跳转到主内容
Motorola Edge (2022) Display Replacement
你所需要的
  1. Motorola Edge (2022) Display Replacement, Heat the right edge: 步骤 1 中的图像 1,1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Display Replacement, Separate the right adhesive: 步骤 2 中的图像 1,3 Motorola Edge (2022) Display Replacement, Separate the right adhesive: 步骤 2 中的图像 2,3 Motorola Edge (2022) Display Replacement, Separate the right adhesive: 步骤 2 中的图像 3,3
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge (2022) Display Replacement, Slice the right adhesive: 步骤 3 中的图像 1,2 Motorola Edge (2022) Display Replacement, Slice the right adhesive: 步骤 3 中的图像 2,2
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  4. Motorola Edge (2022) Display Replacement, Heat the bottom edge: 步骤 4 中的图像 1,1
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  5. Motorola Edge (2022) Display Replacement, Slice the bottom right corner adhesive: 步骤 5 中的图像 1,2 Motorola Edge (2022) Display Replacement, Slice the bottom right corner adhesive: 步骤 5 中的图像 2,2
    • Rotate the pick around the bottom right corner to slice the adhesive.
  6. Motorola Edge (2022) Display Replacement: 步骤 6 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 6 中的图像 2,2
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  7. Motorola Edge (2022) Display Replacement: 步骤 7 中的图像 1,1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  8. Motorola Edge (2022) Display Replacement: 步骤 8 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 8 中的图像 2,2
    • Rotate the pick around the bottom left corner to slice the adhesive.
  9. Motorola Edge (2022) Display Replacement: 步骤 9 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 9 中的图像 2,2
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  10. Motorola Edge (2022) Display Replacement: 步骤 10 中的图像 1,1
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  11. Motorola Edge (2022) Display Replacement: 步骤 11 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 11 中的图像 2,2
    • Rotate the pick around the top left corner to slice the adhesive.
  12. Motorola Edge (2022) Display Replacement: 步骤 12 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 12 中的图像 2,2
    • Slide the pick along the top edge to slice the adhesive.
  13. Motorola Edge (2022) Display Replacement, Remove the back cover: 步骤 13 中的图像 1,2 Motorola Edge (2022) Display Replacement, Remove the back cover: 步骤 13 中的图像 2,2
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
  14. Motorola Edge (2022) Display Replacement, Separate the camera bezel adhesive: 步骤 14 中的图像 1,2 Motorola Edge (2022) Display Replacement, Separate the camera bezel adhesive: 步骤 14 中的图像 2,2
    • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
    • Slide the pick back and forth along the edge to slice the adhesive.
  15. Motorola Edge (2022) Display Replacement: 步骤 15 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 15 中的图像 2,2
    • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
  16. Motorola Edge (2022) Display Replacement, Remove the camera bezel: 步骤 16 中的图像 1,2 Motorola Edge (2022) Display Replacement, Remove the camera bezel: 步骤 16 中的图像 2,2
    • Lift the camera bezel from the phone and remove it.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
    • Follow this guide to replace the back cover and camera bezel adhesive.
  17. Motorola Edge (2022) Display Replacement, Detach the left wireless charging coil tape: 步骤 17 中的图像 1,2 Motorola Edge (2022) Display Replacement, Detach the left wireless charging coil tape: 步骤 17 中的图像 2,2
    • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
    • Slowly lift the spudger up until the tape detaches from the speaker.
  18. Motorola Edge (2022) Display Replacement, Detach the right wireless charging coil tape: 步骤 18 中的图像 1,2 Motorola Edge (2022) Display Replacement, Detach the right wireless charging coil tape: 步骤 18 中的图像 2,2
    • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
    • Slowly lift the spudger up until the tape detaches.
  19. Motorola Edge (2022) Display Replacement: 步骤 19 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 19 中的图像 2,2
    • Use a Phillips screwdriver to remove the 10 4 mm screws securing the motherboard cover.
  20. Motorola Edge (2022) Display Replacement: 步骤 20 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 20 中的图像 2,2
    • Adhesive secures the motherboard cover to the motherboard itself.
    • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
  21. Motorola Edge (2022) Display Replacement: 步骤 21 中的图像 1,3 Motorola Edge (2022) Display Replacement: 步骤 21 中的图像 2,3 Motorola Edge (2022) Display Replacement: 步骤 21 中的图像 3,3
    • Insert an opening tool between the motherboard cover and the midframe.
    • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  22. Motorola Edge (2022) Display Replacement, Remove the motherboard cover: 步骤 22 中的图像 1,3 Motorola Edge (2022) Display Replacement, Remove the motherboard cover: 步骤 22 中的图像 2,3 Motorola Edge (2022) Display Replacement, Remove the motherboard cover: 步骤 22 中的图像 3,3
    • Slowly pull the motherboard cover up and away from the phone and remove it.
  23. Motorola Edge (2022) Display Replacement, Move the graphite film: 步骤 23 中的图像 1,2 Motorola Edge (2022) Display Replacement, Move the graphite film: 步骤 23 中的图像 2,2
    • Use your fingers to move the graphite film that covers the battery out of the way.
  24. Motorola Edge (2022) Display Replacement, Disconnect the battery: 步骤 24 中的图像 1,2 Motorola Edge (2022) Display Replacement, Disconnect the battery: 步骤 24 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  25. Motorola Edge (2022) Display Replacement, Apply isopropyl alcohol: 步骤 25 中的图像 1,2 Motorola Edge (2022) Display Replacement, Apply isopropyl alcohol: 步骤 25 中的图像 2,2
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the gaps along the battery's edges.
    • Tilt the device as you apply alcohol to help it flow under the battery.
    • Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
    • Only apply a few drops initially and apply more as necessary. If you apply too much alcohol, it may overflow onto the motherboard and daughterboard.
  26. Motorola Edge (2022) Display Replacement, Separate the battery's adhesive: 步骤 26 中的图像 1,3 Motorola Edge (2022) Display Replacement, Separate the battery's adhesive: 步骤 26 中的图像 2,3 Motorola Edge (2022) Display Replacement, Separate the battery's adhesive: 步骤 26 中的图像 3,3
    • Take care not to puncture or bend the battery during the removal process—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Apply a suction cup to the battery.
    • Pull up on the suction cup with strong, steady force to create a gap between the battery and the frame.
    • If the battery doesn't budge, apply a few more drops of isopropyl alcohol and try again.
    • Continue to pull up on the suction cup while sliding the opening pick back and forth to slice the adhesive. Continue this process until the battery separates from the frame.
  27. Motorola Edge (2022) Display Replacement, Remove the battery: 步骤 27 中的图像 1,2 Motorola Edge (2022) Display Replacement, Remove the battery: 步骤 27 中的图像 2,2
    • Remove the battery from the midframe.
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Follow this guide to install new battery adhesive.
  28. Motorola Edge (2022) Display Replacement, Transfer the battery's foam strip: 步骤 28 中的图像 1,3 Motorola Edge (2022) Display Replacement, Transfer the battery's foam strip: 步骤 28 中的图像 2,3 Motorola Edge (2022) Display Replacement, Transfer the battery's foam strip: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to remove the foam strip from the battery's bottom edge.
    • Before installing your new battery, apply the foam strip to it.
  29. Motorola Edge (2022) Display Replacement, Place the motherboard cover back on: 步骤 29 中的图像 1,2 Motorola Edge (2022) Display Replacement, Place the motherboard cover back on: 步骤 29 中的图像 2,2
    • Before continuing your repair, place the motherboard cover back on the phone to protect the cameras and motherboard.
  30. Motorola Edge (2022) Display Replacement, Place the back cover back on: 步骤 30 中的图像 1,2 Motorola Edge (2022) Display Replacement, Place the back cover back on: 步骤 30 中的图像 2,2
    • Place the back cover on the phone to secure the motherboard cover.
  31. Motorola Edge (2022) Display Replacement, Loosen the display adhesive: 步骤 31 中的图像 1,1
    • Flip your phone over to access the display.
    • Apply a heated iOpener to the display for at least five minutes to loosen the adhesive underneath.
  32. Motorola Edge (2022) Display Replacement, Insert an opening pick: 步骤 32 中的图像 1,3 Motorola Edge (2022) Display Replacement, Insert an opening pick: 步骤 32 中的图像 2,3 Motorola Edge (2022) Display Replacement, Insert an opening pick: 步骤 32 中的图像 3,3
    • Once the display is hot to the touch, apply a suction handle to the bottom of the display as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the display.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the display and the frame.
    • The display adhesive is very strong, so this may take multiple attempts. If you're having trouble, reheat the display and try again.
