跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
2017年带 Touch Bar 的15寸 MacBook Pro 电池更换
你所需要的
  1. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 禁用自动重启: 步骤 1 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 禁用自动重启: 步骤 1 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 禁用自动重启: 步骤 1 中的图像 3,3
    • 在开始此步骤之前,你必须禁用 Mac 的自动重启功能。自动重启功能会让 MacBook 在掀开盖子时自动开机。这个功能在拆卸过程中也可能会被意外触发。使用本指南或按照下面的简要说明来禁用自动启动。这项指令可能并不适用于所有 Mac。
    • 开机,并打开终端
    • 将以下命令复制粘贴到(或完全键入)终端窗口中:
    • sudo nvram AutoBoot=%00
    • [回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return
    • 你现在可以安全地关闭Mac电脑,并打开底壳,它不会再意外启动了。
    • 当修理完成、成功组装复原Mac电脑后,在「终端」中使用以下命令来启用「自动启动」功能:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - 回复
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - 回复
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - 回复
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - 回复
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - 回复
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - 回复
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - 回复
    Not able to do that with damaged screen
    richardjgreen - 回复
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - 回复
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - 回复
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - 回复
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - 回复
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - 回复
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - 回复
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - 回复
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - 回复
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - 回复
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - 回复
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - 回复
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - 回复
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - 回复
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - 回复
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - 回复
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - 回复
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - 回复
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
    Read the comments section at the bottom of the article before proceeding with the repair. It is unnecessary to remove the logic board. I actually removed the 45mm plastic bar to enable the cables to slip out then in. It is only there to frustrate repairers!
    Jack - 回复
  2. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 底壳: 步骤 2 中的图像 1,1
    • 开始之前,请完全关闭并拔下 MacBook Pro的电源插头。
    • 关闭显示屏并翻转整个笔记本电脑。使用P5 五角螺丝刀卸下固定底壳的六个螺丝,长度如下:
    • 四颗 4.7 mm 螺丝
    • 两颗 6.6 mm 螺丝
    • 在拆卸螺钉时请注意螺丝的方向 —— 需要以微小的角度重新安装。
    • 在整个维修过程中,记录每个螺丝并确保它准确地回到原来的位置以避免损坏你的设备。
    These screws are TINY and different lengths. I highly recommend purchasing the recommended magnetic project mat.
    Steve - 回复
    So this need to replace each and every screw in its exact former position explains exactly the excruciating difficulty I am having in getting the set of four shorter screws screws back in after everything else having gone successfully. Wanna scream at the top of my lungs. Maybe this point needed to be made in all ALL CAPS and BOLD for me. So can I still just start over trying each screw in each hole or have I messed up the threads in trying to screw in screws mismatched to their holes?
    hatuxka - 回复
    The front screws are at a slight angle, pay attention when putting them back!
    Cristian Caprar - 回复
    I did not have the magnetic project mat, but instead I stuck loops of blue painter's tape on the table, wrote the step number on them in sharpie, and stuck the screws/covers for the corresponding step on them.
    dunhamsteve - 回复
    If the battery you are replacing is swollen and you do not know it is - swollen, Watch out!
    You may strip threads on some of the screws. Rotate the unscrewing as in a clockwise - counterclockwise manner if some of them start to feel tight.
    G Sena - 回复
  3. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 3 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 3 中的图像 2,2
    • 将抽吸手柄按到底壳前缘附近,螺丝孔之间。
    • 提起吸力手柄,足以打开底壳下方的小间隙。
    You can probably just skip to step 6 if battery is swollen. These steps will likely be taken care of for you.
    G Sena - 回复
    is it safe to open without a suction cup? Im thinking you could start prying from the air vents.
    Lé Hönque - 回复
  4. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 4 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 4 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 4 中的图像 3,3
    • 将三角撬片的角落滑入刚刚在底壳下方形成的间隙中。
    • 将三角撬片滑动到最近的角落,然后在MacBook Pro 侧面的一半处滑动。
    • 这将打开第一个固定底壳的隐藏夹子。你应该感受并听到弹出声。
  5. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 5 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 5 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 5 中的图像 3,3
    • 在对面重复上一步,使用三角撬片打开第二个夹扣。
  6. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 6 中的图像 1,1
    • 抬起底壳的前缘(与显示屏合页相对的一侧),使指尖滑到下面并抓住它。
    • 如果无法抓住,则盖子中间附近的两个额外隐藏的夹子可以在此时自由弹出。
    • 不要抬得太高,也不要试图拆下底壳。
  7. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 7 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 7 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 7 中的图像 3,3
    • 将底壳牢固地拉向 MacBook 的前部(远离合页区域),以分离固定底壳的最后一个夹子。
    • 首先在一个角落拉,然后在另一个角落拉。
    • 往拉到一边 —— 不要往上。
    This step drew blood. Darn you Apple!
    Kyle B - 回复
    I found it easier to insert a screwdriver through the hole (not too far down), and use that to pull sideways, as it was hard to get a strong grip with my fingers.
    Athanassios Diacakis - 回复
    If you have a black stick, or a nylon probe tool, you can insert it at the back at the point closest to the screw holes, and use that to push the lower case forward. I’ve seen this help me quite a few times, and it makes it quite easier.
    Adrian Brown - 回复
    I like adrianbrown's suggestion. Spot on!
    wmetzgerusa - 回复
    Its difficult if the side catches arent released properly, check them again if it seems too much.
    tonygreenfield - 回复
    I snapped one of the spring loaded logic board grounding pins. Take your time. Leverage from the back in order to push it out versus pulling on it.
    stevanuscg - 回复
    Take the opening pick and stick the edge down behind the hinge all the way to one side, so it is perpendicular to the case, and give it a twist. That end should pop free. Do the same on the other side and there you go.
    Indawg Wetrust - 回复
    Thanks Indawg Wetrust, Made it very easy!
    Louis C - 回复
    They, iFixit, are not kidding. Quite a bit of force needed.
    Norm Hils - 回复
    This step requires a lot of force to slide the back cover away. Make sure you get a good grip of the mac body and of the back panel.
    It helps if you know what the mechanism inside the case looks like, try to find a picture and imagine pulling out those prong things, also if you understand this mechanism, you can more easily put the case back on!
    wangmeow - 回复
    I literally cut myself with the bottom case, when it finally got freed from the upper case. I have opened a lot of macs, phones, and other items in my life, this was a first. Some light duty cloth gloves next time.
    I didn’t understand some suggestions above. Tried Indawg Wetrust but didn’t really get it. Now looking back, it means use the pick just on the tiny lip of the cover, close to the hinge. Not on the antenna, but just on th slip of metal I believe. If that can help others.
    Julien - 回复
    Just grab it with your fingers and pull firmly to the front (sliding), not a big deal.
    Carlos Joaquin - 回复
  8. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 8 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 8 中的图像 2,2
    • 取下底壳。
    • 要重新安装底壳:
    • 将其固定到位并将滑动夹子对准显示屏合页附近。向下按并将盖子滑向合页。它应该在夹扣合上时停止滑动。
    • 当滑动夹完全啮合且下壳看起来正确对齐时,用力向下按下底壳以啮合四个隐藏的夹子。你应该感觉到并听到它们啮合到位。
    I am doing a battery replacement for a client on this model. The battery has swollen more than I have ever seen before on a Mac! Roughly a ½” higher, once cover removed. Cover was so tight that one screw stripped and had to drill out one screw after trying everything else! Fortunately, I’m an exmechanic/machinist and I own a full size drill press! None of the screw extraction tools sold by ifixit worked or were applicable until I finally got the cover off. Then the small screw pliers from Japan were easier to use than anything else I own. My tools are mostly for larger nuts, bolts and screw extraction. Possibly a mini hammer driver screwdriver would work if one could be made small enough for tiny screws! Ross
    Ross Elkins - 回复
  9. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 电池接口: 步骤 9 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 电池接口: 步骤 9 中的图像 2,2
    • 剥离并取下最靠近电池的主板边缘的大矩形电池板盖。
    • 如果盖子不易剥落,请使用 iOpener,吹风机或热风枪轻轻加热以软化下面的粘合剂,然后再试一次。
    • 如果在重新组装时盖子没有牢固就位,请尝试将其旋转180度。必须正确定位,以使下面的粘合垫与板上螺丝接触。
    What is the though behind this step? I have replace my trackpad before, and I did not do this step. At the time, there was no guide. As a result, I’m wondering how this changes/or if it is necessary for the repair process.
    Anthony Bleyer - 回复
    It’s necessary in order to disconnect the battery. Always disconnect the battery before making repairs.
    Jeff Suovanen -
    I found my one of my fan making some noise, when open the bottom of my Mac I see this piece floating over the fan. Trying to put it back where it goes but don’t seem to stick anymore and move around. Does this piece is really necessary or I can simply remove it or order a new one from you?
    Alexandre Bolduc - 回复
    It should be pretty easy to reattach. Put a dab of rubber cement or a bit of double-sided tape on top of each of the screws underneath the cover, press the cover down, and close up your MacBook. It should stay put. Don’t use superglue or anything else that will harden over the screw heads and make it impossible to fit a driver in there later.
    Jeff Suovanen -
    Do you know if this piece is necessary. I lost mine.
    scoop scoop - 回复
    My Macbook doesn’t appear to even have this piece.
    Nate Bartlett - 回复
    This cover is not attached to anything critical underneath, so do not be afraid that you can break anything like pulling anything from the mainboard. Just pull it out. To reattach, I removed the old double side adhesive tape and replaced with fresh one.
  10. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 10 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 10 中的图像 2,2
    • 剥去覆盖电池板数据线接口的任何胶带。
    • 使用撬棒轻轻撬起电池板数据线的 ZIF 接口上的锁定盖板。
    Wow, mine peeled up from the board. Now I have some board level soldering. Any part number on the connector for this cable on the board.
    Mark Mata - 回复
    I second that; does anybody know where this battery board data cable connector can be purchased?
    Tim - 回复
    The replacement battery did not come with the “tape” in this cable so it was very difficult to reinsert the cable into the zif socket. Now I can’t get the replacement battery to charge.
    J D - 回复
    I have the same issue, My battery is not charging. Did you figure out how to get your battery to charge?
    Jeremy Smith -
    In my case, the original replacement was faulty. iFixIt sent an RMA without hesitation, and I am happy to report that the new one works fine. But also recheck this step and steps 13/14.
    J D -
    Note that the tape covering that comes on the OEM battery is not included in the battery sent from iFixIt. I removed it from the old and attached it to the new, but it does not “re-stick” very well, so it’s rather difficult to re-insert. Be careful, the ribbon is fragile.
    J D - 回复
    I broke the locking flap! Also, my original tape lost its stickiness as well. I cut out a small piece of electrical tape to keep the cable snug in place. Also will work to keep it secure since I broke the locking flap.
    Edward Pascua -
    I was able to reinsert the cable easily a number of times with the nice Ifixit angled tweezers as the ziff connectors tiny latch came off! I ended up using a bit of Pliobond 25, contact cement to mke sure the data cable doesn’t move. A future repair will just pull off or at most need an xacato blade knife to slit the rubbery cement. Ross
    Ross Elkins - 回复
    REALLY important. You need to really pull this back in snug for things to work when you reassemble.
    Michael Stelzner - 回复
    I didn’t seem to have any tape covering it, I just proceeded to the next step
    Nathan Skene - 回复
    My battery board connecter is broken. Let me know where can I get these cables.?
    Lalitha Prasad - 回复
    I recommend to just lift a little the right end (end of the cable side), then keep the socket in place with a spudger while removing this adhesive tape, to avoid any accident like ripping off your socket. With a little care, it is safe and easy to remove completely.
  11. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 11 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 11 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 11 中的图像 3,3
    Mein Sicherungsbügel ist abgebrochen, oder zumindest nicht mehr auf dem ZIF-Stecker. Ist dieser Sicherungsbügel sehr wichtig, oder kann ich das Kabel dennoch zurück stecken?
    Fabio Jock - 回复
    Hallo Fabio, wahrscheinlich wird das Kabel ohne den Bügel nicht mehr halten. Das Zurückstecken geht, aber es bleibt nur sehr fragil drin.
    Fabian Neidhardt -
    Sie sollten in der Lage sein, das Kabel wieder anzuschließen und mit einem guten Klebeband abzudichten.
    mark - 回复
    My zif connector was already open. It apparently never got closed during manufacture. Being so tiny this made it difficult to see why there was nothing to pry up with the spudger. Once I put my finger on top of it I realized the flap was already verticle.
    Ian Simmons - 回复
    lock flap broke when I was about to close it, is there any way to fix it? The computer can't find the battery
    Gabriel - 回复
    I had no issue here but I recommend to use a second spudger to keep the rest of the socket in place while GENTLY lifting the lock. It should lift without effort.
    When putting it back, be careful, there might be a little piece of transparent adhesive foil on top of the socket, gently lift it up on the side of the cable. The cable should slide in easily, but do not force it. About 0.5mm of the cable contacts will be VISIBLE on the left side, when the cable is fully it, do not force it more than that.
    コネクタのプラスチックが割れたのですが、代替品を教えてもらえませんか?
    Kazuhito Miyawaki - 回复
  12. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 12 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 12 中的图像 2,2
    • 将电池板数据线从插槽中滑出,将其断开。
    • 沿电缆方向平行于主板滑动。
    If this breaks, what’s the risk to the computer?
    Jose Lopez - 回复
    I tried powering mine on after my zif connector socket broke. It made bad electrical noises. I had water damage at one point and cleaned the unit very well but never replaced the battery. Through excesive, a hot and bad battery, or water damaged weakening the area mine came right off with the tape when i peeled it up. Im working on finding the part and will attempt to solder it back. Of course i still need a battery which ours was swollen. After water damage it worked great for over a year though.
    Mark Mata - 回复
    Mine broke and now the Macbook will not power on, this was after a battery replacement, the Macbook powered up afterwards, but after transporting it, it would not power up. I removed the back cover and noticed the battery board cover was missing and the zif gate for the battery data connector was half off.
