跳转到主内容
加入维修社区 - 创建账户
How to Repaste a Laptop
你所需要的
    1. How to Repaste a Laptop, Power down and prepare your laptop: 步骤 1 中的图像 1,1
      • Completely power off and unplug your laptop before you start.
      • Close the display and flip the entire laptop upside-down.
      询问修复机器人
      添加评论
    2. How to Repaste a Laptop, Expose any hidden screws: 步骤 2 中的图像 1,2 How to Repaste a Laptop, Expose any hidden screws: 步骤 2 中的图像 2,2
      • If your laptop has hidden screws underneath rubber feet, use the tip of a spudger or an opening pick to remove them.
      • If any feet are adhered, it might help to lightly heat them with an iOpener or a hair dryer to soften the adhesive underneath.
      询问修复机器人
      添加评论
    3. How to Repaste a Laptop, Unfasten the back cover: 步骤 3 中的图像 1,2 How to Repaste a Laptop, Unfasten the back cover: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      FixMat
      $36.95
      • Use a screwdriver to remove the screws that secure the back cover.
      • Every laptop is different, and the types of fasteners used will vary.
      • Use the most snug-fitting screwdriver or bit size for your laptop.
      • A screwdriver or bit that's either too small or too big can strip the heads of screws. To extract a stripped screw, follow this guide.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
      询问修复机器人
      添加评论
    4. How to Repaste a Laptop, Pry up the back cover: 步骤 4 中的图像 1,2 How to Repaste a Laptop, Pry up the back cover: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      Suction Handle
      $2.95
      • Use the flat end of a spudger or an opening pick to pry up the back cover.
      • On laptops with extra tight back covers, a suction handle is a useful tool to help create a gap big enough to insert an opening pick.
      • Work your way around the whole perimeter of the laptop, twisting your tool as you go to unclip the back cover.
      • Most laptops use plastic clips in conjunction with screws to keep the back cover secured in place.
      询问修复机器人
      添加评论
    5. How to Repaste a Laptop, Remove the back cover: 步骤 5 中的图像 1,2 How to Repaste a Laptop, Remove the back cover: 步骤 5 中的图像 2,2
      • Once all of the clips have been disengaged, lift the back cover up and away from the laptop to remove it.
      • Lift slowly and carefully, checking that no cables are attached to the back cover before you fully remove it.
      询问修复机器人
      添加评论
    6. How to Repaste a Laptop, Disconnect the battery: 步骤 6 中的图像 1,3 How to Repaste a Laptop, Disconnect the battery: 步骤 6 中的图像 2,3 How to Repaste a Laptop, Disconnect the battery: 步骤 6 中的图像 3,3
      • Don't skip this step. Disconnecting your laptop's battery is a vital safety step before any repair.
      • Use the tip of a spudger or your finger to disconnect your laptop's battery.
      • All battery connectors are different. Some slot into place, some press and snap into place. Some have locking mechanisms, and some have pull-tabs.
      • If it's unclear how to safely disconnect your battery, consult your laptop's manual.
      询问修复机器人
      添加评论
    7. How to Repaste a Laptop, Unfasten the heat sink: 步骤 7 中的图像 1,3 How to Repaste a Laptop, Unfasten the heat sink: 步骤 7 中的图像 2,3 How to Repaste a Laptop, Unfasten the heat sink: 步骤 7 中的图像 3,3
      • Some laptop heat sinks and fans connect as one assembly, and some have separate fans.
      • Disconnect, unscrew, and remove any fans that sit atop your laptop's heatsink.
      • Use a screwdriver to remove the screws securing the heatsink to the chassis.
      • During reassembly:
      • Tighten the heat sink screws around the CPU or GPU in an "X" pattern.
      询问修复机器人
      添加评论
    8. How to Repaste a Laptop, Remove the heat sink: 步骤 8 中的图像 1,2 How to Repaste a Laptop, Remove the heat sink: 步骤 8 中的图像 2,2
      • Lift the heat sink away from the motherboard to remove it.
      • If the heat sink feels stuck, check for heat pipes caught underneath case overhangs, screws you forgot to remove, or stickers or tape.
      • The existing thermal paste may still be tacky. It might help to gently wiggle the heat sink side-to-side to separate it from the thermal paste holding it down.
      • Don't pull on the heatsink too hard; the heat pipes may be susceptible to bending or creasing.
