跳转到主内容
How to Replace the Adhesive for Your Motorola Phone
你所需要的
  1. How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: 步骤 1 中的图像 1,3 How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: 步骤 1 中的图像 2,3 How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: 步骤 1 中的图像 3,3
    • Use the flat end of a spudger or your fingernail to scrape and remove the old adhesive from the phone body and back cover.
    • Pay attention to areas around the cameras and outer edge of the phone. Any remaining chunks will prevent your part from aligning properly.
  2. How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: 步骤 2 中的图像 1,2 How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to any remaining adhesive.
    • Use a microfiber cloth to remove the remaining adhesive.
    • If you are having trouble removing the adhesive, apply a few drops of alcohol to the adhesive and scrape it with a spudger.
  3. How to Replace the Adhesive for Your Motorola Phone, Remove the protective film: 步骤 3 中的图像 1,1
    • Remove the clear protective film from the new adhesive.
  4. How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: 步骤 4 中的图像 1,2 How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: 步骤 4 中的图像 2,2
    • Be very careful during this step! The adhesive is very sticky, and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Before placing the adhesive on the frame, use the cameras to ensure the adhesive's proper alignment.
    • Lay the adhesive on the frame.
    • Press down firmly on the adhesive along the perimeter of the midframe to secure it to the phone.
  5. How to Replace the Adhesive for Your Motorola Phone: 步骤 5 中的图像 1,2 How to Replace the Adhesive for Your Motorola Phone: 步骤 5 中的图像 2,2
    • Grab the blue protective film's pull tab on the top of the phone and pull towards the bottom of the phone.
    • Pull carefully so the adhesive does not separate from the phone.
  6. How to Replace the Adhesive for Your Motorola Phone, Put the back cover on: 步骤 6 中的图像 1,1
    • If your phone has a rear fingerprint sensor, make sure to secure it in its cutout on the back cover before proceeding.
    • Align the back cover over the back of the phone.
    • Press down firmly for one minute along the perimeter of the back cover and camera bezel to secure it with the new adhesive.
终点
Spencer Day
于09/14/22注册
149,568 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,623篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 41
总计 1,722
