跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch OLED Model Screen OLED Assembly Replacement
你所需要的
  1. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 3,3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    询问修复机器人
    添加评论
  2. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 3,3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    询问修复机器人
    添加评论
  3. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the top screw: 步骤 3 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the top screw: 步骤 3 中的图像 2,2
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
    添加评论
  4. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the bottom screws: 步骤 4 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the bottom screws: 步骤 4 中的图像 2,2
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
    询问修复机器人
    添加评论
  5. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the right screw: 步骤 5 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the right screw: 步骤 5 中的图像 2,2
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
    添加评论
  6. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the left screw: 步骤 6 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the left screw: 步骤 6 中的图像 2,2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
    添加评论
  7. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Open the kickstand: 步骤 7 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Open the kickstand: 步骤 7 中的图像 2,2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    询问修复机器人
    添加评论
  8. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the back-side screws: 步骤 8 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the back-side screws: 步骤 8 中的图像 2,2
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
    添加评论
  9. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the rear case: 步骤 9 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the rear case: 步骤 9 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the rear case: 步骤 9 中的图像 3,3
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
    添加评论
  10. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the shield plate's tape: 步骤 10 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the shield plate's tape: 步骤 10 中的图像 2,2
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
    添加评论
  11. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 11 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 11 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
    询问修复机器人
    添加评论
  12. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the primary Wi-Fi antenna: 步骤 12 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the primary Wi-Fi antenna: 步骤 12 中的图像 2,2
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
    询问修复机器人
    添加评论
  13. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 3,3
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
    询问修复机器人
    添加评论
  14. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the primary Wi-Fi antenna: 步骤 14 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the primary Wi-Fi antenna: 步骤 14 中的图像 2,2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
    询问修复机器人
    添加评论
  15. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 3,3
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
    添加评论
  16. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 16 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 16 中的图像 2,2
    • Remove the primary Wi-Fi antenna.
    询问修复机器人
    添加评论
  17. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the secondary Wi-Fi antenna: 步骤 17 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the secondary Wi-Fi antenna: 步骤 17 中的图像 2,2
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
    询问修复机器人
    添加评论
  18. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 步骤 18 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 步骤 18 中的图像 2,2
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
    询问修复机器人
    添加评论
  19. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the secondary Wi-Fi antenna: 步骤 19 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the secondary Wi-Fi antenna: 步骤 19 中的图像 2,2
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
    询问修复机器人
    添加评论
  20. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 3,3
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
    添加评论
  21. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 21 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 21 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 21 中的图像 3,3
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
    询问修复机器人
    添加评论
  22. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the shield plate: 步骤 22 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the shield plate: 步骤 22 中的图像 2,2
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
    询问修复机器人
    添加评论
  23. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 23 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 23 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Thermal Putty
    $9.95
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    添加评论
  24. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the battery: 步骤 24 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the battery: 步骤 24 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery.
    添加评论
  25. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the tape: 步骤 25 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the tape: 步骤 25 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the tape: 步骤 25 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
    询问修复机器人
    添加评论
  26. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the daughterboard: 步骤 26 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the daughterboard: 步骤 26 中的图像 2,2
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
    询问修复机器人
    添加评论
  27. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the daughterboard: 步骤 27 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the daughterboard: 步骤 27 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the daughterboard: 步骤 27 中的图像 3,3
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    询问修复机器人
    添加评论
  28. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the heat sink: 步骤 28 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the heat sink: 步骤 28 中的图像 2,2
    • Use a Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    询问修复机器人
    添加评论
  29. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the heat sink: 步骤 29 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the heat sink: 步骤 29 中的图像 2,2
    • Insert a spudger between the heat sink's bracket and the motherboard.
    • Pry up with the spudger to separate the heat sink from the motherboard.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    询问修复机器人
    添加评论
  30. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 30 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 30 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 30 中的图像 3,3
    • Insert a spudger in the gap between the fan and the heat sink.
    • Pry up with the spudger to separate the heat sink from the adhesive beneath it.