    Charles Braxton - 回复
    Same here, I broke the cable which was soldered on the mainboard. I tried to hold it on place with a tape, but I couldn‘t charge my macbook though. Then I tried to solder it and I also failed. I wish I had read the comments before :/
    Sebastian Fritsch - 回复
    I couldn‘t find the fpc 6 pin connector with 0,5 mm grid. However I managed to connect the flex cable directly on the mother board with 0,3 mm isolation filament! It was tough but I‘m so happy that it works again :)
    Would you be able to give a little instruction on how you were able to make this work? I’m super curious and need a solution to the same issue.
    Tim -
    Anybody know where this connected can be purchased? Mine completely snapped to pieces the moment I touched it.
    Tim - 回复
    Surprised by the tolerance of this little connector to my mistake of not flipping up the not very noticeable clamping element on side opposite to where the contact tip is inserted. The contact tip pulled right out without having done that. Saw in a video I should have done that before pulling the contact tip out. Remembered when reinstalling it.
    hatuxka - 回复
    The cable is stuck on the board underneath with adhesive, so it is best to first work it a little from left under (as the picture is oriented) in order to break the adhesive, and then pull it sideways. At all times, I kept the socket safe with a spudger to avoid ripping it off the board. The cable will come out with a little effort. Remember, it is the socket you need to take care of, not the cable (the cable will be thrown away with the old battery).
    I had issues in reassembly - the lever for the ZIF socket was missing. I think it came off with the tape. I found the lever, but it was way too small for me to reattach (I couldn't hold it well enough with the tweezers and wasn't sure where the hinge pins went).
    The computer did not recognize the battery or recognized it with errors (if I got the cable just right) without the lever.
    My solution was to cut a tiny bit of electrical tape and put it on the back of the ribbon cable to make it thicker. This gave it enough traction to stay in the socket and pushed the ribbon onto the contacts.
    dunhamsteve - 回复
  13. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 13 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 13 中的图像 2,2
    • 使用 T5 Torx 螺丝刀卸下固定电池电源接口的3.7 mm 薄饼螺丝。
    It was actually T6 in my case
    Fedor Pudeyan - 回复
  14. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 14 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 14 中的图像 2,2
    • 使用撬棒提起电池电源接口,断开电池。
    • 在维修时,将接口抬高到足以使其与插座分离。如果意外接触,可能会损坏你的MacBook Pro。
    I tossed a piece of tape on the connector just to be safe.
    Kyle B - 回复
    wondering if i didn’t heed this warning close enough. mac not powering on. only black screen with battery and lightning bolt beneath it. What happens if this connector makes contact?
    ONYCHA HAZEL - 回复
    im in the exact same boat right now.
    Was everything okay in your case?
    Anthony Gasbarro -
    Same here until I realized that I never reconnected the tiny power button/Touch ID connector in step 31! It’s underneath the headphone cable jack from step 30. Mine was hiding under the board and I carefully fished it out with a tweezers.
    ajm0824 -
    I have the same issue. Followed Instructions to theT. Battery is connected properly as it fully charged however, it will not power on. If i disconnect the battery and connect the power adaptor, it powers on. How did you resolve your issue?
    Ian Duff -
    Mine will power on, but will not charge.
    J D - 回复
    Hi, did you manage to fix this? Ive got the same issue sadly.
    Cooldude2222 -
    Same problem, any solution?
    federico.cirillo - 回复
    Lifting up to about 75 degrees is more that enough and safe, and I did also use some electrical tape to block the contact. When this goes back, there is no socket in place, it is just the screw that keeps it there.
    I put electrical tape on this as well. Glad I did. "Being careful" during the whole process gets lost when you're focusing on other parts.
    Jay - 回复
  15. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 触控板组件: 步骤 15 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 触控板组件: 步骤 15 中的图像 2,2
    • 使用T3 Torx 螺丝刀卸下固定触控板电缆盖板支架的两颗1.9 mm 螺丝。
    • 卸下支架。
    T3 doesn’t seem to fit, somehow on my a1707 the driver doesn’t grip and it just slips on the screw.
    What am I doing wrong?
    I don’t have a T2 to try, what can I do?
    Luciano Colosio - 回复
    I managed to get a holt of a T2, but still no luck: there are a bunch of screws that seem to be T2 but everything I stick inside them just spins around and doesn’t grip :(
    T4 worked perfectly
    DonPanchito - 回复
    Indeed, a T4 worked for me, also.
    Roy Vanegas - 回复
    T3 doesn’t fit, so can’t progress. %#*@, why would fixit sell incomplete kits?!
    Rolf Rau - 回复
  16. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 16 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 16 中的图像 2,2
    • 使用撬棒断开触控板电缆,方法是将其连接器从主板垂直向上撬起。
    I managed to pry the metal bit with screw holes off first. Whoops.
    Nathan Skene - 回复
    Make sure the spudger goes under the entire plastic connector, not just the surface metal place, as you risk damaging it like the comment above.
    If you get to this point and realize that the connector isn't lining up quite as perfectly as you hoped, don't panic. Open up the lid enough to get a couple fingers under the trackpad to support it. Use your T5 to loosen all of the trackpad screws JUST A COUPLE TURNS not all the way. It will flex around a little bit in the housing and give you some slack if you need it. Then just tighten it all back up again.
    halp - 回复
  17. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 17 中的图像 1,1
    • 在触控板带状电缆上施加温和的热量,使粘合剂软化,使其固定在电池上。
    • 你可以使用 iOpener,吹风机或热风枪,但请注意不要使电池过热。电缆应该是温暖的,但不要太烫手。
    I used a hairdrier. Barely needed to hold it there for 20 seconds before I could peel it off.
    Nathan Skene - 回复
    This cable can be carefully peeled off the battery by hand by those deft of hand. Gradually and inching along its length.
    hatuxka - 回复
    Just warming it gently made it easy to peel off. Work with care starting from the free end, lift a little, move your grip, etc. Do not lift it all at once, there is a risk of breaking it. It is safe to then move it at 180 degrees angle, completely on the other side.
    All my battery packs were swollen. The trackpad ribbon cable was barely adhered to this battery pack. No heating necessary.
    Richard Schletty - 回复
    Rubbing with your finger and heat the ribbon. Works also.
    Schwoegi - 回复
    I didn't need to heat the ribbon, I carefully peeled it back without putting to much pressure on it. I can however, if the adhesive is stronger than on my computer, to warm it up slightly.
    jacoboliverlanger - 回复
  18. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 18 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 18 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 18 中的图像 3,3
    • 小心地将触控板电缆从电池上剥离,然后将其推开。
    • 请勿折叠或撕裂电缆。如果你遇到麻烦,请不要过于用力 —— 加热并再试一次。
    thin ifixit pick opener sliding gently/slowly underneath ribbon cable towards the front edge of mbp did the trick for me. no need for heat.
    Macrepair SF - 回复
    In my case the sticky part of the track pad ribbon remained on the battery. So after replacement the trackpad ribbon does not have a sticker to stay on the battery.
    Neil Robinson - 回复
    Did it work all right without the adhesive there?
    That happened to me too! I thought that was what was supposed to happen, until I read your comment. I managed to peel it off the battery, but before I could catch it it rolled up into a tight ball. I got about half of it unrolled and onto the ribbon.
    rileybk -
    Since this step you can skip the part with removing the trackpad and logic board and just remove 7 screws (step 47, except green and blue) holding the logic board so you can lift it for a few millimetres just to take off the battery. You can find a YouTube videos where a guy is replacing the battery very easily. So waste of time and a lot of places to screw up you MacBook doing it this way.
    durmstrang - 回复
    This comment and that YouTube video saved me a lot of time - thanks!
    Note that there are 8 logic board screws to remove excluding green and blue (now on step 46) and battery board screws are on step 50; the rest of these steps are irrelevant, making this a very easy replacement.
    Max Z -
    My logic board has 9 screws. Each fan has 3 plus the other three in the blowup. Total waste of time and effort to remove the logic board when it can be tilted up to remove the battery. As stated, no need to remove the trackpad either.
    F#%K Apple for making this a difficult job when the batteries were just screwed in before. Absolutely no need for such difficult glue and hiding cables apart from sheer bastardry!
    Jack -
  19. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 19 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 19 中的图像 2,2
    • 使用T5 Torx 螺丝刀卸下固定触控板组件的13颗螺丝:
    • 九个 5.8 mm 螺丝
    • 四个 4.9 mm 螺丝
    • 这些螺丝看起来非常相似,所以不要混淆它们。
    • 由于 Force Touch 触控板上的点击动作,这些螺丝会随着时间的推移而松动。在安装它们时添加一点缺氧胶可以帮助保证它们的安全。
    • 松散地安装螺丝并检查触控板对齐方式,然后将其拧紧。
    Using a piece of cellophane tape can help hold the trackpad in place with with proper clearance all around.
    Russell Johnson - 回复
  20. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 20 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 20 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 20 中的图像 3,3
    • 将显示器略微打开,但保持 MacBook 倒置。触控板组件应分开并平放在显示屏上。
    • 轻轻地将触控板的带状电缆穿过机箱中的插槽。
    • 在重新组装时,请仔细注意触控板电缆的正确插槽 —— 它通过电池旁边的窄插槽,而不是靠近 MacBook Pro 前缘的较大插槽。
    WARNING - READ THE NEXT STEP NOW OR YOU WILL LOSE THE WASHERS. Please update this with BIG RED LETTERS in the step to indicate what is about to happen, or you’ll skip forward and the washers will fly everywhere. I’m really upset right now.
    Jason Sherron - 回复
    I would add step 21 to step 20. The warning about potentially losing the washers should be part of this step, not a separate one.
    fippolito - 回复
    this step is BS, I didn’t remove the touch bar, you just need to remove enough screws on the upper board to be able to pull the battery plastic frame and put it gain…
    what a loss of time!
    a m - 回复
    Merci beaucoup vous venez de me sauver
    DJAIMBA-LIMTA Winega Martial - 回复
  21. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 21 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 21 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 21 中的图像 3,3
    • 当你卸下触控板组件时,请务必小心不要丢失固定在螺钉柱上的九个小金属垫圈。(它们轻轻一动就会飞出来而弄丢。)
    • 卸下触控板组件。
    They are not kidding about the jumping washers.
    Kent Folsom - 回复
    Pro Tip: put your magnetic mat under the trackpad as you slide it out to catch the tiny washers. Alternatively, a magnetic tool bowl, or a terry cloth towel so the lighter guys can’t get far if they fall.
    Kent Folsom - 回复
    Mine are made of aluminum or stainless or something that magnets don't attract. Flypaper, maybe? :-D
    dgatwood -
    Can I change the battery with out removing the trackpad and logic board?
    Mateo Munoz - 回复
    yes
    I did it, you just have you remove enough screws on the board to bend it upwards in order to pull the battery frame that’s it…
    my mac is working fine
    a m -
    yep lost a washer in the process
    Jason Sherron - 回复
    My trackpad underside was dusty. Without thinking, I tried to blow off some of the dust. One washer and one double washer were finally found thanks to a bright flashlight and the contrasting color of the wood floor.
    hatuxka - 回复
    One of the washer remained stuck on the body, luckily I observed it on the working table when I cleaned the dust from the trackpad casing area. Be VERY careful to not loose these tiny metal pieces!
    Without the washers the clicking and moving mouse around doenst work well. very important
    Herbie Computer Service - 回复
    Ok, I have all but 1 round washer. I found the rest. Not knowing a source (not even in my extensive parts collection) I will reassemble with the middle one without a washer. If anyone knows of a parts source (other than buying a trackpad assembly) please post here, Thanks.
    Carl Schultz - 回复
    When you put the trackpad to the side, write a note and put it on top so you don’t forget about the washers when you come to reassemble it.
    Robert Such - 回复
    Followed the advice on disassembly but did not on re-assembly. Lost one of the larger ones.
    Recommend changing text to RED (They will fly off and get lost with very little provocation.)
    *also agree with Robert Such but I was in a bit of a hurry to finish. Take your time.
    G Sena - 回复
    I agree. An obvious warning at or right after the removal of the trackpad screws should be added. The trackpad washers can be easily dislodged and go missing if you are not prepared to protect against that from happening.
    mmorder - 回复
    I used a clean paint brush to dust off the back of the trackpad and internals. One of the round washers flew out of the assembly and got lost. The washers are super easy to lift off the posts. BE VERY GENTLE WITH THE TRACKPAD REMOVAL AND HANDLING!
    Justin Lopez - 回复
    This needs to be moved WAY up higher. You are 100% guaranteed to lose one by the time you start the previous step, because the trackpad will fall the microsecond you start to open the case. Really, you shouldn't remove the last screw until you're holding the trackpad from underneath.
    Also, the battery replacement kit should really come with at least one extra washer, because I can pretty much guarantee nobody will ever do this without losing one. It is darn near impossible to deal with something that lightweight. Even putting the trackpad down on the counter is enough to lose one, much less having it drop out of the bottom while you're cracking open the laptop.
    dgatwood - 回复
    I found it, and it wasn't in a place you might expect. There's a bit of metal trim on the back of the trackpad itself, and the washer was underneath that. I actually had to dump all the washers out onto the bottom case, and suddenly it peeked out from under the metal rim. Worse, these things are aluminum (or maybe metallized mylar), so you can't pick them up with magnets....
    It might be a good idea to put some masking tape on the trackpad to hold it in place so that it doesn't drop out when you open the lid. Then very carefully press it down from the underside with a spudger after you have opened the lid fully and have your hand under it to catch the trackpad so that it doesn't suddenly drop.
    dgatwood -
    Pro tip: During reassembly, put the plastic backing from the battery down on top of your display, put the trackpad upside-down on top of that, and slowly close the top case down onto it, working the cable through the slot. Then, when it is almost fully closed, use the plastic backing to maneuver the trackpad into position so that the pins line up.
    dgatwood - 回复
    Be careful when you remove this touchpad! I followed every step from the instructions provided here and also checked some video tutorials on YouTube from time to time. Everything went well after swapping the battery, at least that's what I thought. When I started the computer, unfortunately, my keyboard and touchpad didn't work, and the fans were very loud. I used an external keyboard and mouse, searched online for the problem, and tried some solutions such as PRAM reset, but nothing worked. Anyway, I opened the computer again and found that the end of the cable attached to the touchpad was loose. After putting it back in place, everything worked flawlessly.
