简介
使用本指南更换Apple Watch Series 3 破旧的电池。
本指南展示的是标准流程,以GPS版本为例,但在GPS+蜂窝移动网络版本上是相似的。任何重要的区别都有在文中标记出来。
注意: 如果你的电池膨胀了, 看看这个,小心处理。
你所需要的
在这个步骤中使用的工具:Tesa 61395 Tape$5.99
移除电池。
如果需要,可以尝试重新使用现有的粘合剂来固定电池。另外,可以尝试使用一小块双面胶,如Tesa 61395,或一丁点液体胶,如E6000。
由衷感谢以下译者:
83%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
9条评论
Hi
I’m having problem with my Apple Watch series 3, a red snake shown in the watch, I bought a brand new battery here in ifix and i proceed to install it but I’m having the same problem. Can someone help me.
thanks
Have you checked our Apple Watch troubleshooting page for the charging issue?
followed all the steps properly. But the Apple watch does not switch on! The new battery does not seem to work.
After replacing the Battery will the watch be waterproof enough to swim with/ have the same water resistance as when it was new
If you cleaned both the backside of the lens and the case groove where the adhesive was very well and replaced the adhesive getting it squarely on the case lip just as the original one was installed, I would expect the watch to be as sealed and water resistant as it was when new.
