跳转到主内容
加入维修社区 - 创建账户
iPad Air 4 Battery Replacement
你所需要的
  1. iPad Air 4 Battery Replacement, Prepare your iPad for disassembly: 步骤 1 中的图像 1,1
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
    询问修复机器人
    添加评论
  2. iPad Air 4 Battery Replacement, Heat the left edge: 步骤 2 中的图像 1,1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
    添加评论
  3. iPad Air 4 Battery Replacement, Screen removal information: 步骤 3 中的图像 1,2 iPad Air 4 Battery Replacement, Screen removal information: 步骤 3 中的图像 2,2
    • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
    • Camera module and ambient light sensors
    • Display cables
    • Screen magnets
    • Display edges
    添加评论
  4. iPad Air 4 Battery Replacement, Anti-Clamp instructions: 步骤 4 中的图像 1,3 iPad Air 4 Battery Replacement, Anti-Clamp instructions: 步骤 4 中的图像 2,3 iPad Air 4 Battery Replacement, Anti-Clamp instructions: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    询问修复机器人
    添加评论
  5. iPad Air 4 Battery Replacement: 步骤 5 中的图像 1,3 iPad Air 4 Battery Replacement: 步骤 5 中的图像 2,3 iPad Air 4 Battery Replacement: 步骤 5 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    询问修复机器人
    添加评论
  6. iPad Air 4 Battery Replacement: 步骤 6 中的图像 1,2 iPad Air 4 Battery Replacement: 步骤 6 中的图像 2,2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    询问修复机器人
    添加评论
  7. iPad Air 4 Battery Replacement, Insert an opening pick: 步骤 7 中的图像 1,3 iPad Air 4 Battery Replacement, Insert an opening pick: 步骤 7 中的图像 2,3 iPad Air 4 Battery Replacement, Insert an opening pick: 步骤 7 中的图像 3,3
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the top left edge of the screen.
    • Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
    • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
    • Insert the tip of an opening pick into the gap.
    • Don't insert the opening pick more than 3 mm or you'll damage the display edges.
    • Leave the pick in to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  8. iPad Air 4 Battery Replacement, Separate the left edge adhesive: 步骤 8 中的图像 1,3 iPad Air 4 Battery Replacement, Separate the left edge adhesive: 步骤 8 中的图像 2,3 iPad Air 4 Battery Replacement, Separate the left edge adhesive: 步骤 8 中的图像 3,3
    • Don't insert the pick more than 3 mm or you'll damage the display edges.
    • Insert a new opening pick in the gap you just created.
    • Slide the opening pick along the left edge to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  9. iPad Air 4 Battery Replacement, Heat the bottom edge: 步骤 9 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
    询问修复机器人
    添加评论
  10. iPad Air 4 Battery Replacement, Separate the bottom edge adhesive: 步骤 10 中的图像 1,3 iPad Air 4 Battery Replacement, Separate the bottom edge adhesive: 步骤 10 中的图像 2,3 iPad Air 4 Battery Replacement, Separate the bottom edge adhesive: 步骤 10 中的图像 3,3
    • Don't insert the pick more than 3 mm or you'll damage the display cables.
    • Insert a new opening pick in the bottom left corner.
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick in the bottom right corner to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  11. iPad Air 4 Battery Replacement, Heat the right edge: 步骤 11 中的图像 1,1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    询问修复机器人
    添加评论
  12. iPad Air 4 Battery Replacement, Separate the right edge adhesive: 步骤 12 中的图像 1,3 iPad Air 4 Battery Replacement, Separate the right edge adhesive: 步骤 12 中的图像 2,3 iPad Air 4 Battery Replacement, Separate the right edge adhesive: 步骤 12 中的图像 3,3
    • The right edge of the iPad contains the screen magnets, display cables, and a digitizer cable. These components are easily damaged if an opening pick is inserted too far.
    • Insert a new opening pick in the bottom right corner and slide along the right edge to separate the adhesive. Make sure to note the following marked areas:
    • Don't insert an opening pick more than 2 mm or you'll damage the screen magnets.
    • The screen magnets are located directly above the SIM card slot (Wi-Fi + Cellular models only) and volume buttons.
    • Don't insert an opening pick more than 3 mm or you'll damage the display and digitizer cables.