    Mercan - 回复
    I had the same problem as Mercan. The touchpad and keyboard would not work. The cable on the back of the touchpad had a partial open on the connector. The only thing I can add is the connector on the back of the trackpad has a lever that must be raised, the the cable inserted and closed. (Just like the data cable on the system board) BIg shout out to Mercan. Thanks.
    Dwight
    dwightbridges - 回复
    If you were fortunate to not lose any washers, replace the screws into the posts to prevent their loss before re-assembly.
    johnewert - 回复
  22. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 主板组件: 步骤 22 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 主板组件: 步骤 22 中的图像 2,2
    • 使用 T3 Torx 螺丝刀,卸下固定键盘接口支架的两颗 1.9 mm 螺丝。
    • 卸下支架。
    I’m just curious - why did the entire logic board have to come out in order the replace the battery? It seems like after the trackpad you could skip to battery removal. Is it to protect the board? Thanks!
    Todd Wood - 回复
    Yeah this is where I stopped and said, wait, you have to remove the entire logic board?
    So I looked around for more tutorials and indeed, it is not at all necessary. You just need to remove a few of the board's screws, enough to lift the board up and slide the battery cables out. That is all. This tutorial is way way overcooked.
    Here you go:
    https://youtu.be/F6uUs4x6lv8?si=DOPj131K...
    Timbre Studio -
    I am also wondering if it is necessary to remove the logic board. I’m just looking to remove a leaking battery from my macbook pro and safely discard of it while I get a replacement as it is releasing some chemical smell which I assume must NOT be good for one’s health.
    Jean Lescure - 回复
    Sehr geehrtes IFIXIT Team, bitte um Info warum für den Ausbau des Akkus auch das Bord ausgebaut werden muss? Danke für Ihre Antwort!
    Josef Lix - 回复
    As far as I can tell there is a part of the battery that is below the logic board. It’s the thin black stripes next to the battery pcb on either side. You can see it after the logic board is removed on step 50.
    Bhav - 回复
    Absolutely correct. No way to skip the steps.
    Cristian Caprar -
    Please, elaborate.
    Because the one small cable to the right is the battery data cable, it's been disconnected in step 10 and then presumably comes out with the battery (there's no indication it is glued nor instructions to unglue it by heating it and it doesn't look like it is UNDER the logic board) and the only cable that is UNDER the logic board is the keyboard cable, whose connector gets disconnected in next step but needs not being further removed.
    I can't imagine all these risky actions (both when disassembling and reassembling are actually needed!
    Luca Ciminelli -
    Actually, a T4 Torx driver works perfectly.
    DonPanchito - 回复
    T3 stripped mine, should have used T4. Screw Extracting Pliers to the rescue.
    Peter Eltgroth - 回复
    Hands up everyone that’s never buying an apple product again?
    Nathan Skene - 回复
    Hah yep never again.
    Timbre Studio -
    I can confirm that the logic board removal is mandatory, because two battery connection cords are under the logic board and cannot be removed otherwise. Even if that would be possible by cutting them, it is not possible to install the new battery anyway.
    Thanks for your hands-on feedback Cristian.
    Would you please elaborate? Which "two battery connection cords?" What I see in step 50 are the keyboard cable (which needs not removing) and the battery board cable, whose connector has already been disconnected (step 10) and comes out with the battery, because new battery shows the cable (and the board).
    Luca Ciminelli -
    the cables CAN be slid out with slight upward pressure on the loosened logic board. There is no need to remove it entirely.
    Marc -
    Not necessary to remove the logic board.
    Here is proof:
    https://youtu.be/F6uUs4x6lv8?si=jYWU64q_...
    Timbre Studio -
    I'm about to try this again. My MB Pro late 2016 has had three battery replacements so far.
    The first one went fine but found the battery cable receptacle had poor solder joints on it and was repaired by Luis's shop in NYC - bit thank you to those guys. They did the last battery swap too as I was too busy to try it myself.
    Now my battery shows full but has zero capacity so going to replace it once again.
    I've never removed the logic board to do the replacement of the battery! I simply loosen the retaining screws on the logic board and very carefully slide the cable past the interference and Voila it's out and in. Of course, be very careful doing this so you don't warp the board much.
    I'll post the post battery stuff here once I do this for the 4th time.
    Marc - 回复
  23. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 23 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 23 中的图像 2,2
    • 使用撬棒通过将其接口从主板垂直向上撬开来断开键盘。
    Again, make sure you pry from underneath, not only the metal plate. Goes off easily and then it also gets back easily when putting it back.
    Don't do what I did :( When I reinstalled the logic board and bolted down everything, I realized I didn't pull keyboard cable connector through and was stuck underneath the board. Rather than taking the time to disconnect all the cables and unbolt everything to carefully pull the cable back through, I unbolted only left side and attempted to pull cable through using tweezers. I tore the cable which is very fragile. This ultimately disabled my keyboard. Hopefully, people will read this and will not happen to anyone. If it does, the cable can easily be purchase from Amazon for $6. The cable that worked for me is part #821-00612-04.
    Edward Pascua - 回复
  24. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 24 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 24 中的图像 2,2
    • 使用 T3 Torx 螺丝刀,卸下固定显示屏面板柔性电缆上的盖子的两颗 3.5 mm 螺丝。
    • 移除显示屏柔性电缆盖。
    This is another step where T4 was a better fit (for me) than T3).
    Anne Scheer - 回复
  25. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 25 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 25 中的图像 2,2
    • 使用T3 Torx 螺丝刀卸下固定显示屏面板电缆接口支架的两个 1.7 mm 螺丝。
    • 从显示屏面板电缆接口上卸下支架。
    This appears to be a T4 not a T3
    Rich Murfitt - 回复
    They are definitely T3 ;) But not all driver kits are created equal. If your T4 works better for you, go with that.
    Jeff Suovanen -
    I concur the the T3 didn’t work, T4 worked great.
    David Balogh - 回复
    't4'나사에 전해 맞습니다.
    jinwoo KIM - 回复
    The bracket of the display board connector in my case is glued. So wasnt able to remove it.
    Neil Robinson - 回复
    I also found a T3 to be too small and T4 too large. I skipped this step and was able to complete the installation by using this connector (still secured by the screws I couldn’t take out) as a hinge to carefully lift the logic board up when needed. I ended up not requiring any of the adhesive remover liquid to remove the battery; just heat from a hairdryer and elbow grease to slide the cards under each cell. Laptop working perfectly again now with this new battery.
    Martin - 回复
    I used my T3 on my 2017 but I had to press a bit harder to get these to unscrew.
    tomasponce - 回复
  26. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 26 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 26 中的图像 2,2
    • 用撬棒直接撬起以断开显示屏面板柔性电缆。
    When putting it back, I did not notice any “click”, but it was definitely secured in place. Just do not overpress it expecting the “click”. It fits back easily.
  27. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 27 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 27 中的图像 2,2
    • 使用 T3 Torx 螺丝刀从铰链盖上卸下四个 2.0 mm 螺丝(每侧两个螺丝)。
  28. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 28 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 28 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 28 中的图像 3,3
    • 移除两个铰链盖。
    My hinge covers seemed to be "aged" and cracked upon reinstall, so do not over-tighten upon reinstall. Was not detrimental overall.
    Jay - 回复
    Mine were aged and cracked, too.
  29. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 29 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 29 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 29 中的图像 3,3
    • 使用 T3 Torx 螺丝刀卸下两个 2.4 mm 螺丝,它们用于固定Touch ID和耳机插孔电缆接口的盖板支架。
    • 卸下支架。
    Again, a T4 worked here, not T3.
    David Balogh - 回复
    't4'나사에 전해 맞습니다.
    jinwoo KIM - 回复
    it’s a T4, not T3. Correct this mistake.
    [deleted] - 回复
    T3 worked for me. MBP 2016.
    Gustavo Guida - 回复
    I only had the bottom screw of this pair to remove. The other is missing,
    Jonathan B - 回复
    The top screw of the cover bracket screws into a larger bottom screw. You need to keep that bottom one separate from the others as it is the only one that has a hole for the top screw.
    Bob Donovan - 回复
    Thank you Bob Donovan! I got already confused
    Dennis Doerrich - 回复
  30. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 30 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 30 中的图像 2,2
    • 通过将其接口从主板垂直向上撬起来断开耳机插孔电缆。
    Be very careful with this connector, pry from the bottom of the body, not from the side of the fan, as there is the next connector under it. Just be gentle and patient. Lifting it up to about 100 degrees is safe.
    I ripped it. Game over. Is it?
    Jan Becker - 回复
  31. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 31 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 31 中的图像 2,2
    • 通过从主板垂直向上撬起接口,断开电源按钮和 Touch ID 传感器。
    Pry this from the fan side (right side of the body) and be VERY careful, the cable is extremely thin. Lift it up gently under the previous cable. When putting it back, just work gently, it will snap easily into place if positioned correctly. Do not force it back.
    On the reassembly this was a crucial part I have forgotten.
    Without this, and NVRAM autoboot disabled my MBP wouldn’t start up and only show me the battery state.
    webrockers - 回复
  32. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 32 中的图像 1,1
    • 使用 T3 Torx 螺丝刀卸下固定 Touch Bar 数字转换器接口盖板支架的 1.3 mm 螺丝。
    Screw was stipped. I had to cut a flathead slot in the head with a Dremel cutting disk. It then came out OK.
    Nick Rhind - 回复
    My screw here was or became stripped just like Nicks. However, I didn't use a dremel or anything else to make a cut. I left the screw in and when the board was removed and started the adhesive removal, I layed the board over and supported it. This worked fine but keep a look out so that the ribbon isn't stretched. Assembled back without issues
  33. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 33 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 33 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 33 中的图像 3,3
    • 使用镊子,将支架滑向 MacBook Pro 的侧边,直至其拆除主板上的插槽固定。
    • 卸下支架。
    When replacing the bracket make sure to loop it through the metal flange so it stays secure.
    Daniel Moravec - 回复
    Lift it gently on the left, 10 degrees, then slide it to the right so that it is freed from the metal strip holding it from under the logic board. It will be obvious how to put it back once you have it out, it has a small cut on the right that has to go first in the metal strip from under the board, then let the left side down.
    Who would have thought that reversing this step would be the hardest part of the process? Man, that's hard to hook. :-D
    dgatwood - 回复
  34. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 34 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 34 中的图像 2,2
    • 将 Touch Bar 数字转换器电缆从主板上垂直向上撬开,断开它。
  35. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 35 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 35 中的图像 2,2
    • 使用 T3 Torx 螺丝刀卸下固定 Touch Bar 显示屏电缆接口支架的两个 1.9 mm 螺丝。
    • 卸下支架。
    It’s T4, not T3.
    [deleted] - 回复
    Completely stripped the screws on this one - T3 seemed too small, but T4 was too big.. Any way to get replacement screws for this step?
    Benjamin Schemmel - 回复
    T4 worked better for me than the T3. I would suggest trying both lightly as the T3 might strip the screw for you. be careful here… T3 almost stripped the screw.
    Hung Nguyen - 回复
    T3 from the kit I bought here works fine for all the steps where they call for T3. So far!
    rileybk - 回复
    T3 from the ifixit kit works fine for me
    Nathan Skene - 回复
    tomasponce - 回复
    It is a very tight T3 - I stripped the head on one of these screws so be very careful here. (T4 wouldn't fit) I think this screw was welded in!
    Tim Lightfoot - 回复
  36. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 36 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 36 中的图像 2,2
    • 将接口从主板垂直向上撬开,断开 Touch Bar显示屏电缆的连接。
    100 degrees lift is safe
  37. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 37 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 37 中的图像 2,2
    • 使用 T3 Torx 螺丝刀:
    • 卸下两个 1.3 mm 螺丝,将左侧的 Thunderbolt 柔性电缆盖固定。
    • 从右侧的Thunderbolt电缆盖上卸下另外两个1.3 mm 螺丝。
    Amazingly, the top right screw here was not a T3 at all but a T4.
    tomputnam7 - 回复
    Top screw head seems to be stripped. Tried various other sizes to no avail.
    Les Hartzman - 回复
    Top screw stripped for me. Stuck here. Can’t progress.
    Jason Sherron - 回复
    Noticed the screws of left bracket of the thunderbolt connector didnt tighten into place (after it goes in and tightens it freely rotates). The right one did. Although both are scecured and working.
    Neil Robinson - 回复
    When reassembling you need to push down snug to make sure the thunderbolt ports work.
    I stripped the same screw here too, but I was able to very gently fold the connector up (being extremely careful to not damage the connector or the board
    Kris - 回复
  38. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 38 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 38 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 38 中的图像 3,3
    • 从主板垂直向上撬开左侧Thunderbolt柔性电缆,将其断开。
    • 从内侧边缘离风扇最近的地方撬起。
    • 将柔性电缆接口轻轻推向侧面,以免干扰主板的拆卸。
    Pry on the middle of the connector, not the sides, as it is pretty long. Be careful to position it correctly when putting it back and do not force it back.
  39. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 39 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 39 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 39 中的图像 3,3
    • 重复以断开另一侧的 Thunderbolt 柔性电缆接口。
    • 小心地将柔性电缆接口推到一边,这样就可以使主板无间隙地脱离。
    One speaker had some adhesive. Careful prying!
    Dylan James - 回复
  40. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 40 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 40 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 40 中的图像 3,3
    • 通过将撬棒的扁平端滑动到接口附近的每根电缆下方,断开两个扬声器接口。
    • 轻轻扭动或撬起以断开两个扬声器。
    BE VERY CAREFULL WITH THE SMALLER SPEAKER CONNECTOR!
