跳转到主内容
加入维修社区 - 创建账户
iPhone 15 Pro Front Camera Assembly Replacement
你所需要的
  1. iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: 步骤 1 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: 步骤 1 中的图像 2,2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
    添加评论
  2. iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: 步骤 2 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: 步骤 2 中的图像 2,2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    添加评论
  3. iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: 步骤 3 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: 步骤 3 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: 步骤 3 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    添加评论
  4. iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: 步骤 4 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: 步骤 4 中的图像 2,2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
    询问修复机器人
    添加评论
  5. iPhone 15 Pro Front Camera Assembly Replacement, Heat the bottom edge: 步骤 5 中的图像 1,1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    询问修复机器人
    添加评论
  6. iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 3,3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    询问修复机器人
    添加评论
  7. iPhone 15 Pro Front Camera Assembly Replacement, Screen information: 步骤 7 中的图像 1,1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    添加评论
  8. iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 3,3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  9. iPhone 15 Pro Front Camera Assembly Replacement, Heat the right edge: 步骤 9 中的图像 1,1
    • Heat the right edge of the screen until it's hot to the touch.
    询问修复机器人
    添加评论
  10. iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: 步骤 10 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: 步骤 10 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: 步骤 10 中的图像 3,3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    询问修复机器人
    添加评论
  11. iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: 步骤 11 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: 步骤 11 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: 步骤 11 中的图像 3,3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
    询问修复机器人
    添加评论
  12. iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: 步骤 12 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: 步骤 12 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: 步骤 12 中的图像 3,3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  13. iPhone 15 Pro Front Camera Assembly Replacement, Heat the top edge: 步骤 13 中的图像 1,1
    • Heat the top edge of the screen until it's hot to the touch.
    询问修复机器人
    添加评论
  14. iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 步骤 14 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 步骤 14 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 步骤 14 中的图像 3,3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
    询问修复机器人
    添加评论
  15. iPhone 15 Pro Front Camera Assembly Replacement, Heat the left edge: 步骤 15 中的图像 1,1
    • Heat the left edge of the screen until it's hot to the touch.
    添加评论
  16. iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 步骤 16 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 步骤 16 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 步骤 16 中的图像 3,3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    询问修复机器人
    添加评论
  17. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: 步骤 17 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: 步骤 17 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: 步骤 17 中的图像 3,3
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
    询问修复机器人
    添加评论
  18. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: 步骤 18 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: 步骤 18 中的图像 2,2
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
    询问修复机器人
    添加评论
  19. iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: 步骤 19 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: 步骤 19 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: 步骤 19 中的图像 3,3
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
    询问修复机器人
    添加评论
  20. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: 步骤 20 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: 步骤 20 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: 步骤 20 中的图像 3,3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    询问修复机器人
    添加评论
  21. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: 步骤 21 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: 步骤 21 中的图像 2,2
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
    询问修复机器人
    添加评论
  22. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: 步骤 22 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: 步骤 22 中的图像 2,2
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
    询问修复机器人
    添加评论
  23. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: 步骤 23 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: 步骤 23 中的图像 2,2
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    添加评论
  24. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: 步骤 24 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: 步骤 24 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: 步骤 24 中的图像 3,3
    • Use the tip of an opening pick to pry up and disconnect the three rear camera press connectors from the top right of the logic board.
    • The third connector is hidden beneath the top one—lift the top cable slightly to reveal the third connector.
    询问修复机器人
    添加评论
  25. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: 步骤 25 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: 步骤 25 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the three screws securing the rear cameras:
    • One 3.8 mm‑long screw
    • One 3.2 mm‑long screw
    • One 2.8 mm‑long screw
    询问修复机器人
    添加评论
  26. iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: 步骤 26 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: 步骤 26 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: 步骤 26 中的图像 3,3
    • Be careful not to touch or smudge the camera lenses during this step.
    • Insert the point of a spudger between the top right corner of the rear cameras and frame.
    • Pry up until you can grab the rear cameras with your fingers.
    • Remove the rear cameras.
    询问修复机器人
    添加评论
  27. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: 步骤 27 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: 步骤 27 中的图像 2,2
    在这个步骤中使用的工具:
    Standoff Screwdriver for iPhones
    $5.49
    • Use a Phillips #000 screwdriver to remove the 2 mm‑long screw securing the top of the earpiece speaker.
    • Use a standoff screwdriver to remove the remaining screw securing the bottom left corner of the earpiece speaker.
    • If you don't have a standoff screwdriver, you can use a thin flathead one instead. Apply constant, downward pressure to avoid damaging the shallow notches in the screw head.
