简介
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the battery on your Google Pixel 5a.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
For optimal performance, calibrate your newly installed battery after completing this guide.
你所需要的
Take note of the two seams on the edge of the phone:
Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
Place a suction cup as close to the right edge of the screen as possible.
Lift the suction cup with a strong steady force until a small gap forms between the bezel and midframe.
Insert the tip of an opening pick into the bezel seam about 4-5 cm from the bottom of the phone.
Use a T3 Torx driver to remove the 4.6 mm-long screw securing the screen connector bracket.
Use a pair of tweezers to remove the screen connector bracket.
Use a T3 Torx driver to remove six of the screws securing the midframe to the motherboard:
Four 4.6 mm screws
One 4.0 mm screw
One 2.0 mm screw
Use the pointed end of a spudger to pry up on the black plastic cover at the bottom left of the phone.
Use a T3 Torx driver to remove the remaining four screws securing the midframe to the motherboard:
Three 4.6 mm screws
One 4.0 mm screw
Insert the pointed end of a spudger under the top right corner of the midframe.
There is a black plastic clip at the top of the midframe that secures it to the top of the frame. To detach it, use the spudger to pull the midframe down and then pry up.
There are two small plastic bits that help hold the midframe in place. Take care not to misplace them, as without the midframe to hold them in place, they are very easy to lose.
Use the flat end of a spudger to pry up on the battery connector to disconnect it.
Apply 2-3 drops of high concentration (90% or higher) isopropyl alcohol under each corner of the battery and allow it to penetrate for 2-3 minutes to help weaken the adhesive.
Insert a pick into the gap to the right of the battery and slide its tip underneath the battery.
Slide the pick along the right side of the battery to slice through the adhesive securing it to the midframe.
Once the right side of the battery begins to separate from the midframe, leave an opening pick in the gap to keep the battery slightly raised.
Apply a few drops of isopropyl alcohol directly to the adhesive securing the battery to the midframe. Let the isopropyl penetrate the adhesive for 2-3 minutes.
Repeat the last step with an opening card to slice through the remaining adhesive under the right side of the battery.
Remove the battery.
Remove any remaining adhesive from the phone, and clean the entire area under the battery with isopropyl alcohol. If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing your new battery.
Apply a few new strips of pre-cut adhesive or Tesa tape.
Press the new battery firmly into place for 5-10 seconds.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 5a Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
3等其他人完成本指南。