    The instructions say “TWIST”… DO NOT &&^&^$^ TWIST IT!!!
    I broke the connector off the PCB.. now the left speaker is gone forever!
    robert - 回复
    DO NOT TWIST
    The connectors are very delicate, you must use the spudger as a lever to lift the cable.
    May be the worst part of the whole procedure
    Paolo Zangheri - 回复
    Both of the connector cables were secured with adhesive for me. Had to take my time and work gently to loosen.
    Alfred Haas - 回复
    Which ended up screwing me when reinstalling. The adhesive made it really tough to slide connector in. I ended up breaking the socket connection to board. No more left speaker!!! Argh!
    Alfred Haas -
    I broke off the left speaker connector. I wonder if I can solder it back on. Anyone know??
    When putting these back, these seem to just be pushed down from above, rather than slotting in from the back
    Nathan Skene - 回复
    Add me to the Broken Connector club ?. No right speaker for me. Have to think how I can soldier some pins on to fix the connector, or just leave it alone so I don’t make it worse. I should have read thru the instructions and all the comments. Oh well. Shoulda wouldas
    Robert Lee - 回复
    By far the most delicate step. I suggest SLOWLY peeling away the adhesive until gone, then CAREFULLY pull the cable away from the connector.
    The connector is NOT secured well, and you WILL break it off if you don’t proceed with extreme patience in this step. The cable pulls toward the sky. I held the connector down while I gently lifted the cable.
    Daniel Moravec - 回复
    YES!! I followed your advice and pushed on the connector with tweezers while using the smudger to gently lift up and off. Got them both off successfully!
    Craig Shinn -
    Very easy to snap back into place if you didn’t muck up the connector while removing it. Just finger press directly from the top and they snap right into place.
    Daniel Moravec - 回复
    I used tweezers to carefully hold the sides of the connector as I slowly worked the cable out. Work under the adhesive by rocking the spudger forward and backward (not twisting). As you work toward the connector, gently pull the spudger out every so often and slide back under the cable till you eventually reach the connector. If you do it this way, have steady hands and patience! A magnifying glass helps too.
    Chris Hiepler - 回复
    I heated a little bit the area and then used a spludger to keep the entire socket + connector in place, then SLOWLY and GENTLY introduced a spludger from the top under the cable to break the adhesive. Once the cable was free from the adhesive (3-5 degrees lift, not more!), then I used a spludger to keep the socket in place (it is a U shape with the bottom near the battery cell, I introduced another spludger under the cable from the opposite direction (from UP of the body if the battery is DOWN) and then pried UP the connector. It does not slide, it just pops out of the socket. Putting it back is very easy, just press it gently down and it will get in the socket with a small click sound.
    Same on the other connector.
    DO NOT rush the part where the cable is freed from the adhesive, that makes the operation much safer and simpler!
    You update your guide:
    Use the hairdryer to loosen the adhesive for both of the speaker connections, as this will prevent undue stress of the connector and prevent it from snapping the cable or breaking the connector.
    wayne - 回复
    I used Dental floss threaded under and around the speaker cable to cut through the adhesive (really easy) and then one spudger on the circuit board and another to lift the connector out of the socket. Took me a while to workout what to do and the comments above really helped.
    Robert Brace - 回复
    Mint flavor or just regular?
    Tim -
    The floss method worked perfectly! I threaded the floss under a metal trail close to the battery to guide the floss.
    Mint flavored.
    Ryan Stephens -
    哈哈哈哈,我直接把整个底座给撬下来了,这些两个扬声器彻底报废,哈哈哈哈
    DpX - 回复
    I use a blow dryer to heat it up and a thin string/floss to cut the glue. It worked well.
    Volvo Truck - 回复
    Anybody have a solution on how to resolder this connector now that mine no longer works?
    Chris Champeau - 回复
    The directions indicate using a plastic spudger to disconnect these. I found success using a metal spudger to release the adhesive then lift the connectors from their sockets. Reverse the procedure for re-assembly.
    johnewert - 回复
    I too found that the cables were stuck to the board and I would not easily get the spudger under the cables. I put a little of the adhesive remover near the cable which loosened the cables, making it easier to use the spudger to lift the connectors off the board.
    gil - 回复
    At least I wont be lonely in the broken speaker club.. Ffs these instructions could be a bit more careful than "twist and pry". Instantly the whole connector came off.
    Robin - 回复
    Ha - I now have both left and right speakers gone. I'm going to try and resolder the connectors to the pins they got ripped off of. I'm not too confident but will try.
    Vish Talreja - 回复
  41. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 41 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 41 中的图像 2,2
    • 剥去覆盖麦克风电缆接口插座的任何胶带。
    Again I kept the entire socket in place while peeling up.
  42. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 42 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 42 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 42 中的图像 3,3
    • 通过从主板垂直向上撬开麦克风电缆的ZIF接口,打开锁定翻盖。
    I broke off the locking tab upon reinstall, so be careful. Hoping the tape helps hold things together!
    Jay - 回复
  43. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 43 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 43 中的图像 2,2
    • 将电缆拉向风扇,直至其从插座中松开,从而断开麦克风的连接。
    • 如果可能,请拉动连接到电缆的胶带,而不是电缆本身,以降低损坏的风险。
    Be VERY careful fishing that circuit/cable back into the socket. I was using regular tweezers that have a sharp edge. It scratched the circuit under the black plastic sleeve (which is thin). That cable kills your internal mic (which Ifixit does sell a replacement for).
    Jerod Waggoner - 回复
    +1 for pulling on the tape instead. That worked great.
    halp - 回复
  44. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 44 中的图像 1,1
    • 使用 T5 Torx 螺丝刀卸下固定天线电缆束的单个 2.9 mm 螺丝。
    might be easier to do 45 first if the cables are getting too much in the way of the screw
    Kris - 回复
  45. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 45 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 45 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 45 中的图像 3,3
    • 从插座中垂直向上撬开所有三根天线电缆。
    • 将镊子或撬棒的扁平端滑到每根电缆下方,直到它靠近插座,然后轻轻扭动或撬起以断开连接。
    • 要重新连接每根电缆,请将接口直接对准其插槽,然后向下按,使其卡入到位。
    That is the hardest part. Can’t get one of the three plugs back into position.
    Stefan Scholtz - 回复
    Stefan is right. Mine proved impossible and I think I smashed (yes, smashed) the “sockets” they are supposed to “snap” back into (they didn’t for me). For now, they are taped down (and wifi works well), but looking into soldering these if it won’t ruin the connection.
    Jerod Waggoner - 回复
    Use microscope and fine tweezers.
    Jo Luyckx - 回复
    Do not force them. they snap on with little effort when they are aligned just right. Be patient.
    J D - 回复
    Takes quite a bit of realigntment repositioning to place these back.
    Neil Robinson - 回复
    These are VERY tricky to reconnect. ADVICE: Push down on these at and angle and then snap them in and slowly rotate them to get them to stick. It took me FOREVER to figure this out.
    I had no problem getting these on. The trick is to come from just above the connector and pull back on the cable a little bit at the same time. A fully stretched cable will overshoot the connector so that’s why I pulled it back. I used the black spudger to snap it in place. Everything seems fine. There definitely is a slight snap.
    Daniel Moravec - 回复
    I always worked from the cable towards the connector to pry it up, and then when putting it back, it can seem tricky, but I used to push the connector back a little (towards the cable side) before trying to gently press it down. This seems to align it better to the socket. DO NOT force it, but it needs a little force to hear the “click” if it connects properly.
    Correct positioning before pressing down is the key here and it can get very frustrating, so be patient. A microscope /optical zoom would help.
    Also, I advise to start with the longest cable, the one you disconnect first, as it is easier to maneuvre, to get a feeling of how the connector is positioned correctly. The move to the shorter cables.
    After a frustrating 20 minutes, I tried with the longest one as suggested. Made a re-affirming click. The other two were a wresting match and just eased into place when it happened.
    This was the hardest part of the entire process for me. I'd say I probably spent an hour on these. Have patience.
    Jay -
    I think it would help if there was a close-up photo directly above the connectors so you can see how much of the solder on the board is visible. That would help with the positioning of the plug.
    tomasponce - 回复
  46. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 46 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 46 中的图像 2,2
    • 卸下固定主板组件的所有十个螺丝:
    • 两个 2.6 mm T3 Torx螺丝
    • 五个2.9 mm T5 Torx螺丝
    • 一个3.7 mm T5 Torx螺丝
    • 一个3.9 mm T8 Torx 螺丝(大头)
    • 一个4.0 mm T8 Torx 螺丝
    • 在重新组装过程中,只能松散地安装这些螺钉。如有必要,调整面板位置,直到所有接口对齐,然后拧紧螺丝。
    I needed a T9 for the green 3.9 mm “T8” Torx screw
    Nicholas Waller - 回复
    My 3.9mm upper left screw (green) is T8 Torx, while the upper right 3.8mm (blue) screw is a T9 Torx. Note that both are not included in the kit sold by iFixit for this repair @jeffsu
    Alessandro Di Clemente - 回复
    EDIT: actually the T8 is included in the kit description but was not inside the one I got
    I had 4 bits in my driver set that I got. One was the T8 that others seemed to have been missing. Maybe they realized this and added to the new kits.
    Scott Shore - 回复
    No T8 in my kit. Now I have a half disassembled macbook pro I can’t finish. Sweet.
    Jamie Wilkinson - 回复
    On my A1707, the Green and Blue are T10 (although T8 and T9 do ‘fit’ but with slack).
    Shawn Marston - 回复
    Don’t confuse the 3.9 torx8 (green) with the 3.8 torx8 (blue): the green one has a tapped hole for one of the two torx3 of step 29.
    Robert Cailliau - 回复
    I have now discovered that an apple technician cross threaded one of the 2.9mm screws and lost another screw earlier -_-.
    Ben Gove - 回复
    Are these T8 screws security versions? If not, why does iFixit include a TR8 security driver in the kit?
    matt - 回复
    Reinstalling Note: I learned the hardway - Count (12 by my method) the number of connectors:
    5 on the right edge.
    4 on the left edge (I count 2 at the very top left, on under the other).
    2 on the bottom edge near the center (NOTE: if you change a keyboard you will need the keyboard ribbon connector from the old case/keyboard).
    1 cluster for antenna (3 wires & 1 ground screw)
    david - 回复
    It's actually 15 connectors, as somebody else pointed out further down:
    5 on the right edge (touchbar digitizer, thunderbolt, mic, touchbar, speaker)
    4 on the left edge (power, touch id, thunderbolt, speaker)
    4 on the bottom (trackpad, keyboard, batter power, battery data)
    2 on the top (display, antenna bundle)
    halp - 回复
  47. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 47 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 47 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 47 中的图像 3,3
    • 将两个橡胶减振条从粘合剂上剥离(但不要除去),将它们固定在风扇上。
    • 如果需要,使用iOpener,吹风机或热风枪轻轻加热以软化粘合剂,使阻尼器更容易分离。
    Only needs to be lifted from the fan, not from the heat pipe, and gently. If the rubber “end connector” comes out from underneath the heap pipe, do not worry, it can be easily positioned back in place when the logic board is out! Do not spend time trying to push it back now.
    The damping strips came off completely. May try electricians tape.
    Spot - 回复
  48. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 48 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 48 中的图像 2,2
    • 主板组件是紧密配合的,但是你可以通过在左边缘下方插入一个撬棒并轻轻地将其拉出来使其更容易移除。
    • 移除主板时应该没有阻力。仔细检查所有电缆,如果需要,将它们放在一边,这样它们就不会卡在电路板上。
    • 从左侧抬起,取下主板。
    A headcount for all the connectors that need to be exposed when reassembling would be really useful here. I count 15. If you have less you’ve missed something.
    Dom - 回复
    This connection is VERY easy to forget when you reassemble. If you go to startup your computer and you see the battery icon but the computer will not start with the power button, this is the connection you missed when reassembly. Drove me nuts until I figured that one out!
    deancuebas - 回复
    Absolutely DO NOT lift the board by the cables as the picture might lead you to think!
    Also, when lifting up the board, if you feel any resistence, make sure that:
    - all the screws were removed!!
    - move cables and connectors gently away in the area where you are lifting, they can easily catch the logic board and it feels immediately resisting the lift
    After lifting the left side to be able to keep it between your fingers, work toward the middle and then the right, moving the connectors and cables away to free the board for lifting.
  49. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 49 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 49 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 49 中的图像 3,3
    • 重新安装主板组件时:
    • 检查橡胶减振器的对齐情况,并根据需要进行调整。
    • 将天线电缆束穿过主板和散热器之间的间隙,并确保在将电路板降低到位时正确对齐。
    • 确认在安装时没有电缆被困在电路板下面。仔细检查每个标记的位置。
    Start from the right, position it down in place and make sure the cables are not under the board, then get the antenna cables from beneath with tweezers, then work to the left, paying attention to get the cables away so the board can go down in place.
    Note, when reassembling, upper left orange box refers to TWO cables that must be out from underneath - Step 31, “power button and Touch ID sensor”, is small and I didn’t notice it (missing) under the flap of Step 30 headphone jack. So had to fish out later.
    Kip Bryan - 回复
  50. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 电池: 步骤 50 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换, 电池: 步骤 50 中的图像 2,2
    • 卸下固定电池板的两颗螺丝:
    • 2016-2017 款: 使用T5 Torx螺丝刀卸下两个3.5毫米螺丝。
    • 2018-2019款:使用P2 五角螺丝刀拆下3.2 mm 螺丝。
    On my mid 2018 15.3” i9 MBP the battery board screws were PL1
    Brian Eustis - 回复
    I second this. If your repair is time-sensitive, consider making sure you have a PL1 driver in advance. Seeing that IFixit doesn’t seem to sell them, I bought a german-made Wiha driver, hoping the quality would be high. You never want these things to strip!