    • Don't insert an opening pick more than 5 mm or you'll damage the display edges.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  13. iPad Air 4 Battery Replacement, Heat the top edge: 步骤 13 中的图像 1,1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    询问修复机器人
    添加评论
  14. iPad Air 4 Battery Replacement, Separate the top edge adhesive: 步骤 14 中的图像 1,3 iPad Air 4 Battery Replacement, Separate the top edge adhesive: 步骤 14 中的图像 2,3 iPad Air 4 Battery Replacement, Separate the top edge adhesive: 步骤 14 中的图像 3,3
    • The top edge of the iPad contains the front camera module and two ambient light sensors. These components are easily damaged if an opening pick is inserted too far.
    • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
    • Insert a new opening pick in the top right corner and slide along the top edge to separate the adhesive. Make sure to note the following:
    • Don't insert an opening pick more than 3 mm or you'll damage the ambient light sensors.
    • Don't insert an opening pick more than 2 mm or you'll damage the front camera module.
    • Leave the pick in the top left corner to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  15. iPad Air 4 Battery Replacement, Reposition the screen: 步骤 15 中的图像 1,3 iPad Air 4 Battery Replacement, Reposition the screen: 步骤 15 中的图像 2,3 iPad Air 4 Battery Replacement, Reposition the screen: 步骤 15 中的图像 3,3
    • Don't try to remove the screen yet, as it's still attached to the frame by delicate ribbon cables.
    • Grip the left edge of the screen and fold it open like a book.
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
    添加评论
  16. iPad Air 4 Battery Replacement, Disconnect the battery: 步骤 16 中的图像 1,2 iPad Air 4 Battery Replacement, Disconnect the battery: 步骤 16 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
    添加评论
  17. iPad Air 4 Battery Replacement, Battery connector information: 步骤 17 中的图像 1,3 iPad Air 4 Battery Replacement, Battery connector information: 步骤 17 中的图像 2,3 iPad Air 4 Battery Replacement, Battery connector information: 步骤 17 中的图像 3,3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    添加评论
  18. iPad Air 4 Battery Replacement, Create a battery blocker: 步骤 18 中的图像 1,3 iPad Air 4 Battery Replacement, Create a battery blocker: 步骤 18 中的图像 2,3 iPad Air 4 Battery Replacement, Create a battery blocker: 步骤 18 中的图像 3,3
    • Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
    • The strips should be about 4 cm long so you can easily grip them.
    询问修复机器人
    添加评论
  19. iPad Air 4 Battery Replacement, Insert the card strips: 步骤 19 中的图像 1,3 iPad Air 4 Battery Replacement, Insert the card strips: 步骤 19 中的图像 2,3 iPad Air 4 Battery Replacement, Insert the card strips: 步骤 19 中的图像 3,3
    • Insert the card strips on each side of the battery connector until they stop.
    添加评论
  20. iPad Air 4 Battery Replacement, Unfasten the display and digitizer cable brackets: 步骤 20 中的图像 1,2 iPad Air 4 Battery Replacement, Unfasten the display and digitizer cable brackets: 步骤 20 中的图像 2,2
    • Use a Phillips screwdriver to remove the three screws securing the display and digitizer cable brackets to the logic board:
    • Two 1.1 mm screws
    • One 1.5 mm screw
    询问修复机器人
    添加评论
  21. iPad Air 4 Battery Replacement, Remove the display cable bracket: 步骤 21 中的图像 1,3 iPad Air 4 Battery Replacement, Remove the display cable bracket: 步骤 21 中的图像 2,3 iPad Air 4 Battery Replacement, Remove the display cable bracket: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    • The display cable bracket is held in place by a small latch at the bottom.
    • Use tweezers or your fingers to pivot the latch out from the top and remove the bracket.
    添加评论
  22. iPad Air 4 Battery Replacement, Remove the digitizer cable bracket: 步骤 22 中的图像 1,2 iPad Air 4 Battery Replacement, Remove the digitizer cable bracket: 步骤 22 中的图像 2,2
    • Use tweezers or your fingers to remove the digitizer cable bracket.
    询问修复机器人
    添加评论
  23. iPad Air 4 Battery Replacement, Disconnect the display cables: 步骤 23 中的图像 1,3 iPad Air 4 Battery Replacement, Disconnect the display cables: 步骤 23 中的图像 2,3 iPad Air 4 Battery Replacement, Disconnect the display cables: 步骤 23 中的图像 3,3
    • Use the flat end of a spudger to disconnect the two display cables by lifting straight up on the press connectors.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    询问修复机器人
    添加评论
  24. iPad Air 4 Battery Replacement, Disconnect the digitizer cable: 步骤 24 中的图像 1,2 iPad Air 4 Battery Replacement, Disconnect the digitizer cable: 步骤 24 中的图像 2,2
    • Repeat the previous step for the digitizer cable.