    • Insert an opening pick into the gap between the frame and the display.
    • Do not insert more than 3 mm of the pick to avoid damaging the display ribbon cable.
  33. Motorola Edge (2022) Display Replacement: 步骤 33 中的图像 1,3 Motorola Edge (2022) Display Replacement: 步骤 33 中的图像 2,3 Motorola Edge (2022) Display Replacement: 步骤 33 中的图像 3,3
    • When slicing the bottom adhesive, don't insert the opening pick more than 3 mm to avoid damaging the fingerprint sensor.
    • Slide the opening pick along the bottom edge of the phone to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
  34. Motorola Edge (2022) Display Replacement: 步骤 34 中的图像 1,3 Motorola Edge (2022) Display Replacement: 步骤 34 中的图像 2,3 Motorola Edge (2022) Display Replacement: 步骤 34 中的图像 3,3
    • Don't insert the opening pick more than 6 mm to avoid damaging the heat spreader.
    • Insert a second opening pick near the bottom right corner and slide it along the right edge to slice the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from resealing.
  35. Motorola Edge (2022) Display Replacement: 步骤 35 中的图像 1,3 Motorola Edge (2022) Display Replacement: 步骤 35 中的图像 2,3 Motorola Edge (2022) Display Replacement: 步骤 35 中的图像 3,3
    • Insert a third opening pick at the top right corner of the display.
    • When slicing near the front facing camera, don't insert the opening pick more than 2 mm to avoid damaging the earpiece speaker cutout and the front camera.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick inserted in the top left corner to prevent the adhesive from resealing.
  36. Motorola Edge (2022) Display Replacement: 步骤 36 中的图像 1,3 Motorola Edge (2022) Display Replacement: 步骤 36 中的图像 2,3 Motorola Edge (2022) Display Replacement: 步骤 36 中的图像 3,3
    • Insert a fourth opening pick in the top left corner of the display.
    • Don't insert the pick more than 2 mm to avoid damaging the heat spreader and the fingerprint sensor.
    • Slide the pick along the left edge to slice the adhesive.
    • The screen should be detached at this point.
  37. Motorola Edge (2022) Display Replacement, Remove the back cover: 步骤 37 中的图像 1,2 Motorola Edge (2022) Display Replacement, Remove the back cover: 步骤 37 中的图像 2,2
    • Flip your phone over to access the back cover.
    • Remove the opening picks and back cover from the phone.
  38. Motorola Edge (2022) Display Replacement: 步骤 38 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 38 中的图像 2,2
    • Remove the motherboard cover.
    • The wireless charging coil may have adhered to the battery adhesive. If it has, pull up gently to detach it.
  39. Motorola Edge (2022) Display Replacement: 步骤 39 中的图像 1,2 Motorola Edge (2022) Display Replacement: 步骤 39 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the display cable's press connector.
  40. Motorola Edge (2022) Display Replacement, Loosen the display cable adhesive: 步骤 40 中的图像 1,1
  41. Motorola Edge (2022) Display Replacement, Separate the cable adhesive: 步骤 41 中的图像 1,3 Motorola Edge (2022) Display Replacement, Separate the cable adhesive: 步骤 41 中的图像 2,3 Motorola Edge (2022) Display Replacement, Separate the cable adhesive: 步骤 41 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grip the display cable just below the press connector.
    • Gently pull the display cable towards the bottom of the phone until it's freed from its space under the motherboard.
    • Continue pulling the cable to separate its adhesive.
  42. Motorola Edge (2022) Display Replacement, Remove the display: 步骤 42 中的图像 1,3 Motorola Edge (2022) Display Replacement, Remove the display: 步骤 42 中的图像 2,3 Motorola Edge (2022) Display Replacement, Remove the display: 步骤 42 中的图像 3,3
    • The display may have lightly readhered to the frame during the last few steps. If it has, use an opening pick to detach the display from the frame before continuing.
    • Before removing the display, make sure that the display's ribbon cable is completely detached from the adhesive on the midframe.
    • Gently pull up on the display and thread the ribbon cable through the hole in midframe to remove the display.
  43. Motorola Edge (2022) Display Replacement: 步骤 43 中的图像 1,1
    • During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
    • Follow this guide if you're using a precut adhesive card.
结论
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
Spencer Day
于09/14/22注册
55,203 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 46
总计 915
