跳转到主内容
Google Pixel 6 Pro Battery Replacement
你所需要的
  1. Google Pixel 6 Pro Battery Replacement, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 6 Pro Battery Replacement, Anti-Clamp instructions: 步骤 2 中的图像 1,3 Google Pixel 6 Pro Battery Replacement, Anti-Clamp instructions: 步骤 2 中的图像 2,3 Google Pixel 6 Pro Battery Replacement, Anti-Clamp instructions: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Pro Battery Replacement: 步骤 3 中的图像 1,3 Google Pixel 6 Pro Battery Replacement: 步骤 3 中的图像 2,3 Google Pixel 6 Pro Battery Replacement: 步骤 3 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Pro Battery Replacement: 步骤 4 中的图像 1,3 Google Pixel 6 Pro Battery Replacement: 步骤 4 中的图像 2,3 Google Pixel 6 Pro Battery Replacement: 步骤 4 中的图像 3,3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Pro Battery Replacement, Loosen the display adhesive: 步骤 5 中的图像 1,1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  6. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: 步骤 6 中的图像 1,3 Google Pixel 6 Pro Battery Replacement, Insert an opening pick: 步骤 6 中的图像 2,3 Google Pixel 6 Pro Battery Replacement, Insert an opening pick: 步骤 6 中的图像 3,3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Pro Battery Replacement, Slice the adhesive: 步骤 7 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Slice the adhesive: 步骤 7 中的图像 2,2
    • Insert a second opening pick at the bottom edge and slide it to the bottom right corner of the screen to slice the adhesive.
  8. Google Pixel 6 Pro Battery Replacement: 步骤 8 中的图像 1,3 Google Pixel 6 Pro Battery Replacement: 步骤 8 中的图像 2,3 Google Pixel 6 Pro Battery Replacement: 步骤 8 中的图像 3,3
    • The screen of the Google Pixel 6 Pro is not only held in place by adhesive but also small plastic pins. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (~3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Pro Battery Replacement: 步骤 9 中的图像 1,2 Google Pixel 6 Pro Battery Replacement: 步骤 9 中的图像 2,2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Pro Battery Replacement: 步骤 10 中的图像 1,2 Google Pixel 6 Pro Battery Replacement: 步骤 10 中的图像 2,2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Pro Battery Replacement, Open up the phone assembly: 步骤 11 中的图像 1,3 Google Pixel 6 Pro Battery Replacement, Open up the phone assembly: 步骤 11 中的图像 2,3 Google Pixel 6 Pro Battery Replacement, Open up the phone assembly: 步骤 11 中的图像 3,3
    • Avoid straining the display cable during the following procedure.
    • Carefully fold the screen to the left side of the phone assembly like you would open the front cover of a book.
  12. Google Pixel 6 Pro Battery Replacement, Unfasten the display bracket screw: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • While the Pixel 6 Pro uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx T3 screwdriver to remove the 2.0 mm-long 3IP Torx Plus screw securing the display cable metal bracket.
  13. Google Pixel 6 Pro Battery Replacement, Remove the display cable bracket: 步骤 13 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Remove the display cable bracket: 步骤 13 中的图像 2,2
    • Use a pair of tweezers to remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 6 Pro Battery Replacement, Disconnect the display cable: 步骤 14 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Disconnect the display cable: 步骤 14 中的图像 2,2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  15. Google Pixel 6 Pro Battery Replacement, Remove the screen: 步骤 15 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Remove the screen: 步骤 15 中的图像 2,2
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and sensor cutout for any protective liners. Remove these liners before you close the phone up.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
  16. Google Pixel 6 Pro Battery Replacement, Loosen the graphite film adhesive: 步骤 16 中的图像 1,1
    • Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
    • Don't apply heat directly onto the battery. It is susceptible to heat damage and could cause a thermal event.
  17. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: 步骤 17 中的图像 1,3 Google Pixel 6 Pro Battery Replacement, Remove the graphite film: 步骤 17 中的图像 2,3 Google Pixel 6 Pro Battery Replacement, Remove the graphite film: 步骤 17 中的图像 3,3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the motherboard shield.
    • Remove the graphite film.
  18. Google Pixel 6 Pro Battery Replacement, Peel off the graphite film: 步骤 18 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Peel off the graphite film: 步骤 18 中的图像 2,2
    • If you want to replace your battery it's enough to peel the bottom part of the graphite film off the battery. If you want to replace your rear camera you need to remove it completely. In case you only want to replace the earpiece speaker or the front facing camera, you can leave it in its place.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top right corner of the battery.
    • Fold the graphite film in direction of the selfie camera to get free access to the battery.
  19. Google Pixel 6 Pro Battery Replacement, Remove the graphite film: 步骤 19 中的图像 1,3 Google Pixel 6 Pro Battery Replacement, Remove the graphite film: 步骤 19 中的图像 2,3 Google Pixel 6 Pro Battery Replacement, Remove the graphite film: 步骤 19 中的图像 3,3
    • If the graphite film becomes hard to peel off, it has most likely cooled down. Reapply your iOpener or heat gun to the rear glass for 1-2 minutes to reheat it.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
  20. Google Pixel 6 Pro Battery Replacement, Unfasten the charging port bracket screws: 步骤 20 中的图像 1,1
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long 3IP Torx Plus screws securing the charging port metal bracket.
  21. Google Pixel 6 Pro Battery Replacement, Remove the charging port bracket: 步骤 21 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Remove the charging port bracket: 步骤 21 中的图像 2,2
    • Use a pair of tweezers to remove the charging port bracket.