    Tech Medic -
    On my mid 2018 15.3 i9 MBP the keyboard cable is farther to the left (as shown at Step 23)! When reinstalling, make sure it is under the battery cable and its connector sticking up between the battery cable and the aluminum battery frame.
    Wolf Naegeli - 回复
    So if I’ve understood correctly, almost all the above could have been skipped if apple just made these two screws accessible? Wow, just wow
    Nathan Skene - 回复
    The screws are accessible, but the ribbon is under the board...
    Chi Wang -
    Dear Chi Wang, which cables do we remove once the logic board has been lifted? In step 49 and further I can only see the keyboard cable (which needs not getting removed) and the battery board cable doesn't look like it is under the board...
    Luca Ciminelli -
    P2 bit end broke unscrewing the second of these screws… Now I have a piece of the bit stuck in the screw head and a MacBook completely disassembled…
    one.dakine.howlie - 回复
    Same just happened to me a, but I could get the screw out with a small pair of pliers, and then remove the broken tip from it with some banging on the desk. Took me 5 min, but I wasn’t sure that it will work, so I was a bit nervous 😬
    Eike R -
    I bought the battery + "kit" pack here and it doesn't include p2 screws. wow.... it seems like you own people don't even know what tools is needed for this? wow... just wow...
    CHIACHE LEE - 回复
    I used P0.8 for my Mac 2018
    Martin Lundgren - 回复
    I used P0.8 on my MacBook 2018
    There is no P2 in the kit 😞
    Michele Merega - 回复
    Pas de P2 dans le kit pour les 2 dernières vis, c’est inadmissible !!! Mon mac est en pièces et je ne peux pas finir !!! J’ai pourtant bien acheté le bon kit complet…
    Guillaume Gérald - 回复
    Bonjour @guillaumegerald, je suis désolée d'apprendre cela. Veuillez contacter notre service client au support@ifixit.com (pour la boutique américaine) ou au eustore@ifixit.com (pour la boutique européenne et française) en indiquant ce qui s'est passé et votre numéro de commande. Ce sera un plaisir de vous aider !
    Claire Miesch -
    C'est possible qu'il y a un malentendu ? Je crois qu'on a seulement besoin du P2 pour les modèles 2018/2019 et il est inclut dans le kit pour ces modèles là : MacBook Pro 15" Retina (Mid 2018-2019) Battery. Par contre, il n'est pas inclut dans le kit pour les modèles plus vieux car pour ceux-ci, un Torx T5 suffirait ?
    Sandra Hiller -
    There is no P2 in the kit, that's really annoying, as I could not continue.
    A friend of mine owned a P2 bit, but I had to drive >100 km to fetch it.
    Oti - 回复
    Dead end! There is no P2 tip in the kit. I guess I'll have to find a P2 bit somewhere else (if that's what it is; other comments suggest PL1 or P0.8). Until then, stuck with a fully disassembled MBP. iFixit, this is frankly disappointing.
    Mark Morin - 回复
    For my 2018 15" MBP, I found a P 0.8 driver on Amazon with next-day delivery and it did the trick. This step definitely needs some iFixing.
    Mark Morin -
    I couldn't find a P2 driver but it probably would have been too big anyway. The P 0.8 worked. Perhaps a P1 would have worked too but not sure.
    Mark Morin -
    The P2 head now supplied by the kit is worthless. The metal used by who ever made it must be tin. I was able to remove the first screw but the second screw stripped the P2 head. I purchased a Wiha 26794 Precision Pentalobe Screwdriver Set from Amazon that has a P2 screwdriver. Hopefully these are made better. Looks like iFixIt tried to fix their kit but did not go all the way or did not test what they are supplying. Luckily my daughter does not need the laptop immediately so the delay to wait for the proper screwdriver should not matter.
    rimcrazyph - 回复
    My kit came with a separate bag supposed to contain a P2 bit but in actuality, it was a P5 bit. My MacBook Pro 2018 is currently laying in pieces along with my sanity and patience.
    Rico - 回复
  51. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 51 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 51 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 51 中的图像 3,3
    • 套件中提供的液体粘合剂去除剂可能会损坏MacBook Pro显示屏上的抗反射涂层以及塑料键盘键。
    • 为了保护你的显示器,请在显示器和键盘之间放置一张铝箔,并在工作时将其留在那里。
    • 此外,尽可能使用画家的胶带密封触控板下方的区域。或者,你也可以直接在触控板区域下面铺上吸水毛巾,以吸收多余的粘合剂去除剂。
    I didn’t have any solution and was hesitant to simply use an Isopropyl Alcohol solution of any concentration let along subject my electronics to liquid and aluminum foil, so I simply took a card (something between a metrocard and credit card… i used a rewards card) and brute forced the adhesive while dry (making sure to direct the bulk of the force laterally and not down into the screen below and mostly wiggle back and forth instead of straight on). About 10 minutes later with a sore hand it worked just fine and avoided steps 52-62. (You may want to try the string method detailed in step 62 if stubborn and after started with card.
    ajm0824 - 回复
    The alu foil and the paint tape make it much safer, use them!
    Also removing battery with adhesive remover is quite dangerous (I don't like the idea of liquids around my MacBook insides) so you can do it slowly a carefully with just some plastic cards (like in step 57) putting below the batteries (I used my old credit cards to do this).
    durmstrang - 回复
    What about WD-40? in a spray can!
    Richard Holmes - 回复
  52. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 52 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 52 中的图像 2,2
    • 要控制粘合剂去除剂的流动,请使用书本或泡沫块将 MacBook Pro 的后边缘(铰链面)抬高几英寸。
  53. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 53 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 53 中的图像 2,2
    • 现在你的MacBook Pro已经完全准备好了,现在是时候准备好了。
    • iFixit粘合剂去除剂含有丙酮,温和的皮肤和眼睛刺激性。
    • 处理和使用粘合剂去除剂时请戴上护目镜。(套件中包含护目镜。)
    • 戴护目镜时不要戴隐形眼镜。
    • 套件中还包括防护手套。如果您担心可能的皮肤刺激,请立即戴上手套。
  54. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 54 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 54 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 54 中的图像 3,3
    • 从你的粘合剂去除剂瓶中取下黑色橡胶塞。
    • 在切割涂抹器尖端之前拧开以松开或取下瓶盖。
    • 这会打开瓶子并在切割涂抹器尖端之前使压力均衡。如果跳过此步骤,粘合剂去除器可能会在切割尖端时意外喷出。
    • 用剪刀剪掉涂抹器的密封尖端。
    • 靠近狭窄的尖端切割将使您获得更好的控制,
    • 因此你可以少量使用粘合剂去除剂。在进一步操作之前,请拧紧并关闭瓶盖。
    Eignet sch auch Isopropyl-Alkohol 99,9%?
    Felix - 回复
    The latest Adhesive Remover arrives already with a tiny hole at the tip and the bottle cap and tip is now black instead of clear.
    tomasponce - 回复
    The plastic bottle containing the adhesive remover included with my battery kit does not have a long and tapered cap/tip; as pictured. The one included in my kit from ifixit is much shorter and too wide to fit into the space between the battery and the case as pictured. I adapted by getting a paper clip and placing it where I wanted the solvent to flow to. I then touched solvent bottle tip to the paper clip just above, allowing the solvent to flow down the paper clip to the point below the battery where it will go to work. I did not have to squeeze the bottle in order for small amounts to flow to the desired location. I would move the paper clip and bottle along the edges of the battery as pictured, it worked out well for me.
    Virginia Gentleman - 回复
    Addendum to the comment above: The paperclip I used was partially unbent so that it was effectively a straight wire I could use to place where I wanted the solvent to flow.
    I've done this repair now four times. I've NEVER used any solvent.
    The credit card/plastic scraper works pretty well but of all the ideas, my favorite is the very strong nylon fishing line. Something in the 50 - 100 lb variety so it won't break easily. The other thing that really helps is if the whole case is warm - NOT hot but warm like 100 deg F or something. This makes the adhessive much more likely to separate that when it is cold.
    I've done it in the winter and summer so definitely can attest to it being easier in the summer when it's warmer.
    Also, despite having replaced the battery now four times, I have yet to reapply any adhesive. The replacement battery pack sticks just fine in place with no effort.
    I place wax paper (or the equivalent) under the old battery as I'm plying up each cell. That way the cell doesn't stick back down. When I'm putting in the new battery, I use the wax paper (or similar) to keep the cells from sticking down in the wrong place. Then remove it and lay down the cells.
    Marc -
  55. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 55 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 55 中的图像 2,2
    • 在靠近风扇的边缘开始,在右侧的两个电池单元下方涂抹几滴粘合剂去除剂。
    • 你不需要使用太多。小瓶子含有的溶剂量是拆除所有电池所需溶剂量的两倍以上。
    The bottle may (will!) squirt liquid. I used a bit of absorbant paper around the tip while turning the bottle upside down and putting the tip where it needs to go. Be especially careful not to drip liquid onto the speakers.
    For this type of work I always have a roll of thick toilet paper nearby: its leaves are smaller than those of kitchen paper.
  56. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 56 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 56 中的图像 2,2
    • 在右侧的两个电池单元之间添加几滴粘合剂去除剂,使其在下部电池单元下方流下。
    • 等待约两分钟,液体粘合剂去除剂渗透并削弱电池粘合剂,然后再进行下一步。
    This is by far the most time consuming step. Be generous with the adhesive remover and give it several minutes to work. You'll actually need a bit of force to work the card through the glue. I managed to get everything off without deforming or damaging the battery but it took a lot of patience.
    Alex Jenkins - 回复
  57. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 57 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 57 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 57 中的图像 3,3
    • 几分钟后,将塑料卡的一角插入电池下方,从底部最右边的电池开始。
    • 这不需要太大的力量。如果您遇到问题,请使用更多的粘合剂去除剂,并再浸2-3分钟。
    • 尽量不要让电池变形。损坏或刺破的电池可能会泄漏危险化学品和/或着火。
    • 将卡从一侧向另一侧摆动,并将其完全滑到两个电池单元下方。
    • 提起电池以完全分离粘合剂,但不要尝试将其从MacBook中取出。
    • 将塑料卡暂时放在电池下面,以防止粘合剂在进行下一步时重新粘合。
    I had a great deal of difficulty loosening the batteries. The solvent seemed to have little effect on the adhesive strips. Despite efforts, I deformed the batteries trying to get them free.
    Kent Folsom - 回复
    I also had a great deal of difficulty. I had to apply the adhesive remover 5 times before I could wiggle the card underneath the first battery sections. And it left the adhesive on the computer case; it did not remove the adhesive along with the battery sections.
    rileybk - 回复
    Took me three applications of adhesive remover. Think it really is about wiggling though.
    Nathan Skene - 回复
    It took me about 10 minutes or so to remove all battery modules. I used the adhesive remover as per the guide and also used the card with the corner doing most of the penetration instead of the blunt end. I also would gently wiggle the battery up and down while I applied more adhesive remover to allow it a better chance of getting underneath. BTW, my adhesive strips ran left to right and not back to front on the outer batteries, so I would think it would be more ideal to put the adhesive remover down the left and right sides of the outer batteries. The inner batteries (under trackpad) adhesive strips ran front to back. Keep this in mind when using the remover to loosen them up.
    Steven Wonder - 回复
    Once one of the packs is loose, stick a leaf of toilet paper under it, so that it cannot stick to the body again, while you are working on the other packs.
    One YouTuber uses a fairly short narrow and small thin-bladed and very essentially flexible cake spatula to push in under the battery lobes never sweeping sideways. No chemicals except for 99% propanol to remove the adhesive residue.
    hatuxka - 回复
    See my comment in Step 63. Might save you time and trouble. Putty knife to remove batteries, then hot dryer to get black strips off followed by de-solv-it (or the Ifix-it remover) to get off the adhesive junk.
    Carl Schultz - 回复
    I wanted to comment on what worked for me.
    I did put some of the remover on like they showed.
    I used the credit card plastic tool to kind of get underneath it.
    Then I used plastic putty knife and slowly and carefully pried the batteries off. I take no responsibility here for you, but it worked for me. Also I used 99% isopropoyl to clean the adhesive off.
    Also so you are probably reading this because it is hard, put the trackpad back like the other person said before you put the batteries in. I did that and it probably saved me time.
    Also as you reassemble, make you go look at every connector and there are a bunch and make sure those leads are all coming up through the logic board. I don't want to tell you I thought I was done 2x when I found a small cable at the end I missed. If you do end up in that case, you can remove some of the screws, and use the curved tweezers to kind of snake the cable up top. I know you aren't there yet, but as someone ahead of you, you'll remember this tip.
    Bryan Tanoue - 回复
    The trick here was the use of a putty knife. As someone mentioned, the adhesive strips on mine also ran the direction of the width of the computer, not from the screen side down. Thus, putting the adhesive remover where the directions said only worked on the uppermost adhesive strip. The adhesive remover did nothing to help the process...
    Tim Lightfoot - 回复
    If you're very careful not to deform the packs, you can (ON THE SIDE PACKS ONLY) use the spudger to help gently push through stubborn adhesive. DO NOT use it on the middle packs though, because there are little squarish holes in the body that you could push the spudger through and end up gouging the hell out of your display. And then you'll be back here tomorrow praying there's a tut for that :)
    halp - 回复
  58. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 58 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 58 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 58 中的图像 3,3
    • 切换到MacBook Pro的左侧,然后重复上一步以分离另外两个电池。
    • 暂时将第二张塑料卡留在原位。
  59. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 59 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 59 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 59 中的图像 3,3
    • 沿着两个中央电池单元的顶部边缘涂抹几滴粘合剂去除剂。
    • 在这两个电池下方的底盘中有开口,这使得粘合剂去除剂可以泄漏并且可以防止其完全穿透。
    • 注意泄漏,如果需要,沿侧边涂抹更多的粘合剂去除剂。
    Where are your gloves? :-)
    David Hampson - 回复
  60. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 60 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 60 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 60 中的图像 3,3
    • 几分钟后,取出你的第一张塑料卡,并在其中一个中央电池单元的顶部边缘下方插入一个角。
    • 从一侧到另一侧摆动并将其滑到电池单元下方,直到所有粘合剂分离。
    • 如果遇到问题,请勿过度用力,不要让电池变形。使用更多粘合剂去除剂并重试,或跳过两个步骤以获得替代方法。
    Once you get the card edge under a cell, you can apply a couple of drops on top of the card and it will flow down to the working edge of the card. This will make moving the card back and forth a lot easier.
