此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
你所需要的
工具
具有前缀“J”和“PH”的位通常被认为是相同的。 不要被他们相似的外表所愚弄 - 他们是完全不同的。
十字(PH)螺丝设计成使十字螺丝刀凸出,如果施加过大的扭矩。 这样可以防止损坏螺钉和螺丝刀或钻头。
日本工业标准(J)螺丝不凸出,并有90度角。
222等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
24指南评论
Excellent guide. could not figure out the difference by looking.
It would be clearer if the displayed drawing of each bit actually said J-bit or PH-bit, and because both have 90 degree corners, maybe change the J-bit description to “have 90 degree square inside corners“ and include in the PH description “have 90 degree rounded inside corners.
Otherwise, with interpretation, your article helped me.
what size hex shaft do these smaller bits have?. i have an electric precision screw driver, for electronics. i go through the PH1 bits very quickly. i can NOT find them for sale anywhere on earth. does anybody know where to purchase these things?? and/or tell me how i should word the query. all im getting is 1/4 hex shaft results. very frustrating
4mm bit size
Anthony Cole - 回复 分享
