跳转到主内容
加入维修社区 - 创建账户
Stuck Luggage Handle Lubrication
你所需要的
  1. Stuck Luggage Handle Lubrication, Gain Access into Liner Compartment: 步骤 1 中的图像 1,3 Stuck Luggage Handle Lubrication, Gain Access into Liner Compartment: 步骤 1 中的图像 2,3 Stuck Luggage Handle Lubrication, Gain Access into Liner Compartment: 步骤 1 中的图像 3,3
    • Open the zipper at the base of the bag, then open the zipper in the compartment liner to expose the handle mechanisms.
    • Inspect the handle housing.
    • All metal bars should be straight and plastic housings should be intact. This guide cannot fix handles that are stuck due to any damage to the hardware.
    询问修复机器人
    添加评论
  2. Stuck Luggage Handle Lubrication, Check Function of Toggle Buttons: 步骤 2 中的图像 1,3 Stuck Luggage Handle Lubrication, Check Function of Toggle Buttons: 步骤 2 中的图像 2,3 Stuck Luggage Handle Lubrication, Check Function of Toggle Buttons: 步骤 2 中的图像 3,3
    • There are multiple sets of holes along the external sides of the handle housing. The toggle buttons of the handle (sometimes referred to as 'spring clips') lock into these holes, raising and lowering the height of the retractable handle.
    • Check the function of this mechanism by pressing the handle's release button and watching the toggle buttons:
    • When the luggage handle is fully functional, the handle release button causes these toggle buttons to fully retract into the holes.
    • When the luggage handle mechanism is sticky or fully stuck, the handle release button does not cause the toggle buttons to retract properly.
    询问修复机器人
    添加评论
  3. Stuck Luggage Handle Lubrication, Depress Toggle Buttons to Test Handle: 步骤 3 中的图像 1,3 Stuck Luggage Handle Lubrication, Depress Toggle Buttons to Test Handle: 步骤 3 中的图像 2,3 Stuck Luggage Handle Lubrication, Depress Toggle Buttons to Test Handle: 步骤 3 中的图像 3,3
    • With one hand pressing the handle release button, use a pointed object (like a screwdriver) in the other hand to depress each toggle button into the handle housing manually. This should allow the handle to slide to a new position.
    询问修复机器人
    添加评论
  4. Stuck Luggage Handle Lubrication, Remove Handle Clips: 步骤 4 中的图像 1,3 Stuck Luggage Handle Lubrication, Remove Handle Clips: 步骤 4 中的图像 2,3 Stuck Luggage Handle Lubrication, Remove Handle Clips: 步骤 4 中的图像 3,3
    • Use a Phillips PH1 screwdriver to remove the four screws at the top handle bracket.
    • Then remove the two black plastic retaining clips that were kept in place by the red screws.
    • Be careful not to lose these pieces! Put them somewhere safe and accessible, they'll be reused later on.
    询问修复机器人
    添加评论
  5. Stuck Luggage Handle Lubrication, Remove Handle: 步骤 5 中的图像 1,3 Stuck Luggage Handle Lubrication, Remove Handle: 步骤 5 中的图像 2,3 Stuck Luggage Handle Lubrication, Remove Handle: 步骤 5 中的图像 3,3
    • Using the screwdriver trick from Step 3, depress the toggle buttons and pull the handle out of the handle housing as far as you can.
    • Once the handle is in its highest position, use a repeated side-to-side movement to free the black plastic sleeves on the bottom portion of the handle.
    • With the handle separated from the bag, press the handle release button multiple times and take a mental note of how deep the toggle buttons depress.
    询问修复机器人
    添加评论
  6. Stuck Luggage Handle Lubrication, Lubricate Handle: 步骤 6 中的图像 1,3 Stuck Luggage Handle Lubrication, Lubricate Handle: 步骤 6 中的图像 2,3 Stuck Luggage Handle Lubrication, Lubricate Handle: 步骤 6 中的图像 3,3
    • Spray lubricant into the toggle button mechanism on both sides of the handle. Wipe away excess lubricant with a rag.
    • We recommend using Gear Hugger Multipurpose Lubricant. Functional substitutes include 3-IN-ONE Oil and WD-40.
    • Press the handle release button repeatedly to spread the lubricant within the mechanism.
    • The toggle buttons should depress noticeably deeper than in Step 5. Reapply lubricant and retest if necessary.
    • Apply a thin layer of lubricant to the bars of the removed handle. Wipe away any excess.
    询问修复机器人
    添加评论
  7. Stuck Luggage Handle Lubrication, Reinsert Handle into Bag: 步骤 7 中的图像 1,2 Stuck Luggage Handle Lubrication, Reinsert Handle into Bag: 步骤 7 中的图像 2,2
    • Reinsert the handle:
    • While holding the handle release button, use a repeated up-and-down movement to insert the black plastic sleeves into the handle housing.
    • Continue to hold the handle release button, and insert the handle all the way back in.
    • You should notice the handle's function has significantly improved.
    • Move the handle up and down, testing every position.
    • If the handle is still malfunctioning, it may need to be fully replaced.
    询问修复机器人
    添加评论
  8. Stuck Luggage Handle Lubrication, Reinstall Plastic Clips: 步骤 8 中的图像 1,2 Stuck Luggage Handle Lubrication, Reinstall Plastic Clips: 步骤 8 中的图像 2,2
    • Reinstall the 2 black plastic clips.
    • Reinstall all 4 red screws.
    • Do not overtighten.
    询问修复机器人
    添加评论
  9. Stuck Luggage Handle Lubrication, Close Bag: 步骤 9 中的图像 1,2 Stuck Luggage Handle Lubrication, Close Bag: 步骤 9 中的图像 2,2
    • Check the liner compartment to make sure no tools have been left behind.
    • Close the zipper at the perimeter of the liner.
    • Close the zipper to the compartment at the bottom of the bag.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
Zach Mueller
于02/23/23注册
1,789 声望
创作了9篇指南
团队
Patagonia Patagonia 的会员
Community
9 名成员
创作了154篇指南
1指南评论
These comments are based on repairing an Antler wheelie bag (10+ years old) just now..
1/ One of the 2 screws holding on the telescopic handle had stripped it's thread into the vertical aluminum tube. Temp fix while on hols was gaffer tape to stop the screw coming out. Lasting (hopefully) fix was just a thicker screw. Fairly easy.
2/ The extension handle was sticking and I worked out the reason was that the outer aluminium tube was dented. I removed the extension handle assembly and managed to treat the dents with a combination of a nut driver/ socket on a screwdriver - just small enough to get into the undented tube - and a small hammer to gently tap out the dents from the outside. The socket was inside the tube to stop it deforming inwards. By rotating the socket as I pulled it out, I managed to avoid getting the socket stuck in the aluminium tube. Once dents reduced and extension handle action was easier, I reassembled the handle into the wheelie bag. This was quite hard - but succeeded eventually!
Tom4G - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 156
过去 30 天: 1,009
总计 7,341
