跳转到主内容
Razer Blade RZ09-0102 Battery Replacement
Nicole Schukow
Nicole Schukow6 其他贡献者
最后更新于 June 28, 2021
15分钟
中等
A guide to remove and replace the battery for the Razer Blade RZ09-0102. You may want to replace your battery if the battery cannot hold a charge or drains after an unreasonably short time. The battery needs to be removed if working on other components as well.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Razer Blade RZ09-0102 Battery Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
    I need the screws is there any way I can get them?
    Lupita Muro - 回复
  2. Razer Blade RZ09-0102 Battery Replacement, Battery: 步骤 2 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
  3. Razer Blade RZ09-0102 Battery Replacement: 步骤 3 中的图像 1,1
    • Unlock the ZIF connectors securing the right ribbon cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Carefully pull the two ribbon cables out of their sockets.
  4. Razer Blade RZ09-0102 Battery Replacement: 步骤 4 中的图像 1,1
    • Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
    You know where I can buy that kind white ribbon, it hard find anywhere.
    loona.ot12 - 回复
  5. Razer Blade RZ09-0102 Battery Replacement: 步骤 5 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement: 步骤 5 中的图像 2,2
    • Carefully pull out the two connectors out of their sockets.
    • Pull parallel to the motherboard, not straight up.
  6. Razer Blade RZ09-0102 Battery Replacement: 步骤 6 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement: 步骤 6 中的图像 2,2
    • Pull the wide battery connector towards the battery to disconnect it from the motherboard.
  7. Razer Blade RZ09-0102 Battery Replacement: 步骤 7 中的图像 1,2 Razer Blade RZ09-0102 Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the battery from the laptop.
    I lost some of the screws! What are the right replacement screws for the back cover and the battery?
    Anon - 回复
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
6等其他人完成本指南。
2指南评论
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
Erfan Moradi - 回复
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
Giorgi Kikuashvili - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 45
总计 26,450
