此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
Lightning 接口、耳机插孔和蜂窝天线位于一个组件上,必须一起拆卸和更换。如果您尝试了 清洁 Lightning 接口 后仍无法解决问题,更换 Lightning 接口可以解决充电和连接功能故障。
您也可以使用本指南更换 麦克风密封垫。
你所需要的
视频概述
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
将新的替换部件与原部件进行比较。在安装前,您可能需要转移剩余的部件或从新部件上揭掉保护胶带。
要重新组装设备,请按相反顺序执行这些说明。
请将您的电子废弃物送往 R2 或 e-Stewards 认证的回收机构。
维修未按计划进行?请查看我们的 iPhone 5 Answers 社区 获取故障排除帮助。
513等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
67指南评论
Just a quick note that if you're doing this teardown because your iPhone 5 isn't charging unless you apply some force to the Lightning cable, the problem may simply be some lint or other crud in the Lightning port. Blow some compressed air in there before you disassemble your iPhone and see if it solves the problem - it did for me.
Adam Engst - 回复 分享
THANK YOU for your comment, Adam, and the others that took the time to confirm it worked for them. Thankfully I read it before attempting this repair on my iPhone 5S. It took only 10 seconds with a very skinny (<1 mm) screwdriver, scraping the deep edge of the port, and I pulled out a wad of pocket lint that was about the size of a pea when uncompressed. A paperclip would have done the job. Charger works perfectly now.