    • When installing a new screen, rest the screen on the edge of the frame to avoid stretching the cables. Don't let the screen fall off the frame or else you risk tearing the cables.
    询问修复机器人
    添加评论
  25. iPad Air 4 Battery Replacement, Remove the screen: 步骤 25 中的图像 1,1
    • Grip the left edge of the screen and lift it away.
    • During reassembly, before installing a screen, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
    添加评论
  26. iPad Air 4 Battery Replacement, Disconnect the bottom speaker: 步骤 26 中的图像 1,2 iPad Air 4 Battery Replacement, Disconnect the bottom speaker: 步骤 26 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the bottom speaker cable by prying straight up on the rear of the connector.
    询问修复机器人
    添加评论
  27. iPad Air 4 Battery Replacement, Disconnect the SIM card reader: 步骤 27 中的图像 1,2 iPad Air 4 Battery Replacement, Disconnect the SIM card reader: 步骤 27 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the tape covering the SIM card reader ZIF connector.
    询问修复机器人
    添加评论
  28. iPad Air 4 Battery Replacement: 步骤 28 中的图像 1,3 iPad Air 4 Battery Replacement: 步骤 28 中的图像 2,3 iPad Air 4 Battery Replacement: 步骤 28 中的图像 3,3
    • Use tweezers or a spudger to lift up the latch on the SIM card reader ZIF connector.
    • Use tweezers to pull the SIM card reader cable from its socket.
    询问修复机器人
    添加评论
  29. iPad Air 4 Battery Replacement, Disconnect the bottom right cellular antenna interconnect cable: 步骤 29 中的图像 1,3 iPad Air 4 Battery Replacement, Disconnect the bottom right cellular antenna interconnect cable: 步骤 29 中的图像 2,3 iPad Air 4 Battery Replacement, Disconnect the bottom right cellular antenna interconnect cable: 步骤 29 中的图像 3,3
    • Repeat the previous two steps to disconnect the bottom right cellular antenna interconnect cable.
    询问修复机器人
    添加评论
  30. iPad Air 4 Battery Replacement, Peel back the bottom right cellular antenna interconnect cable: 步骤 30 中的图像 1,2 iPad Air 4 Battery Replacement, Peel back the bottom right cellular antenna interconnect cable: 步骤 30 中的图像 2,2
    • Use tweezers or your fingers to peel the bottom right cellular antenna interconnect cable to the edge of the frame.
    • If the cable is difficult to remove, use a few drops of high-strength (>90%) isopropyl alcohol to soften the adhesive.
    询问修复机器人
    添加评论
  31. iPad Air 4 Battery Replacement, Battery adhesive information: 步骤 31 中的图像 1,2 iPad Air 4 Battery Replacement, Battery adhesive information: 步骤 31 中的图像 2,2
    • The battery is secured to the frame with eight adhesive strips:
    • Three under each battery cell
    • Two under the battery boards
    询问修复机器人
    添加评论
  32. iPad Air 4 Battery Replacement, Apply isopropyl alcohol to the left edge of the battery: 步骤 32 中的图像 1,3 iPad Air 4 Battery Replacement, Apply isopropyl alcohol to the left edge of the battery: 步骤 32 中的图像 2,3 iPad Air 4 Battery Replacement, Apply isopropyl alcohol to the left edge of the battery: 步骤 32 中的图像 3,3
    • Prop the left side of the iPad up so the isopropyl alcohol can flow under the battery.
    • Apply a few drops of high-strength (>90%) isopropyl alcohol along the left edge of the battery.
    • Be careful if you're using a syringe with a needle or other sharp instrument to dispense isopropyl alcohol—a punctured battery may leak dangerous chemicals or cause a fire.
    • Let the alcohol soak for one minute to soften the adhesive under the battery.
    询问修复机器人
    添加评论
  33. iPad Air 4 Battery Replacement, Separate the lower battery cell adhesive: 步骤 33 中的图像 1,3 iPad Air 4 Battery Replacement, Separate the lower battery cell adhesive: 步骤 33 中的图像 2,3 iPad Air 4 Battery Replacement, Separate the lower battery cell adhesive: 步骤 33 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Lay the iPad down flat on your work surface.
    • Insert a plastic card under the left side of the lower battery cell to separate the adhesive securing it to the frame.
    • Don't force the card or bend the battery—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • If it's difficult to insert or slide the card, apply more isopropyl alcohol, wait one minute, and try again.