    询问修复机器人
    添加评论
  28. iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: 步骤 28 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: 步骤 28 中的图像 2,2
    • Remove the earpiece speaker.
    询问修复机器人
    添加评论
  29. iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: 步骤 29 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: 步骤 29 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: 步骤 29 中的图像 3,3
    • The microphone cable covers the front sensors press connector.
    • Use the tip of an opening pick to disconnect the microphone press connector from the top left corner of the logic board.
    • Lift the cable out of the way so you can access the two press connectors on the logic board's top edge.
    询问修复机器人
    添加评论
  30. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 步骤 30 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 步骤 30 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 步骤 30 中的图像 3,3
    • Use the tip of an opening pick to pry up and disconnect the front sensors and front camera press connectors from the top edge of the logic board.
    询问修复机器人
    添加评论
  31. iPhone 15 Pro Front Camera Assembly Replacement, Remove the front camera assembly: 步骤 31 中的图像 1,1
    • Remove the front camera assembly.
    • Be careful not to touch or smudge the camera or sensor lenses.
    询问修复机器人
    添加评论
  32. iPhone 15 Pro Front Camera Assembly Replacement, Disassembly complete: 步骤 32 中的图像 1,1
    • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
    询问修复机器人
    添加评论
  33. iPhone 15 Pro Front Camera Assembly Replacement, Install the front camera assembly: 步骤 33 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Install the front camera assembly: 步骤 33 中的图像 2,2
    • Be careful not to touch or smudge the front camera or sensor lenses.
    • If the replacement cameras include a plastic liner to protect the lenses, keep it in place until just before you reinstall the screen.
    • Use tweezers to align the front camera assembly with its recess in the frame and set it into place.
    询问修复机器人
    添加评论
  34. iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: 步骤 34 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: 步骤 34 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: 步骤 34 中的图像 3,3
    • Use your finger or the flat end of a spudger to connect the front camera assembly's press connectors to their sockets on the top edge of the logic board.
    询问修复机器人
    添加评论
  35. iPhone 15 Pro Front Camera Assembly Replacement, Connect the microphone: 步骤 35 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Connect the microphone: 步骤 35 中的图像 2,2
    • Use your finger to connect the microphone press connector to its socket on the top left corner of the logic board.
    询问修复机器人
    添加评论
  36. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: 步骤 36 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: 步骤 36 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: 步骤 36 中的图像 3,3
    • Align the gasket on the top right corner of the earpiece speaker with its recess in the frame.
    • Press the gasket into its recess, then lower the earpiece speaker into place.
    询问修复机器人
    添加评论
  37. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker screws: 步骤 37 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker screws: 步骤 37 中的图像 2,2
    • Use a Phillips #000 screwdriver to install the 2 mm‑long screw securing the top of the earpiece speaker.
    • Use a standoff screwdriver to install the remaining screw securing the bottom left corner of the earpiece speaker.
    询问修复机器人
    添加评论
  38. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: 步骤 38 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: 步骤 38 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: 步骤 38 中的图像 3,3
    • Be careful not to touch or smudge the camera lenses.
    • Align the rear camera assembly with its recess in the frame and set it into place.
    询问修复机器人
    添加评论
  39. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly screws: 步骤 39 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly screws: 步骤 39 中的图像 2,2
    • Use a Phillips #000 screwdriver to install the three screws securing the rear cameras:
    询问修复机器人
    添加评论
  40. iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: 步骤 40 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: 步骤 40 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: 步骤 40 中的图像 3,3
    • Use the flat end of a spudger to connect the three rear camera press connectors—starting with the black one—to their respective sockets on the logic board.
    询问修复机器人
    添加评论
  41. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: 步骤 41 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: 步骤 41 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: 步骤 41 中的图像 3,3
    • The adhesive remaining on the phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
    询问修复机器人
    添加评论
  42. iPhone 15 Pro Front Camera Assembly Replacement: 步骤 42 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement: 步骤 42 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement: 步骤 42 中的图像 3,3
    • Any unevenness will compromise the iPhone's seal. Clean the frame thoroughly.
    • Apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to a cotton swab or lint-free cloth.
    • Wipe along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    询问修复机器人
    添加评论
  43. iPhone 15 Pro Front Camera Assembly Replacement, Orient the adhesive: 步骤 43 中的图像 1,1
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
    询问修复机器人
    添加评论
  44. iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: 步骤 44 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: 步骤 44 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: 步骤 44 中的图像 3,3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    • When the adhesive is aligned, set it down along the bottom edge.