  22. Google Pixel 6 Pro Battery Replacement, Unfasten the motherboard cover screws: 步骤 22 中的图像 1,1
    • Use a Torx T3 screwdriver to remove the five 5.1 mm-long 3IP Torx Plus screws securing the motherboard cover.
  23. Google Pixel 6 Pro Battery Replacement, Remove the motherboard cover: 步骤 23 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Remove the motherboard cover: 步骤 23 中的图像 2,2
    • Use a pair of tweezers or your fingers to carefully remove the motherboard cover.
  24. Google Pixel 6 Pro Battery Replacement, Disconnect the battery cable: 步骤 24 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Disconnect the battery cable: 步骤 24 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  25. Google Pixel 6 Pro Battery Replacement, Apply high concentration isopropyl alcohol: 步骤 25 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Apply high concentration isopropyl alcohol: 步骤 25 中的图像 2,2
    • There's only adhesive underneath the top and bottom areas of the battery and not underneath the center. The see-through plastic strip around the center of the battery is not especially useful during the removal procedure. Feel free to remove it for easier handling by opening its adhesive seal and pulling it out from underneath the battery.
    • Bring your phone assembly to an ~45° angle.
    • This helps to spread the isopropyl alcohol evenly in the following step. You can hold the phone in one hand and apply the alcohol with the other or secure your suction handle to the rear glass and use its handle as a stand for your phone.
    • Apply a few drops of high concentration (over 90%) isopropyl alcohol into the gap between the motherboard and the top left and bottom left corner of the battery.
  26. Google Pixel 6 Pro Battery Replacement, Insert an opening pick: 步骤 26 中的图像 1,3 Google Pixel 6 Pro Battery Replacement, Insert an opening pick: 步骤 26 中的图像 2,3 Google Pixel 6 Pro Battery Replacement, Insert an opening pick: 步骤 26 中的图像 3,3
    • Insert an opening pick into the gap between the top right corner of the battery and the midframe.
    • Use your opening pick to pry up the battery by tilting your pick downwards and widen the gap between battery and the midframe.
  27. Google Pixel 6 Pro Battery Replacement, Widen the gap: 步骤 27 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Widen the gap: 步骤 27 中的图像 2,2
    • Work your way along the right edge of the battery and widen the gap between battery and midframe until you have enough space to insert a plastic card.
  28. Google Pixel 6 Pro Battery Replacement, Insert a plastic card: 步骤 28 中的图像 1,3 Google Pixel 6 Pro Battery Replacement, Insert a plastic card: 步骤 28 中的图像 2,3 Google Pixel 6 Pro Battery Replacement, Insert a plastic card: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • If you can't manage to remove the battery by only using high concentration isopropyl alcohol (over 90%) you can try a combination with heat. In this case prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath the battery.
    • Insert a plastic card underneath the right edge of the battery.
    • Slide the plastic card along the right edge of the battery to separate it from the midframe.
    • Use your plastic card to pry up the battery.
  29. Google Pixel 6 Pro Battery Replacement, Remove the battery: 步骤 29 中的图像 1,2 Google Pixel 6 Pro Battery Replacement, Remove the battery: 步骤 29 中的图像 2,2
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
13等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
203,419 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,820篇指南
7条评论
White flickering screen after battery replacement. I checked all the connections and it seemed that they were all right.
Svitlana Kennedy - 回复
I found an important and critical piece missing in this guide. In steps 6 through 10 your goal is to get the screen separate from the phone chassis. While they do mention to be sensitive around the front camera the guide doesn't mention that you also need to be sensitive around the left-side center of the phone as well. This is where the screen cable connects to the motherboard. I wouldn't even put a pick or tool anywhere near that area. I didn't put too much pressure or anything but it looks like I somehow hit that cable while removing the screen. I don't see any damage to the cable or the screen but when I turn the phone on my screen now outputs several always on bright pink and green lines running through it indicating something went wrong here. So I went from replacing the battery to having to replace the screen too. Between the cost of the new battery and a new screen it probably would've been cheaper to just buy another used Pixel 6 Pro.
Dan - 回复
Sorry, I have a question, did you change the screen?
RICCC -
I went through this process successfully; Several notes;
1. As Dan Mentions, careful of the screen cable, but also be careful of the alignment pins top left and bottom right of the screen - they block the insertion of the pry picks.
2. A hair dryer (750W) on low speed, high heat, works a charm and is much faster and easier than the iOpener.
3. There's an additional wiring ribbon cutting across the battery from top middle to left-middle. It can be easily disconnected, but it isn't shown on the pictures, nor mentioned in the instructions.
4. When you've reconnected the screen wiring ribbon, it says "Don't touch the screen as it needs to calibrate." Mine did nothing. It just turned on and presented the login screen. I used my fingerprint and the device worked. So I powered off and proceeded to affix the screen to the adhesives.
5. Once everything was assembled, I powered on and the finger print reader stopped working (was undetectable). There is a solution to this, but it really should be in this Guide.
Marc Aniballi - 回复
Was replacing the screen, decided I might as well replace the battery while I was at it. That seems to be working fine (including fingerprint sensor) but now the loudspeaker sounds like it's underwater. Not sure how that happened. 😞
Andrew - 回复
添加评论
浏览统计数据:
过去 24 小时: 31
过去 7 天: 297
过去 30 天: 1,488
总计 32,843