      询问修复机器人
      添加评论
    9. How to Repaste a Laptop, Clean off the old thermal paste from the heat sink: 步骤 9 中的图像 1,2 How to Repaste a Laptop, Clean off the old thermal paste from the heat sink: 步骤 9 中的图像 2,2
      • Before applying new thermal paste, you must first remove any old thermal paste and leftover residue from both the processor surface and the heat sink.
      • Use the flat end of a spudger to scrape as much solidified thermal paste off of the heat sink as possible.
      • Scrape gently. Avoid gouging or poking the copper contact surface.
      询问修复机器人
      添加评论
    10. How to Repaste a Laptop: 步骤 10 中的图像 1,2 How to Repaste a Laptop: 步骤 10 中的图像 2,2
      在这个步骤中使用的工具:
      Arctic Silver ArctiClean
      $11.99
      • Use a coffee filter or a lint-free cloth and a couple drops of isopropyl alcohol (a.k.a. IPA, >90% concentration) to clean the remaining thermal paste residue off the thermal contact surface of your heat sink.
      • Alternatively, you can use a dedicated cleaning agent such as Arctic's ArctiClean or isopropyl alcohol swaps or wipes.
      • Once the surface is mostly clean, use another, fresh piece of coffee filter or lint-free cloth with more IPA to further remove any oils or extra residue.
      • Avoid touching the heat sink's contact surface once it's clean. Small dust particles or even oils from a fingerprint can reduce the effectiveness of the thermal paste application.
      • Allow the heat sink to dry completely.
      询问修复机器人
      添加评论
    11. How to Repaste a Laptop, Clean off the old thermal paste from the processor: 步骤 11 中的图像 1,1
      • Don't use any metal objects or tools for this step, as they could mar the fragile, exposed processor.
      • Use the flat end of a plastic spudger or the edge of an old credit card to remove any large chunks of solidified thermal paste from the surface of the processor.
      • Don't use excess force here—you don't want to gouge the surface.
      • Be careful working near any small soldered components on the motherboard surrounding the chip.
      询问修复机器人
      添加评论
    12. How to Repaste a Laptop: 步骤 12 中的图像 1,3 How to Repaste a Laptop: 步骤 12 中的图像 2,3 How to Repaste a Laptop: 步骤 12 中的图像 3,3
      在这个步骤中使用的工具:
      $11.99
      • Like with the heat sink, use a coffee filter or a lint-free cloth and a couple drops of >90% isopropyl alcohol to clean the remaining thermal paste residue off the processor surface.
      • You can alternatively use a dedicated cleaning agent such as Arctic's ArctiClean or isopropyl alcohol swaps or wipes for the processor as well.
      • Avoid touching the processor during this procedure. Small dust particles or oils from fingerprints can reduce the effectiveness of the thermal paste application or otherwise harm your chip.
      • Allow the processor to dry completely.
      询问修复机器人
      添加评论
    13. How to Repaste a Laptop, Apply new thermal paste: 步骤 13 中的图像 1,1
      • Use your tube of thermal paste to apply a small drop to the middle of the processor die, about the size of a grain of rice.
      • The mounting pressure from reinstalling the heat sink will usually adequately spread the thermal paste out, but some applications recommend manually spreading the thermal paste. Follow this guide for how to do that.
      • If you accidentally get a little bit of thermal paste on the green PCB surface surrounding the processor die, don't worry! It won't cause any problems.
      • You don't need to apply any thermal paste to the heat sink—only the processor.
      • The processor is now ready for the heat sink to be reinstalled.
      • Return to Step 8 and follow the instructions in reverse order to reassemble your laptop.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
取消:我没有完成这个指南。
15等其他人完成本指南。
Carsten Frauenheim
于03/10/20注册
168,174 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了50,078篇指南
3指南评论
i cant unscrew the screws in my heatsink and accidentally loose them i dont want to put pressure the board i might break it any way to fix and unscrew them??
Shiraiki - 回复 分享
muss ich die Capacitors und den Vram auch repasten wenn ich die / den Heatsink entferne?
finde keine klare antwort im internet dazu
Alibi - 回复 分享
Alibi, ich verwende Online-Übersetzung, daher ist mein Deutsch möglicherweise nicht das Beste. In den meisten Anwendungen verwenden diese Komponenten Wärmeleitpads anstelle von Wärmeleitpaste. Wenn sie gerissen oder gerissen sind, müssen sie beim erneuten Einfügen möglicherweise auch ersetzt werden, wenn Sie die ursprüngliche Dicke erreichen können.
Carsten Frauenheim - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 50
过去 7 天: 331
过去 30 天: 1,421
总计 63,580
