跳转到主内容
Huawei Mate 8 Display Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch7 其他贡献者
最后更新于 April 2, 2025
没有估计
中等
Use this guide to replace the defective display of your Huawei Mate 8.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Huawei Mate 8 Display Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei Mate 8 Display Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Display Replacement: 步骤 2 中的图像 1,1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Display Replacement: 步骤 3 中的图像 1,2 Huawei Mate 8 Display Replacement: 步骤 3 中的图像 2,2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Display Replacement: 步骤 4 中的图像 1,3 Huawei Mate 8 Display Replacement: 步骤 4 中的图像 2,3 Huawei Mate 8 Display Replacement: 步骤 4 中的图像 3,3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 1,3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 2,3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 3,3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Display Replacement: 步骤 6 中的图像 1,3 Huawei Mate 8 Display Replacement: 步骤 6 中的图像 2,3 Huawei Mate 8 Display Replacement: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Display Replacement: 步骤 7 中的图像 1,1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Display Replacement: 步骤 8 中的图像 1,2 Huawei Mate 8 Display Replacement: 步骤 8 中的图像 2,2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Display Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Display Replacement, Battery: 步骤 10 中的图像 1,1
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
    • If the adhesive strip rips, grab and twist it around the tweezer tips a couple of times and then continue.
  11. Huawei Mate 8 Display Replacement: 步骤 11 中的图像 1,3 Huawei Mate 8 Display Replacement: 步骤 11 中的图像 2,3 Huawei Mate 8 Display Replacement: 步骤 11 中的图像 3,3
    • Do not bend or puncture the battery, damage to the cell can cause battery fires.
    • Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
    • Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
  12. Huawei Mate 8 Display Replacement: 步骤 12 中的图像 1,2 Huawei Mate 8 Display Replacement: 步骤 12 中的图像 2,2
    • Lift the top end of the battery to pull the battery off of the remaining adhesive strip.
    • When reassembling your phone, apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
    • Never reinstall a battery that has been bent or damaged during removal.
  13. Huawei Mate 8 Display Replacement, Display: 步骤 13 中的图像 1,1
    • Remove the four Phillips #00 screws holding the daughterboard and loudspeaker to the phone.
  14. Huawei Mate 8 Display Replacement: 步骤 14 中的图像 1,2 Huawei Mate 8 Display Replacement: 步骤 14 中的图像 2,2
    • Use the flat end of a spudger to disconnect the loudspeaker connector cable.
    • Use the tip of a spudger to lift the daughterboard from the phone.
  15. Huawei Mate 8 Display Replacement: 步骤 15 中的图像 1,2 Huawei Mate 8 Display Replacement: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Insert the flat end of a spudger under the loudspeaker at the gap on the left side.
    • Work the spudger under the loudspeaker to seperate it from the adhesive and remove the loudspeaker.
    • Use tweezers to take the vibration unit out of its housing.
  16. Huawei Mate 8 Display Replacement: 步骤 16 中的图像 1,1
    • Remove the eight Phillips #00 screws securing the motherboard to the phone.
  17. Huawei Mate 8 Display Replacement: 步骤 17 中的图像 1,2 Huawei Mate 8 Display Replacement: 步骤 17 中的图像 2,2
    • Remove the bracket from the rear camera flex cable.
    • Use tweezers to disconnect the antenna cable.
  18. Huawei Mate 8 Display Replacement: 步骤 18 中的图像 1,3 Huawei Mate 8 Display Replacement: 步骤 18 中的图像 2,3 Huawei Mate 8 Display Replacement: 步骤 18 中的图像 3,3
    • Use the flat end of a spudger to disconnect the volume and power flex cable on the bottom left side of the mainboard.
    • Work the flat end of a spudger under the top right side of the mainboard to pry it out.
    • Remove the mainboard.
  19. Huawei Mate 8 Display Replacement: 步骤 19 中的图像 1,2 Huawei Mate 8 Display Replacement: 步骤 19 中的图像 2,2
    • Remove the antenna interconnect cable.
    • Remove the power and volume switch assembly.
  20. Huawei Mate 8 Display Replacement: 步骤 20 中的图像 1,3 Huawei Mate 8 Display Replacement: 步骤 20 中的图像 2,3 Huawei Mate 8 Display Replacement: 步骤 20 中的图像 3,3
    • Use tweezers to remove the earpiece speaker.
    • Remove the red rubber gasket.
    • Remove the ambient light and proximity sensor.
结论
9等其他人完成本指南。
于11/23/16注册
231,682 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,765篇指南
1指南评论
Tidy. Really tidy like.
Marc Vestabule - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 112
总计 6,209
