跳转到主内容
How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone
你所需要的
  1. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Enter the CQATest menu: 步骤 1 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Enter the CQATest menu: 步骤 1 中的图像 2,2
    • Open the phone app.
    • Open the dial screen.
    • Enter *#*#2486#*#* on the dial pad.
    • If the CQATest menu doesn't come up immediately, press "Call".
  2. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Select the CQA menu mode: 步骤 2 中的图像 1,1
    • If any pop-ups appear, allow them.
    • Select "CQA Menu Mode" from the options.
  3. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Select the sensor option: 步骤 3 中的图像 1,1
    • Select "Sensor" from the options.
  4. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Select Fingerprint Egis FOD SMTP: 步骤 4 中的图像 1,1
    • Select "Fingerprint Egis Fod SMTP" from the options.
  5. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 5 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 5 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 5 中的图像 3,3
    • Press "START" on the top left corner of the screen.
    • You should see a menu that says "Normal Scan: ok, click NEXT" with a list of tests under it.
    • If any of the tests failed, restart from the beginning of this guide.
    • Press "NEXT" on the top right corner.
    • Wait until the message at the top of the screen changes to "Put FLESH FLAT, click NEXT".
  6. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the indented pink box: 步骤 6 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the indented pink box: 步骤 6 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the indented pink box: 步骤 6 中的图像 3,3
    • For the next two steps, make sure you're using the pink box that has a small square indented in it and not the pink box that has grooves.
    • With the indented side facing down, place the pink box over the red box on the bottom of the screen.
    • Make sure the pink box covers the red box as much as possible. Deviations could result in a "Fail" result or an inaccurate calibration.
  7. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 7 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 7 中的图像 2,2
    • Press down on the pink box with your thumb.
    • While pressing down on the box, use your other hand to select "NEXT" on the top right of the phone.
    • Continue pressing down on the box until the message at the top of the screen changes to "Put BLACK FLAT, click NEXT".
  8. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the black box: 步骤 8 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the black box: 步骤 8 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the black box: 步骤 8 中的图像 3,3
    • With the indented side facing down, place the black box over the red box on the bottom of the screen.
    • Make sure the black box covers the red box as much as possible. Deviations could result in a "Fail" result or an inaccurate calibration.
  9. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 9 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 9 中的图像 2,2
    • Press down on the black box with your thumb.
    • Continue pressing down on the box until the message at the top of the screen changes to "Put FLESH CHART, click NEXT".
  10. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the grooved pink box: 步骤 10 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the grooved pink box: 步骤 10 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the grooved pink box: 步骤 10 中的图像 3,3
    • For the next two steps, make sure you're using the pink box that has grooves and not the pink box that has a small square indented in it.
    • With the grooved side down and the grooves vertical, place the pink box over the red box on the bottom of the screen.
  11. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 11 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 11 中的图像 2,2
    • Continue pressing down on the box until you get a message about the calibration results.
  12. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 12 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: 步骤 12 中的图像 2,2
    • You will see "Calibration test: ok" if the calibration was successful.
    • If you see "Calibration test: fail" at the top of the screen, restart from the beginning of this guide.
结论
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
55,203 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 74
过去 30 天: 389
总计 4,899