    Scott Shore - 回复
    I'd consider looking at step 62 first.
    Benny Baggott - 回复
    It was really hard to get the middle batteries out. Two of my card have now missing corners that broke off. I did then the mistake to use a metal spade to get under the battery and pinched it. as a result it started to burn slightly (could blow it out though).
    After moving outside to reduce risk of fire, I tried the Step 62 with a wire that I squeezes in and pulled through carefully. The pinched batter I then pulled the wire from the other side, to avoid damaging the battery even more.
    So far so good, the batteries are out and the burn stains were easy to remove. Let's hope everything still works...
    Matt - 回复
  61. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 61 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 61 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 61 中的图像 3,3
    • 取回你的第二张塑料卡并重复上一步以分离剩余的中央电池。
  62. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 62 中的图像 1,1
    • 如果你无法将卡放在任何电池单元下面,请尝试在电池单元下方使用一块牙线或电线,并以锯切动作左右拉动以分离粘合剂。
    • 戴上厚手套或将牙线缠绕在几个手柄上,以免伤到手指。
    Wouldnt the wire damage the underside of the cells?
    Tom Jackson - 回复
    Yes, but you should never re-use a glued-down battery after removing it like this. These batteries are not designed to be re-used, and can pose a fire risk even when removed carefully.
    Jeff Suovanen -
    I used dental floss + pastic card for the middle part. Avoided using the adhesive remover for the middle ones.
    Neil Robinson - 回复
    I didn’t have to resort to this method, but if I did I would think some fishing line would be a good option. Put some candle wax on it if it starts to bind. I use this method to remove car dash phone holders that are siliconed down to the dash.
    Steven Wonder - 回复
    I used this method, (while waiting for the iFixIt glue dissolver kit: was over a weekend; so too late). Works well with a strong, doubled (with slight, about 1 turn per cm, twist) 25SWG (0.5mm, 0.02inch) copper wire, wrapped around spare small screwdriver handles. Ensure that the angle of the wire is _very_ _flat_ while ‘sawing’ slowly; take your time, quite a lot of force is required to sheer through the spongy pads in places. I started with the 2 larger central cells to refine the technique.
    Shawn Marston - 回复
  63. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 63 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 63 中的图像 2,2
    • 抬起并取出电池。
    • 在安装新电池之前,请从MacBook Pro的外壳中取出所有剩余的粘合剂。
    • 使用镊子或带手套的手指剥去任何大条粘合剂。
    • 用塑料工具刮掉剩余的粘合剂块,并用粘合剂去除剂或异丙醇清洁下面的区域。向一个方向擦拭(不来回),直到机箱清洁并为新电池做好准备。
    • 这可能需要相当多的工作,所以要耐心等待。
    Mine was very difficult to remove and clean. I spent forever trying to clean up the residue. However, I tried 70% isopropyl on two bays and the iFixit adhesive remover in the other two, and covered with food plastic wrap. Went to lunch and when I got back I used razor blade scraper (like used to remove stickers from glass), and it was pretty easily cleaned. Both chemicals worked just as well. Just soak and let the chemicals do the work.
    Philip Edelbrock - 回复
    I didn’t use any solution to remove the battery and found that using the plastic tool to start an adhesive strip I was able to pull each one off by hand in one shot
    ajm0824 - 回复
    I found the best way to do this was to put the hairdrier on the adhesive for a few seconds, then it just peeled off in one go. Wasted a lot of time trying to scratch them off before this.
    Nathan Skene - 回复
    SECOND THIS ADVICE!! Use a hairdryer it will save you a lot of time and the old adhesive will come off much, much cleaner
    Judah Trimmer -
    Yes, hairdryer and use the plastic card to push/scrape one end so you can grab it with your fingers, then peel off the adhesive strip.
    Robert Such -
    It’s going to cost $25 to dispose of the battery some places.
    hatuxka - 回复
    Used a putty knife and removed the batteries, then hair dryer and removed the remaining black strips. Used De-Solv-it (my usual computer anti-glue) to get the gooey glue off. Went well and clean. New batteries in and reassembled.
    Carl Schultz - 回复
    By far the easiest way to remove the adhesive strips for me was to use tweezers. After removing the battery I had mostly large swaths of adhesive. first I used the tweezers, open, then laid it on an angle so the edge laid flat against the surface. Then scraped up side of the adhesive. I wedged up sufficient adhesive so that i could grab it angled (lengthwise not with the point) , Then i slowly pulled up the adhesive without a tear nearly every time, almost satisfying.
    Steven Sanborn - 回复
    Another great tip for removing the old adhesive tape: use a #11 Xacto knife blade. It's basically a very sharp flat blade (the edge is perpendicular to the handle, like a mini paint scraper), that works beautifully to remove the adhesive remnants!
    jiclark - 回复
  64. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 64 中的图像 1,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 64 中的图像 2,3 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 64 中的图像 3,3
    • 在粘贴之前,请仔细检查新电池的合适性和对齐情况。
    • 在早期型号上,请注意电池数据线,并确保它不会被挤压或困在电池板下面。
    • 如果你的电池预装在底部,请将其翻转并小心地剥离衬垫以露出粘合剂。如果你的电池没有附带粘合剂,请使用薄的双面胶带(如Tesa 61395)将电池放在适当的位置。
    • 小心放置电池并将其放置到位。
    • 将每个电池牢牢按住5-10秒钟,将其固定在下壳上。
    In this photo, the holes that are shown in Step 51, where it states, “2018-2019 models: Use a P2 Pentalobe driver to remove both 3.2 mm screws,” are in a different position, so that re-securing the battery board doesn’t seem possible.
    Sarr Sheffer - 回复
    Step 51 shows the correct procedure for two different models; this step shows only one model, because the procedure here works for both. Order the correct replacement battery for your model, and you’ll have no problem.
    Jeff Suovanen -
    I strongly recommend re-installing the touchpad BEFORE installing the battery. Doing that and feeding the ribbon cable through the correct slot will ensure that you don’t block the path of the cable. I did not do this and had to cut some of the framing plastic away to give me just a bit more slack to be able to reconnect the cable.
    After you have the touchpad back in, do a “dry” fit of the battery to make sure you see how the battery should go in so you don’t affect the ribbon cable. Then you can peel off the adhesive protection strips to secure the battery.
    Les Hartzman - 回复
    After reading this comment I went straight back to steps 19/20 and reversed them before installing the battery… will update if something is notable!
    Nathan Skene -
    Be careful here. When I went to peel up the liner on one of the batteries the adhesive strip came up with it. It should be smooth under the liner. If you start seeing ragged adhesive, stop peeling, push it back down, and try another corner.
    J D - 回复
    The version i got had the individual adhesives stuck to what look like tempered plastic that covered the whole battery. Removing the main plastic took off all adhesives at the same time. Its usefull to have another set of hands at this stage.
    Neil Robinson - 回复
    I had the same problem as others with the adhesive sticking harder to the plastic cover than to the batteries themselves. Another set of hands here would indeed be useful. This was actually the hardest step of the entire process as you cannot reposition the batteries once you set them down. Luckily it seems there is at least a little wiggle room in there. Make sure the power connection lines up with its screw holes as the number one priority.
    james - 回复
    I took off the top side full cover of plastic before sticking which meant all the individual cells were flopping about - leave it on until after sticking it down (as per the next step!).
    Jonathan B - 回复
    Unsticking the packs is messy and dangerous since they may tear if too much force is applied, especially if swollen.
    But do they need to be glued in?
    The batteries should not move: in time that would damage the connections. Measuring carefully, the space between the unibody and its lower case is 8.2mm. The thinnest packs are 7.0mm: there is some room.
    Instead of taking the protective sheets off the glue patches, I put bits of double-sided tape on top. The batteries are now easier to remove, but they cannot slide around.
    However, after turning the machine upside up, they are in fact “hanging” from the “ceiling”! My office tape solution works, but the thinner packs might in time unstick and fall down.
    It may be advisable to use the strong glue anyway, or else put some thermally conductive silicone sponge between them and the lower case.
    The batteries are under the palms of your hands: they don’t get warm, leaving the protective sheets on should not have any effect. The unibody case there is 0.8mm thick.
    Position the battery first with the back covers on it, to feel how it would fit in place (the battery logic board position is a good reference, and the relative distance to the two speakers). Only when you get a good feeling of the position, remove the adhesive covers and put it in place. SLOWLY, there are not many chances to pull it up again if you do it wrong!!
    Cristian Caprar - 回复
    I pressed on the batteries for 5-10 seconds but they did not stay stuck after a few days.
    tomasponce - 回复
    The bettery didnt feet well and there are some part wich are a little bit left up uppon the unibody but there were no solution since the size didn t feet it is a problem ?
    Lisa Luna Marie Lombardo - 回复
    Looks like I have the new version too Tesa 61395 not needed?
    Matthew Mueller - 回复
    I would add another comment about the battery data cable and the fact that you need to make sure you remove it from the old battery and reuse it with the new battery if you have one of the older models of the MacBook Pro.
    Olle Landström - 回复
  65. 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 65 中的图像 1,2 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换: 步骤 65 中的图像 2,2
    • 正确放置和安装电池后,将其剥离并从顶部丢弃透明塑料衬垫。
    • 确保衬里不会意外地拉掉任何黑色电池组件覆盖物。如果需要,在剥离衬垫时使用镊子将它们固定到位。
    • 校准新安装的电池:将其充电至100%,并继续充电至少2小时。拔下电源并正常使用以排空电池。当您看到低电量警告时,请保存您的工作,并保持笔记本电脑一直打开,直到它因电池电量不足而进入睡眠状态。等待至少5个小时,然后不间断地将笔记本电脑充电至100%。
    • 如果你在安装新电池后发现任何异常行为或问题,则可能需要重置MacBook的SMC。
    In order to not remove everything, I reduce the procedure in following only steps 1 to 18 (until trackpad cable is pushed away).
    Then I removed the “low “ screws of step 46 in order to losen the fixation of “bottom” of the motherboard, as there is no room to remove the battery board and its ribbons).
    Then I removed the two screws of the step 50 (battery board). To take off the glued battery, I used twine or thread (e.g. as shown here: https://www.youtube.com/watch?v=fupkPz55...) but not acetone nor diluant.
    Then I lifted very carefully the bottom of the motherboard both to push away the battery board and its ribbons and to reinsert the new battery board and ribbons.
    Then I proceed backward to remount (step 50, step 46 then step 18 to 1).
    Note: my “old” battery was so inflated that the two screws of the lower case near the trackpad were difficult to remove (sometimes, this leads to a malfunctioning…
    Thank to Jeff for this overall procedure which helps me a lot.
    jompo - 回复
    Did they change the step numbers? You mention step 46 and 50, but now it looks like these are steps 47 and 51.
    strells -
    Hi Strells, in the english or french version, it seems that it is always step 50 (two screws for battery) and 46 (“lower” screws for motherboard).
    jompo -
    As Jompo Discovered, I also concur: LB removal not necessary. “removed the “low “ screws of step 46 in order to losen the fixation of “bottom” of the motherboard, as there is no room to remove the battery board and its ribbons)”
    Be careful, I removed all screws from LB & disconnected speakers as well. .
    Macrepair SF -
    @jompo Can you share your revised steps? I have to do this battery change ASAP.
    roopesh -
    Thanks @jompo! Great tip... no, awesome tip! Worked like a charm for me, and saved a ton of work/mess. I've never done the solvent method on any of the batteries I've replaced with the help of iFixIt's excellent guides; I use a plastic card with a 'sharpened' edge to work the batteries loose. Way, way easier than having to take all the innards out (and risk breaking something) and using the solvent.
    Another tip: the best tool for removing the remaining double-sided adhesive tape is a #11 Xacto blade; it's basically a super sharp tiny 'paint scraper' shape, and removes the tape remnants beautifully.
    Also, quick note to the great folks behind iFixIt: I finally wised up and am buying all my batteries from you now. I learned my lesson about buying cheap knock-offs on Amazon that had to be replaced again in a year. No more; from now on, you get all my business!
    Huge thanks all around!
    jiclark -
    Thanks a lot jompo! Your approach worked like a charm and saved a lot of time (and me potentially breaking something :D). The bit of lifting the motherboard up to take out the battery ribbon was a bit of a fiddle but in the end was worth it. The twine and thread approach definitely is less risker as we can avoid liquid damage from the use of the adhesive remover.
    Nisan Nathan -
    wow, this was awesome. thanks whoever wrote it. very well described.
    Astrit Mulla - 回复
    I did the same a @jumbo . So, I’d be happy to rewrite this into a much shorter and less hazard format as @jumbo suggests which works perfectly and has many fewer steps and less risk of injury to the trackpad, motherboard and connected components. I did this in about an hour on my MacBook Pro late 2016.
    Marc - 回复
    Did you ever rewrite this @marcemarc ? I have to do this ASAP and would love to cut out as many steps as possible.
    roopesh -
    I didn’t rewrite it but basically stopped at step 19, and could get the batteries out without solvents or crazy efforts. Heat, slow working with a good spudger and they pop out.
    One thing really important was I found my battery data connector on the motherboard had a loose connection. I had tried three different batteries and it wat the data cable connect on the motherboard. So, that was touch to figure out but it did solve the problem. Bottom line, be careful when disconnecting or manipulating the battery data cable latch.
    Marc -
    Plastic liner is not releasing from the battery cells. If I hold the foam pad in place the plastic sheet rips the foam.