    • Remove the heat sink.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    添加评论
  31. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the fan's ZIF connector: 步骤 31 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the fan's ZIF connector: 步骤 31 中的图像 2,2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
    询问修复机器人
    添加评论
  32. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 32 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 32 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
    询问修复机器人
    添加评论
  33. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the fan: 步骤 33 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the fan: 步骤 33 中的图像 2,2
    • Use a Phillips driver to remove the three 3 mm screws securing the fan to the frame.
    询问修复机器人
    添加评论
  34. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the fan: 步骤 34 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the fan: 步骤 34 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the fan: 步骤 34 中的图像 3,3
    • Use a spudger to lift the fan out straight out of the frame.
    • Remove the fan.
    询问修复机器人
    添加评论
  35. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the power button board's ZIF connector: 步骤 35 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the power button board's ZIF connector: 步骤 35 中的图像 2,2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power button board's ZIF connector.
    询问修复机器人
    添加评论
  36. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 36 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 36 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to pull the power button board cable straight out of its connector on the motherboard.
    询问修复机器人
    添加评论
  37. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: 步骤 37 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: 步骤 37 中的图像 2,2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the right Joy-Con sensor rail's ZIF connector.
    询问修复机器人
    添加评论
  38. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 38 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 38 中的图像 2,2
    • Use a pair of tweezers to pull the right Joy-Con sensor rail's cable straight out of its connector on the motherboard.
    询问修复机器人
    添加评论
  39. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the right Joy-Con sensor rail: 步骤 39 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the right Joy-Con sensor rail: 步骤 39 中的图像 2,2
    • Use a Phillips driver to remove the two 3.8 mm screws securing the left Joy-Con sensor rail to the frame.
    询问修复机器人
    添加评论
  40. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the right Joy-Con sensor rail: 步骤 40 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the right Joy-Con sensor rail: 步骤 40 中的图像 2,2
    • Remove the right Joy-Con sensor rail.
    询问修复机器人
    添加评论
  41. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the display's ZIF connector: 步骤 41 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the display's ZIF connector: 步骤 41 中的图像 2,2
    • Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
    询问修复机器人
    添加评论
  42. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 42 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 42 中的图像 2,2
    • Use a pair of tweezers to pull the display cable straight out of its connector on the motherboard.
    询问修复机器人
    添加评论
  43. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the right speaker: 步骤 43 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the right speaker: 步骤 43 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the right speaker: 步骤 43 中的图像 3,3
    • Use tweezers, or your fingers, to pull the left speaker's JST connector out of its socket.
    询问修复机器人
    添加评论
  44. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the left speaker: 步骤 44 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the left speaker: 步骤 44 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the left speaker: 步骤 44 中的图像 3,3
    • Use tweezers, or your fingers, to pull the right speaker's JST connector out of its socket.
    询问修复机器人
    添加评论
  45. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the left Joy-Con sensor rail's ZIF connector: 步骤 45 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Disconnect the left Joy-Con sensor rail's ZIF connector: 步骤 45 中的图像 2,2
    询问修复机器人
    添加评论
  46. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 46 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 46 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 46 中的图像 3,3
    询问修复机器人
    添加评论
  47. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the motherboard: 步骤 47 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the motherboard: 步骤 47 中的图像 2,2
    • Use a Phillips driver to remove the five screws securing the midframe to the frame:
    • Three 3 mm screws
    • Two 4.4 mm screws
    询问修复机器人
    添加评论
  48. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the motherboard: 步骤 48 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the motherboard: 步骤 48 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the motherboard: 步骤 48 中的图像 3,3
    • Insert a spudger between the motherboard and the frame.
    • Pry up with the spudger to separate the motherboard from the frame.
    • Remove the motherboard.
    询问修复机器人
    添加评论
  49. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Left Joy-Con Sensor Rail: 步骤 49 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Left Joy-Con Sensor Rail: 步骤 49 中的图像 2,2
    • Use your fingers to gently peel back the left Joy-Con sensor rail's cable from the frame.
    询问修复机器人
    添加评论
  50. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the left Joy-Con sensor rail: 步骤 50 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the left Joy-Con sensor rail: 步骤 50 中的图像 2,2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the frame.
    询问修复机器人
    添加评论
  51. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the left Joy-Con sensor rail: 步骤 51 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the left Joy-Con sensor rail: 步骤 51 中的图像 2,2
    • Remove the left Joy-Con sensor rail.
