跳转到主内容
TicWatch E3 Motherboard Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch 另一个贡献者
最后更新于 May 7, 2024
20 - 40 分钟
中等
Use this guide to replace the motherboard in your TicWatch E3.
You’ll need replacement adhesive when reassembling the device. Your device will function normally, but will lose its IP (Ingress Protection) rating.
你所需要的
工具
查看更多...
  1. TicWatch E3 Motherboard Replacement, Power down your watch: 步骤 1 中的图像 1,2 TicWatch E3 Motherboard Replacement, Power down your watch: 步骤 1 中的图像 2,2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. TicWatch E3 Motherboard Replacement, Loosen the adhesive: 步骤 2 中的图像 1,1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. TicWatch E3 Motherboard Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 TicWatch E3 Motherboard Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 TicWatch E3 Motherboard Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • Insert an opening pick into the recess between the watch frame and the top edge of the back cover.
    • Push the opening pick to create a gap between the back cover and the watch frame.
  4. TicWatch E3 Motherboard Replacement, Pry up the back cover assembly: 步骤 4 中的图像 1,3 TicWatch E3 Motherboard Replacement, Pry up the back cover assembly: 步骤 4 中的图像 2,3 TicWatch E3 Motherboard Replacement, Pry up the back cover assembly: 步骤 4 中的图像 3,3
    • Twist the opening pick to widen the gap between the back cover assembly and the watch frame.
    • Pry upward to loosen the back cover assembly.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the motherboard.
  5. TicWatch E3 Motherboard Replacement, Free the back cover assembly: 步骤 5 中的图像 1,2 TicWatch E3 Motherboard Replacement, Free the back cover assembly: 步骤 5 中的图像 2,2
    • Carefully lift up the bottom edge of the back cover assembly to make sure it isn't adhered to the watch frame anymore.
    • Avoid straining or tearing the sensor or battery cables.
  6. TicWatch E3 Motherboard Replacement, Open the watch: 步骤 6 中的图像 1,2 TicWatch E3 Motherboard Replacement, Open the watch: 步骤 6 中的图像 2,2
    • Grab the back cover assembly and carefully bring it into an upright position next to the watch housing.
  7. TicWatch E3 Motherboard Replacement, Disconnect the battery cable: 步骤 7 中的图像 1,2 TicWatch E3 Motherboard Replacement, Disconnect the battery cable: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. TicWatch E3 Motherboard Replacement, Disconnect the sensor cable: 步骤 8 中的图像 1,2 TicWatch E3 Motherboard Replacement, Disconnect the sensor cable: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the sensor cable by prying the connector straight up from its socket.
  9. TicWatch E3 Motherboard Replacement, Remove the back cover assembly: 步骤 9 中的图像 1,2 TicWatch E3 Motherboard Replacement, Remove the back cover assembly: 步骤 9 中的图像 2,2
    • Remove the back cover assembly.
  10. TicWatch E3 Motherboard Replacement, Disconnect the display cables: 步骤 10 中的图像 1,2 TicWatch E3 Motherboard Replacement, Disconnect the display cables: 步骤 10 中的图像 2,2
    • Use a spudger to disconnect the right display cable by prying the connector straight up from its socket.
  11. TicWatch E3 Motherboard Replacement: 步骤 11 中的图像 1,2 TicWatch E3 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use a spudger to disconnect the left display cable by prying the connector straight up from its socket.
  12. TicWatch E3 Motherboard Replacement, Free the display cable: 步骤 12 中的图像 1,3 TicWatch E3 Motherboard Replacement, Free the display cable: 步骤 12 中的图像 2,3 TicWatch E3 Motherboard Replacement, Free the display cable: 步骤 12 中的图像 3,3
    • Carefully slide an opening pick underneath the display cable to separate it from the motherboard.
    • Use your opening pick to fold the display cable in an upright position.
  13. TicWatch E3 Motherboard Replacement, Unfasten the motherboard screws: 步骤 13 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 4.1 mm-long screws securing the motherboard.
  14. TicWatch E3 Motherboard Replacement, Pry up the motherboard: 步骤 14 中的图像 1,2 TicWatch E3 Motherboard Replacement, Pry up the motherboard: 步骤 14 中的图像 2,2
    • Insert a spudger underneath the edge of the motherboard opposite to the watch buttons.
    • Pry up to loosen the motherboard.
  15. TicWatch E3 Motherboard Replacement, Remove the motherboard: 步骤 15 中的图像 1,2 TicWatch E3 Motherboard Replacement, Remove the motherboard: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the motherboard.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components like the watch buttons or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch E3 answers community for help.
3等其他人完成本指南。
于11/23/16注册
232,108 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,845篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 302