    Lee Gwaltney - 回复
    Newer batteries have foam protection that needs to be removed. The blue tape between the foam and the battery peels off from the battery. https://i.imgur.com/NDwhyVO.jpg
    hishamalbeik -
    Missing one critical helpful notation and photo on the reassembly part - a checklist of all the cables and connectors that need to be checked to make sure they are not caught under the motherboard. I missed the keyboard cable and it cost me half an hour. I checked off all the ones I could remember to make sure they were clear, but just missed that one. A photo with circles and a checklist would be a big help to make sure everything is clear. Otherwise, everything was very well done.
    J Wade Caldwell Jr - 回复
    That’s in Step 49. Easy to miss, but it’s there! I feel your pain though, I’ve made that same mistake.
    Jeff Suovanen -
    I think that was the same cable I missed… at the bottom by the battery connector. I mentioned it to ifixit to add a checklist as well…. Who is responsible for editing this guide? Do you know?
    robert -
    That happened to me, as well. I agree that the list is implied in the instructions (working in reverse during re-assembly), but I also missed the two small cables on the upper left (headphone and touch-id cables). I had almost everything re-assembled by the time I realized my mistake and had to pull everything back apart again to fix the issue. I think that was just me being eager to finish, thinking the hard part was done. (But kudos to the authors for these instructions - my laptop battery is now working great, and everything is functional!!!)
    dot1000 -
    I did the same thing as @jompo did. Works perfectly fine. Thank you jompo, thanks to the author and thank you ifixit team.
    artoo - 回复
    OK well, followed the instructions to the word, & pleased to say my problem has now been resolved. So very many thanks for the fix kit & cracking easy to follow instructions. The MacBookPro lives to fight another day.
    rayholliman - 回复
    in knapp 3h habe ich den Akku gewechselt gehabt, passt auf die Unterlegscheiben vom Trackpad auf… die gehen schnell verloren und das Tastaturkabel vergisst man auch mal ganz schnell. Der Guide ist eine super Hilfe gewesen und ohne den hätte ich sicher das MBP noch nicht mal aufbekommen.
    swordper - 回复
    Only 67,000 easy steps!
    Billy HW - 回复
    that’s what I thought :D But as others mentioned it can be reduced to a nice amount of steps. but anyway: I think producers should make their products waaaay easier to restore those parts like accumulator, ram, HD or even processor cores.. long live the good old desktop pc with motherboards as big and heavy as macbook airs from nowadays ;)
    julia.kadauke -
    Great instructions I finally got my mac book back alive! I am noticing that the battery settings do not show that it is charging even though it is plugged in…tried resetting the SMC still nothing indicating it is charging…I have no idea if it is calibrating correctly. Has been plugged in for about 2 hours but only indicates a 30% charge
    Judah Trimmer - 回复
    This guide worked very well for me. Triple-checked all the connectors when reassembling. I was able to get everything inside the machine cleaned up very well including the fans and the fan ports. Very well done!
    Randy Allen - 回复
    Got through and it worked perfectly! Then I realized the up arrow key was no longer working :(
    Ended up sending it to Apple for a free keyboard replacement since it’s the notorious butterfly keyboard problem.
    Hopefully it will come back with the same battery and they won’t mind I replaced it.
    Bob Donovan - 回复
    Very good guide, I didn’t remove the whole mother board tho (A1707) but this is not my first time replacing a battery of macbook.
    I used alcohol 96% to get the glue off the battery and a old card.
    The way to do it if you don’t want to take apart the whole laptop is to follow this guide to step 23 and unscrew the mother board screws then start to take out the battery and slide the cable while holding up the motherboard.
    Frederick aa - 回复
    I FixIt 😎
    Ho acquistato il kit completo per il mio mbp 15" touchbar 2018.
    Ho seguito la guida fino al punto 18, poi il 46 Ed il 50.
    Non ho usato il solvente adesivo per staccare la vecchia batteria ma mi sono aiutato con la scheda in plastica e con un filo di rame sottile che facevo passare sotto le batterie, una alla volta. Mi sono anche aiutato con un phon per far ammorbidire il nastro adesivo originale sotto le batterie.
    L’unica accortezza sta nello stare attenti quando si toglie e poi si inserisce la scheda della batteria sotto la scheda madre. Io ci son riuscito senza problemi.
    Ora il mbp è in carica: sto seguendo i consigli di ifixit per la calibrazione della batteria.
    Comunque una guida perfetta, in ogni minimo dettaglio. Se avete pazienza, dimestichezza, seguitela ed avrete una batteria nuova in circa 1,5h di lavoro.
    Mimmo Villani - 回复
    Uh oh I did this and now the machine won’t turn on. When I open the lid it shows the battery level for a second then it disappears. No amount of key presses seems to work. Any ideas here? I assume I messed up the keyboard or some other connection?
    Elijah Delventhal - 回复
    Ah I fixed it. Double check step 31, that was my issue. The connector for the power button is right below another one.
    Elijah Delventhal -
    Same. Thanks .
    Pat Splat -
    For sure we need every step so its clear. One misstep and its game over. Shouldnt there be a note or step to work backwards after battery is installed?
    Steven Sanborn - 回复
    Anyone know is the purpose of waiting 5 hours to charge the battery back up? I thought leaving a li-ion battery drained is bad for it. Or is it critical that it isn't completely drained but just at the auto sleep mark?
    bkbkbk - 回复
    @bkbkbk Most likely there's some type of logic that Apple has that is detecting the battery level over time. My assumption is the 5 hr window is very conservative since Apple does not publish the actual time frame.
    mprindle - 回复
    I replaced the battery using the guide. Everything looks good. However, the Mac won't start. It does charge the battery, and occasionally shows the screen with the green battery. What else can I try?
    Falk Eckert - 回复
    I would check you reconnected the power button you disconnected in step 31 as per the comments above.
    Jono -
结论
请按逆序重组你的设备。
把你的电子废料带到 R2 或 e-Stewards 认证的回收商
维修未按计划进行?请查阅论坛 来获取帮助。
148等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jeff Suovanen
于08/06/13注册
439,253 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,410篇指南
67条评论
it’s an unbelievably undesired design that glues everything together. And the design arrangement for the screen was just… annoying.
makrovfisher - 回复
Holy &&^&^$^ $@$*, good thing you dont have to delaminate the screen just to replace the battery. Wtf.
vojvodic021 - 回复
El Torx t3 no me estaria funcionando…. En mi 2017 macbook pro
teatro - 回复
Why removing the logic board. I don’t understand it seems useless. Just detach the battery cables and the battery.
sciack - 回复
There is a video on youtube that shows this (think its turkish, and they only disconnect the battery and start removing it from there with a plastic spatuala). I think its more to do with the fact that this guide doesnt want accidental spillage of adhesive remover onto the logic board. Also to avoid and damage to the board when cleaning the remenants.
Neil Robinson -
Can I start at step 50 to replace my battery?
w.a.moses - 回复
@sciack: well - the point here is that one uses some liquid to soften the glue from the batteries in place - what if that liquid gets onto the mainboard?! And if this where you who spilled it onto the mainboard, and if this guide wouldn’t contain the removement of the logic board, I bet you would be the first wining, crying etc….
Florian Cokl - 回复
Do you really need to use glue remover? On previous version you could simply peel off the battery. There is adhesive with the new battery anyway. Might need a touch of alcohol/acetone in between but this seems like overkill?!
[deleted] - 回复
Skill level: Novice, first time doing this kind of project on macbook pro 2017. The 65 step process seems daunting (for a novice). But, once you get started and stick to the plan its not difficult. All the credit goes to the Ifixit and author of this manual. In first round, I skipped from 24 to step 50 thinking I had cleared the battery, only to find the top section buried under the board. But, thanks to the clear instructions I was able to salvage the project and the macbook/battery works great. Maybe put in warning at step 24. Also placing new battery in exact location is tricky. Suggestion, remove sticky pad covers one at a time once in location. Suggestion: use the organizer (with the box grid) and put labels with step #, that way once replacement is complete, putting macbook back is easy. Thanks
RS20 - 回复
Really good instructions and kit. As RS20 says, ORDER THE ORGANIZER! Also, to be explicit, you must perform all steps. Ribbon cables to the flanking batteries are under the mainboard and so it needs to be removed. Adhesive on mine was very strong, and I ended up repeatedly putting the adhesive remover on the edge of the removal card and then sliding it under each battery.
Vincent Hamrick - 回复
I’ve followed the instructions but my battery will not charge. I’ve taken it all the way down to dead at this point and can no longer turn the laptop on. When I did get it on, the left fan was running continuously. I don’t believe I’ve damaged anything in the process but it’s certainly possible. I’ve tried resetting PRAM and SMC a multitude of times, it just doesn’t seem to recognize the power cord being plugged in. I’ve tested the power cord with other computers and have confirmed this cable working.
Any idea why it would turn on (ie it’s running on the new batter) but then not charge?
Sean McKenzie - 回复
I am having the same Fan issue, the left fan just runs and runs, any idea how to fix it?
Michael Fellows -
anyone have a issue of left Fan running at 6488 RPM’s after this. If the system is on the left Fan is running full speed now.
Jeremy Teynor - 回复
I am having the same issue, Left fan running at full after the install. Do you ever get a solution to this? I have reset the SMC but that has not fixed it.
mkuchynka -
I had the same issue, took it for service and was told the fan failed, I suspect there is a step somewhere where it gets easily damaged but I do not for the life of me know where it would be
Chris Champeau -
Having same issue, did you have any luck?
Pat Splat -
I have the same problem, looks like a mosfet might have broken off. I found this video that explains what might have happen: https://youtu.be/MgPighrnTA0?si=XTn_SjRy....
I haven't yet checked to see if my mosfet has broken off, it just takes to long to disassemble everything. But I'm pretty sure I have the same issue.
Chad Schilder -
Absolutely incredible guide. Very satisfying to finish this successfully.
I used an egg carton for a screw organizer and, at 49 yo proud to say didn’t use any magnifying/corrective eye wear! Smallest screws I’ve ever seen.
Only a few minor issues - upper right screw in Step 29 refused to go back in (I think it’ll survive), REMEMBER there’s 2 ribbon cables in steps 31/34 - I installed the logic board forgetting about the lower cable….LUCKILY was able to fish it out from underneath after realizing it during reassembly. Also forgot to pull the trackpad ribbon all the way though and put a neat sharp crease in it on reassembly. Just massaged it back flat and works fine.
Thanks to the author/iFixit very much for this!!
Shawn Chaney - 回复
Amazing guide. Glad i decided to let Apple do it for $199! Not confident enough to have done this on my own. Repair came back today. Letter inside says they replaced 661-07954 SVC ENCL TC W/BAT ANSI GRAY MB under keyboard program and 605-02685 Logic Board 2.8GHZ 16GB RP555 256GB FCC w/sympton being failed sensor test. Does anyone understand this. Symptom was enlarged battery because i only had 110 cycles since unit always plugged in due to external monitor use. Computer always ran fine.
Stephen Lifshey - 回复
Think I have the same issue as you with a swollen battery, how long was your repair time via Apple in total? How was it only $200, it appears to be closer to $350 based on their site repair pricing. Thanks for any potential info.
Eric -
I Echo Jompos strategy about not having to remove the LB. I would add that in order to loosen the “Fixation” of the LB, I removed all the screws attaching the board to the lower case. I also disconnected L & R speaker cables from LB. Used spudgers wedged on either side of LB to carefully raise LB enough to carefully slide battery flat cable out from under LB. Insertion of new battery flat cable under edge of LB was done with care and good lighting. Battery extracted with a silicon, rubber cake icing spreader. No liquids or floss used here.
Macrepair SF - 回复
Well, I went through the whole process. I’m experienced at working inside machines, although it’s been a while. Now… the Mac says it has no battery available. I opened it back up and the ZIF socket for the battery data cable is missing its lever. I tried carefully and fully re-seating the connector since only the lever is missing, but no joy. Looks like I have a very expensive and under powered desktop system now. :-(
Stuart Craig - 回复
Expensive failure. Torx heads stripped out, lost washers, can’t reseat the cover screws. Do not attempt this, imho.
Jason Sherron - 回复
Well I followed the instructions to the letter, Very well written & clearly explained. Pleased to report that all went well & my problem has been resolved. The MacBook Pro lives on to fight another day. Many thanks to the team at iFixit.
rayholliman - 回复
Battery replacement seemed to go as expected. While plugged in to the wall charger, mac boots fine, and behaves normally - Except, there is no battery detected. System Report (Apple Menu > About This Mac > System Report >Hardware > Power : Battery Installed: NO . Seems the new replacement battery is faulty. I did double check the battery data cable connection is as seen in STEP 12. Any other ideas?
Jay Cole - 回复
My new battery from you guys is not charging. Why is that?
ruinnoj - 回复
Did you make sure to lift the flap protecting the contacts of the data cable for the battery?
Filip Remplakowski -
Apple has definitely made improvements in the 2017 models as far as removing and re-installing the mother boards. I was not looking forward to that part given what a pain it was in earlier macbook pro’s but this time that went very easily! There are still an awful lot of connectors but if you keep them in order with their screws where the cat won’t walk across your desk and scatter them then this felt much easier than previous versions. I know that earlier models had you remove the mother board just so you didn’t get acetone on the speakers but it seems that on the 2017 model that some of the battery cabling actually goes under the lip of the motherboard and so you really can’t safely get it out without doing this where on older models if you were willing to risk the speaker cones you didn’t need to do it. On the 2017 it seems you really do need to do it. Waiting for the iFixit guide to post apocalyptic appendectomy ;)
james - 回复
I changed my battery yesterday according all working steps, shown above. The description is very well, many thanks for sharing that. Unfortunately my MacBook does not show me the new battery at all. I reseted the SMC as described in the Link shown at the end of the description.
What else can I do to “register” the new battery pack to my MacBook? Or what else can I double check. Any help is highly appreciated.
Many thanks in advance.
Sven B. - 回复
Disconnect and reconnect both the battery connector and data cable. Check both carefully for damage, contamination, etc. Make sure they’re correctly plugged in and fully seated. If you still have trouble, I’d suspect a defective battery.