    询问修复机器人
    添加评论
  52. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the bottom rail: 步骤 52 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Unfasten the bottom rail: 步骤 52 中的图像 2,2
    • Use a Phillips driver to remove the two 3 mm screws securing the bottom rail to the frame.
    添加评论
  53. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the bottom rail: 步骤 53 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the bottom rail: 步骤 53 中的图像 2,2
    • Remove the bottom rail.
    添加评论
  54. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Separate the power board button's adhesive: 步骤 54 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Separate the power board button's adhesive: 步骤 54 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Separate the power board button's adhesive: 步骤 54 中的图像 3,3
    • Use your fingers to gently peel back the power board button's cable from the frame.
    询问修复机器人
    添加评论
  55. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the power button board: 步骤 55 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the power button board: 步骤 55 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the power button board: 步骤 55 中的图像 3,3
    • Use your fingers to pull the power button board out from its plastic slots in the frame.
    • Remove the power button board.
    询问修复机器人
    添加评论
  56. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Apply isopropyl alcohol: 步骤 56 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Apply isopropyl alcohol: 步骤 56 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Adhesive Remover
    $19.99
    询问修复机器人
    添加评论
  57. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 57 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 57 中的图像 2,2
    • Tilt the top edge of the device upward to allow the isopropyl alcohol to work its way underneath the battery.
    • Hold for 1-2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
    询问修复机器人
    添加评论
  58. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Separate the battery's adhesive: 步骤 58 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Separate the battery's adhesive: 步骤 58 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Separate the battery's adhesive: 步骤 58 中的图像 3,3
    • Insert an opening pick into the gap between the battery and the wall of the battery well.
    • Carefully dig the tip of the opening pick underneath the battery and slide it along the edge to begin slicing the adhesive.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    询问修复机器人
    添加评论
  59. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 59 中的图像 1,1
    • Leave the opening pick in place and apply a few more drops of adhesive remover or isopropyl alcohol inside the battery well.
    • Tilt the top edge of the device upward and wait 1-2 minutes for the isopropyl alcohol to weaken the adhesive.
    询问修复机器人
    添加评论
  60. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 60 中的图像 1,2 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 60 中的图像 2,2
    • Continue sliding the opening pick deeper along the top edge of the battery, slicing more of the adhesive underneath.
    询问修复机器人
    添加评论
  61. Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 61 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 61 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement: 步骤 61 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Once there's enough room, insert a plastic card underneath the battery and slowly pry the battery up.
    • Apply more isopropyl alcohol if you have difficulty prying.
    • Be careful not to bend the battery as you pry.
    询问修复机器人
    添加评论
  62. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the battery: 步骤 62 中的图像 1,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the battery: 步骤 62 中的图像 2,3 Nintendo Switch OLED Model Screen OLED Assembly Replacement, Remove the battery: 步骤 62 中的图像 3,3
    • Pry up with the plastic card to completely separate the battery's adhesive.
    • Remove the battery.
    • Use adhesive remover or isopropyl alcohol and a microfiber cloth to clean up any remaining adhesive left behind in the battery well before you install the new battery.
    • If your new battery does not come with pre-installed adhesive, follow this guide to install pre-cut adhesive on the bottom of the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    询问修复机器人
    添加评论
  63. Nintendo Switch OLED Model Screen OLED Assembly Replacement, Only the screen OLED assembly remains: 步骤 63 中的图像 1,1
    • You're now left with the Screen OLED Assembly.
    询问修复机器人
    添加评论
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
245,452 声望
创作了1,203篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了32,107篇指南
2指南评论
Hi Alex (or anyone who knows and wants to answer), why do you indicate in point 61 to replace the battery and not reuse it after removal? Should it be replaced even if the console is practically new and has only been used for a few weeks?
Mario Rega - 回复 分享
you could've punctured it, severed the wires, or bent it during removal. even if none of that happened, it would certainly be soaked in isopropyl alcohol since dissolving the strong glue underneath requires it. If you reuse the old battery, then it might light your house up while you're docking or charging it. I'd certainly not want to use a console with a battery soaked with alcohol.
Leooooo1061 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 91
过去 30 天: 447
总计 17,607
