当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
使用本指南更换iPad 6的前置玻璃和数字化器组件。
“主屏幕按钮中的触控 ID 传感器与主板配对。为了保留触控 ID 功能,您需要将原始主屏幕按钮传输到新的前面板组件。
“使用电池阻滞器隔离电池时要非常小心。”电池触点很容易损坏,导致不可逆转的损坏。如果您选择在不隔离电池的情况下完成指南,请避免使用金属工具,除非完全必要(例如拆卸螺丝时),以防止电池短路和损坏敏感电路组件。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
在这个步骤中使用的工具:Anti-Clamp$24.95-
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
这个步骤还没有翻译 帮忙翻译一下
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
Skip the next step.
这个步骤还没有翻译 帮忙翻译一下
Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
Insert an opening pick into the gap between the digitizer and the frame.
这个步骤还没有翻译 帮忙翻译一下
在这个步骤中使用的工具:Polyimide Tape$9.99-
Remove the front panel assembly.
If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
要重新组装您的设备,请按相反的顺序按照以下说明操作。
180等其他人完成本指南。
由衷感谢以下译者:
100%
[deleted]正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
47条评论
does the front panel of the ipad5 fit here?
cndals0075 - 回复
The display connectors on the iPad 5 and iPad 6 are at different angles and not directly compatible with each other. We have not yet tried to force the connectors from an iPad 6 display onto an iPad 5 and vice versa to see what happened.
