此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
当你的Apple Watch触摸屏损坏或者不响应你的触摸操作时,你自然无法用滑动的方式让它关机。不过,参照本教程,使用数码表冠和侧边按钮也可让它关机。在关机之后,你就可以开始维修了。
就是这样,你的手表已经安全的关机了,你也可以开始你的维修了。
84等其他人完成本指南。
由衷感谢以下译者:
100%
Raymond Morgan正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8指南评论
Hi Jeff, is this supposed to work with series 3 watches. All I see is the time and a red lightning bolt which then disappears and then reappears
Ed Rutmayer - 回复 分享
Readers,
If a red lightning bolt is on screen, it needs charged. When charging, it’ll turn green. Note: if watch is drained, it may be a bit before it’s green. If watch is blank or has an Apple Magnetic Charger and red bolt, leave it on for 30m. It should be green by then. If not, and using a Non-Apple “knock off” Charger, try an Apple Magnetic Watch Charger, Apple USB Adapter, and a working wall outlet (NOT a laptop or power bank). If it won't charge or reads “accessory isn't supported”, check for plastic films on either side of magnetic charge pad, and remove it. Clean the back of the watch and unplug and disconnect everything for about 10s. Then plug in and try to charge it. Both are magnetic and “stick” together. You should see the green bolt after some charge time. If not, then force restart (Jeff’s step 1) until Apple logo, then let go. No logo? Try another Apple Charger, Apple Adapter, and/or wall outlet. It’s $159 for a screen fix on a $200 watch. If all of this fails, better to just buy a new one.