    • Leave the plastic card in place to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  34. iPad Air 4 Battery Replacement: 步骤 34 中的图像 1,3 iPad Air 4 Battery Replacement: 步骤 34 中的图像 2,3 iPad Air 4 Battery Replacement: 步骤 34 中的图像 3,3
    • Insert the flat end of a spudger underneath the plastic card for additional leverage.
    • Pry against the card to separate the remaining adhesive.
    询问修复机器人
    添加评论
  35. iPad Air 4 Battery Replacement, Separate the upper battery cell adhesive: 步骤 35 中的图像 1,2 iPad Air 4 Battery Replacement, Separate the upper battery cell adhesive: 步骤 35 中的图像 2,2
    • Repeat the previous two steps for the upper battery cell.
    询问修复机器人
    添加评论
  36. iPad Air 4 Battery Replacement, Heat the logic board: 步骤 36 中的图像 1,1
    • Lay your iPad screen side down on a clean surface.
    • Apply a heated iOpener to the back of the iPad about 4 cm from the right edge.
    • Let the iOpener soften the adhesive for two minutes.
    询问修复机器人
    添加评论
  37. iPad Air 4 Battery Replacement, Lift the logic board: 步骤 37 中的图像 1,3 iPad Air 4 Battery Replacement, Lift the logic board: 步骤 37 中的图像 2,3 iPad Air 4 Battery Replacement, Lift the logic board: 步骤 37 中的图像 3,3
    • Lay the iPad screen side up.
    • Slide the flat end of a spudger under the cellular wireless connector until the logic board lifts and the battery blocker card strips are loose.
    • Don't force the spudger in or pry up. If it's difficult to insert or slide the spudger, apply more heat. Alternatively, a few drops of high-strength (>90%) isopropyl alcohol may be used to soften the adhesive.
    • Leave the spudger in to prevent the adhesive from re-sealing.
    询问修复机器人
    添加评论
  38. iPad Air 4 Battery Replacement, Apply isopropyl to the battery boards: 步骤 38 中的图像 1,3 iPad Air 4 Battery Replacement, Apply isopropyl to the battery boards: 步骤 38 中的图像 2,3 iPad Air 4 Battery Replacement, Apply isopropyl to the battery boards: 步骤 38 中的图像 3,3
    • Lift the left edge of the battery cells.
    • Apply a few drops of high-strength (>90%) isopropyl alcohol to the battery boards which sit along the right edge of the battery cells.
    询问修复机器人
    添加评论
  39. iPad Air 4 Battery Replacement, Separate the battery board adhesive: 步骤 39 中的图像 1,3 iPad Air 4 Battery Replacement, Separate the battery board adhesive: 步骤 39 中的图像 2,3 iPad Air 4 Battery Replacement, Separate the battery board adhesive: 步骤 39 中的图像 3,3
    • Slide an opening pick under the battery board to separate the adhesive securing it to the frame.
    询问修复机器人
    添加评论
  40. iPad Air 4 Battery Replacement, Lift the battery connector out: 步骤 40 中的图像 1,3 iPad Air 4 Battery Replacement, Lift the battery connector out: 步骤 40 中的图像 2,3 iPad Air 4 Battery Replacement, Lift the battery connector out: 步骤 40 中的图像 3,3
    • Remove the battery blocker card strips.
    • Lift the battery up and away from the frame so its connector clears the standoff post.
    • Don't let the battery connector touch the contacts on the logic board.
    询问修复机器人
    添加评论
  41. iPad Air 4 Battery Replacement, Remove the battery: 步骤 41 中的图像 1,2 iPad Air 4 Battery Replacement, Remove the battery: 步骤 41 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $25.95
    • Lift both halves of the battery out of the iPad at the same time.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove the old battery adhesive from the frame using tweezers and high-strength (>90%) isopropyl alcohol with a lint-free cloth where needed.
    • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
    询问修复机器人
    添加评论
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 4 answers community for help.
取消:我没有完成这个指南。
11等其他人完成本指南。
Chayton Ritter
于08/21/20注册
26,951 声望
创作了105篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了19,278篇指南
1指南评论
This article seems to imply that the battery is paired to the IPad, and that the battery health tool won't work. I have an early IPad Air 4 updated to the latest iOS version. The only issue I'm having is that the battery is showing it's age, and is acting up some. If I replace the battery successfully, will there be any impact on the functionality of the iPad? Will it act as though it has a legitimate battery, or will it constantly nag me that I'm not using the original Apple part?
Michael Rensing - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 35
过去 7 天: 317
过去 30 天: 1,452
总计 51,054