    询问修复机器人
    添加评论
  45. iPhone 15 Pro Front Camera Assembly Replacement: 步骤 45 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement: 步骤 45 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement: 步骤 45 中的图像 3,3
    • Continue peeling the back liner off of the adhesive while setting the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
    询问修复机器人
    添加评论
  46. iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: 步骤 46 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: 步骤 46 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: 步骤 46 中的图像 3,3
    • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    询问修复机器人
    添加评论
  47. iPhone 15 Pro Front Camera Assembly Replacement, Remove the top liner: 步骤 47 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the top liner: 步骤 47 中的图像 2,2
    • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
    询问修复机器人
    添加评论
  48. iPhone 15 Pro Front Camera Assembly Replacement, Adhesive information: 步骤 48 中的图像 1,1
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
    询问修复机器人
    添加评论
  49. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: 步骤 49 中的图像 1,1
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    询问修复机器人
    添加评论
  50. iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: 步骤 50 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: 步骤 50 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: 步骤 50 中的图像 3,3
    • Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
    询问修复机器人
    添加评论
  51. iPhone 15 Pro Front Camera Assembly Replacement, Connect the battery: 步骤 51 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Connect the battery: 步骤 51 中的图像 2,2
    • Use your finger or the flat end of a spudger to connect the battery press connector.
    询问修复机器人
    添加评论
  52. iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: 步骤 52 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: 步骤 52 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: 步骤 52 中的图像 3,3
    询问修复机器人
    添加评论
  53. iPhone 15 Pro Front Camera Assembly Replacement, Fasten the logic board cover: 步骤 53 中的图像 1,1
    • Use a Y000 screwdriver to install the six screws securing the logic board cover:
    询问修复机器人
    添加评论
  54. iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: 步骤 54 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: 步骤 54 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: 步骤 54 中的图像 3,3
    • Once you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing accidentally sticks to it.
    • Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
    询问修复机器人
    添加评论
  55. iPhone 15 Pro Front Camera Assembly Replacement: 步骤 55 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement: 步骤 55 中的图像 2,2
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the frame.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the frame.
    询问修复机器人
    添加评论
  56. iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: 步骤 56 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: 步骤 56 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: 步骤 56 中的图像 3,3
    • Align the screen over the frame, then lower it into place.
    询问修复机器人
    添加评论
  57. iPhone 15 Pro Front Camera Assembly Replacement, Press the screen: 步骤 57 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Press the screen: 步骤 57 中的图像 2,2
    • Firmly press along the edges of the screen to engage the clips and compress the adhesive.
    询问修复机器人
    添加评论
  58. iPhone 15 Pro Front Camera Assembly Replacement, Install the pentalobe screws: 步骤 58 中的图像 1,1
    • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
    询问修复机器人
    添加评论
  59. iPhone 15 Pro Front Camera Assembly Replacement, Heat the screen: 步骤 59 中的图像 1,2 iPhone 15 Pro Front Camera Assembly Replacement, Heat the screen: 步骤 59 中的图像 2,2
    • To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
    询问修复机器人
    添加评论
  60. iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: 步骤 60 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: 步骤 60 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: 步骤 60 中的图像 3,3
    • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the iPhone's original box, take the lid and place it on a flat surface.
    • If you don't have the original box, skip this step for an alternate method.
    • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
    • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes, ideally overnight.
    询问修复机器人
    添加评论
  61. iPhone 15 Pro Front Camera Assembly Replacement: 步骤 61 中的图像 1,3 iPhone 15 Pro Front Camera Assembly Replacement: 步骤 61 中的图像 2,3 iPhone 15 Pro Front Camera Assembly Replacement: 步骤 61 中的图像 3,3
    • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    询问修复机器人
    添加评论
  62. iPhone 15 Pro Front Camera Assembly Replacement: 步骤 62 中的图像 1,1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    询问修复机器人
    添加评论
结论
Congratulations on replacing the front camera assembly!
After your repair, depending on the replacement part, you may be able to pair it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
取消:我没有完成这个指南。
2等其他人完成本指南。
Spencer Day
于09/14/22注册
194,932 声望
创作了1,243篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了26,591篇指南
1指南评论
with ios 18, can you use the repair assistant tool to fix faceid? if not is there some sort of device i can use to pair the logic board with the faceid? if not, is my best bet for the front camera and faceid to work again just sending it in to apple for repairs?
Jesse Beckmann - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 181
过去 30 天: 534
总计 10,767
