当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
遵循本指南更换 Lightning 接口组件,包括底部麦克风,天线转换电缆和 Lightning 接口。
你所需要的
加热 iOpener并将其穿过反向钳。
折叠 iOpener,使其位于 iPhone 的底部边缘。
等待一分钟,让粘合剂有机会释放并出现开口间隙。
将撬片插入间隙中。
跳过接下来的三个步骤。
在这个步骤中使用的工具:Magnetic Project Mat$19.95
卸下将显示屏电路支架固定在电路板上如下的四个十字螺丝:
两个1.3毫米的螺丝
两个2.8毫米的螺丝
卸下支架。
拧下用于固定Taptic Engine旁边支架的三颗螺丝钉:
一个 1.3毫米的Y000型螺丝钉。
一个 2.7毫米的十字型螺丝钉。
一个 2.9毫米的十字型螺丝钉。
将新的更换部件与原始部件进行比较 —— 在安装之前,你可能需要拆掉剩余部件或从新部件上撕下粘合剂背衬。
请按逆序重组你的设备。
将你的电子废料带到R2 or e-Stewards 认证的回收商.
维修不像计划中一样进行?查阅iPhone 8 问题解答论坛 来排查错误。
请按逆序重组你的设备。
109等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
29条评论
I love how you mention the “antenna converter cable” twice but never show what the &&^& that part even looks like??
Sorry about that! It’s actually shown in the 3rd image in the last step. I cropped the photo so that it’s zoomed in more to show it.
I would HIGHLY recommend not attempting this fix. I have done a variety of repairs on iPhones (screens, batteries, etc.) and decided to try this to address a broken microphone. I could make regular phone calls but couldn’t use speakerphone or FaceTime. After replacing the lightening charger using the instructions and the iFixit parts, I still can’t use the speakerphone or FaceTime function. To make matters worse, my phone won’t charge through the lightening connector, won’t wirelessly charge, and people can’t hear me even when I make a regular phone call anymore. In other words, I started with one fairly minor problem and, due to this repair, have a whole bunch of new (much more significant) issues. Don’t make the same mistake I did.
Don’t know about the charging issues, but the reason replacing the microphone didn’t help is because you replaced the wrong microphone.
iPhone 8 has 3 mics.
- One for regular phone calls - which is the one you replaced
- One for the front-facing camera - which is used for the speakerphone and FaceTime and is located near the earpiece
- One for the back-facing camera
Excelente guía..!!
