跳转到主内容
加入维修社区 - 创建账户
Opening Procedure
你所需要的
  1. Opening Procedure, Power down your watch: 步骤 1 中的图像 1,2 Opening Procedure, Power down your watch: 步骤 1 中的图像 2,2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    询问修复机器人
    添加评论
  2. Opening Procedure, Loosen the adhesive: 步骤 2 中的图像 1,1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    询问修复机器人
    添加评论
  3. Opening Procedure, Insert an opening pick: 步骤 3 中的图像 1,3 Opening Procedure, Insert an opening pick: 步骤 3 中的图像 2,3 Opening Procedure, Insert an opening pick: 步骤 3 中的图像 3,3
    • Insert an opening pick into the recess between the watch frame and the top edge of the back cover.
    • Push the opening pick to create a gap between the back cover and the watch frame.
    询问修复机器人
    添加评论
  4. Opening Procedure, Pry up the back cover assembly: 步骤 4 中的图像 1,3 Opening Procedure, Pry up the back cover assembly: 步骤 4 中的图像 2,3 Opening Procedure, Pry up the back cover assembly: 步骤 4 中的图像 3,3
    • Twist the opening pick to widen the gap between the back cover assembly and the watch frame.
    • Pry upward to loosen the back cover assembly.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the motherboard.
    询问修复机器人
    添加评论
  5. Opening Procedure, Free the back cover assembly: 步骤 5 中的图像 1,2 Opening Procedure, Free the back cover assembly: 步骤 5 中的图像 2,2
    • Carefully lift up the bottom edge of the back cover assembly to make sure it isn't adhered to the watch frame anymore.
    • Avoid straining or tearing the sensor or battery cables.
    询问修复机器人
    添加评论
  6. Opening Procedure, Open the watch: 步骤 6 中的图像 1,2 Opening Procedure, Open the watch: 步骤 6 中的图像 2,2
    • Grab the back cover assembly and carefully bring it into an upright position next to the watch housing.
    询问修复机器人
    添加评论
  7. Opening Procedure, Disconnect the battery cable: 步骤 7 中的图像 1,2 Opening Procedure, Disconnect the battery cable: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    询问修复机器人
    添加评论
  8. Opening Procedure, Disconnect the sensor cable: 步骤 8 中的图像 1,2 Opening Procedure, Disconnect the sensor cable: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the sensor cable by prying the connector straight up from its socket.
    询问修复机器人
    添加评论
  9. Opening Procedure, Remove the back cover assembly: 步骤 9 中的图像 1,2 Opening Procedure, Remove the back cover assembly: 步骤 9 中的图像 2,2
    • Remove the back cover assembly.
    询问修复机器人
    添加评论
结论
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch E3 answers community for help.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Dominik Schnabelrauch
于11/23/16注册
260,173 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了26,593篇指南
1指南评论
I appreciate the details and sequence of photos. I hope I won't need this guide, but it's comforting to know you put this together!
BruceG - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 47
总计 724
