跳转到主内容
Google Pixel Midframe Replacement
Claudia Mendez
Claudia Mendez7 其他贡献者
最后更新于 January 30, 2023
25分钟
中等
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
Prereq guide for midframe removal. Although the midframe itself rarely needs to be replaced, it must be removed in order to replace other components.
你所需要的
工具
查看更多...
  1. Google Pixel Midframe Replacement, Display: 步骤 1 中的图像 1,1
    • Turn off the device.
    • Prepare an iOpener to heat the edges of the display and soften the adhesive underneath. Alternatively, you may use a heat gun or a hair dryer.
    • The surfaces near the speaker and microphone (top and bottom respectively) have larger adhesive sections. These areas may require slightly longer heat exposure. The display should be heated until it's slightly too hot to touch, for roughly two minutes.
  2. Google Pixel Midframe Replacement: 步骤 2 中的图像 1,3 Google Pixel Midframe Replacement: 步骤 2 中的图像 2,3 Google Pixel Midframe Replacement: 步骤 2 中的图像 3,3
    • In the following steps, you will separate the display panel by slicing though the adhesive bonding the display to the Pixel's chassis.
    • For reference, the back of the display panel is shown at left. Note the narrow clearance between the side of the display unit and the OLED panel. (The bezels indicate this spacing on the front.)
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
  3. Google Pixel Midframe Replacement: 步骤 3 中的图像 1,2 Google Pixel Midframe Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Suction Handle
    $2.99
    • Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
    • If your display is cracked, cover it with packing tape to help the suction cup adhere and prevent glass shards from popping loose.
    • You may need to apply more heat if this doesn't come up. Don't be impatient, this will take time. Once you can gently insert a tool in the gap, move on to the next step.
  4. Google Pixel Midframe Replacement: 步骤 4 中的图像 1,3 Google Pixel Midframe Replacement: 步骤 4 中的图像 2,3 Google Pixel Midframe Replacement: 步骤 4 中的图像 3,3
    • Insert an opening pick or a playing card into the gap between the chassis and the display assembly.
    • Begin to slide the opening pick around the edge of the display, cutting through the adhesive that secures it.
    • Do not try to lift or pry the screen off with the pick. Simply slide it around to detach the adhesive.
    • The display panel is extremely fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
  5. Google Pixel Midframe Replacement: 步骤 5 中的图像 1,3 Google Pixel Midframe Replacement: 步骤 5 中的图像 2,3 Google Pixel Midframe Replacement: 步骤 5 中的图像 3,3
    • Continue carefully separating the adhesive around the rest of the device.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
  6. Google Pixel Midframe Replacement: 步骤 6 中的图像 1,3 Google Pixel Midframe Replacement: 步骤 6 中的图像 2,3 Google Pixel Midframe Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    • With the adhesive cut, slowly lift the display up from the top (the side with the speaker-grille cutout), carefully flip it over vertically toward the bottom of the device, and rest it on its face, as shown.
    • Don't forget there's sticky adhesive everywhere, so consider resting an opening pick between the screen and display, to avoid spreading the gunk!
    • Do not attempt to completely remove the display yet, as it is still connected by a fragile ribbon cable. Be careful to not to strain the cable while positioning the display.
  7. Google Pixel Midframe Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the two black 3.5 mm T5 screws securing the display cable connector bracket.
  8. Google Pixel Midframe Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the bracket that holds the display connector in place.
    • This is just a piece of metal, and should come up very easily. (The cable is removed in the next step.)
  9. Google Pixel Midframe Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to pry up the display cable connector, freeing the display.
    • On reassembly, gently snap one side in, then the other.
    • Do not force this type of connector into place, as damage can occur. (You will need to feel a light snap, but force beyond this will permanently damage your connector.)
  10. Google Pixel Midframe Replacement: 步骤 10 中的图像 1,1
    • Remove the display.
    • Some replacement displays do not come with an earpiece speaker grille. If your replacement screen doesn't have one, be sure to transfer the grille from your old display to the new one.
    • During reassembly, pause here to test the functionality of your new part and replace the display adhesive.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  11. Google Pixel Midframe Replacement, Midframe: 步骤 11 中的图像 1,1
    • Use a T5 Torx driver to remove the nine 3.5 mm screws securing the midframe.
  12. Google Pixel Midframe Replacement: 步骤 12 中的图像 1,1
    • The midframe is held tightly in place by five clips. To release these clips, apply inward pressure with an opening tool as shown in the steps below.
  13. Google Pixel Midframe Replacement: 步骤 13 中的图像 1,1
    • Wedge an opening pick into the notch that is located at the bottom right corner of the phone.
  14. Google Pixel Midframe Replacement: 步骤 14 中的图像 1,3 Google Pixel Midframe Replacement: 步骤 14 中的图像 2,3 Google Pixel Midframe Replacement: 步骤 14 中的图像 3,3
    • Slide the opening pick up both sides of the device in the small space between the midframe and the rear case to release the clips holding it in place.
    • Note that the clips are not released by sliding through them, but rather the inward pressure the opening pick creates as it enters the gap around them.
    • If the clasps fail to come undone, try pushing the edge you're working on inward with your hand, or using a thicker tool like a spudger.
    • Do not attempt to remove the midframe yet! There is still a fragile ribbon cable underneath connecting the earpiece speaker to the motherboard.
  15. Google Pixel Midframe Replacement: 步骤 15 中的图像 1,2 Google Pixel Midframe Replacement: 步骤 15 中的图像 2,2
    • Use a spudger to pry the earpiece speaker cable connector straight up, disconnecting it from the motherboard.
    • Remove the mid-frame from the device.
    • During reassembly, reattach the earpiece speaker cable and insert the top side of the midframe before you snap the clips back into place.
结论
3等其他人完成本指南。
Claudia Mendez
于04/26/17注册
1,851 声望
撰写一个指南
团队
Cal Poly, Team S23-G1, Livingston Spring 2017 Cal Poly, Team S23-G1, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G1
4 名成员
创作了13篇指南
1指南评论
how can i Use the tweezers to remove the bracket that holds the display connector in place ??
Neyla Bhm - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,804
