跳转到主内容
Google Pixel 7 Loudspeaker Replacement
你所需要的
  1. Google Pixel 7 Loudspeaker Replacement, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 7 Loudspeaker Replacement, Screen removal information: 步骤 2 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Screen removal information: 步骤 2 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Screen removal information: 步骤 2 中的图像 3,3
    • The screen of the Google Pixel 7 is held in place by a safety frame of plastic clips and adhesive.
    • During the removal procedure, make sure to insert your opening picks under the safety frame to avoid separating it from the screen.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen.
  3. Google Pixel 7 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 3 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 3 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. Google Pixel 7 Loudspeaker Replacement: 步骤 4 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement: 步骤 4 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement: 步骤 4 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Google Pixel 7 Loudspeaker Replacement: 步骤 5 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement: 步骤 5 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement: 步骤 5 中的图像 3,3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. Google Pixel 7 Loudspeaker Replacement, Loosen the display adhesive: 步骤 6 中的图像 1,1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
  7. Google Pixel 7 Loudspeaker Replacement, Insert an opening pick: 步骤 7 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Insert an opening pick: 步骤 7 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Insert an opening pick: 步骤 7 中的图像 3,3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
  8. Google Pixel 7 Loudspeaker Replacement, Prevent damage to your phone: 步骤 8 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Prevent damage to your phone: 步骤 8 中的图像 2,2
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  9. Google Pixel 7 Loudspeaker Replacement, Slice the bottom edge adhesive: 步骤 9 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Slice the bottom edge adhesive: 步骤 9 中的图像 2,2
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  10. Google Pixel 7 Loudspeaker Replacement: 步骤 10 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement: 步骤 10 中的图像 2,2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  11. Google Pixel 7 Loudspeaker Replacement, Release the left clips: 步骤 11 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Release the left clips: 步骤 11 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Release the left clips: 步骤 11 中的图像 3,3
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  12. Google Pixel 7 Loudspeaker Replacement, Slice the top edge adhesive: 步骤 12 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Slice the top edge adhesive: 步骤 12 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Slice the top edge adhesive: 步骤 12 中的图像 3,3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  13. Google Pixel 7 Loudspeaker Replacement, Release the right clips: 步骤 13 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Release the right clips: 步骤 13 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Release the right clips: 步骤 13 中的图像 3,3
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
  14. Google Pixel 7 Loudspeaker Replacement, Open up the phone assembly: 步骤 14 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Open up the phone assembly: 步骤 14 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Open up the phone assembly: 步骤 14 中的图像 3,3
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame before continuing.
  15. Google Pixel 7 Loudspeaker Replacement, Release the display cable bracket: 步骤 15 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Release the display cable bracket: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
  16. Google Pixel 7 Loudspeaker Replacement, Remove the display cable bracket: 步骤 16 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Remove the display cable bracket: 步骤 16 中的图像 2,2
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the cameras.
  17. Google Pixel 7 Loudspeaker Replacement, Disconnect the display cable: 步骤 17 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Disconnect the display cable: 步骤 17 中的图像 2,2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Google Pixel 7 Loudspeaker Replacement, Screen information: 步骤 18 中的图像 1,1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  19. Google Pixel 7 Loudspeaker Replacement, Separate the screen: 步骤 19 中的图像 1,1
    • Separate the screen from the phone.
    • During reassembly:
    • Check that all screws are tightened and there are no loose parts.
    • Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  20. Google Pixel 7 Loudspeaker Replacement, Peel off the lower graphite foil: 步骤 20 中的图像 1,3 Google Pixel 7 Loudspeaker Replacement, Peel off the lower graphite foil: 步骤 20 中的图像 2,3 Google Pixel 7 Loudspeaker Replacement, Peel off the lower graphite foil: 步骤 20 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to carefully peel the lower graphite foil off the battery and midframe.
    • If you're having a hard time peeling off the foil, apply a heated iOpener to the foil for two minutes to loosen its adhesive.
  21. Google Pixel 7 Loudspeaker Replacement, Unfasten the loudspeaker screws: 步骤 21 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Unfasten the loudspeaker screws: 步骤 21 中的图像 2,2
    • Use a Torx T3 screwdriver to remove the three 5.1 mm-long screws securing the loudspeaker.
  22. Google Pixel 7 Loudspeaker Replacement, Remove the loudspeaker: 步骤 22 中的图像 1,2 Google Pixel 7 Loudspeaker Replacement, Remove the loudspeaker: 步骤 22 中的图像 2,2
    • Use a pair of tweezers to lift the loudspeaker out of its recess and remove it.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 answers community for help.
Dominik Schnabelrauch
于11/23/16注册
246,554 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,618篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 97
总计 4,070
