跳转到主内容
How to Replace the Battery Adhesive for Your Motorola Phone
你所需要的
  1. How to Replace the Battery Adhesive for Your Motorola Phone, Remove the remaining adhesive: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    • If there's any alcohol remaining from battery removal, use a lint-free cloth to wipe it up or allow the alcohol to dry off before installing new adhesive.
    • Before performing this repair, ensure the display cable is tucked in its space under the motherboard. If the cable is sticking out, the new adhesive won't be able to lay completely flat.
    • Use tweezers to remove all of the old adhesive from the battery's recess.
  2. How to Replace the Battery Adhesive for Your Motorola Phone, Find the adhesive's proper orientation: 步骤 2 中的图像 1,3 How to Replace the Battery Adhesive for Your Motorola Phone, Find the adhesive's proper orientation: 步骤 2 中的图像 2,3 How to Replace the Battery Adhesive for Your Motorola Phone, Find the adhesive's proper orientation: 步骤 2 中的图像 3,3
    • Before removing any liners, use the guide lines on the new adhesive to find the proper orientation in the battery recess.
  3. How to Replace the Battery Adhesive for Your Motorola Phone, Expose the adhesive: 步骤 3 中的图像 1,2 How to Replace the Battery Adhesive for Your Motorola Phone, Expose the adhesive: 步骤 3 中的图像 2,2
    • Use the pull tab on the blue liner to separate the adhesive from the white liner.
  4. How to Replace the Battery Adhesive for Your Motorola Phone, Apply the new adhesive: 步骤 4 中的图像 1,3 How to Replace the Battery Adhesive for Your Motorola Phone, Apply the new adhesive: 步骤 4 中的图像 2,3 How to Replace the Battery Adhesive for Your Motorola Phone, Apply the new adhesive: 步骤 4 中的图像 3,3
    • Be very careful during this step! The adhesive is very sticky, and can't be repositioned once it sticks.
    • With the adhesive in its proper orientation, lay it sticky side down in the battery recess.
    • Use a spudger or your fingers to firmly press down on the blue liner to secure the new adhesive to the frame.
  5. How to Replace the Battery Adhesive for Your Motorola Phone: 步骤 5 中的图像 1,2 How to Replace the Battery Adhesive for Your Motorola Phone: 步骤 5 中的图像 2,2
    • Use the pull tab to peel the blue liner from the adhesive.
    • Make sure the adhesive is sticking to the frame and isn't being pulled up with the blue liner.
    • If the adhesive is being pulled up, lay it back down, press down firmly on it with a spudger or your fingers, and try again.
  6. How to Replace the Battery Adhesive for Your Motorola Phone: 步骤 6 中的图像 1,3 How to Replace the Battery Adhesive for Your Motorola Phone: 步骤 6 中的图像 2,3 How to Replace the Battery Adhesive for Your Motorola Phone: 步骤 6 中的图像 3,3
    • Before laying the battery in its recess, temporarily reconnect the battery's press connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
    • Lay the battery in its recess.
    • Firmly press down on the perimeter and center of the battery to adhere it to the frame.
  7. How to Replace the Battery Adhesive for Your Motorola Phone: 步骤 7 中的图像 1,2 How to Replace the Battery Adhesive for Your Motorola Phone: 步骤 7 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
结论
The battery is now ready for use. Return to your phone's repair guide and continue reassembly.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
149,840 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,639篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 49
总计 1,828
