跳转到主内容
How to Test the Hardware on Your Motorola Phone
  1. How to Test the Hardware on Your Motorola Phone, Open the apps menu: 步骤 1 中的图像 1,1
    • From the home screen, swipe up from the bottom of the phone to open the applications menu.
  2. How to Test the Hardware on Your Motorola Phone, Open the device help app: 步骤 2 中的图像 1,1
    • Select the "Device Help" application from the menu.
  3. How to Test the Hardware on Your Motorola Phone, Select device diagnosis: 步骤 3 中的图像 1,1
    • Select "Device diagnosis" from the menu.
  4. How to Test the Hardware on Your Motorola Phone, Select hardware test: 步骤 4 中的图像 1,1
    • Select "Hardware test" from the menu.
  5. How to Test the Hardware on Your Motorola Phone: 步骤 5 中的图像 1,1
    • You can now select which hardware test you would like to run, or you can run a full hardware test.
终点
20等其他人完成本指南。
Spencer Day
于09/14/22注册
154,760 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
6指南评论
is built using the open source software libraries listed below. These libraries are distributed under associated licenses, acknowledgements and required copyright notices also listed below:
Michael Lassiter - 回复
Thank you for your help and approval
What if my Motorola phone doesn't have the device help in the app menu then how do I go about running diagnostics on it OH and Just so you know I don't have any mobile data connection so I can't use the phone codes.
Sean Jacob Higgins - 回复
Having problems with my phone
Lisa Jablon - 回复
I want to see how I could take apps off Motorola moto04
Antonio “Mono” Cabrera - 回复
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 170
过去 30 天: 882
总计 54,027