Jeff Suovanen -
A swollen battery was making my laptop chassis warp and the pandemic meant Apple couldn’t fix this laptop for me. I felt uneasy about leaving a potential fire hazard lying around the house so I bought the battery from this site and followed this guide. Although it’s not for the faint hearted, it’s not that bad either. Just be organised, read through the steps at least once and maybe look at some youtube videos of people doing the process. I learned a lot from those and felt the preparation meant the process went smoothly. Took me about 3.5 hours. Have a strategy for managing the screws as you remove them so it’s easy to put the same ones back again. I grouped them by each step in the guide.
After calibrating the battery, it’s obviously decent quality as it took ages to run down from 100% to 0% as recommended. It’s a weight off my mind knowing it’s sorted and the laptop feels better than new. Repairing stuff to make it last longer is cool and hopefully I’ll get another few years out of my Macbook Pro.
Geoff Simmonds - 回复
Just completed the battery replacement. Excellent guide . I ordered the organizer and install kit, and that helps a lot. 90% successful, but unfortunately broken the right speaker connector. Battery is charging now, now showing as normal, cycle count 1 and capacity of 6793
Robert Lee - 回复
Thank you for the tutorial. I followed the instructions. After finishing it, I could see the battery sign in the middle of the screen and it was charged to 100%. But I could not turn it on. I tried multiple ways to try to start and didn’t get any response, the button and keyboard did not work. I opened it up again and rechecked all the connections. I took it to Apple authorized Micro Center today and they would not fix it because I used IFIXIT. Could anyone help? Thank you.
Chen - 回复
I got battery replacement from ifixit.com. I did follow the steps on this guidelines. Now, my Macbook Pro doesn’t turn on power. I try steps again for fixing but I have no clue what is it going on…. Can you guys help? I did my best but I don’t know if there is error….
Yeimi - 回复
I managed to do this without any issues. Nothing broken, everything seems to be working fine. Let’s see how the battery works after initial calibration. I got a battery with 0 cycles, but it is very old, manufactured in 23-Oct-2017 (a few days older than the macbook it goes into…). The age of the battery is pretty disappointing for a new battery, but the repair guide was very good.
After doing a SMC reset and performing the battery recalibration as instructed by the guide (charge to 100% and keep it charging for more than 2h, run it to a full discharge and then recharge), the faulty battery service message is gone and my MacOS reports the battery in good condition.
As said above, the battery is pretty old, even if new. After the recalibration (2 cycles now on the battery), the full charge it can hold (as reported by coconutBattery) is 6139 mAh, approx 8% below the design capacity of 6669 mAh it reports. Definitely not above 6300 mAh as specified in the description of the battery in the online shop.
Let’s see if this degrades rapidly or remains in these parameters.
The previous battery replacement I bought from iFixit was for my Late 2013 Macbook Pro 15” and it behaved in a similar way, dropped after the recalibration from design capacity 8755 mAh (nice capacity compared to 2017 Macbook) to 8130 mAh max capacity, and it remained there for more than a year.
As always - excellent instruction, great parts, had everything I needed on hand with the parts and tool kit. You guys did it again, thats why I keep coming back!
florwj - 回复
Followed the instructions. Now it will not boot. My advice is not to take out the logic board. Looks like I will have to buy a new logic board or MacBook pro.
Chris Spaulding - 回复
Hello, I just finished (need to get the cover on) but my battery works and the computer works. Thank you to the author I have a few notes and tips to anyone doing this as well.
I would have the following on hand before you do this to avoid delays that I encountered.
1. 2-3.0 reader magnifying glasses so you can see clearly when super close up.
2. headlamp or good light source
3. blue locktite for re-assembly of the screws.
4. b-7010 double-sided electronics repair tape I bought 5mm but had to cut some to 1.5mm or so.
a good mini tool kit with magnetic bits and plastic tools for prying stuff like the instructions show.
5. I replaced the usb-c ports with this kit from am… 12.00 as of 11-2021
6. small hair dryer to remove the tape from the battery
7. 20lb or so fishing line about 2-3’ to cut the battery out if you don’t have the solution which I left behind.
8. I tape each screw and number it so I know what step it was from on pieces of paper it makes a big difference later on if you can’t do this in one shot.
4-5 hours
david f - 回复
I'd like to echo these suggestions. I used the kit from ifixit, which included all the necessary tools, etc.Just add masking / painters tape. Some screws did have thread locker on them, but I did not reapply under reinstall.
If this is something you don't do all the time (I don't), go slow and take it easy disconnecting / reconnecting things. Find screw threads gently and don't go nuts over tightening things. It's not for the heavy handed or if you're in a rush. Read the comments to see what pitfalls others experienced BEFORE you start tearing into things.
My experience went pretty well with 2 minor issues. Bottom Line: If you're not an expert, be fully prepared for the fact that you may brick your Mac. Otherwise, leave it to the pros with their experience and parts bins!
Jay -
On the logic board replacement be very careful there are a bunch of small cables that need to be held up to get it in I forgot the fan cable then another one and you have to be patient plus don’t cross thread the screws so easy to do…. one of the small brackets actually screws into one of the screws in the back so be careful of numbering the screws… as I said above…. good luck…
replacing the usb c was the biggest improvement!!! but note the rubber washers didn’t go back in on my install from the usb c so hoping that is not a big issue…..
david f - 回复
Fantastic guide, this was like dismantling a bomb… so much can go wrong (I had to work around a commonly stripped screw), but the guide and the comments were super helpful. Totally get why the logic board needs to be removed due to the solvent use… the batteries are really stuck in there.
The bundled kit was totally worth it, the only thing missing is the heat gun… but a hairdryer would work in a pinch.
Thanks for everything you do ifixit!
Kris - 回复
I should have read all the steps before I started this project to get a better idea of what I was getting into. Not bad overall though.
Instructions are pretty accurate. Just have to read.
G Sena - 回复
Thanks again iFixit. I was going to have Apple do the replacement, but I didn't want to be without my MBP for however long it was going to be at the Mac hospital, plus I saved some $ doing it myself. With the iFixit instructions and tools it was not that hard. The Torx T3 screws are small, so have good reading glasses if you want to see these tiny little things. I love iFixit
Jon Martinez - 回复
I actually sent the book to apple store to have the battery replace. But once they opened up my working MacBook Pro, they said there is sign of water damage hence the replacement cost would not be $199, but will be $14xx, which they will need to replace everything, on my WORKING FINE book?????? That is insane!
Kevin GhoMiMc - 回复
If I had to replace this battery again (2017 MBP), I would not. My fingers are just too large for this kind of work. I've worked with all kinds of fasteners over the years, but I'll let someone else deal with T3 x 1.9mm screws next time. Luckily, I used my magnetic bowl during disassembly., else they all would have been lost. Previous MacBook had a removable battery cover.
Would suggest update guide at step 40 to use more care to disconnect speaker cables. Prying up (gently) on the connector broke the (tiny) solder joints at the logic board. It looks as if the only way to sort this out is to replace the logic board.
Also tore the keyboard to logic board cable. But it looks as if this can be replaced.
I used a plastic putty knife to aid in battery removal.
For the sake of compact internal design (fine/small diameter lead wiring cables, ribbons) and high bond strength battery to case adhesives, servicing / replacement is made unnecessarily difficult, though my guess is Apple Engineering could care less.
Dave
Dave - 回复
Worked great for me. Although I was a bit disheartened when I discovered that the 65 steps did not include re-assembly.
A suggestion: please expand the list of tools to include the consumables that will be required In this case: aluminium foil, painters tape, paper towels.
There is one thing you might want to add to these instructions, One of the two T8 screws in step 46 has a threaded hole in it. If you confuse them during re-assembly, re-installing the cover bracket in step 29 is impossible, and you get extremely frustrated trying.
Roderick Stewart - 回复
These instructions were excellent.
A couple of lessons from my experience: I already owned a precision electric screwdriver that I elected to use. Everything was going great until step 25 when I had the electric screwdriver cam out of a T3. To continue the repair I had to drill out the affected screw. My advice, use the provided iFixit screwdriver set as it worked flawlessly.
For this repair I elected to NOT use a placement mat for my screws. Instead I used several small jewelry/hobby plastic bags to put the screws in, each labeled with the Step Number (and description) it was associated with. This proved to be quite useful in this case.
Lastly, double, triple, quadruple check that you have every single connector, ribbon cable, and antenna passed through the logic board before continuing with the reassembly.
Overall it took me nearly 5 hours to complete this repair and I would recommend it to anyone with the ability to have light hands and a little patience.
Kolby Brooks - 回复
Trying to remove the rest of the adhesive strips was the most annoying part of this. Also those washers on the trackpad really are paper thin, do not blow on it lol
I also managed to apply PTM7950 thermal pads on the CPU and GPU which was a dry crusty mess that wasn’t doing anything and slowed the computer down and made the fans kick in straight away. If your mac is more than 3 years old (if you have this one it is) I highly recommend doing this as it’s running practically like new again. You have to take out the logic board anyway so applying thermal pads or repasting is not much more difficult.
Thank you iFixit for the clear tutorial.
Filip Remplakowski - 回复
Great guide! Took about 3.5 hours for inexperienced me.
David Sawyer - 回复
Was not looking forward to doing this but I went ahead and following the instructions took me roughly 3 hours of time so definitely set a day aside for anyone not experienced with it. Got to say I have a new battery on my laptop! Thanks IFixit!
Kenny Chhoeun - 回复
Thank you for this thorough guide. The patient made a full recovery.
After my first attempt, my fans maxed out, and the keyboard and trackpad didn't work. The reason was that the flex coming from the trackpad had disconnected slightly on the trackpad itself.
Solution was to disconnect the flex carefully - there is adhesive. Put some kapton tape to cover the adhesive, then reconnect the flex. Put another layer of kapton on top to hold the flex in place. Reconnect everything and it worked! The reason for this to happen was that I had placed the batteries slightly too far down - this caused the flex to be just so slightly too short. So make sure to place the batteries very carefully.
Konrad Beckmann - 回复
I followed all end and back, it took me 2,5 hour now the mac dont work. Just show me 100% Green Battery Icon when I push the touchbar button. helps!?
M473J - 回复
I experienced the same problem:
I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
I missed connecting the left TouchID sensor from step 31.
webrockers -
My macbook wont turn on after installing the battery. It just shows an empty battery with a slight red and a lightening bolt. It has been on the charger for over a day and nothing has changed. I opened it up and it looks like both fans spin up when the red battery icon pops up and then they stop when the icon goes away. So frustrating.
Chris Khoury - 回复
I had a similar problem.
webrockers -
Same story like https://de.ifixit.com/User/4379923/M473J
It mocks me with a green battery icon (which is increasingly loading).
No reset of NVRAM or PRAM seem to have an effect.
webrockers - 回复
webrockers -
Definitely give yourself time to do this replacement as you don't want to rush it. I was able to follow these instructions and not F it up, so you probably can too. Be sure to read the comments on each step as they are great tips.
Hardest part was reconnecting the antennas. I used my phone's camera in one hand (zoomed in to the max) and tweezers in the other. When I got it aligned I placed the phone down (without moving the other hand) and grabbed the plastic stick and gave it a little push down.
Tyler - 回复
Great set of instructions, I'm no novice, been building PCs and repairing laptops and phones for friends for years. This sas my first battery replacement on a mac so I took my time.
Only had 2 issues which are not due to the instructions
1. I didn't connect the power switch connector fully... so couldn't boot up, had to go back in and do recheck all the connectors to be sure.
2. Fans were loud and I was in a boot loop when I powered on. Finally realised I should do the SMC Reset.
Now works like a charm, thanks to the iFixit community!!!
Dan - 回复
Decided to replace the battery after my Macbook suddenly stopped charging from any of the USB C ports, then ran out of charge. I thought this was a charger problem, but replacement chargers and leads didn't solve the problem. Wasn't convinced it was a battery problem, but decided to try and change the battery anyway. Completed the battery replacement without any significant problems. Bought the kit. All the tools worked fine. Dislodging the glued in old battery required a bit of time and patience with the adhesive remover, but was okay. Most difficult bit was removing the speaker cables, which are glued on and required careful patient removal to avoid breaking anything, which the comments warned about. Macbook now working fine, so delighted !
Chuteyman - 回复
This guide is excellent. I had to do this twice. The first time, everything went well, but I had procrastinated so long that the battery I ordered went bad so I installed a dead battery. The second time, everything went well again and the laptop is working perfectly.
Just want to mention, Apple will replace your battery for like $200, so doing this yourself is a dumb idea. After my first attempt failed, I took it to the Apple store and they said it would now cost $600 because it wasn't a stock battery.
Also, the first time I did this I followed the comments and skipped the logic board removal. It was a little tricky but it worked fine. Second time I removed the logic board and all is well. Thanks to whoever wrote this guide.
Jon - 回复
Looking at current battery service pricing from Apple, you save about 200$ CAD doing this yourself. It is not a dumb idea.
Alex Jenkins -
Awesome guide. Thank you Jeff! Gotta be generous and patient with the adhesive remover, and put quite a bit of thumb muscle to remove the battery, but it works out in the end. I would recommend getting the magnetic project mat even though I didn't have it, I certainly wish I did (lots of different tiny screws to keep track off, ended up labelling a piece of masking tape with step # and placing them on it, but that was one bump of my table away from a massive headache). Anyways, so glad I found ifixit, will definitely come back to fix more stuff.
Alex Jenkins - 回复
Does anyone know what Voltage each of the 6 batteries should have?
Kai Römer - 回复
It was a long journey, but it worked out in the end. No components damaged. Grateful for these guides.
Andrew Meyer - 回复
Glad I didn’t read the instructions before I started! Just methodically got rolling and stayed on it until reverse order! All went perfectly well. Just go slowly.
Jim Ryser - 回复
添加评论
浏览统计数据:
过去 24 小时: 80
过去 7 天: 563
过去 30 天: 2,610
总计 202,272
