简介
Follow this guide to replace the camera bezel and back cover adhesive pads in your Motorola phone. This process is a general procedure that applies to any Motorola phone with a plastic back cover and separate camera bezel.
If your back cover comes off in one piece, follow this guide.
你所需要的
Use the flat end of a spudger or your fingers to scrape and remove the old adhesive from the phone body.
Peel and remove the white adhesive backing from the camera bezel's new adhesive pad.
Lay the adhesive pad over the cameras, with the sticky side facing upward.
Lay the camera bezel over the cameras and press it onto the adhesive pad.
Lift the camera bezel and adhesive pad from the phone.
Place the bezel over the cameras.
Press firmly to adhere the bezel to the phone body.
Use the flat end of a spudger or your fingers to remove the old adhesive from the back cover.
If you're having trouble removing the adhesive, apply a heated iOpener to soften the adhesive.
Peel and remove the white adhesive backing from the back cover's new adhesive pad.
Line up the new adhesive on the phone and lay it onto the frame.
Press down firmly on the adhesive along the perimeter of the midframe to secure it.
Grab and peel the blue protective film, beginning with the cutout.
Remove the protective film.
Align the back cover over the phone.
Press down firmly along the perimeter of the cover and around the camera bezel to secure it with the new adhesive.
3等其他人完成本指南。
