Patagonia Freewheeler/Freightliner 系列行李箱拉杆更换指南
简介
转到步骤 1可伸缩拉杆是滚轮行李箱的关键部件。若出现弯曲或磨损,可能导致卡顿或完全无法使用,影响出行体验。
本指南将演示如何更换 Patagonia Freewheeler 和 Freightliner 系列滚轮行李箱的拉杆。但某些情况下,简单的润滑即可解决问题。如需润滑方法,请参考:行李箱拉杆润滑处理。
目前无替换零件供应。如需维修,请前往 Patagonia 当地零售店 评估,或通过 邮寄维修服务 寄回 Patagonia。
相关教程
你所需要的
按下拉杆释放按钮,收缩把手上的伸缩卡舌。
如果卡舌无法收缩,可用尖头工具(如螺丝刀)手动将卡舌压入把手外壳。
向上提起拉杆使其脱离外壳。通过左右小幅晃动,使拉杆底部的黑色塑料套筒松脱。
请妥善丢弃损坏的拉杆。
测试拉杆是否正常工作。将拉杆移动至所有档位,并确保每个档位都能牢固锁定:
完全伸展
中间档位(仅限中号和小号行李箱)
完全收回至把手外壳内
当按下拉杆释放按钮时,伸缩卡舌应能灵活移动。
合上内衬拉链和主仓拉链。
5等其他人完成本指南。
由衷感谢以下译者:
100%
Monica正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2指南评论
I depressed the pins. It worked once or twice. But now, I have to depress the pins every time to get the handle to work OR even with the pins depressed it will still not retract or if retracted it will still not open.
What is the solution?
I love this suitcase otherwise, but the handle has always been tricky needing just the right angle on the way in and having to jiggle it to get it out.
Help Patagonia!
Hi Sharon,
The solution to depress the pins was meant to be a temporary solution when your handle is stuck in the extended position. Unfortunately, it means that your handle needs to be replaced as the handle trigger mechanism and pins are not functioning properly. Contact Patagonia for a new handle. You can either call us and we will can ship you a new one and you can replace yourself, or you can go to a Patagonia Retail Store and get a new handle there, afterwhich you can use the handing guidelines for replacement. Please visit our website for phone number and to locate a store near you. Copy and paste this URL in your search engine bar or click on the link.
