉
    • 一个1.1毫米长的Y000螺钉
  25. iPhone SE 2022 屏幕替换, 移除Home键保护盖: 步骤 25 中的图像 1,2 iPhone SE 2022 屏幕替换, 移除Home键保护盖: 步骤 25 中的图像 2,2
    • 使用镊子小心的移除Home键保护盖
  26. iPhone SE 2022 屏幕替换, 断开Home键连接: 步骤 26 中的图像 1,3 iPhone SE 2022 屏幕替换, 断开Home键连接: 步骤 26 中的图像 2,3 iPhone SE 2022 屏幕替换, 断开Home键连接: 步骤 26 中的图像 3,3
    • 使用开机工具在 home键排线接口的左下方撬起,使其从插座上断开。
    • 如果接头向上翻转而没有分离,请用撬棒的扁平端向下压接头顶部的排线,同时撬起接口的左边。 小心不要损坏排线或接口,否则传感器将无法使用。
  27. iPhone SE 2022 屏幕替换, 加热Home键排线胶水: 步骤 27 中的图像 1,1
    • 准备一个iOpener ,放在Home键所在的屏幕上至少两分钟,以软化胶水,
    • 如果没有iOpener,也可以使用吹风机、热风枪或热板,但要注意不要使手机过热--屏幕和电池都很容易受热损坏。
  28. iPhone SE 2022 屏幕替换, 断开Home键排线的连接: 步骤 28 中的图像 1,3 iPhone SE 2022 屏幕替换, 断开Home键排线的连接: 步骤 28 中的图像 2,3 iPhone SE 2022 屏幕替换, 断开Home键排线的连接: 步骤 28 中的图像 3,3
    • 小心地将三角撬片放到 home键排线下方,并将其与屏幕的背面分开。
    • 在此过程中请避免损坏排线。 Home键的排线缆缠绕在接口周围,猛地断开连接可能会撕裂排线。请尝试将排线朝前置相机的方向向上折叠。
  29. iPhone SE 2022 屏幕替换, 移除Home键组件: 步骤 29 中的图像 1,3 iPhone SE 2022 屏幕替换, 移除Home键组件: 步骤 29 中的图像 2,3 iPhone SE 2022 屏幕替换, 移除Home键组件: 步骤 29 中的图像 3,3
    • 使用镊子将 Home键组件从屏幕的正面提起,从而将其卸下。
    • 要重新安装,首先将排线穿过屏幕前面的孔,如图所示。
    • 更换部件可能自带Home键的Y000 螺丝 。请 卸下不必要的螺钉,以便重新安装Home键保护盖。
    Do you know where I can get a replacement part
    GamErPlayer - 回复
    Sorry if this is a dumb question, but is there a guide to actually installing the part once these steps are all completed? I get the idea of going backwards, but it seems like there are places that adhesive must be applied, and perhaps some tips on how to do that correctly (or incorrectly! :D ) that might warrant spelling it our for us old folks.
    Jim - 回复
    I’ve got a SE3 here and got the part from Apple self repair! How ever that does not configure
    Kurnaz Tilki - 回复
结论
请在重新密封手机前将手机开机并测试你的维修是否成功。
若要重新组装你的设备,请按倒序执行这些说明。
固定新屏幕的最好方法是在框架上贴一张定制的双面胶,然后将屏幕放回原来的位置。
请将你的电子垃圾送到R2或e- steward认证的回收商
修理遇到困难? 试试 故障排除, 或者访问我们的A论坛 寻求帮助。
19等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Dominik Schnabelrauch
于11/23/16注册
228,969 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,410篇指南
6条评论
HOLA
Cambié la pantalla del iphone se 2022 , pero no me funciona la nueva pantalla. al volver a poner la original que solo estaba quebrada pero funcionaba, ahora ya no funciona.
Claudio Salinas - 回复
no funciona. al parecer es otra pantalla. no da imagen
Ipoint Tech -
la pantalla 2020 no me funciono tampoco en un se 2022.
Ipoint Tech - 回复
i real need my phone fix for school im only 12
Tyveiair Hardy - 回复
Jim - 回复
^ I second that, if I'm going to guy it, I would like to know what all the steps are spelled out.
Aerus Roman - 回复
添加评论
浏览统计数据:
过去 24 小时: 54
过去 7 天: 381
过去 30 天: 1,641
总计 41,267
